2009 Scirocco lost ABS coding and running rough
Jim Beagley
C?ID=349735
Hi. I had a quick look at a Scirocco for a friend last night, which is running rough and the dash is lit up like a christmas tree. A quick plug in revealed no engine fault codes, but faults in almost every other unit, and the ABS unit has lost its coding. Please could you help me with the long coding for the ABS. Attached is an autoscan. Most of the other faults appear to be voltage related. It has been to another garage before coming to me, and I suspect they let the battery run flat when they were looking at it. I have not had a chance to investigate the rough running yet, as it was dark last night, but it idles badly and misses occasionaly. I dont think its related to the other faults, but I will plug in and have a look at fuel trims later.
Any help or guidance with the long coding would be much appreciated. Thankyou!
Tuesday,22,January,2019,16:49:32:06582
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
VIN: WVWZZZ13Z9V003074   License Plate: SG58WZE
Mileage: 133750km-83108mi   Repair Order:
Chassis Type: 13 (1K0)
Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 37 42 44 46 4C 52 53 56
          62
VIN: WVWZZZ13Z9V003074   Mileage: 133750km-83108miles
08-Auto HVAC -- Status: Not registered 0011
10-Park/Steer Assist -- Status: Not registered 0011
14-Susp. Elect. -- Status: Not registered 0011
15-Airbags -- Status: Not registered 0011
25-Immobilizer -- Status: Not registered 0001
2E-Media Player 3 -- Status: Not registered 0011
37-Navigation -- Status: Not registered 0011
44-Steering Assist -- Status: Not registered 0011
46-Central Conv. -- Status: Not registered 0011
4C-Tire Pressure II -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
Address 01: Engine (CAW)       Labels:. 06J-906-026-CAW.clb
   Part No SW: 06J 906 026 AR    HW: 06J 906 026 D
   Component: MED17.5             2718
   Revision: A7H06---    Serial number: VWX7Z0H53NJ058
   Coding: 0403000318070060
   Shop #: WSC 00020 790 00000
   VCID: 7AB80FE235C6EF9A93-802E
Readiness: 0000 0001
   Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
   Revision: 00H35001
   Coding: 003B00F5002200FD000B00EB001D00813000
   Shop #: WSC 46967 001 1048576
   VCID: 76A01BD2C1DE8BFAF7-8022
01130 - ABS Operation
                    Fault Status: 01101000
                    Reset counter: 2
                    Mileage: 133749 km
                    Count: 2
                    Count: 4608
                    Count: 125
                    Count: 50192
                    Count: 60672
            000 -  -
                    Reset counter: 2
                    Mileage: 133749 km
                    Count: 16391
                    Count: 8192
                    Count: 195
                    Count: 41728
                    Count: 65024
   Part No SW: 1K0 907 044 DA    HW: 1K0 907 044 DA
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 699A40AE406054026A-803C
   Revision: 00H54000    Serial number: 00000008437930
   Coding: ED8C8F0300041A0067960E001900000000087F075C400124000000000000
   VCID: 3326E2C6522CDED210-8066
   Subsystem 1 - Part No: 1K8 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 111007 022  0602
   Coding: 00038805
   Shop #: WSC 00020
   Component: RLS     170608 054  0402
   Coding: 00208936
   Shop #: WSC 00020
                    Fault Status: 00101100
                    Reset counter: 42
                    Mileage: 133749 km
                    Voltage: 9.50 V
                    Reset counter: 42
                    Mileage: 133749 km
                    Voltage: 9.50 V
                    Fault Frequency: 46
                    Reset counter: 2
                    Mileage: 133749 km
                    Voltage: 11.70 V
00154 - Windshield Wiper Motor;  Passenger Side (V217)
                    Reset counter: 42
                    Mileage: 133749 km
                    Voltage: 9.45 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                    Reset counter: 42
                    Mileage: 133749 km
                    Voltage: 9.45 V
Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
   Part No SW: 1K0 919 475 F    HW: 1K0 919 475 F
   Component: PARKHILFE     005 1506
   Revision: 00005000    Serial number: 0 263 004 300
