Passat B7 ACC retrofit issue
kamold
Australia
C?ID=241363
Hi All,
Have run into an issue with a B7 ACC retrofit and am looking for any ideas to try.
We installed an ABS unit from an Alltrack that had factory ACC. Flashed to sw 042 and coded up OK. No faults. Bled and adapted, tested OK.
ACC stalk installed.
Radar installed and wired up to new gateway with ext CAN interface and wired to CCS in steering column, calibrated with a laser.
ECU coded for ACC (byte 6 bit 1)
Steering wheel coded for ACC stalk.
4F coded for ACC.
On powering on the vehicle the radar logs a bunch of faults complaining that it can't communicate with other modules. I can communicate with the radar module fine over diagnostics, read measuring blocks etc.
Swapped the gateway with a known working gateway from my car, same faults.
I believe that the CDAA engine is compatible with ACC, though not certain.
If I clear the faults in 13 radar, they are will not return until after a power cycle. However the ECU fault doesn't clear, even when the radar reports it has no faults (I guess because they need to power on together fault free).
So I disabled the radar and coded everything back to regular cruise control for now.
Friday,01,February,2019,17:55:46:58930
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4441.4
VIN: WVWZZZ3CZEP018933   License Plate:
Mileage: 64930km-40345mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 42 44 46 4C 4F 52 53 5F
          61 62 6C 72
VIN: WVWZZZ3CZEP018933   Mileage: 64930km-40345miles
Address 01: Engine (CDA)       Labels:. User\06J-907-115-CDA.lbl
   Part No SW: 06J 906 027 DE    HW: 06J 907 309 B
   Component: MED17.5.2        05 5359
   Revision: PAH04---    Serial number: VWZCZ000000000
   Coding: 0404000C24070360
   Shop #: WSC 11111 111 45725
   VCID: 71BF2B0FADA779AF613-8024
053283 - Please Check Fault Codes in Control Module for Automatic Distance Regulation
               U1023 - 000 -
                    Mileage: 64931 km
                    Date: 2019.02.01
                    Time: 17:50:25
                    Temperature: 63.0°C
                    Temperature: 34.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.684 V
Readiness: 1110 0101
   Part No SW: 0AM 300 061 G    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 5110
   Revision: 00043014    Serial number: CU501310305706
   Shop #: WSC 00028 028 00001
   VCID: 2F3BED777B132F5F377-807A
Address 03: ABS Brakes        Labels: None
   Part No SW: 3AA 698 109 N    HW: 3AA 614 109 AN
   Component: J104   C2 450M VE01 0042
   Revision: --H07---    Serial number: 00000007374038
   Coding: 0120698
   Shop #: WSC 00046 000 00000
   VCID: 44D1B2DBC295BC07FA5-8010
   Part No SW: 3AA 907 044 BQ    HW: 3AA 907 044 BQ
   Component: Climatronic   H05 0505
   Revision: 00001K02
   Coding: 061401A002
   Shop #: WSC 00028 028 00020
   VCID: 00597ECB9A8D60279ED-8054
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 N    HW: 3AA 937 087 N
   Component: BCM PQ47 M    422 0474
   Revision: BA422001
   Coding: 0008000000000000009802805400006403514E88406C8D60648046200041
   VCID: 45D7AFDFC5AF850FEDB-8010
   Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 20111  26  0612
   Coding: 00B795
   Component: RLS 051213 05  54  0403
   Coding: 0230ED
Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
   Part No SW: 3AE 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0018
   Revision: --------    Serial number: 28261332703948
   Coding: 308101
   ASAM Dataset: EV_EPHVA18VW47X0000 001006
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 3FDBBD37A7F3DFDFA77-806A
Address 13: Auto Dist. Reg        Labels: User\3AA-907-567.lbl
   Part No SW: 3AA 907 567 A    HW: 3AA 907 567
   Component: AC201  RDW A    036 0170
   Revision: 00036000    Serial number: 00000000606197
   Coding: 0010000
   Shop #: WSC 05311 000 08193
   VCID: 3829D62B8E5DE8E766D-806C
   Part No SW: 5N0 959 655 AE    HW: 5N0 959 655 AE
   Component: J234__105 VW10 HI   2418
   Revision: 28019000    Serial number: 003N5PQ1G72M
   Coding: 0012341
   VCID: 00597ECB960D60279ED-8054
   Subsystem 1 - Serial number: 6332MTS615733283
   Subsystem 2 - Serial number: 6342MTS624763273
   Subsystem 3 - Serial number: 6351HTS6V7NMGCKR
   Subsystem 4 - Serial number: 6361HTS6MTJRGCKJ
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 CN    HW: 5K0 953 569 AS
