- Dec 16, 2020
- 6
- 2
- saint-prix, France
- C?ID=68124
Do you need to retrofit an Auto-Hold button to use this? My A3 e-tron has no button, just a blank space in front of the armrest:
Scan and maps shown here:
2018 Audi A3 e-tron
Thursday,07,December,2017,14:36:25:29905 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 17.11.0.0 (x64) HEX-NET CB: 0.4409.4 Data version: 20171026 DS285.1 www.Ross-Tech.com VIN: WAUSPBFF8JA063478 License Plate: E-TRON-1 Mileage: 17km-10mi Repair Order...forums.ross-tech.com
I wish you would have the same solution for a T6 MK100 unit.Yes, button retrofit and wiring plugued on the ABS pump needed + Coding
Bytes 1 and 3 are the 7th and 8th digits of the VIN respectively.
Does anyone got same info for 47 byte abs modules?
I actually only need to change it from RHD to LHD.We have some info but I'm not extremely confident building those from scratch. I'd post a link to the thread and complete scan in question here to see if anyone can assist.
Sure, il get it tomorrow. ThanksOK, with any luck that may be limited to 3 Bytes but the Auto-Scan prior to modifications would be very helpful.
77=0 80=0
79=2 9B=K 2K Caddy
7E=7 98=H 7H T6
88=A 83=3 A3 Passat-NMS
A2=Z AB=Z
94=0 66=0
9C=8 8D=V 8V RS3(rdw)
AA=F 7D=F FF RS3(nar)
BF=Z 91=Z
No, it is:Byte4 and Byte17 are not mirrors
I would urge you to log your deceleration rates to determine if you are running to the problem that we have been struggling with for years on this platform. I've been trying to resolve this issue myself on multiple TTRS and RS3 track cars. Several competitive racers I know were forced to sell their vehicles due to this limitation as it was not permitting them to be competitive in their classes.
The ABS system on these cars is limited to roughly 1.1 G in braking (as logged, not as displayed in the dash), we have been able to address this on the golf platform by adjusting brake bias and adding more rear brake pressure but these settings are not available on the TTRS/RS3.
I started a thread here to try and get the issue resolved:
Adjust brake bias or abs pump coding
I have a 2018 TTRS (8S) that I actively track and am looking for a what to change the brake bias to allow for more rear brake pressure. On other VW/Audi cars I could adjust the "Brake Boost" and "Hydraulic Brake Booster" values which allows for more rear bias. Unfortunately on the 8S TTRS these...forums.ross-tech.com
No, it is:
Byte 00 <> Byte 17
Byte 02 <> Byte 18
Byte 04 <> Byte 19
Byte 14 <> Byte 24
Byte 15 <> Byte 25
Byte 16 <> Byte 26