   Coding: 100001
   VCID: 3522DCDE9C58C0E23E-8060
                    Reset counter: 42
                    Mileage: 133749 km
                    Time: 19:24:46
                    Reset counter: 42
                    Mileage: 133749 km
                    Time: 19:23:24
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376     HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0069
   Revision: 00000000    Serial number: 18060801950003
   Coding: 000180
   VCID: 66804B92917E7B7A47-8032
03262 - Comfort Restriction
            000 -  -
                    Fault Frequency: 17
                    Reset counter: 2
                    Mileage: 133749 km
                    Time: 19:03:41
                    Error Code: 2
                    Bin. Bits: 00000000
01768 - Sensor for Vehicle Leveling; Right; Supply Voltage
                    Fault Status: 01100010
                    Reset counter: 2
                    Mileage: 133749 km
                    Time: 19:03:41
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 2
                    Mileage: 133749 km
                    Time: 19:03:41
                    Bin. Bits: 00000000 00001000
01769 - Sensor for Vehicle Leveling; Front Right (G289)
                    Fault Status: 00101010
                    Reset counter: 42
   Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
   Component: 0H AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 003D1D0021SI
   Coding: 0012360
   VCID: 6FAE2EB67E84BA3234-803A
   Subsystem 1 - Serial number: 6332MSME3A240F59J
   Subsystem 2 - Serial number: 6342MSME27036C237
   Subsystem 3 - Serial number: 6352QSME6A0F1215H
   Subsystem 4 - Serial number: 6362QSME73583123A
            002 - Lower Limit Exceeded - Intermittent - MIL ON
   Part No SW: 1K0 953 549 CB    HW: 1K0 953 549 CB
   Coding: 0002002
   VCID: 74A421DA17A299EAC9-8020
   Part No SW: 1K8 920 970 F    HW: 1K8 920 970 F
   Component: KOMBIINSTRUMENT VDD 2444
   Revision: V0003000    Serial number: VWX7Z0H53NJ058
   Coding: 0003403
   Shop #: WSC 33359 002 1048576
   VCID: 3522DCDE5C58C0E23E-8060
                    Reset counter: 42
                    Mileage: 133749 km
                    Time: 19:23:33
                    Reset counter: 42
                    Mileage: 133749 km
                    Time: 19:24:29
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K08610041C
   Coding: 39903A020002020002
                    Reset counter: 2
                    Mileage: 133749 km
                    Time: 03:11:08
                    Reset counter: 2
                    Mileage: 133749 km
                    Time: 03:11:09
03109 - Tire Pressure Monitoring Control Module 2 (J793)
                    Reset counter: 2
                    Mileage: 133749 km
                    Time: 03:11:13
            000 -  -
                    Reset counter: 2
                    Mileage: 133749 km
                    Time: 03:11:13
   Component: IMMO            VDD 2444
   Part No SW: 5N0 035 342 A    HW: 5N0 035 342 A
   Component: SG EXT.PLAYER H13 0062
   Revision: A1001003    Serial number: 7667024737
   VCID: 25020C9E2CF8B0628E-8070
                    Reset counter: 42
                    Mileage: 133749 km
                    Time: 19:21:45
                    Reset counter: 42
                    Mileage: 133749 km
                    Time: 19:22:15
   Part No SW: 1T0 035 680 B    HW: 1T0 035 680 B
   Component: RNS-MID       H03 0800
   Revision: AB001001    Serial number: VWZ6Z7H7178048
   Coding: 040004000400001200
   VCID: 2D12F4BE7408882246-8078
                    Reset counter: 42
                    Mileage: 133749 km
                    Time: 19:22:06
                    Reset counter: 42
                    Mileage: 133749 km
                    Time: 19:20:50
   Part No SW: 1Q0 959 701 F    HW: 1Q0 959 701 F
   Component: Tuer-SG         008 2018
   Coding: 0016949
   VCID: 373ED6D6465432F22C-8062
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 185    2301
   Revision: 00H15000
   VCID: 2A18FFA285E69F1AA3-807E
00750 - Warning Lamp
                    Fault Status: 11101101
                    Reset counter: 2
                    Voltage: 11.63 V
                        DD
                    Temperature: 6.0°C
