OpenPilot
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
A thing is happening:
As of this morning, we have a fork of Comma AI OpenPilot that can steer my 2018 Golf R. We're doing it by filtering the HCA_01 (Heading Control Assist) CAN messages from the A5 camera and inserting our own, and transparently passing the rest of its traffic. We're filtering Extended CAN right at the CAN gateway, so all the wiring and hardware bits are tucked away safe and invisible, plus it lets us integrate and enhance the ACC radar later on.
This could be used, in combination with VCDS coding, to provide Active Lane Guidance functionality for vehicles that don't even have cameras from the factory. No windshield replacements, no CP, no FEC. :) Same may go for ACC. OpenPilot will use feedback from the factory radar, if present, but it can do purely vision-based ACC as well, and those CAN messages could be simulated.
The PID feedback loops aren't dialed in yet, so it wants to pingpong between the lane markers, but now that we know it's feasible the rest will come together quickly. That's the theory anyway. Maybe I'll end up upside-down in a ditch. If I disappear off the Internet forever after posting this, Ross-Tech, please update my interface registrations to my wife and children.
In other news, I accidentally found out a MQB vehicle can go ignition-on with the CAN gateway entirely unplugged. It would really prefer not to, but it will. 3,502 line Auto-Scan.
Wednesday,30,January,2019,10:29:27:21122
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4451.4
Dealer/Shop Name: Southwest Ohio Luxobarge Rescue
Workshop Code: 444 08607 000005
VIN: WVWVF7AU2JW177386   License Plate: 2018GOLFR
Mileage: 22407km-13923mi   Repair Order: REL1891-HNIF-WHOOPS
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 39 3C 42 44
          47 4B 52 5F 75 A5 A9 D6 D7
VIN: WVWVF7AU2JW177386   Mileage: 22407km-13923miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-DJJA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 P    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 0A2500122466010E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259P 001003
   ROD: EV_ECM20TFS0208V0906259P_VW37.rod
   VCID: CDD2285C9C831C22E6-8098
9 Faults Found:
21630 - No Communications with HVAC Control Module (J301)
          U0164 00 [032] - -
                    Mileage: 22283 km
                    Engine speed: 0.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 9 °C
                    Intake air temperature: 9 °C
                    Voltage terminal 30: 12.753 V
                    Unlearning counter according OBD: 32
                    Engine: operating status: ES
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 9.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 578 min
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
                    Cruise control switch actuation-Control component verified: No
                    T_AST_SAE: 0 s
19854 - Steering Column Control Module
          U0212 00 [032] - No Communications
                    Mileage: 22283 km
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 12.773 V
                    ECU_STATE: ENG_STOP
                    T_ES: 578 min
                    T_AST_SAE: 0 s
22008 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [040] - -
                    Mileage: 22283 km
                    Unlearning counter according OBD: 37
                    ECU_STATE: ENG_STOP
                    T_ES: 578 min
                    T_AST_SAE: 0 s
19311 - Door Control Module - Driver's Door
          U0199 00 [032] - No Communications
                    Mileage: 22283 km
                    ECU_STATE: ENG_STOP
                    T_ES: 578 min
                    T_AST_SAE: 0 s
22055 - No Communications with Power Steering Control Module
          U0131 00 [032] - -
                    Mileage: 22283 km
                    ECU_STATE: ENG_STOP
                    T_ES: 578 min
                    T_AST_SAE: 0 s
19868 - No Communication with Instrument Cluster
          U0155 00 [032] - -
                    Mileage: 22283 km
                    ECU_STATE: ENG_STOP
                    T_ES: 578 min
                    T_AST_SAE: 0 s
19870 - No Communication with Diagnostic Gateway
          U0146 00 [032] - -
                    Mileage: 22283 km
                    ECU_STATE: ENG_STOP
                    T_ES: 578 min
                    T_AST_SAE: 0 s
19875 - No Communication with ABS Brake Control Module
          U0121 00 [032] - -
                    Mileage: 22283 km
                    ECU_STATE: ENG_STOP
                    T_ES: 578 min
                    T_AST_SAE: 0 s
19879 - Body Control Module (Central Electric)
          U0140 00 [032] - No Communications
                    Mileage: 22283 km
                    ECU_STATE: ENG_STOP
                    T_ES: 578 min
                    T_AST_SAE: 0 s
Readiness: 0000 0100
   Part No SW: 0GC 300 012 A    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1403
   Revision: 00H06V07
   ROD: EV_TCMDQ381061.rod
   VCID: A10AA4ECB09BE84272-80F4
   Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
   Component: ESC           H25 0523
   Revision: 00000000    Serial number: 63627000001098
   Coding: 01FA6BA154272173457A030860C96980D62A84A2C0069677384250D8C2A8430B00000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 8346CE640A471A5240-80D6
25 Faults Found:
8192 - Databus
          [FCAN: ACC_07 message is not received]
                    Reset counter: 128
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:11
8196 - Databus
          [FCAN : ACC_10 message is not received]
                    Reset counter: 128
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:11
8206 - Databus
          [FCAN: Airbag_03 message is not received]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:09
8214 - Databus
          [FCAN: Diagnose_01 message is not received]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:09
8222 - Databus
          [FCAN : Getriebe_11 message is not received]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:09
