Adaptive Cruise Control retrofit (2014 Q5)
vipers
Bucharest Romania
C?ID=28396
Hello, I have a Audi Q5 2014, I retrofit succesfuly the front parking sensors, rear view camera and the ACC.
All items from ebay. my problem is that the Brake guard assist is not working,the ACC is working properly, but let me tell you what I done
1. install the ACC sensor 8R0 907 561 A
2.change the can gateway from 8R0 907 468 C to 8R0 907 468 D, my original gateway did not have the chanel for assistance
3.change the Steering wheel module from normal cruise control to adaptive cruise control module , so change from 8K0 953 568 M to 8K0 953 568 Q
4. I was at Audi dealer and remove the component protection after change the can gateway and install the ACC so they remove the component protection of all the systems
I keep the coding of the ACC 008189
Recode the steering wheel from 000037 to 00003F
Recode the engine from
2A254012243601080000 to
2A254012245601080000 so byte 6 from 36 to 56
recode the instrument cluster from
03BF220003010008010000 to
03BF220007010008010000 so byte 4 from30 to 70
After make all this I was luky and the ACC was not misadjusted so the ACC is working great only a problem with BRAKE GUARD ASSIST THAT IS NOT WORKING.
Please advise me what did I mist, I add mt original scan before start the retrofit and the actual one
Original scan before retrofit is
VCDS Version: Beta 14.7.1
Data version: 20140601
VIPER ALARMS
Sunday,17,August,2014,13:58:46:10212
Chassis Type: 8R (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 69 6C
          6D 72 AC
VIN: WAUZZZ8R6EA027688   Mileage: 3740km-2323miles
Address 01: Engine (J623-CGLC)       Labels: 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 JN    HW: 03L 906 018 JL
   Component: R4 2,0L EDC   H25 2929
   Revision: 45H25---
   Coding: 2A254012243601080000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM20TDI01103L906018JN 003003
   ROD: EV_ECM20TDI01103L906018JN.rod
   VCID: 7F077F45E6DA98C20C-802A
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 8R1 927 156 J    HW: 0B5 927 156 K
   Component: 0B5 20 TDIRdW H01 0002
   Revision: --H01---
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 438F33B5CAB23C2228-8016
   Part No SW: 8R0 907 379 AF    HW: 8R0 907 379 AF
   Component: ESP8 quattro  H09 0030
   Coding: 21DDCC01
   VCID: 040DF0A9873CFB1A51-8051
   Part No SW: 8K0 907 064 GH    HW: 8K0 907 064 FH
   Component: BCM2 2.0      H12 0633
   Coding: 05A54000000000000000
   VCID: 7CFD8849FFCC83DA29-8029
   Part No SW: 8K1 820 043 AJ    HW: 8K1 820 043 AJ
   Revision: C1000000    Serial number: 01170720130591
   Coding: 342102E000
   Shop #: WSC 03859 246 12345
   VCID: 70E5AC79A384F7BA85-8025
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000651761902
   Coding: 260080118034AFE01781400300001D0D4F9C670826090201000008004401030100000020000000
   Shop #: WSC 12345 389 03859
   VCID: 78F59459CBF4AFFA4D-802D
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 130712  H11 0050
   Coding: 01DD13
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Coding: 02005C
   Component: E1 - LDS  H03 0031
Address 15: Airbags (J234)       Labels: 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003JPDB0CY3Y
   Coding: 30463431313030303030554A304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 48952499F3941F7AFD-801D
   Serial number: 6334MSME7D237A16M
   Serial number: 6344MSME7A131A43D
   Serial number: 6352QSME0D354D58S
   Serial number: 6362QSME71323B409
   Serial number: 63732SME4633154C.