   Component:    KSG PQ35 G2  020 0205
   Coding: 81900A0002830C7F3F04840570085ACE903C00
   VCID: 03467206420CAE52C0-8056
   Component: LIN BACKUP HORN H08 9001
   Subsystem 2 - Part No: 1K8 951 171
   Component: DWA-Sensor      001 0104
                    Fault Status: 01100101
                    Reset counter: 2
                    Mileage: 133749 km
                    Time: 03:11:07
                    Reset counter: 2
                    Mileage: 133749 km
                    Time: 03:11:09
                    Reset counter: 42
                    Mileage: 133749 km
                    Time: 19:23:25
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 2
                    Mileage: 133749 km
                    Time: 03:52:18
   Part No SW: 1Q0 959 702 F    HW: 1Q0 959 702 F
   Coding: 0016948
   VCID: 383CD5EA4B4A3D8A25-806C
Address 53: Parking Brake
                    Reset counter: 42
                    Mileage: 133749 km
                    Time: 19:22:06
                    Reset counter: 42
                    Mileage: 133749 km
                    Time: 19:20:50
Address 62: Door, Rear Left
End----(Elapsed Time: 01:28, VBatt start/end: 11.7V/11.6V. VIgn 11.6V)-----
AIB Wolfgang
Hello
Just compared this VIN. There is no EPB for this car.
So you have to correct the installation list without "53". Battery fully charged.
Delete all faults, scan again and see what will pop up again.
ABS is coded with : Coding: 003B00F5002200FD000B00EB001D00813000
and that seems right
Jef
HQ
Not registered 0011 = that module is on the network and talking, but not on the CAN Gateway's party list. You need to add those modules to the [Installation List] of the CAN Gateway.
http://www.ross-tech.com/vcds/tour/installation-list.php
EPB, as noted by AIB Wolfgang doesn't exsist in this car, so uncheck it. The other two that are listed as "Cannot be reached", uncheck them as well. After you sort out the Gateway's Installation List, clear all DTCs and see where we stand with this.
What happened to cause this because I would have to say it is very unlikely this happened for no reason... I suspect some one was playing games here and I'd just like to know what game it was. :p
Jim Beagley
C?ID=349735
Thankyou for your help. I am not sure what the previous garage did exactly, although i know they tried to re-code the ABS module. Further investigation needed me thinks!
I will have a go at it and let you know how I get on.
Jim Beagley
C?ID=349735
I've had another quick look at it today, and sorted out the CAN Gateway instalation list, which has cleared up most things. The ABS module rejects the code above - possibly because it's the same as the code already stored. There are a couple of susp. electrical faults - could these be causing the faults? Autoscan below. Thank you!
Thursday,24,January,2019,18:00:31:06582
Mileage: 133760km-83114mi   Repair Order:
Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 37 42 44 46 52 56
VIN: WVWZZZ13Z9V003074   Mileage: 133760km-83114miles
Readiness: 0110 0101
   Revision: 00H35001
            000 -  -
                    Reset counter: 5
                    Count: 3
                    Count: 4608
                    Count: 195
                    Count: 40448
   Coding: 00038805
   Shop #: WSC 00020
   Coding: 00208936
   Shop #: WSC 00020
   Coding: 100001
   Coding: 000180
            000 -  -
                    Reset counter: 5
                    Mileage: 133769 km
                    Time: 04:12:14
                    Error Code: 2
                    Bin. Bits: 00000000
                    Reset counter: 5
                    Mileage: 133769 km
                    Time: 04:12:14
                    Reset counter: 5
                    Mileage: 133769 km
                    Time: 04:12:14
   Coding: 0012360
   Coding: 0002002
   Coding: 0003403
   Coding: E9A81F064002120002
   Shop #: WSC 00020 790 12345
   Coding: 0016949
   Component: EPS_ZFLS Kl. 183    2301
   Revision: 00H15000
   Coding: 0016948
End----------(Elapsed Time: 01:15, VBatt start/end: 13.8V/13.5V)-----------
Gone But Not Forgotten
Vehicle Identification No.WVWZZZ13Z9V003074
ModelScirocco 2.0
SCI
Date of production22.07.2008
Year2009
Sales type1379W2
Engine CodeCAWB
Transmission CodeKNU
Looks like the right part number.......