8226 - Databus
          [FCAN : Getriebe_14 message is not received]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:09
8232 - Databus
          [FCAN: Kombi_02 message is not received]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:09
8234 - Databus
          [FCAN: Kombi_03 messag is not received]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:09
8246 - Databus
          [FCAN: Motor_Code_01 message is not received]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:09
8250 - Databus
          [FCAN: Motor_07 message is not received]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:09
8252 - Databus
          [FCAN: Motor_11 message is not received]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:09
8254 - Databus
          [FCAN: Motor_12 message is not received]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:09
8256 - Databus
          [FCAN: Motor_14 message is not received]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:09
8258 - Databus
          [FCAN: Motor_20 message is not received]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:09
8268 - Databus
          [FCAN: VIN_01 message is not received]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:09
8343 - Databus
          [FCAN : Gateway_79 message is not received]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:09
8362 - Databus
          [FCAN: RCTA_01 is not received]
                    Reset counter: 128
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:11
8366 - Databus
          [FCAN: Charisma_01 is not received]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:09
8368 - Databus
          [FCAN: Charisma_07 is not received]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:09
8382 - Databus
          [FCAN: HCA_01 not received]
                    Fault Frequency: 8
                    Reset counter: 129
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:09
8384 - Databus
          [FCAN: HCA_01 received with invalid checksum]
                    Reset counter: 129
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:09
16409 - Display for Tire Pressure Monitoring
          C1146 02 [008] - Signal Failure
                    Reset counter: 121
                    Mileage: 22283 km
16410 - Display for Tire Pressure Monitoring
                    Reset counter: 121
                    Mileage: 22283 km
16411 - Display for Tire Pressure Monitoring
                    Reset counter: 121
                    Mileage: 22283 km
16416 - Display for Tire Pressure Monitoring
                    Reset counter: 121
                    Mileage: 22283 km
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0464858592
   Coding: 032C0C
   VCID: BC3475983739A5AA41-80E8
12715780 - Databus
          [Ausfall BEM_02-Botschaft - kein Signal/Kommunikation]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
12716548 - Databus
          [Ausfall Systeminfo - Botschaft -  kein Signal/Kommunikation]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
12716804 - Databus
          [Ausfall Motor_14 - Botschaft -  kein Signal/Kommunikation]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
12717060 - Databus
          [Ausfall Gateway_73 - Botschaft - kein Signal/Kommunikation]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
12717316 - Databus
          [Ausfall Gateway_71 - Botschaft - kein Signal/Kommunikation]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
12718084 - Databus
          [Ausfall Airbag_02 - Botschaft - kein Signal/Kommunikation]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0002000420010201110501401211142A
   Shop #: WSC 08607 444 00001
   VCID: ED9288DC3CC3FC2286-80B8
   Air quality sensor:
459009 - Databus
          [Airbagsteuergerät - kein Signal/Kommunikation]
                    Reset counter: 121
459024 - Databus
          [Frontsensorik - kein Signal/Kommunikation]
                    Reset counter: 128
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:12
459013 - Databus
          [Diagnoseinterface für Datenbus - kein Signal/Kommunikation]
                    Reset counter: 121
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001735200577
   Coding: 000000000000080000000000000000000000000000000000000000000000
   ROD: EV_BCMBOSCH_018.rod
   VCID: 8640D77039752F7A67-80D2
   Component: WWS    171209  043 0551
   Serial number:         171213061443
   Component: RLHS  047 0105
   Serial number: S4Y18M01D10H22M47S41
   Coding: 00A8DD
19 Faults Found:
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
                    Reset counter: 81
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:42:51
528405 - Databus
          [Airbag_01 Datenbus fehlende Botschaft]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
528917 - Databus
          [ESP_21 Datenbus fehlende Botschaft]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
529941 - Databus
          [BEM_02 Datenbus fehlende Botschaft]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
531221 - Databus
          [Diagnose_01 Datenbus fehlende Botschaft]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
531477 - Databus
          [Charisma_03 Datenbus fehlende Botschaft]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
533269 - Databus
          [ESP_20 Datenbus fehlende Botschaft]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
533781 - Databus
          [ESP_02 Datenbus fehlende Botschaft]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
534549 - Databus
          [FLA_01 Datenbus fehlende Botschaft]
                    Reset counter: 128
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
535317 - Databus
          [Gateway_71 Datenbus fehlende Botschaft]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
536085 - Databus
          [Gateway_73 Datenbus fehlende Botschaft]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
540693 - Databus
          [LWR_AFS_01 Datenbus fehlende Botschaft]
                    Reset counter: 128
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
541973 - Databus
          [Motor_04 Datenbus fehlende Botschaft]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
