2009 VW Tiguan tire size change
RDillman
C?ID=54068
The customer complaint is the speedo is off (a common complaint it seems with these vehicles). This one has had a tire change, from the stock 235/50/R18 to 235/55/R18. I'm unsure how to change the impulse counter coding in the cluster. Any help would be appreciated. Regards, Randy
Santos
Please post an Auto-Scan from the vehicle.
Under the instrument cluster coding, The parameter is usually listed as the "distance impulse".
RDillman
C?ID=54068
OK, thanks for the help:
Auto scan:
VCDS Version: Release 12.12.2 (x64)
Data version: 20140212
Unique Training Solutions
Monday,17,March,2014,12:00:06:36970
Chassis Type: AX (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 36 42 44 46 47 4F 52 53 55
          56 62 65 69 72 77
VIN: WVGAV7AX3AW001325
1C-Position Sensing -- Status: Malfunction 0010
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 06J 906 026 DN    HW: 06J 906 026 DA
   Component: MED17.5 TFSI 2,0    4668
   Revision: AAH10---    Serial number:
   Coding: 0423010A19070160
   Shop #: WSC 01324 020 00200
   VCID: 79F3738B304938D6DC9-802C
7 Faults Found:
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - Intermittent
                    Mileage: 105778 km
                    Date: 2050.14.04
                    Time: 16:32:19
                    RPM: 2398 /min
                    Load: 27.4 %
                    Speed: 103.0 km/h
                    Temperature: 95.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 960.0 mbar
001378 - System Voltage
               P0562 - 000 - Too Low - Intermittent
                    Mileage: 105981 km
                    Date: 2050.14.07
                    Time: 10:05:57
                    Temperature: 63.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 980.0 mbar
               P0300 - 000 -  - Intermittent
                    Mileage: 105981 km
                    Date: 2050.14.07
                    Time: 11:08:23
                    RPM: 754 /min
                    Load: 27.0 %
                    Temperature: 49.0°C
                    Temperature: 29.0°C
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected - Intermittent
                    Mileage: 105981 km
                    Date: 2050.14.07
                    Time: 11:08:32
                    RPM: 784 /min
                    Load: 25.5 %
                    Temperature: 51.0°C
                    Temperature: 30.0°C
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected - Intermittent
                    Mileage: 105981 km
                    Date: 2050.14.07
                    Time: 11:08:32
                    RPM: 784 /min
                    Load: 25.5 %
                    Temperature: 51.0°C
                    Temperature: 30.0°C
000772 - Cylinder 4
               P0304 - 000 - Misfire Detected - Intermittent
                    Mileage: 105981 km
                    Date: 2050.14.07
                    Time: 11:08:32
                    RPM: 784 /min
                    Load: 25.5 %
                    Temperature: 51.0°C
                    Temperature: 30.0°C
000770 - Cylinder 2
               P0302 - 000 - Misfire Detected - Intermittent
                    Mileage: 105981 km
                    Date: 2050.14.07
                    Time: 11:08:32
                    RPM: 784 /min
                    Load: 25.5 %
                    Temperature: 51.0°C
                    Temperature: 30.0°C
Address 02: Auto Trans        Labels: 09G-927-750.lbl
   Part No SW: 09G 927 750 KN    HW: 09G 927 750 KN
   Component: AQ 250 6F           1590
   Revision: 00H76000    Serial number:
   Coding: 0000840
   VCID: 87178573F6BDDE265AD-80D2
Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
   Part No SW: 5N0 614 517 N    HW: 5N0 614 517 N
   Component: J104    C2 450 V2   0008
   Revision: --H13---    Serial number: 00000002301350
   Coding: 0002329
   VCID: 3973B38B70C9F8D69C9-806C
   Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
   Component: ClimatronicPQ35 133 1213
   Revision: 00133024    Serial number: 00000000000000
   VCID: 6DDB57DB74019476401-8038
   Part No SW: 5K0 937 087 C    HW: 5K0 937 087 C
   Component: BCM PQ35 H+   008 3019
   Revision: BL008001
   Coding: 6D580A1B98232EC48088008534000D0441555186536D8D605C8000000000
   VCID: 356BBFBB9CD11CB6781-8060
   Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 13100  012 0203
   Coding: 009795
   Component: RLS 081009 05  54  0402
   Coding: 03304D
                    Reset counter: 37
                    Mileage: 105981 km
                    Date: 2050.14.07