   Crash sensor for front airbag; passenger side:
   Serial number: 63832SME7448505A0
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862MGN000HP
   Coding: 000037
   VCID: 48952499FB941F7AFD-801D
Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 930 T    HW: 8R0 920 930 T
   Component: KOMBIINSTR.   H35 0563
   Revision: 00300000    Serial number: WX829MK7E
   Coding: 03BF220003010008010000
   VCID: 458B2DADCC86021206-8010
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0056
   Revision: 1Y070028    Serial number: 2841Y137060222
   Coding: 80CF07FF00
   VCID: 4A911E91E598ED6AEB-801F
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0141
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Component: TSG FA        H02 0508
   Revision:             Serial number: 0000069284918
   Coding: 011D12205C00440004
   VCID: 4FA70F851EFAC842BC-801A
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
   Component: RCEPS         H38 0507
   Revision: 00001000    Serial number: 0015679286
   Coding: 100000000001
   Shop #: WSC 06334 000 00000
   ROD: EV_RCEPSAU48X.rod
   VCID: 3B7F4B55B24244E260-806E
   Revision: 00002001    Serial number: 0311756507
   Coding: 01000E28203A30818520053680040047
   Shop #: WSC 06342 000 00000
   Component: TSG BF        H02 0508
   Revision:             Serial number: 0000069064964
   Coding: 011D12205E00440004
   VCID: 4E99128119F0C14AB7-801B
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 00000001342333
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3973515DB87E76F272-806C
   Part No SW: 4G0 035 056 J    HW: 4G0 035 056
   Component: Radio U STD   H60 0133
   Revision: AB001007    Serial number: 230GW0D7670407
   Coding: 010003020100000001
   VCID: 285584195BD4FF7A1D-807D
   Part No SW: 8R1 035 666 E    HW: 8R1 035 666 C
   Component: H-BN-EU       H46 0793
   Revision: --------    Serial number: 205GZ0D7863017
   Coding: 160100060005E3FF0580EF7E00000403000200000000000002
   VCID: 3A714E51B5787DEA7B-806F
   Subsystem 1 - Part No: 8R0 060 884 BC
   Component: EUR 2013/2014  1603
   Component: DU7 High  H42 0104
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Component: CD-Database  5298
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000069084705
   Coding: 010C12204000240004
   VCID: 46892AA1F180090A0F-8013
Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
   Part No SW: 8K0 907 383 D    HW: 8K0 907 383 D
   Revision: 1G001001    Serial number: 00000193928029
   Coding: 0109080000000000
   Shop #: WSC 25397 000 00000
   VCID: 356B5D6D9C66929296-8060
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H07---    Serial number: 525PA8-J27A2M4
   Coding: 1030010
   VCID: 346D6069571C8B9AA1-8061
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B7F4B55BA4244E260-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H52 0330
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000069084829
Address AC: Reductant Control (J880)       Labels: None
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H09 0010
   Revision: 00000000    Serial number: 131850650
   ROD: EV_RDCMA00100.rod
   VCID: 2B5F7B154222D462F0-807E
End-------------------------(Elapsed Time: 03:51)--------------------------
And actual one after retrofit
VCDS Version: Release 14.10.0
Data version: 20141022
Viper Alarms
Tuesday,18,November,2014,10:48:58:10212
Scan: 01 02 03 05 08 09 13 15 16 17 19 42 44 46 52 53 56 5F 62 69
          6C 6D 72 AC
VIN: WAUZZZ8R6EA027688   Mileage: 6240km-3877miles
5F-Information Electr. -- Status: OK
   Revision: 45H25---
   Coding: 2A254012245601080000
   VCID: 7F077F45E6DA98D9161-802A
   Revision: --H01---
   VCID: 438F33B5CAB23C39329-8016
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Coding: 21DDCC01
   VCID: 040DF0A9873CFB014B3-8051
   VCID: 7CFD8849FFCC83C1333-8029
   Coding: 342102E000
   VCID: 70E5AC79A384F7A19FB-8025
   Coding: 260080118034AFE01781400300001D0D4FDC670826090201000008004401030100000034000000
   VCID: 78F59459CBF4AFE157B-802D
   Coding: 01DD13
   Coding: 02005C
Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
   Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
   Component: ACC3          H08 X090
   Coding: 008189
   Shop #: WSC 00056 666 28888
   VCID: 37775765866A60999E1-8062
   VCID: 48952499F3941F61E7B-801D
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Component: Lenks.Modul   H03 0004
   Revision: --------    Serial number: 90372LAD00196
   Coding: 00003F
   VCID: 448D30A9C7BC3B010B3-8011
   Coding: 03BF220007010008010000
   VCID: 458B2DADCC8602091CD-8010
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H10 0055
   Revision: 1Z070013    Serial number: 1341Z108267006
   Coding: 80CF07FF00
   Shop #: WSC 06443 128 28888
   VCID: 4C9D1889EFECF341C33-8019
   VCID: 4FA70F851EFAC859A61-801A
   Coding: 100000010001
   VCID: 3B7F4B55B24244F97A9-806E
   Coding: 01000E28203A70818520053680040047
   Component: GTO BF  H06 0050
   VCID: 4E99128119F0C151AD7-801B
   VCID: 3973515DB87E76E9685-806C
   VCID: 285584195BD4FF6107B-807D
   Coding: 160100060005EBFF2582EF7E00000403040000000000000002
   VCID: 3A714E51B5787DF161F-806F
   VCID: 46892AA1F1800911157-8013
   VCID: 356B5D6D9C6692898CD-8060
   Coding: 1030010
   VCID: 346D6069571C8B81BB3-8061
   VCID: 3B7F4B55BA4244F97A9-806E
   VCID: 2B5F7B154222D479EA9-807E
End-------------------------(Elapsed Time: 03:52)--------------------------
Please help me with a solution for this
Thank you
