Hi
I am retrofitting auto hold assist to my 2012 A7 US.
I checked Elsa and actual wiring that wiring for E540 Auto hold assist is already established in my car.
So I bought E540 button 4g1927225b and replaced with stock 4g1927225c
Nevertheless, I can't get the coding for activating auto hold assist in 03 ABS control module.
Any comment or assistance is appreciated.
Wednesday,06,February,2019,15:23:00:14904
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: WAUSGCFC3CN License Plate:
Mileage: 127276km-79085mi Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 28 36 3B 3C 42 44 46
52 53 55 56 5F 62 6C 6D 72 82 85 8B 8E 8F 90
VIN: WAUSGCFC3CN010369 Mileage: 127276km-79085miles
Address 01: Engine (J623-CGXB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 A HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH05 0010
Revision: --H05---
Coding: 1A2A0034056600060000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551A 003011
ROD: EV_ECM30TFS0214G0907551A_003.rod
VCID: 270B071F8F6EB7BFFF7-8072
Readiness: 1110 1101
Part No SW: 4G0 927 158 P HW: 0BK 927 156 R
Component: 0BK 30TFSIUSA H08 1006
Revision: --H08---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002018
VCID: 3B23CB6F63E6035F8BF-806E
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 G HW: 4G0 907 379 G
Component: ESP PREMIUM H09 0250
Coding: 44A70F0122E5F0804B00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004017
VCID: 3537DD5745C2D52F7DB-8060
Part No SW: 4H0 907 064 BR HW: 4H0 907 064 BR
Component: BCM2 2.0 H31 0330
Coding: 0D8A2000000000000000
VCID: 7AAD0E6B2CDCFA57D09-802E
Component: J764 ELV MLB H39 0046
Serial number: 2311000115430013
Part No SW: 4G0 820 043 L HW: 4G0 820 043 L
Component: KLIMA 4 ZONEN H11 0065
Serial number: 17051100040345
Coding: 688328BA1C
ASAM Dataset: EV_AirCondiComfoUDS 002036
VCID: 280904238270B8C7F6D-807C
0369 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuerger? f? Spurhalteassistent: kein Signal / Kommunikation]
Reset counter: 50
Mileage: 127276 km
Date: 2019.02.06
Time: 15:17:22
Voltage terminal 30: 14.37 V
Outside air temperature: -8.0 캜
Engine speed: 716 /min
0379 - Supply Voltage Terminal 30 for Coolant Pump
B11D5 01 [009] - Electrical Failure
Reset counter: 50
Mileage: 127276 km
Date: 2019.02.06
Time: 15:17:22
Voltage terminal 30: 14.36 V
Interior temperature: 11.10 캜
Part No SW: 4H0 907 063 BG HW: 4H0 907 063
Component: BCM1 2.0 H12 0100
Revision: 11012002 Serial number: 00000000911965
Coding: 0D0F2097073E9FE081000884A0003820CF9CD308A2090125800308453B00
VCID: 6E85323B6094A6F77C1-803A
Component: WWS57X 110509 H35 0051
Serial number: 110516092801
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11462126
Coding: 02562B
Subsystem 3 - Part No SW: 4G0 941 531 G HW: 4G0 941 531 G
Component: E1 - LDS H07 0044
Serial number: 12 05 2011 00000186
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R0MWD06
Subsystem 5 - Part No SW: 8K0 959 772 C HW: 8K0 959 772
Component: SLR-B8 H05 0006
Serial number: 0006285058
Coding: 853000
Subsystem 6 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A31 LED Mod1L H02 0001
Serial number: 00000000001105100076
Subsystem 7 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A27 LED Mod1R H02 0001
Serial number: 00000000001105096052
Subsystem 8 - Part No SW: 4H0 907 705 J HW: 4H0 907 705 C
Component: EVLS-SG H08 0280
Serial number: WA102276000000284366
Coding: 020300
Subsystem 9 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: C94809A5000000000001
Subsystem 10 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A32 LED Mod2L H02 0001
Serial number: 00000000001104271890
Subsystem 11 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A28 LED Mod2R H02 0001
Serial number: 00000000001105120555
Address 0E: Media Player 1 (R41) Labels: Redir Fail!