                    Time: 10:03:48
                    Voltage: 9.10 V
                    Reset counter: 37
                    Mileage: 105981 km
                    Date: 2050.14.07
                    Time: 10:05:47
                    Voltage: 7.20 V
                    Reset counter: 37
                    Mileage: 105981 km
                    Date: 2050.14.07
                    Time: 09:43:41
                    Voltage: 11.55 V
00927 - Terminal 30 (Right)
                    Fault Status: 00101011
                    Reset counter: 4
                    Mileage: 105182 km
                    Date: 2049.14.30
                    Time: 08:20:03
                        Term 15 Off
                    Voltage: 12.70 V
                    Reset counter: 37
                    Mileage: 105981 km
                    Date: 2050.14.07
                    Time: 10:04:41
                    Voltage: 8.65 V
   Part No SW: 5N0 959 655 K    HW: 5N0 959 655 K
   Component: J234__200 VW10 HI   1916
   Revision: 20013000    Serial number: 003E3PLVLGBG
   Coding: 0012336
   VCID: 458BCF7B0C318C36E81-8010
   Subsystem 1 - Part No: 5N0 959 339 A
   Component: BF-Gewichtsens. 001 0004
   Subsystem 2 - Serial number: 0000000000436L
   Subsystem 3 - Serial number: 0026.08.090000100000660019ÿ†63
   Subsystem 4 - Serial number: 660019ÿ†6332MTS625272719 ÿ†63
   Subsystem 5 - Serial number: 72719 ÿ†6342MTS605642719 ÿ†63
   Subsystem 6 - Serial number: 42719 ÿ†6351HTS6OM8N56KR ÿ†63
   Subsystem 7 - Serial number: N56KR ÿ†6361HTS6L8AN56KR ÿ†63
   Subsystem 8 - Serial number: N56KR ÿ†63727TS68FA709KR ÿ†63
   Subsystem 9 - Serial number: 709KR ÿ†63827TS6OMN609KJ ÿ
   Subsystem 10 - Serial number: 609KJ ÿ
                    Reset counter: 36
                    Mileage: 105981 km
                    Date: 2050.14.07
                    Time: 10:04:10
03551 - Functional Restriction of Seat Occupied Recognition
            000 - - - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 105981 km
                    Date: 2050.14.07
                    Time: 10:04:10
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Coding: 0001332
   VCID: 7AF16C87354F33CED53-802F
   Component: E0221           002 0030
   Part No SW: 5N0 920 971 A    HW: 5N0 920 971 A
   Component: KOMBI         H05 0206
   Coding: 210F00
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 30658EAF6BB3399E2B7-8065
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AE    HW: 1K0 907 951
   Component: J533  Gateway   H06 0111
   Revision:   H06 01    Serial number: 300909F1001549
   Coding: FD81FF47101603006002
   Shop #: WSC 07343 444 100065
   VCID: 6AD15CC745EF834E253-803F
                    Reset counter: 36
                    Mileage: 105981 km
                    Date: 2050.14.07
                    Time: 10:04:49
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223T63ZC04
   Coding: 0000002
   VCID: FEF9E097A9679FEE69B-80AB
                    Reset counter: 37
                    Mileage: 105981 km
                    Date: 2050.14.07
                    Time: 10:05:36
   Component: IMMO          H05 0206
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   Part No SW: 5N0 959 760 A    HW: 5N0 959 760 A
   Component: MEM-FS        H04 0032
   Revision: AA000000    Serial number: 00001001356839
   Coding: 20581300000044440011
   VCID: 3875B68F8BC3E1DE637-806D
                    Reset counter: 37
                    Mileage: 105981 km
                    Date: 2050.14.07
                    Time: 10:05:38
   Part No SW: 5N0 959 701 C    HW: 5N0 959 701 C
   Component: Tuer-SG         008 2005
   Coding: 0005567
   VCID: 356BBFBB5CD11CB6781-8060
   Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.163 0703
   Revision: 1AH03273    Serial number: 00092430239502
   Coding: 0000258
   VCID: 3A71AC8775CFF3CE953-806F
Address 47: Sound System (R12)       Labels: None
   Part No HW: 5K0 035 456
   Component: KonzernAmp 8K H06 0340
   Revision: --------    Serial number: BP218198624897
   ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1.rod
   VCID: 55AB1F3B34913CB6981-8000
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Component: EZE_2         H06 0111
   Coding: 050B0500
   VCID: E6C9A8F711F7272E81B-80B3
   Component: J245EE20SKB13  H01 0220
   Component: J394EE20SKB13  H01 0220
   Part No SW: 5N0 959 702 C    HW: 5N0 959 702 C
   Coding: 0005566
   VCID: 3669B8B741D717AE71B-8063
   Part No SW: 5N0 907 801 E    HW: 5N0 907 801 E
   Component: J540 EPB3  VW-13948 0008
   Revision:   H10       Serial number: 00000000059863
   Coding: 0000057
   VCID: 31638BABA8B93096249-8064
