Sharan 7N lights coding.
Dp41n8w
Finland
C?ID=372411
Hello.
Is there any coding to code 5 Brake lights?
I hawe checked 09 coding and adaptions but have't find it. Second question is that is there possible to code us style park lights/Blinkers? To golf I found both of these options but sharan is mystery.
Btw, I have halogen lights.
Thanks!
Please post an Auto-Scan so people can see how the vehicle is equipped and configured.
Dp41n8w
Finland
C?ID=372411
[b]Removed.  Data from a clone/pirate copy of VCDS is not welcome here.[/b]
Dp41n8w
Finland
C?ID=372411
What!? Sorry I did not know. Tomorrow I Will go back to the Shop!
Dp41n8w
Finland
C?ID=372411
First of all, I´m sorry that I insult you with the pirate/cloned VCDS. I called the seller and I have now his VCDS and laptop in use. Can you tell me is that ´new´VCDS original? He said that he ordered 5 of those from germany. They shoud be original. He quaranteed that this is original. I post here auto-scan:
[b]Removed.  Still from a clone.[/b]
Oh, and the carpet doesn't match the drapes. :rolleyes:
Dp41n8w
Finland
C?ID=372411
Hello.
Thanks!
Monday,15,July,2019,20:25:04:19148
VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4505.4
VIN: WVWZZZ7NZBV023218   License Plate: JHR-126
Mileage: 205830km-127896mi   Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 18 19 25 2E 37 42 44 46 4F 52 53 56
          61 62 72
VIN: WVWZZZ7NZBV023218   Mileage: 205830km-127896miles
18-Aux. Heat -- Status: Sporadic communication error 1000
   Part No SW: 03L 906 018 HJ    HW: 03L 907 309 Q
   Component: R4 2.0l TDI   H24 9979
   Revision: 44H24---    Serial number:
   Coding: 001D001A042401080000
   Shop #: WSC 32500 205 00000
   ASAM Dataset: EV_ECM20TDI01103L906018HJ 003014
   ROD: EV_ECM20TDI01103L906018F_VW36.rod
   VCID: 79AFEDF3195DFE0F8D7-802C
   Part No SW: 02E 300 054 Q    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2602
   Revision: 05351112    Serial number: 00001011130416
   Shop #: WSC 00020 000 90108
   VCID: 2411EC87C2DF53E78E1-8070
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 L    HW: 7N0 614 109 L
   Component: J104   C3 450M VD66 0008
   Revision: --H07---    Serial number: 00000003523186
   Coding: 0027162
   Shop #: WSC 00020 790 00000
   VCID: 363526CF6443D177205-8062
   Part No SW: 5K0 907 044 G    HW: 5K0 907 044 G
   Component: Clima-Sharan  H11 0104
   Coding: 0000000009
   Shop #: WSC 00020 999 00000
   VCID: 2F3B13AB9799E0BF633-807A
9601321 - Humidity sensor
          B1281 29 [008] - Signal Implausible
                    Reset counter: 140
                    Mileage: 205693 km
                    Date: 2019.07.14
                    Time: 12:54:23
   Part No SW: 5K0 937 084 F    HW: 5K0 937 084 F
   Component: BCM PQ35 B    011 0046
   Revision: BA011001
   Coding: 40190A3B89251AC0400800C4540000EC43511322422D25629980874000C1
   Shop #: WSC 00020 790 12345
   VCID: 353721C37545DA6F29F-8060
   Subsystem 1 - Part No SW: 7N1 955 119 A    HW: 7N1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    110911  31  0032
   Serial number:         110922114355
   Coding: 000D9D
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0022
   Serial number: Y10M12D12h07m45s42S1
   Coding: 1780BB
03384 - Windshield Washer Jet Heating
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 88
                    Reset counter: 102
                    Mileage: 202581 km
                    Date: 2013.11.03
                    Time: 19:45:27
                    Voltage: 11.85 V
   Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
   Component: VW10Airbag012 H07 0013
   Serial number: 003GFPR4W1QK
   Coding: 003132
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 3E253EEF40F31937F85-806A
   Serial number: 3493ETS60CF192813DD1
   Serial number: 3503ETS60701528139D8
   Serial number: 3513ETS60DBE127139DY
