2010 2.7tdi A6 allroad CANC
Gremling
Norway, Nordland
C?ID=319714
Hi, just got a chk engine light, quick test with my Vagcom revieled P040D EGR Temp Sensor A Circuit High. Intemittent, erased it, but came back after a few km driving (engine was shut down on purpose, stop at a shop), During next start the warning came back.
No other issues with car, appart from a defect glow plug, has been defect for a few years, but not bothered to replace it before 1 or 2 more fails. As well as the aux heater not starting from time to time (glow plug with flame monitoring issues)
Any advice what adoptation channel to monitor the EGR temp? Wanne see if it can give sny tell tails
Any other tips?
(Can not post autoscan until later tomorrow, but I am owner of original VAGcom, see other posts)
This engine?
Address 01: Engine (CAN)       Labels: Redir Fail!
   Part No SW: 4F7 910 401 L    HW: 4F0 907 401 E
   Component: 2.7TDI EDC17G004AG  0100
   Revision: 16H02---    Serial number:
   Coding: 0125002C191F0928
   Shop #: WSC 00040 218 83826
   VCID: 2C01FA04BA0DFFE712D-8079
Weird! I can't find anything for that ECU. Usually when there's a "Redir Fail!" there's at least some data in German, but I've got nothing. :(
NostraJackAss
In addition to the sensor FYI : If this continues after replacement could mean that a bad wire is possible too & not just the sensor but another track and with no error sometimes could cause a ref voltage to drop out.
Gremling
Norway, Nordland
C?ID=319714
Look at MWB 098.4
Hi, are you sure about engine -> measure block 098 and the 4th. It reads 41,3 deg no change wether engine is running or have been off for a while?
Autoscan below:
Monday,11,February,2019,13:18:42:27784
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4441.4
VIN: WAUZZZ4F8AN014763   License Plate: BR83088
Mileage: 168090km-104446mi   Repair Order: 11 02 2019
Chassis Type: 4F-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 20 34 42 46 4F 52 53 55 56
          5F 62 69 72 76
VIN: WAUZZZ4F8AN014763   Mileage: 168090km-104446miles
   VCID: 2C01FA04BA0DFFE7125-8078
001653 - Cylinder 5 Glow Plug Circuit (Q14)
               P0675 - 000 - Electrical Fault
                    Mileage: 168075 km
                    Date: 2019.02.11
                    Time: 12:25:59
                    RPM: 798 /min
                    Speed: 3.4 km/h
                    Voltage: 12.46 V
                    Temperature: 38.7°C
                    Lambda: 19.5 %
                    Temperature: 9.9°C
001037 - EGR Temperature Sensor 1
               P040D - 000 - Signal too High - MIL ON
                    Fault Status: 11100000
                    Mileage: 168077 km
                    Date: 2019.02.11
                    Time: 12:30:17
                    RPM: 1743 /min
                    Speed: 77.3 km/h
                    Voltage: 13.83 V
                    Temperature: 14.4°C
                    Mass Air / Rev.: 716.8 mg/str
                    Temperature: 63.9°C
                    Absolute Pres.: 1683.0 mbar
Readiness: 1 1 0 0 0
   Part No SW: 4F5 910 156 N    HW: 09L 927 156 C
   Component: AG6 09L 2,7 TDI 140 0020
   Revision: --H04---    Serial number:        4527863
   Coding: 0000002
   Shop #: WSC 02325 785 00200
   VCID: 3333E1786733A01F53F-8066
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 AM    HW: 4F0 614 517 BD
   Component: ESP8 quattro    H03 0100
   Coding: 0000392
   VCID: 6FBB2D084B9BC4FF777-803A
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602601358408
   Coding: 0000135
   Shop #: WSC 02323 785 00200
   VCID: 25170F20D9E7CEAFCDB-8070
   Subsystem 1 - Part No: 4F0 910 132 G
   Component: FBSAUDIC6 EZS   H03 0020
   Component: FBSAUDIC6 KSG   H03 0020
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AL
   Component: KLIMABETAETIGUNGH30 0080
   Revision: 00000074    Serial number: 00000000646450
   Coding: 0002326