542229 - Databus
          [Motor_14 Datenbus fehlende Botschaft]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
542485 - Databus
          [Motor_18 Datenbus fehlende Botschaft]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
556309 - Databus
          [Systeminfo_01 Datenbus fehlende Botschaft]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
558101 - Databus
          [Airbag_02 Datenbus fehlende Botschaft]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
558613 - Databus
          [Gateway_78 Datenbus fehlende Botschaft]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
559125 - Databus
          [Motor_07 Datenbus fehlende Botschaft]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418918005
   Coding: 0471155811
   VCID: CBD6264462971212F8-809E
13 Faults Found:
12666384 - Databus
          [Diagnose-Interface für Datenbus-J533 - Diagnose_01 - kein Signal/keine Kommunikation]
                    Reset counter: 121
12665088 - Databus
          [Bodycomputer 2 / Zentralmodul Komfortsystem / ZKE - Klemmen_Status_01 - kein Signal/keine Kommunikation]
                    Reset counter: 121
12664864 - Databus
          [Steuergerät für BCM - Dimmung_01 - kein Signal/keine Kommunikation]
                    Reset counter: 121
12670210 - Databus
          [Steuergerät für Schalttafeleinsatz-J285 - Kombi_02 - kein Signal/keine Kommunikation]
                    Reset counter: 121
12648465 - Databus
          [Motorsteuergerät - Motor_12 - kein Signal/keine Kommunikation]
                    Reset counter: 121
12648721 - Databus
          [Getriebesteuergerät - Getriebe_11 - kein Signal/keine Kommunikation]
                    Reset counter: 121
12666389 - Databus
          [Diagnose-Interface für Datenbus-J533 - Gateway_72 - kein Signal/keine Kommunikation]
                    Reset counter: 121
12727553 - Databus
          [Steuergerät für Abstandsregelung - Gateway_79.ACC_02_alt - kein Signal/keine Kommunikation]
                    Fault Frequency: 13
                    Reset counter: 128
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:11
12666390 - Databus
          [Diagnose-Interface für Datenbus-J533 - Gateway_79 - kein Signal/keine Kommunikation]
                    Reset counter: 121
13637426 - Databus
                    Reset counter: 121
13639168 - Databus
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01 - kein Signal / keine Kommunikation]
                    Fault Frequency: 17
                    Reset counter: 128
13688835 - Databus
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                    Reset counter: 128
                    Mileage: 22341 km
                    Date: 2019.01.29
                    Time: 20:26:21
12648468 - Databus
          [Motorsteuergerät - Motor_20 - kein Signal/keine Kommunikation]
                    Reset counter: 121
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 331807E15DFFC728949C810580401600000000000000000000
   Shop #: WSC 08607 444 00005
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: BE307F902125B7BA6F-80EA
10 Faults Found:
2109 - Databus
          [FAULT_AWV_CONSISTENCY_FAIL]
                    Reset counter: 128
                    Mileage: 22341 km
                    Date: 2019.01.29
                    Time: 20:26:22
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 14.5 V
2111 - Databus
          [FAULT_ESP_CONS_ACC]
                    Reset counter: 128
                    Mileage: 22341 km
                    Date: 2019.01.29
                    Time: 20:26:22
1799 - Internal Fault
          B200F F0 [008] - Unknown Error Elaboration
          [FAULT_TX_TIMEOUT_ACC_02]
                    Reset counter: 121
                    Mileage: 22283 km
                    Control Module temperature: 11 °C
                    Voltage terminal 15: 12.7 V
1798 - Internal Fault
          [FAULT_TX_TIMEOUT_ACC_04]
                    Reset counter: 121
                    Mileage: 22283 km
1797 - Internal Fault
          [FAULT_TX_TIMEOUT_ACC_06]
                    Reset counter: 121
                    Mileage: 22283 km
1796 - Internal Fault
          [FAULT_TX_TIMEOUT_ACC_07]
                    Reset counter: 121
                    Mileage: 22283 km
1795 - Internal Fault
          [FAULT_TX_TIMEOUT_ACC_10]
                    Reset counter: 121
                    Mileage: 22283 km
1800 - Internal Fault
          [FAULT_TX_TIMEOUT_ACC_13]
                    Reset counter: 121
                    Mileage: 22283 km
1801 - Internal Fault
          [FAULT_TX_TIMEOUT_ACC_15]
                    Reset counter: 121
                    Mileage: 22283 km
1794 - Internal Fault
          [FAULT_TX_TIMEOUT_KN_ACC]
                    Reset counter: 121
                    Mileage: 22283 km
   Serial number: 24111741350693
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: B83C69880301898AA5-80EC
332548 - Databus
          [Gateway - kein Signal/Kommunikation]
                    Reset counter: 121
336388 - Databus
          [Motor - kein Signal/Kommunikation]
                    Reset counter: 121
   Serial number: 003GCR09SK3W
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: C7DE1A747EFFF672DC-8092
   Occupant Detection:
   Serial number: IBH000000000008EZ3AU
   Coding: 303344
   Subsystem 2 - Part No SW: -----------    HW: 480 000 501 18
   Serial number: 35700000000198194A2G
   Subsystem 3 - Part No SW: -----------    HW: 480 000 201 18
   Serial number: 358000000007D82D1A2T
   Subsystem 4 - Part No SW: -----------    HW: 480 402 312 17
   Serial number: 3510001C9284E2D6869H
   Subsystem 5 - Part No SW: -----------    HW: 480 402 712 17
   Serial number: 3520001AB288D0F4E33G
   Subsystem 6 - Part No SW: -----------    HW: 480 402 212 17
   Serial number: 3550001C7284E2D3A79J
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 212 17
   Component: FrontSensor_P  000 6149
   Serial number: 3560001C7284E2D20755
11 Faults Found:
9482752 - Seat Occupied Recognition
          B10B2 00 [008] - Function Restriction due to Missing Message(s)
                    Reset counter: 167
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:14