What could be missing in config, hmmmm let's see ?
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PEWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation units/platform components7KBVehicle class differentiation -130-
drive-off assistanceUG0Without hill start assist/hill descent control/comfort driving assist
Emission standard0GGEmission standard EU4
Trailer hitch1D0without trailer towing
airbag4UFAirbag for driver and front passenger with front passenger airbag deactivation
Aktivkohlebehälter / Ottopartikelfilter1E1Activated carbon canister
Aerials8ZHAntenna for AM/FM reception, "diversity"
Exterior mirror setting6XNExterior mirrors, power-adjustable/ separately heated
Left exterior mirror5SJLeft exterior mirror, convex
Right exterior mirror5RVRight exterior mirror, aspherical
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WLJack for external audio source
Equipment levelsA8ISports equipment
Brake type in rear1KDDisc brakes in rear
batteriesJ1DBattery 380 A (72 Ah)
Brake type, front1LJDisc brakes in front
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0NComponent parts set, complying with vehicle type for Great Britain, various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VFInformation kit in English
brake wear indicator9U1brake wear indicator
Heated washer nozzles9T0Without heated washer nozzles
CD ROM/DVD/SD card7RTDVD (Europe)
CD changer/CD player7A0Without CD changer/CD player
"Charism"2H1"drive select"
General operating permit, alterationsC00Operating permit, initial registration
Roof insert/convertible top3FAroof without cut out
Suspension system in rearUB7Rear shock absorption for sports version
Suspension system in frontG03Shock absorption in front
Insert for the filling up of unleaded fuel/fuel type2G7Filler neck module 1 with insert
Installation differentiation for components0ENInstallation differentiation for transmission MQ 350 -- vehicle components --
Theft protection system7ALAnti-theft alarm system, interior monitoring, backup horn and towing protection
Park distance control7X1Park distance control
Electric interface for external use UF6Electric interface for external use (MEDIA-IN jack)
Manufacturing sequence differentiation0FAStandard manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedal clusterVF0Standard pedal cluster
Headlight activation8K3Daytime headlights with automatic headlight control and coming home function
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Weight category rear axle0YAWeight range 1 installation control only, no requirement forecast
Weight category front axleL55Suspension range 55 installation control only, no requirement forecast
Base engineTQ24-cyl. petrol engine 2.0 l assembly 06J.B
Luggage netting/pocket on backrest(s)4U0Without luggage nets/pockets on backrests
Luggage compartment cover3U1Folding trunk cover
cruise control system8T0Without cruise control system (CCS)
Transmission specificationsG0K6-speed manual transmission
handle for hand brake lever6PChandbrake lever grip (leather)
Rear window wiper and washer system8M1Rear window wiper washer system with intermittent wipe
Rear seats3KCRear bench seat, not split, split backrest, folding
Heating and air-conditioning system9AKClimatronic with impact pressure control, CFC-free
Headlamps8BKTwin headlamps for driving on the left, with integrated high beam
Customized installationFC0Without individual installation
Interior light in footwell6T1Interior light in footwell
Instrument clustersU5BInstrument insert, mph speedometer Great Britain
Breakaway interior rearview mirror4L6Breakaway interior rearview mirror, auto-dimming
Sticker (customized or special edition)0KAWithout decals and emblems
Body styleK8CCoupe
coolbox1W2Glove compartment cooling system
Climatic zones0Y1Standard climatic zones
Compass/road sign displayQR0Without compass/road sign display/ dynamic road sign display
Head restraints3J1Hight-adjustable head restraints for front seats
Fuel quantity for initial filling1Z2Increase in initial standard fuel filling