   VCID: 1D6727C0F1B7066F95B-8048
   Part No SW: 4F0 910 279 N    HW: 4F0 907 279
   Component: ILM Fahrer      H22 0320
   Coding: 0013222
   Shop #: WSC 02335 785 00200
   VCID: 3431E264623DA7274A5-8060
   Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H10 0040
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 01191213
   Shop #: WSC 02335
Address 15: Airbags (J234)       Labels:* 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 Q    HW: 4F0 959 655 G
   Component: Airbag AU1042 H06 0140
   Revision: --------    Serial number: 003F90011G35
   Coding: 30314236303630303032554A304C34463053
   ROD: EV_Airba10AURB4.rod
   VCID: 3537DF6065C7BE2F7DB-8060
   Serial number: 3574SRB400008FD48AAS
   Serial number: 3584SRB400008FB0B8CQ
   Serial number: 35152RB40299F7IGVRBV
   Serial number: 3526HRB402K0N56B7C6
   Serial number: 3554NRB400004E1B052X
   Serial number: 3564NRB400004E8110F/
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
   Component: J0527               0530
   Revision: 00H06000    Serial number: 90055091280337
   Coding: 0002242
   VCID: 270B0528A3EBDCBFFF7-8072
   Component: E0221           H02 0030
Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 933 Q    HW: 4F0 920 933 Q
   Component: KOMBIINSTR.   H06 0138
   Revision: 00300000    Serial number: BH0001X69
   Coding: 0FD76A0302010008010100
   Shop #: WSC 02391 823 56573
   VCID: 3537DF606547BE2F7DB-8060
Address 18: Aux. Heat        Labels: None
   Part No SW: 4F0 910 105 A    HW: 4F0 265 081 AA
   Component: Heizgeraet      H08 0100
   Revision:        B    Serial number: 09018641
   Coding: 0000111
   Shop #: WSC 40376 001 1048576
   VCID: 1B6329D8EFA3085F6BF-804E
01412 - Glow-Plug with Flame Monitoring (Q8)
                    Reset counter: 164
                    Mileage: 167811 km
                    Date: 2019.02.09
                    Time: 14:56:09
                        Start
                    Temperature: 46.0°C
                    Temperature: 58.0°C
   Part No SW: 4F0 907 468 N    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0031
   Revision: MB100028    Serial number: 2800M096090275
   Coding: 000303
   VCID: 3A2DCC5C4C595157909-806E
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0107
   Serial number: 00000000004149089226
   Part No SW: 4F0 857 511 J    HW: 4F0 857 511 G
   Component: FLA           H04 0004
   Revision: AA001002
   Coding: 02010464747464545425363E
   VCID: 2F3BED08871B84FF377-807A
Address 34: Level Control        Labels: 4F0-910-553.clb
   Part No SW: 4F0 910 553 D    HW: 4F0 907 553 A
   Component: J197 LUFTFEDER  H17 0030
   Serial number: 00872000467900
   Coding: 0000220
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000101423312
   Coding: 011F56204040410003
   VCID: 46D5A8AC08A125B7E41-8012
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
   Component: Komfortgeraet   H27 0220
   Revision: 02200027    Serial number: 01192862040000
   Coding: 0139909
   VCID: 313FEB709D2F920F213-8064
   Part No SW: 4F0 910 280     HW: 4F0 907 280
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000473287
   Coding: 0001003
   VCID: 5EE560CCBC315D77CC1-800A
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000101401123
   Coding: 011F56204440410003
   VCID: 45D7AFA035A72EAFEDB-8010
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000521
   Shop #: WSC 02145 785 00200
   VCID: 211F1B30CDCF228FB13-8074
   Part No: 8P0 907 357 H
   Coding: 0000004
   VCID: 3FDBBD485B7B747FA77-806A
   Part No SW: 4F0 035 061 K    HW: 4F0 035 061
   Component: Radio U DAB   H45 0074
   Revision: AB001007    Serial number: 343G/097525398
   Coding: 010103020100000000
   VCID: 24111224DEDD37A7DA5-8070
02877 - Digital Radio Antenna (R183)
                    Reset counter: 124
                    Mileage: 167801 km
                    Date: 2019.02.08
                    Time: 18:33:53
                    Voltage: 11.60 V