          B13BC F2 [008] - No function
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:14
1054976 - Databus
          [NWD: 0x6B7 Kombi_02 Timeout]
                    Reset counter: 167
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:14
1051904 - Databus
          [NWD: 0x30B Kombi_01Timeout]
                    Reset counter: 167
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:14
1052928 - Databus
          [NWD: 0x0FD ESP_21 Timeout]
                    Reset counter: 167
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:14
1051136 - Databus
          [NWD: 0x6B4 VIN_01 Timeout]
                    Reset counter: 167
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:14
1051392 - Databus
          [NWD: 0x6B2 Diagnose_01 Timeout]
                    Reset counter: 167
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:14
1048576 - Databus
          [NWD: 0x5F0 Dimmung_01 Timeout]
                    Reset counter: 167
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:14
1052672 - Databus
          [NWD: 0x392 ESP_07 Timeout]
                    Reset counter: 167
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:14
1053696 - Databus
          [CAN: 0x3DB Gateway_72 Timeout]
                    Reset counter: 167
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:14
1054208 - Databus
          [NWD: 0x3C0 Klemmen_Status_01 Timeout]
                    Reset counter: 167
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:14
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 28121704221561
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 895ADC4C286B40020A-80DC
131108 - Databus
          U1121 00 [024] - Missing Message
          [Time-Out Gateway_71: Time-Out BSG]
                    Reset counter: 123
                    Operating time: 26267 min
                    Supply voltage: Terminal 30: 12.9 V
                    Voltage at switch: 4.98 V
                    Terminal 15 status: active
                    System status: 30
   Part No SW: 5G1 920 891 A    HW: 5G1 920 891 A
   Component: KOMBI         408 3195
   Coding: 03AD301A7F88CF0502886B0B54010000A0000000
   VCID: AB1646C4C2573212D8-80FE
20 Faults Found:
16777008 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_SWA_0x1A keine Kommunikation]
                    Reset counter: 128
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:17
16777010 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_LDW_0x19 keine Kommunikation]
                    Reset counter: 128
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:17
16777028 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_AWV_0x1B keine Kommunikation]
                    Reset counter: 128
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:17
16776960 - Databus
          [ACC_02 keine Kommunikation]
                    Reset counter: 128
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
16776961 - Databus
          [ACC_04 keine Kommunikation]
                    Reset counter: 128
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
16776962 - Databus
          [Airbag_01 keine Kommunikation]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
16776965 - Databus
          [BEM_02 keine Kommunikation]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
16776966 - Databus
          [Daempfer_01 keine Kommunikation]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
16776967 - Databus
          [EPB_02 keine Kommunikation]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
16776968 - Databus
          [ESP_24 keine Kommunikation]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
16776969 - Databus
          [LDW_02 keine Kommunikation]
                    Reset counter: 128
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
16776970 - Databus
          [LWR_AFS_01 keine Kommunikation]
                    Reset counter: 128
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
16776971 - Databus
          [Motor_04 keine Kommunikation]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
16776978 - Databus
          [LH_EPS_01 keine Kommunikation]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
16776982 - Databus
          [SWA_01 keine Kommunikation]
                    Reset counter: 128
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
16776980 - Databus
          [PLA_Status_01 keine Kommunikation]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
16776983 - Databus
          [WBA_03 keine Kommunikation]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
16776988 - Databus
          [TSK_07 keine Kommunikation]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
16776993 - Databus
          [ESP_21 keine Kommunikation]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007198325
   Coding: 030100047F085902FB00827A9C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW37.rod
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Serial number: 29170002448880057427
   Coding: 35FFFF
   Serial number: 3640416404
131593 - Unknown Error Code
          U1301 00 [008] - -
          [Time_out_node_0x09_multifunction_module_on_second_bus]
                    Reset counter: 124
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:11
                    Supply voltage: Terminal 30: 12.0 V
                    Terminal 15: On
131662 - Lane change assistant control module
          U1045 00 [008] - No communication
          [Timeout Knoten 0x4E / 3C - Steuergerät für Spurwechselassistent]
                    Reset counter: 124
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:11
                    Terminal 15: On
131663 - No Communications with Front Sensor Package for Driver Assist. Systems
          U10E0 00 [008] - -
          [Timeout Knoten 0x4F / A5 - Frontsensorik für Fahrerassistenzsysteme]
                    Reset counter: 124
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:11
                    Terminal 15: On
131671 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [008] - -
          [Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
                    Reset counter: 124