Part No SW: 8X0 035 110 C HW: 8X0 035 110
Component: CDC-MP3-Pana H41 0490
Revision: 00000007
VCID: 2D07F537AD129DEF05B-8078
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0043
Revision: 11001001 Serial number: 55901113901962
Coding: 280903
Shop #: WSC 93203 999 11920
ASAM Dataset: EV_EPHVA18AU57X0000 002005
ROD: EV_EPHVA18AU57X0000_002_AU57.rod
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H15 0440
Coding: 3604010101
Shop #: WSC 74565 123 12345
ASAM Dataset: EV_AdaptCruisContrAU57X 002015
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H31 0032
Revision: -------- Serial number: 003D80016DFG
Coding: 30314531313130303036554A304C34473853
VCID: 3333E34F4BB6CB1F53F-8066
Serial number: 3575HRB405H0IDFK4PP6
Serial number: 3585HRB405T0IRE0D90N
Serial number: 3515JRB40570I4AGE9L7
Serial number: 3525JRB40570I4AGLP4E
Serial number: 3554VRB405T0IAMEIOHW
Serial number: 3564VRB405V0IAMEEO4I
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0003
Revision: -------- Serial number: 90372KEN0012G
Coding: 0004FC
VCID: 3829D4635250284766D-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Component: E221 - MFL H07 0009
Serial number: 15 04 2011 11127277
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 931 G HW: 4G8 920 931 G
Component: TBenRdwAcc H71 0375
Revision: 26181114 Serial number: 658060611593004
Coding: 0B8701060F030008020100
ASAM Dataset: EV_RBD4K 004040
ROD: EV_RBD4K.rod
VCID: 323DE64BB4ACC217589-8066
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 E HW: 4G0 907 468 A
Component: J533--Gateway H08 0213
Revision: -------- Serial number: 00000000162020
Coding: 00C1033000
ROD: EV_GatewUDS_AU57.rod
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650522892
Part No SW: 4G0 919 158 D HW: 4G0 919 158 D
Component: KLIMA FOND H07 0056
Serial number: 25051100040507
Coding: 00
ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
VCID: 3039EC43BAA0F0072ED-8064
Part No SW: 4G8 959 760 A HW: 4G8 959 760 A
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000006155198
Coding: C0581B008F002001000001010101102030303232203232
Shop #: WSC 74565 000 00000
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA420108NW0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D07F537AD929DEF05B-8078
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 J HW: 4G0 907 566
Component: J769 SWA MasterH01 0060
Revision: 00H01000 Serial number: 6PZ 010 287-08
Coding: 0000003
VCID: 3635DA5B5444DE37741-8062
Subsystem 1 - Part No: 4G0 907 568 J
Component: J770 SWA Slave H01 0060
Subsystem 2 - Serial number: 6PZ 010 287-28
Subsystem 3 - Serial number: 5F21.05.1100H010003CZ20700
Subsystem 4 - Serial number: Z20700
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 D HW: 4G8 959 793
Component: TSG FA H05 0212
Coding: 011F57225E00628002000413
VCID: 41DFB987018A698FD13-8014
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H33 0010
Revision: 00001000 Serial number: 0025084509
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
Revision: 00002001 Serial number: 0150784972
Coding: 0126023A20FAF48580B00A80020100000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000035544
Subsystem 3 - Part No SW: 7P5 959 591 HW: 4H0 959 591
Component: J245 PS40.033 H07 0006
Serial number: WOO12164930
Coding: 001F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00000268246
Subsystem 5 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H09 0027
Serial number: WA102622000000314109
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
Coding: 011F57225E00628002000402
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000082833
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A0DFE2B9C7C8AD7E09-807E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0013
Serial number: 110601-0004-032
Coding: 1223A6601002A200
ROD: EV_HeadlRegulBasic.rod
VCID: 2C01F833968894E7125-8078
Part No SW: 4G0 035 082 H HW: 4G0 035 082
Component: Radio U SIRIU H51 0138
Revision: AB001007 Serial number: 156EZ0B7510198
Coding: 020007020100000001
VCID: 25170D17F5E2A5AFCDB-8070
02983 - Connection between Impedance Converter 1 and Window Antenna
Reset counter: 50
Mileage: 127276 km
Date: 2019.02.06
Time: 15:16:37
Voltage: 14.90 V
Part No SW: 4G0 035 664 J HW: 4G0 035 664
Component: H-BN-NA H48 1038
Revision: -------- Serial number: 434EY0B7504835
Coding: 090200040003EDEF75128B0E00000003F00001020000000000
Subsystem 1 - Part No: 8R0 060 884 EN
Component: NAR 2017/2018 1602
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB1300U7S$
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 A
Component: E380 BDT C7 H08 0204
Serial number: 90349KEO000H5
Component: CD-Database 3371
03623 - Invalid Secruity/Release Code
Reset counter: 50
Mileage: 127276 km
Date: 2019.02.06
Time: 15:16:52
Hex Value: 0x0004
Hex Value: 0x000B
Count: 6
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F17224000628002000002
VCID: 44D1B0931E987CA7FA5-8010
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H04--- Serial number: 525 PA8J19G7MG
Coding: 1080013
VCID: 26150A1B84E4AEB7C41-8072
Part No SW: 4G8 959 107 M HW: 4G8 959 107 G
Component: HDSG-Modul H13 0039
Revision: 12013001 Serial number: 127100097
Coding: 0A3305C102
ASAM Dataset: EV_HDSGAu573 001014
ROD: EV_HDSGAu571.rod
VCID: 3FDBBF7F77FE1F7FA77-806A
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H04 0212
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4G8 919 604 D HW: 4G8 919 604 D
Component: HeadUpDisplay 007 0103
Coding: CA0000
ASAM Dataset: EV_HUDContiC7 001020
ROD: EV_HUDContiC7.rod
VCID: 3431E0534EB8CC274A5-8060
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H24 0036
Coding: 6A060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 65974D17B5E265AF0DB-8030
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Coding: 3604010101
ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
VCID: 26150A1B8864AEB7C41-8072
Part No SW: 4G0 907 107 B HW: 4H0 907 107
Component: BV-SG H29 0034
Serial number: 000040180905117
Coding: 03A198180111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 25170D17F562A5AFCDB-8070
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 0066E608031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FBB2F3F671EAFFF777-803A
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70B92C437A20B0076ED-8024
End----------(Elapsed Time: 03:02, VBatt start/end: 14.3V/14.5V)-----------