   Part No SW: 4E0 035 666 K    HW: 4E0 035 666 B
   Component: H-BN-EU       H41 0187
   Revision: --------    Serial number: 454GS097510254
   Coding: 010100050002D3EF01002715EF6300030001
   VCID: 2E05F00C80118DF73C1-807A
   Subsystem 1 - Part No: 8R0 060 884 ED
   Component: EUR 2017  2402
   Component: DU7 High  H43 0306
   Serial number: 9356FV091025676
   Subsystem 3 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 S
   Component: Bedienteil MM  H01 0060
   Serial number: 00000001345613
   Component: CD-Database  1293
03175 - Invalid Data Set
            000 -  -
                    Reset counter: 124
                    Mileage: 167801 km
                    Date: 2019.02.08
                    Time: 18:33:44
                    Voltage: 11.90 V
            000 -  -
                    Reset counter: 124
                    Mileage: 167801 km
                    Date: 2019.02.08
                    Time: 18:33:48
                    Bin. Bits: 00001000 00000000
                    Bin. Bits: 00000000 00000000
   Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
   Revision:             Serial number: 0000101403482
   Coding: 010E54204040220003
   VCID: 43D3B1B83B93109FC3F-8016
Address 69: Trailer (J345)       Labels:. 4F0-907-383.clb
   Part No SW: 4F0 907 383 D    HW: 4F0 907 383 D
   Component: Anhaenger     H08 0080
   Revision: 2B002002    Serial number: 00000118780530
   Coding: 0103030000000000
   VCID: 2C01FA04B60DFFE7125-8078
   Revision:             Serial number: 0000101403479
   Part No SW: 4L0 910 283 B    HW: 4L0 919 283 B
   Component: Parkhilfe 4-Kan H02 0500
   Revision: 00H02000    Serial number: 12330917404034
   Coding: 0011416
   VCID: 290F0310B5FFEACFE93-807C
End----------(Elapsed Time: 01:41, VBatt start/end: 14.2V/14.2V)-----------
NEtech
Denmark
C?ID=56995
Should be, find the connector, take it apart, use some resistance, etc.
Gremling
Norway, Nordland
C?ID=319714
Due to faultfinding on temp sensor, I need a correct map/chart/desciptions of Control module -01- Engine blocks, so that I can check values to what seems more correct.
At the moment block 098.4 seems fixed at 41.3 deg Celsius, and block 099.4 fixed at 224.2 deg Celsius, need to know which sensors these are.
Would very much like to know what the windows/tags in Group 007 (007.1, 007.2, 007.3 and 007.4. various air temps and cooling water, I think, but not 100% sure
Group 033.2 (second tag/window of Group 033)
Group 039.3 (third tag/window of Group 033)
Group 043.2 (second tag/window of Group 043)
All tags/windows in group 046 and 047
Group 061.2 (second tag/window of Group 061)
All tags/windows in group 098 and 099
Group 102.1 and 102.2 (First and second tag/window of Group 102)
Basically I am hunting for all the block regarding engine and exhaust temp sensors,
* Exhaust gas recirculation temperature sensor, -G98, sits in the EGR cooler
* My car has the CANC engine, the 2.7tdi, and as far as I have found out so far it is only the 3.0tdi that has the EGT sender no 1, -G235-, located on the exhaust manifold flange in Turbo.
* Exhaust gas sender no 2, not found any written traces or evidence of this one so far, could it be the Landa Probe, -G39- that sits just before the catalytic converter?
* Exhaust gas temperature sender 3, -G495-, that sits on the front exhaust pipe, just below/after the flange for the catalytic converter
* Exhaust gas temperature sender 4, -G648-, that sits just before/above the particulate filter.
Regards
Gremling
Gremling
Norway, Nordland
C?ID=319714
Just to close thread, and sorry for not doing so earlier.
Replaced the temp sensor -G98- between EGR cooler and EGR valve, used OEM part, as non-original (cheap versions) tend to fail shortly after replacement. Problem solved
See item 6, in target page for hyperlink ->https://audi.7zap.com/en/rdw/audi+a6+allroad+quattro/a6ar/2010-603/1/131-131010/
Regards
Gremling