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:11
                    Terminal 15: On
66054 - Extended CAN Bus (SAE Bus C)
          U0047 00 [008] - Performance
          [Globaler Timeout CAN-Extended]
                    Reset counter: 128
                    Mileage: 22341 km
                    Date: 2019.01.29
                    Time: 19:57:35
                    Supply voltage: Terminal 30: 14.2 V
                    Terminal 15: On
   Serial number: HA1-00003.11.17
   Coding: 0001
   VCID: CCD425586799152AF1-8098
9 Faults Found:
16652 - Databus
          [Getriebe - TO -- Get_11]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:18
16654 - Databus
          [Kombi - TO -- Kombi_01]
                    Fault Priority: 8
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:18
17466 - Databus
          [Kombi - TO -- Kombi_02]
                    Fault Priority: 8
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:18
17473 - Databus
          [Motorsteuergerät - TO -- Mot_11]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:18
16657 - Databus
          [Motorsteuergerät - TO -- Mot_12]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:18
17474 - Databus
          [Motorsteuergerät - TO -- Mot_14]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:18
16727 - Databus
          [Motorsteuergerät - TO -- Mot_20]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:18
17475 - Databus
          [Motorsteuergerät - TO -- Mot_Code]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:18
16659 - Databus
          [Gateway - TO -- Sys_01]
                    Fault Priority: 8
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:18
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
0279 - Databus
          [databus - message missing]
                    Reset counter: 128
                    Mileage: 22283 km
0281 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 128
                    Mileage: 22283 km
   Revision: 00000000    Serial number: 17000376691003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: B4245DB81F696DEA89-80E0
7 Faults Found:
12666368 - Databus
          [Timeout Message Gateway_71]
                    Reset counter: 123
                    ELV State: 04
                    Information Clamps: 77 68
                    CoCo State: E0 01
                    WFS State: 17 0E
                    Vehicle speed: 0.00 km/h
                    Voltage: 6F
                    AD-Value H-bridge: 36
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 0A
12666369 - Databus
          [Timeout Message Motor_14]
                    Reset counter: 121
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 17 0E
                    Voltage: 6F
                    CAN signals: 0A
12666370 - Databus
          [Timeout Message ESP_10]
                    Reset counter: 121
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 17 0E
                    Voltage: 6F
                    CAN signals: 0A
12666372 - Databus
          [Timeout Message Gateway_73]
                    Reset counter: 123
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 17 0E
                    Voltage: 6F
                    CAN signals: 0A
12666375 - Databus
          [Timeout Message BEM_02]
                    Reset counter: 121
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 17 0E
                    Voltage: 6F
                    CAN signals: 0A
12666376 - Databus
          [Timeout Message Airbag_02]
                    Reset counter: 121
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 17 0E
                    Voltage: 6F
                    CAN signals: 0A
12666381 - Databus
          [Timeout Message Motor_09]
                    Reset counter: 121
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 17 0E
                    Voltage: 6F
                    CAN signals: 0A
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
0033 - Supply voltage
          [Supply voltage - lower limit exceeded]
                    Reset counter: 123
                    Mileage: 22312 km
                    Date: 2019.01.29
                    Time: 13:36:06
0279 - Databus
                    Reset counter: 128
                    Mileage: 22283 km
          - 00 [008]
                    Reset counter: 128
                    Mileage: 22283 km
   Component: HRE_Master    H12 0080
   Serial number: 0464678659
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: BD32789C2C23ACA276-80E8
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0080
   Serial number: 0465504023
   Coding: 020111
9 Faults Found:
123396 - Databus
          [Airbag ECU Airbag_01 - no signal/no communication]
                    Reset counter: 127
332549 - Databus
          [Gateway ECU Gateway_72 - no signal/no communication]
                    Reset counter: 127
336901 - Databus
          [Braking ECU ESP_33 - no signal/no communication]
                    Reset counter: 127
337156 - Databus
          [Kombi ECU Kombi_01 - no signal/no communication]
                    Reset counter: 127
337184 - Databus
          [BCM ECU Blinkmodi_02 - no signal/no communication]
                    Reset counter: 128
337280 - Databus
          [EPS ECU LWI_01 - no signal/no communication]
                    Reset counter: 127
337312 - Databus
          [Parkhilfe ECU Parkhilfe_01 - no signal/no communication]
                    Reset counter: 127
338032 - Databus
          [ESP_33:: ESC_Konsistenz_RCTA- nicht_konsistent]
                    Reset counter: 128
                    Mileage: 22341 km
                    Date: 2019.01.29
                    Time: 19:57:33
512260 - Extended CAN Bus (SAE Bus C)
   Serial number: 021217EL138903
   Coding: 003E13208000040000000000
   VCID: C3C60E644AC7DA5200-8096
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000018361075
   Coding: 111000
458752 - Databus
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
458809 - Databus
                    Reset counter: 123
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
458803 - Databus
                    Reset counter: 123