   Serial number: 3523ETS6006102813DD8
   Serial number: 35540TS60807039139D4
   Part No SW: 5K0 953 501 BA    HW: 5K0 953 569 H
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20101218301045
   Coding: 1992240000
   VCID: 6A8DC2BF6CFB459774D-803E
   Coding: E30000
   Part No SW: 7N0 920 870 A    HW: 7N0 920 870 A
   Coding: 170D00
   Shop #: WSC 52001 205 09977
   VCID: 303910D78AA7FF477A9-8064
   Part No: 7N0 963 271 A
   Component: Zuheizer        051 2630
   Revision: 00051000    Serial number: 09022126000000
   Coding: 0000041
   VCID: 323D1ADF882BCD570CD-8066
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 171210F2001989
   Coding: 468002
   VCID: 313F15D3812DF64F757-8064
                    Fault Status: 00110100
                    Fault Frequency: 41
                    Reset counter: 140
                    Mileage: 202622 km
                    Date: 2013.11.04
                    Time: 07:01:27
   Component: IMMO          H20 0420
   ROD: EV_Immo_UDS_VDD_RM09.rod
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Revision: A1001003    Serial number: 7669038278
   Coding: 020000
   VCID: 2809F8B7B2F7B787A29-807C
   Part No SW: 3C0 035 279     HW: 3C0 035 279
   Component: RNS315        H05 0010
   Serial number: VWZAZ2K8357962
   Coding: 040004310400000000021000
   ASAM Dataset: EV_RNS315VWEUV1UDS A01005
   ROD: EV_RNS315VWEUV1UDS.rod
   VCID: 6099A0979AC70FC7AA9-8034
1048582 - GPS Antenna
          B1054 13 [009] - Open Circuit
          [GPS antenna open load]
                    Fault Frequency: 54
                    Reset counter: 142
                    Mileage: 202719 km
                    Date: 2019.06.17
                    Time: 06:09:49
   Part No SW: 7N0 959 793 D    HW: 7N0 959 793
   Component: TSG FA        H04 0400
   Revision:             Serial number: 0000110543452
   Coding: 011006208000411011
   VCID: 43D34F1B2B9174DF97B-8016
01705 - Selection Switch for Mirror-Adjust (E48)
                    Reset counter: 109
                    Mileage: 201508 km
                    Date: 2013.10.17
                    Time: 20:39:47
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.324 1401
   Revision: 1BH04739    Serial number: 00133360268701
   Coding: 0000258
   Shop #: WSC 52001 205 88154
   VCID: 41DF45133D8D66CF857-8014
   Component: EZE_2         H35 0614
   Coding: 050B0500
   VCID: 6FBBD3AB5799A0BF233-803A
   Component: J245EE20SKB13  H02 0220
   Part No SW: 7N0 959 792 D    HW: 7N0 959 792
   Component: TSG BF        H04 0400
   Revision:             Serial number: 0000109940236
   Coding: 011006208C00411011
   VCID: 42DD4A1F348B7DD79CD-8016
   Part No SW: 3AA 907 801 D    HW: 3AA 907 801 D
   Component: J540 EPB4  VW-53083 0006
   Revision:   H18       Serial number: 00000000132453
   Coding: 0024067
   Component: Batt.regelung H35 0614
   Coding: 030B185A
   VCID: 71BFD5D341ADB64F357-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370245291
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 E    HW: 7N0 959 795 A
   Component: TSG HL        H03 0400
   Revision:             Serial number: 0000110849005
   Coding: 010004200000411001
   VCID: 45D7510325A54AEFB9F-8010
   Component: TSG HR        H03 0400
   Revision:             Serial number: 0000110846452
End----------(Elapsed Time: 01:53, VBatt start/end: 12.4V/12.3V)-----------
OP has redeemed himself and gone straight. :thumbs:
Moved to Tweaks.
TBAx
C?ID=287144
I don’t see how this would be possible with coding. However it should be feasible with another tool that allows changing of EEPROM contents of the BCM.
Dp41n8w
Finland
C?ID=372411
Okei, thanks! :)
hadez16
C?ID=289891
Afaik @Uwe is about to design a power-user method to export/import the PQ BCM Lighting configuration ;) Aren't you???
Dp41n8w
Finland
C?ID=372411
Oh really? :)
