2010 transporter van DPF problem
akersgarage
C?ID=179893
Hello. Wondering if anyone can help me out.
I have a 2010 VW transporter van 2.0 common rail diesel.
The DPF Light is on all the time, just the DPF light no coil light or engine warning light.
Using VCDS or VAS5052 there are no faults stored in any system.
Checked the soot volume and ash volume. Both coming up 0g
The van drives fine on road, no lack of power etc but DPF warning light on all the time.
I have tried to carry out regeneration while standing using the VAS5052 to begin with. But over half way through the process it cuts out for some reason.
Tried to regen using VCDS, followed the instructions but it's doesn't seen to raise the revs when regen is active.
I think the regen has been activated and light won't go out until it's complete ?
Does any one know if there is a way around this or can anyone help me in the right direction.
Thanks in advance.
akersgarage
C?ID=179893
We removed the DPF and had it tested by a specialist and they said it's spot on and it wasn't worth them cleaning it from their results.
We have also fitted a brand new genuine VW exhaust pressure sensor.
Also the exhaust temp sensor closest to the turbo was reading odd sometimes, so we replaced that aswell again a genuine vw brand new item.
Have you tried clearing fault codes despite the fact that there aren't any?
Has the ECU been remapped? The fact that the fault light is on but there are no DTCs makes me wonder if someone did a hack-job with a remap.
Another (relatively remote) possibility is that you have a wonky cluster that's just turning that fault light on for no good reason.
distrub
Norway
C?ID=192694
Hello
I have the same problem. Was this issue fixed?
Donibcsi
Hungary
C?ID=28126
I have same problem. The car arrived to my garage with P2458 DTC and DPF icon was ON MIL was ON and spring was flashing. No power. I knew it delete this fault and icons OFF but the DPF icon light now. The car work fine has power but the DPF light ON. The carbon mass 0.1g. I tried the DPF regeneration but did not start the regeneration. I updated the software by ODIS but no solution. I drove the car about 50km but the DPF light stay ON. I removed the battery for one night but the problem stay.
Can somebody help me for solution?
Thank you
Wednesday,08,March,2017,07:00:20:19005
VCDS Version: 17.1.3.0
VIN: WV2ZZZ7HZAH235627   License Plate:
Chassis Type: 7H (6N0)
Scan: 01 03 04 08 09 15 17 19 22 25 56 0B
VIN: WV2ZZZ7HZAH235627   Mileage: 116040km-72103miles
Address 01: Engine (J623-CAAC)       Labels: 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 DK    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H32 9135
   Revision: 26H32---    Serial number: 00000000000000
   Coding: 01194012230600080000
   Shop #: WSC 78387 152 452326
   ASAM Dataset: EV_ECM20TDI01103L906019DK 002007
   ROD: EV_ECM20TDI01103L906019DK.rod
   VCID: 77FD13A6CE8779F9D8-8022
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 E    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0103
   Revision: 00H43001
   Coding: 108724AD11A7089A24A888736A6510
   Shop #: WSC 02736 790 49152
   VCID: 3467E4AA977152E13D-8060
Address 08: Auto HVAC (J301)       Labels: 7E5-907-047.clb
   Part No SW: 7E5 907 047 AA    HW: 7E5 907 047 AA
   Component: Climatic-T5   H10 0101
   Revision: 00004001
   Coding: 0000000002
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ClimaticT5 A01002
   ROD: EV_ClimaticT5.rod
   VCID: 6ED336C2B1DD38310B-803A
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 086 B    HW: 7H0 937 086 B
   Component: BCM T5GP M++4 H46 0207
   Revision: BM046001    Serial number: 0154 009100552
   Coding: B8A0203A0E212022002000003C2B8C540000430F60060000300000000000
   Shop #: WSC 02736 790 00000
   VCID: 326BE2B26D655CD12F-8066
   Subsystem 1 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3310
   Subsystem 2 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3310
   Part No SW: 7E0 959 655 A    HW: 7E0 959 655 A
   Component: VW10Airbag00N H05 0011
   Revision: --------    Serial number: 003E5000YWFH
   Coding: 00000000000000000000000000000000304E
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3467E4AA9F7152E13D-8060
   Part No SW: 7E0 920 860 A    HW: 7E0 920 860 A
   Component: KOMBI         H16 0111
   Coding: 160200
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
   ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
   VCID: 26430EE259AD3071B3-8072
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 086 B
   Component: GW-K-CAN TP20 0207
   Coding: 042200
   VCID: 70EF28BAA3E92EC119-8024
   Part No SW: 09N 907 554 A    HW: 09N 907 554 A
   Component: Haldex 4Motion      6007
   Coding: 0000001
   VCID: 3663DEA2410D40F103-8062
   Component: IMMO          H16 0111
   Part No SW: 7E0 035 156     HW: 7E0 035 156
   Component: Radio         H21 0058
   Revision: R0000000    Serial number: VWZAZ1K9812916
   Coding: 0000020001
   VCID: 60CF58FA73099E4189-8034
End-------------------------(Elapsed Time: 02:36)--------------------------
MartinsX
Riga, Latvia
C?ID=268515
Do You have an autoscan before You cleared engine DTC's?
Donibcsi
Hungary
C?ID=28126
No I have not. But only P2458 was there.