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
458857 - Databus
          [RGS_VL_01 Datenbus fehlende Botschaft]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
458851 - Databus
          [Mem_FS_01 Datenbus fehlende Botschaft]
                    Reset counter: 81
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:27:09
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: BB3676843237A29248-80EE
24320 - Steering
          C10AC 07 [009] - Mechanical Failure
          [Belastungszähler hat 99% überschritten Belastungszähler hat 100% erreicht]
                    Reset counter: 89
                    Mileage: 22347 km
                    Date: 2019.01.30
                    Time: 04:08:50
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 11.00 V
                    Temperature: 12.0 °C
                    KFC: 5F
                    KFA: 00 00
                    Environmental conditions: 5F
                    uioUdNotFilt_xdu16: 11.20 V
                    uAdSensI_SwitchedKl30_xdu16: 11.09 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1HMD01KBFQ
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: AE104FD0F145473AFF-80FA
   Serial number: 21121710521279
   Coding: 000000050100165207713F07020000000000000000000000000000000000
   VCID: F2A89BA025FD23DA5B-80A6
7 Faults Found:
13705488 - Databus
          [Diagnose_01 data bus missing message]
                    Reset counter: 121
13705480 - Databus
          [Systeminfo_01 data bus missing message]
                    Reset counter: 121
12601088 - Extended CAN Bus (SAE Bus C)
          [Databus extended no communication]
                    Reset counter: 128
13706046 - Databus
          [LV_Abblendlicht_li_def received error value]
                    Fault Frequency: 16
                    Reset counter: 128
13706047 - Databus
          [LV_Abblendlicht_re_def received error value]
                    Fault Frequency: 16
                    Reset counter: 128
13705988 - Databus
          [FA_Hoehenwert_VL_00 received error value]
                    Reset counter: 124
13705989 - Databus
          [FA_Hoehenwert_HL_00 received error value]
                    Reset counter: 124
   Serial number: 101217ELA06139
   Coding: 003E13208000040000800000
   VCID: C2C80B6055DDD35A0B-8096
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000018233831
   Coding: 091000
458752 - Databus
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
458809 - Databus
                    Reset counter: 123
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
458803 - Databus
                    Reset counter: 123
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
458857 - Databus
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    851 0867
   Coding: 027310020000000051220002001808009F0507F401200405C6
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: B3265EA41A676AD290-80E6
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZJT3480215
   Subsystem 2 - Part No SW: 3G0 919 866 BP    HW: -----------
   Component: NAR 2018  --- 0715
9 Faults Found:
6917 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 128
                    Mileage: 22341 km
                    Date: 2019.01.29
                    Time: 19:57:37
                    Voltage terminal 30: 14.8 V
6937 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 128
                    Mileage: 22341 km
                    Date: 2019.01.29
                    Time: 19:57:38
6938 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Side assist (0x1A) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 128
                    Mileage: 22341 km
                    Date: 2019.01.29
                    Time: 19:57:37
6939 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 128
                    Mileage: 22341 km
                    Date: 2019.01.29
                    Time: 19:57:37
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 128
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:34
                    Voltage terminal 30: 12.3 V
                    BAP-BAP_Function_ID: 02
7184 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Seat adjustment/seat memory (0x10) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 81
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:27:12
                    Voltage terminal 30: 12.4 V
7193 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 128
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:34
7194 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Side assist (0x1A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 128
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:34
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 128
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:43:34
   Component: OCULowMQBUS   009 0570
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
7 Faults Found:
12670464 - Databus
          [CAN TO brake]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
0022 - Databus
          [CAN TO radio]
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
0035 - Databus
          [CAN TO Airbag]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
0036 - Databus
          [CAN TO GPS data]
                    Reset counter: 123
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
0041 - Databus
          [CAN TO Motor ECU]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
13633792 - Databus
          [CAN TO gateway]
                    Reset counter: 123
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
12718848 - Databus
          [CAN TO Steering angle module]
                    Reset counter: 121
                    Mileage: 22283 km
                    Date: 2019.01.29
                    Time: 01:31:29
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 22121712P20035
   Coding: 0003070000000201002213548156890088000E200120
10 Faults Found:
1122563 - Databus
          [Timeout_Airbag_01]
                    Mileage: 22341 km
                    Date: 2019.01.29
                    Time: 19:57:33
                    Control Module temperature: 18 °C
                    Outside air temperature: -7.5 °C