                    Reset counter: 252
                    Mileage: 105981 km
                    Voltage: 7.30 V
                    Count: 50
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 252
                    Mileage: 105981 km
                    Voltage: 9.20 V
                    Count: 52
                    Hex Value: 0x1170
                    Hex Value: 0x0008
                    Hex Value: 0x0101
Address 55: Xenon Range        Labels: 5M0-907-357-V2.lbl
   Component: AFS-Steuergeraet    0142
   Coding: 1324230
   VCID: 346D82BF57AB05BE4FF-8061
   Subsystem 1 - Part No: 7L6 941 329 B
   Coding: 00000020
   Subsystem 2 - Part No: 7L6 941 329 B
   Coding: 00000020
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H10 0034
   Revision: -----19S    Serial number: VWZ4Z7J1120748
   Coding: 0501000001
   VCID: 61C33BEB78D9C016F49-8034
                    Reset counter: 133
                    Mileage: 102650 km
                    Date: 2049.14.01
                    Time: 17:55:21
                    Reset counter: 37
                    Date: 2050.14.07
                    Time: 10:04:31
   Part No SW: 5N0 959 703 C    HW: 5N0 959 703 C
   Component: Tuer-SG         007 2001
   Coding: 0001168
   Shop #: WSC 01324 020 1012552
   VCID: 3777B5B346DDEEA66AD-8062
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 65: Tire Pressure (J502)       Labels: 1K0-937-08x-65.clb
   Component: RDK           008 0817
   Coding: 018705
02801 - Hard Warning
                    Mileage: 101381 km
                    Date: 2048.14.14
                    Time: 11:06:25
                    Text: 3448343303
                    Pressure: 1.90 bar
                    Pressure: 2.40 bar
                    Temperature: -6.0°C
                    Text: 00
                    Speed: 77.0 km/h
02903 - Hard Warning 2
                    Mileage: 101387 km
                    Date: 2048.14.14
                    Time: 12:50:08
                    Text: 3448343309
                    Pressure: 0.10 bar
                    Pressure: 2.40 bar
                    Temperature: 0.0°C
                    Text: A0
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H08 0080
   Revision: 3A002002    Serial number: 00000120161450
   Coding: 0200000100000000
   VCID: 2F678DD37E8D266632D-807A
                    Reset counter: 37
                    Mileage: 105981 km
                    Date: 2050.14.07
                    Time: 10:05:50
   Part No SW: 5N0 959 704 C    HW: 5N0 959 704 C
   Coding: 0001168
   VCID: 3875B68F4BC3E1DE637-806D
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 C    HW: 1Z0 035 729 C
   Component: FSE_2P8x        H35 0170
   Revision: 00000000    Serial number: 00000005096572
   Coding: 0011070
                    Reset counter: 37
                    Mileage: 105981 km
                    Date: 2050.14.07
                    Time: 10:04:49
Yes the distance impulse is in the cluster coding. I will upload an image in a few
Santos
click the drop down for distance impulse and select a different option.
The distance impulse values are defined within the control module. You cannot fine tune further than whats defined by the impulse numbers.
This is a limitation of the control module firmware, not VCDS. Dealer scan-tools will have to work within the same parameters.
How do you know which one?
You don't. VW didn't put this stuff in there so people could install some random sized tires. Sometimes there will happen to be one that's close, other times there won't, so it's going to be trial-and-error.
RDillman
C?ID=54068
Thanks for the replys Uwe and Santos. I drove the vehicle at 60 mph with each option and the one it came in with matched the best. Go figure. Thanks again for the support!! Randy
Thanks for the update Randy. I have a 2012 Tiguan and it came with ridiculous 19" factory wheels. We went with the 4-motion for a reason (not to look cool - but to get around in any amount of snow that mother nature wants to throw at us) so I kept the 19" wheels and bought a used set of 2010 M.Y. 16" take-offs from a guy on the VW Vortex and tossed a set of new grabbers on them.
I will say this much, going from the proper 19" wheels to the tiny 16" has it advantages and disadvantages. I don't know if your customer wanted to save a few bucks on tires .. or if they were looking for a softer ride but if it was the ride I'd suggest telling them to ride out the incorrect speedometer until those tires are spent and keep an eye out for used 17" Tiggy wheels. (Obviously, with the proper 17" tire size to eliminate this entire VSS issue.)