   Revision: FF010042    Serial number: 20131205301221
   Coding: 298AA50000
   VCID: 73B32107DB3B4BBF93F-8026
   Component: E221__MFL-TK6  H07 0022
   Coding: E20000
   Part No SW: 3AA 920 870 N    HW: 3AA 920 870 N
   Coding: 160F01
   VCID: 3D27C73FADFFCDCFB5B-8068
   Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AJ
   Component: J533  Gateway H51 1663
   Revision:   H51       Serial number: 15111300F12906
   Coding: 461007
   Shop #: WSC 21862 418 42054
   VCID: 72BD2403A4A142B7989-8026
03175 - Invalid Data Set
            000 -  -
                    Reset counter: 0
                    Mileage: 64929 km
                    Date: 2019.02.01
                    Time: 17:08:17
   Part No SW: 3AA 959 433 B    HW: 3AA 959 433 B
   Component:    IMMO         043 0407
   Revision: 00043000    Serial number: VWZCZ000000000
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0534
   Revision: 12110009    Serial number: 0007877227
   Coding: 0006B7
   VCID: 3537DF1F95CF158F7DB-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 704 A    HW: 3AA 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0502
   Serial number: 00000003776579
   Coding: 010690
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Mileage: 64929 km
                    Date: 2019.02.01
                    Time: 03:08:41
131584 - Motor for Rear Window Regulator
          B11EE 54 [008] - Missing Calibration / Basic Setting
                    Mileage: 64929 km
                    Date: 2019.02.01
                    Time: 03:08:41
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 195    3501
   Revision: 00H22000
   VCID: 392FD32FB557F1EF993-806C
   Component:    KSG PQ47 ELV 043 0645
   Coding: 02910A8002860E763404941570085F0B005800
Address 4C: Tire Pressure II
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AJ
   Component: EZE_2         H51 1663
   Coding: 00000009
   VCID: 6FBB2D77B7936F5F777-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0004
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0534
   Revision: 14110009    Serial number: 0007854516
   Coding: 0006B6
   ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
   VCID: 3635D81388C91E97741-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0502
   Serial number: 00000003771165
   Coding: 010690
                    Mileage: 64929 km
                    Date: 2019.02.01
                    Time: 03:08:41
                    Mileage: 64929 km
                    Date: 2019.02.01
                    Time: 03:08:41
   Revision:   H19       Serial number: 00000001690396
   Coding: 0022157
   VCID: 3635D81384491E97741-8062
   Part No SW: 5C0 035 680 E    HW: 5C0 035 680 E
   Component: MU-S-ND-ER    H31 0367
   Serial number: VWZAZ2S5222715
   Coding: 02630101BE00000001111101008808001F0100D6002001004F
   Shop #: WSC 02737 790 50316
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 231311472B5B9B3FA3F-8076
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AJ
   Component: Batt.regelung H51 1663
   Coding: F000085A
   VCID: 71BF2B0FA1A779AF613-8024
            000 -  -
                    Fault Frequency: 11
                    Reset counter: 1
                    Mileage: 64929 km
                    Date: 2019.02.01
                    Time: 03:08:39
   Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
   Component: VW428 RVC Mid H04 0040
   Coding: 01640408A201000700
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_CamSysRearPANAVW428 002002
   ROD: EV_CamSysRearPANAVW428.rod
   VCID: 3039EE0B6AAD30A72ED-8064
10489856 - No Basic Setting
          B2010 00 [009] -  -
                    Reset counter: 0
                    Mileage: 64929 km
                    Date: 2019.02.01
                    Time: 02:56:21
                    passive
End----(Elapsed Time: 01:35, VBatt start/end: 11.8V/11.8V. VIgn 11.6V)-----
kamold
Australia
C?ID=241363
As per usual, Golfi_vend to the rescue :)
He asked if I had correctly used SC4 per the wiring diagrams....retrofit 101!!! Follow the WD :banghead: yet again I embarrass myself
Applied power to the radar per the WD and re-applied all coding and ACC and front assist work perfectly, no faults.
The problem was the radar was powering up to early, not finding anyone else to talk to and so logging faults and shutting off.