                    System run time: 285.3 s
                    Voltage terminal 15: 14.3 V
                    mid: 01 A5
                    Status of camera: limited
                    Engine_Running_Info: 1
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1122593 - Databus
          [TIMEOUT_ESP_21]
                    Control Module temperature: -258 °C
                    Outside air temperature: 77.5 °C
                    Vehicle speed: 655.35 km/h
                    System run time: 0.0 s
                    Voltage terminal 15: 11.2 V
                    mid: 01 BF
                    Status of camera: Initializing
                    Engine_Running_Info: 255
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1135155 - Databus
          [Timeout_Gateway_73]
                    Mileage: 22341 km
                    Date: 2019.01.29
                    Time: 19:57:33
                    mid: 01 CC
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1122612 - Databus
          [TIMEOUT_Kombi_01]
                    Mileage: 22341 km
                    Date: 2019.01.29
                    Time: 19:57:33
                    mid: 01 CF
                    Status of camera: operational
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1123606 - Databus
          [TIMEOUT_Licht_Anf_01]
                    Mileage: 22341 km
                    Date: 2019.01.29
                    Time: 19:57:33
                    System run time: 285.8 s
                    mid: 01 B3
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1122625 - Databus
          [TIMEOUT_LWI_01]
                    Mileage: 22341 km
                    Date: 2019.01.29
                    Time: 19:57:33
                    mid: 01 D9
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1122628 - Databus
          [Timeout_Motor_14]
                    Mileage: 22341 km
                    Date: 2019.01.29
                    Time: 19:57:33
                    mid: 01 E5
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1122629 - Databus
          [TIMEOUT_Motor_20]
                    Mileage: 22341 km
                    Date: 2019.01.29
                    Time: 19:57:33
                    mid: 01 E9
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
1122679 - Databus
          [Timeout_TSK_06]
                    Mileage: 22341 km
                    Date: 2019.01.29
                    Time: 19:57:33
                    mid: 02 12
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
0659 - Steering
          C10AC F2 [008] - Lane-Holding Assistance Not Coded
          [HC_interface_at_the_steering_not_activated]
                    Control Module temperature: 8 °C
                    Outside air temperature: 77.0 °C
                    Vehicle speed: 655.34 km/h
                    System run time: 3.4 s
                    Voltage terminal 15: 12.1 V
                    mid: 02 A6
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 171206201656
   VCID: AF2E52D4F64F4E32F4-80FA
0014 - Databus
          [Keine Funktion durch CAN FehlerESPsteuergerätebotschaft fehlt--> keine Klangerzeugung]
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: B93A6C8C380B90825A-80EC
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxR_KEBODAVW481.rod
End----(Elapsed Time: 02:45, VBatt start/end: 11.5V/11.4V. VIgn 11.4V)-----
Video. We need video. :D
PS:
One of our distributors has a 2016 Passat in Germany with this kind of functionality from the factory and he says it's unusable due to behavior much like that.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
I'm going to need a few days for that... ;)
The lane centering feedback loop is substantially useless right now except to validate we can indeed command steering torque, you can't really go hands-off for a meaningful amount of time yet. And, it all needs to be refactored from the current jumble of copypasta we used for discovery and testing. I'm working on that. While that's happening, I've got a camera mount on the way that I wanted for WITW anyway.
Hrm... not sure what you're referring to here. Something besides the usual A5 camera?
No, I'm pretty sure it's got the usual A5 camera.
siLc
Tallinn, Estonia
C?ID=330192
This normally shouldn't be the case with the 3Q0980654 A5 camera, which the Passat B8 and many other MQB cars use. It should definetly keep the car in the center of the lane. Perhaps have the dealer do a SW level update?
golfi_vend
Tartu, Estonia
C?ID=195131
Setting of lane assist needs to be tweaked higher for Autonomous driving feeling. When set in center or lower position, it does feel like drunk driver.
DGMotors
C?ID=57532
It ok, Jesus is taking the wheel! ;)
D-Dub
C?ID=272151
I always wanted to do something like that for my volt to add ACC.
I have the camera behind the mirror for emergency braking collision warning, but no blindspot detectors.
looks like comma.ai supports some of the newer volts, but not the old ones. /sigh
D-Dub
C?ID=272151
instead of bouncing back and forth, can't you just teach it to follow the centerline and use side line as fallback/secondary?
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Got some coarsely tuned PIDs dialed-in today. Amateur cinematography and peanut gallery commentary provided by my sons in the backseat.
There's still some ground to be gained, I'm going to revisit tuning when we get rid of all this snow and salt spray obscuring lane markings everywhere, but it's now very usable on the highway and pretty decent on side/rural roads. I've still got a lot of safety coding yet to be done, but this is going to be a quality OP port.
Once steering is dialed in, I want to do a little work with ACC. We're still using the stock ACC, and probably will for the foreseeable future, but we could could layer on some functionality. After VCDS recoding to permit resume after short stop/resume from steering wheel button, we can monitor for distance to the vehicle in front, and simulate the resume button press to resume anytime. With that same button press simulation, we can use map-based speed limit data we get from OpenStreetMap to adjust the ACC setpoint.
Most of OP's code requires really specific data about every single model and year of vehicle, and it's a really cumbersome thing to maintain. I think I can make this code work for MQB in a very general way, and then process the VIN_01 messages to get the VIN, identify the chassis from that, and keep a lookup table of supported MQB vehicle-classes with their associated tuning constants. That will work really well in the USA, but RoW vehicles don't encode nearly so much vehicle type info into the VIN, so (as one example) distinguishing a RoW Golf from a Golf Sportwagen from a Golf Alltrack when they're all chassis AU may be difficult. Thoughts welcome if anyone knows a way to tell those apart from an Auto-Scan or similar.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
PID loops more or less work. Safeties are about two thirds done. Added some code to simulate LDW_02 messages to the instrument cluster, for yellow/green passive/active and left/right lane visibility. For S&Gs I added automatic detection of the car's configured speed units (MPH vs KPH), and later I want to go back and obey terminal 58 dimming for brightness. Lots more to do, but what we have is working pretty decent. If anyone else wants to give this code a try, we're at a point where I could talk you through building the CAN bus tap. No mods required to the car.
https://github.com/jyoung8607/openpilot/tree/vw-dev/selfdrive/car/vw
# TODO: additional signals
#  * EPS HCA support detection (throw steering error on engage if not supported)
#  * ACC speed setpoint
#  * ACC following distance setpoint
#  * ACC distance to car in front
#  * Test ACC sensor blind/other error to make sure OP can react clearly and promptly
#  * GRA_ACC_01 steering wheel buttons for events, and to send cancels and speed changes
#  * Dimmung messages for EON screen brightness
#  * (( Klemmen_Status_01 for virtual terminal 15, but goes in Panda safety ))
#  * (( VIN_01 for auto platform ID, but probably goes in fingerprint or init ))
#  * ESP_05 ESP_Autohold_aktiv provides DSG and maybe even manual auto-hold state, may be important for auto-resume
#  * ESP_05 ESP_Verzoeg_EPB_verf may signify presence of an EPB, implying ACC stop-and-go support
#  * EPB_01 EPB_Status and friends tell us lots about the EPB, if present, still need to track down handbrake
#  * ACC_06 ACC_Typ may indicate stop-and-go support, @cben = 1, @jyoung8607 = 2
# TODO: Safety
#  * Seatbelt works to disable. Turns out stock ACC doesn't care, so OP gets to handle. Need to spam ACC cancel.
#  * Door open detection works to disable. ACC dies immediately anyway, but tested manually.
#  * Brake pressed. Obviously knocks out stock ACC. Have not made this explicit/redundant in OP yet.
#  * ESP disabled detection works, but stock ACC re-enables and creates a timing/conflict with OP, need to spam cancel.
#  * Gas pressed. Trivial but haven't done yet. Will need to spam ACC cancel.
#  * Control steering torque and ramp rate once we have a reasonable tune model.
# TODO: generic platform detection
#  * Collect 3x VIN_01 messages and detect chassis (e.g., AU=Golf Mk7) with inherent networking model
#  * Optionally, collect Motor_Code_01 for transmission type
# TODO: bus layout detection
#  * At J533 gateway/extended? Required to have any control over ACC long term, even a "lite" model
#  * At R242 camera? More traditional, but no possibility of controlling ACC
#  * At J533 gateway/running gear? Needed for lowline J533 in cars without ACC. Will fingerprint differently.
# FIXME: Temporarily use a hardcoded J533 vs R242 location during development.
Zenerdiode
Newcastle, England
C?ID=24330
Very impressed indeed, Jason. However, I'm glad you're still behind the wheel:
# TODO: Safety
In my line of work (Railway Signalling) anything computer based that life depends on; require the computer to be guaranteed to fail-safe. How? By running three identical processors, each in their own chassis, with identical firmware and each processor executing each MC instruction in unison. The output of each processor is compared by the other two by redundancy management circuits and if two agree and the other one doesn't, the rogue one is physically disabled by the other two deliberately rupturing its security fuse. When two out of three are running, if they disagree the system effectively throws itself on its sword.
# TODO: Buy a Futaba controller so I can drive this thing remotely. :)
OpenPilot running disengaged/datalogging on the Tail of the Dragon:
Disengaged was probably A Good Thing. I'm only 5:30 into it so far, but it seems pretty obvious that it wouldn't have handled the tighter curves correctly at all. :eek:
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
missing all the vroom vroom
My GoPro video sucked :( The only mount I had was an in-car headrest setup intended for demonstrating OpenPilot, something to get the cluster and steering wheel in frame, and its forward view was obstructed. Also it picked up a lot of wind buffeting.
Next year my telemetry will be coming from a strapped down VCDS rig, and I'll see about a better GoPro location and a wind shielded mic. I saw a few guys running rear hatch mounted wind shielded mics and I think I'll try something similar for best vroom vroom.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Oh, it wasn't going to do anything at all, especially at speed. If you don't see those lane recognition lines, OP wouldn't even try to steer, even if engaged. You only see those lines pop up on the straighter parts, the model won't recognize sharper curves.
I did try a late night drive alone super low speed, and managed to find another "bug"... The steering rack has a safety that pops off when it's asked to apply the exact same torque value for greater than 6 seconds. So I need to introduce a tiny bit of noise. I already found out there's a 180 second limit on how long it's willing to steer in total before faulting out. I cheated around that by turning off steering for one frame/2ms every time there's a zero crossing/change of direction.
Anyway, there's still like 40 things wrong with it, but that's down from 50 when I loaded half of your brain-trust onboard and went for BBQ, and they're still alive, so it's going pretty well! ;) I actually had it dialed in really, really well on the Florida-to-North Carolina leg of my trip last week, it's approaching trustable on the highway. Which is, of course, exactly how it's going to go Skynet on me.