Fuel systems1A5Petrol injector fuel system (FSI)
Body measures5C0Without special body measures
Rear license plate bracket6P1Rear license plate carrier (ECE)
Front license plate bracket6W1Front license plate carrier (large)
Paint preservative/transit coating5K5Transport protection film with additional transport protection measures
Steering system arrangementL0RRight-hand drive
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H9Backrest release for front seats with Easy Entry feature
Lumbar support7P1Power adjustable lumbar support in front seats
steering wheels2FNLeather-wrapped multi-function steering wheel with decorative aluminum inserts
Speaker installation8RM8 speakers (passive)
Headlight range control8Q1Headlight range control
Center armrest6E3Front center armrest
Multi-function display/trip computer9Q5Multi-function display with control
Engine cooling8Z5not hot country
Engine specificationsD2L4-cylinder petrol engine 2.0 L/147 KW (16 V) Turbo FSI, homogeneous Basic engine is: T59/T61/TQ2/TU2/TD6/TN6
Left vanity mirror4SDVanity mirror, left, illuminated
Right vanity mirror4TDVanity mirror, right, illuminated
Navigation device7T6Navigation system (MID)
rear fog lamp8TDRear fog light for driving on the left
Front fog lamp/additional headlamp8WDIntegrated front fog light
Rear of platform module base4P0Rear floor panel module, type 1
Platform group class7PAPlatform group class 1
Hubcaps1NLTrims for alloy wheels
WheelsC9TAlloy wheels 8J x 18
Radios8AYRadio navigation system
Smoker's/non-smoker's package9JANon smoker version
Tire pressure monitoring system7K0Without tyre pressure monitor
tireHV3Tires 235/40 R18 95Y xl
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G6Space-saving spare wheel
Restraint systems, front3QT3-point seat belts in front, with tensioner and height adjustment
PDDAdaptive chassis control
PJ3"Interlagos" 4 alloy wheels 8 J X 18 tires 235/40 R 18
PLA"Lights & Vision" package
PU2Multi-function leather steering wheel
R2A"RNS 510", 4 x 20 W
WD2Anti-theft alarm system "Plus" incl. single door opening
WDIMultimedia socket MEDIA-IN
WL1Leather "Vienna"
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q2Gearshift knob/handle in leather
Special labels/plates0SSLabels in English and French
Locking mechanism for boot lid/cover rear4E2Tailgate/trunk lid release from inside (electrically)
Front seat, left3TGSports comfort seat in front, left
Front seat, right3SGSports comfort seat, front, right
Seat belt check9P3Seat belt reminder, electric contact in buckle
Outer rear seat belts3ZB3-point seat belts, outer rear with ECE label
seat coversN1ASeat trim covers in leather
Seat adjustment3L3Manual height adjustment for front seats
seat heater4A3seat heating for front seats separat controlable
Safety head restraint system3K0w/o safety head restraint system
Horns8Y1Two-tone horn
Control number (no PR family)S0CIntroductory volume
Side and rear windows4KFheat protective glass for door, side and rear windows, darkened from b-pillar
power outlet7B212 volt socket in luggage compartment
Bumper2JCComfort bumpers
Rear stabilizer0BFRear stabilizer
Front stabilizer bar0AEFront stabilizer bar
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N3intermittent windscreen wiper with rain sensor
Nameplate set0NWNameplate set "TSI"
Mass damper for steering wheels1Q0steering wheel without balance weight
Door and lid locking system4K3Central locking w/ radio remote control, interior controls and SAFELOCK
Type approval countries/countries with special requirementsB09Type approval country GB/Northern Ireland
Carrier frequency for remote control5D1Carrier frequency 433.92 to 434.42 Mhz
Partition3CAwithout partition
Door and side trim panels3LJDoor and side trim panel in foam film, insert in leatherette
doors0A12 doors
TV reception/digital radio receptionQV0without TV/digital radio reception
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EXSpecial identification plate for EU
Delivery equipment2A0Without delivery equipment
First aid kit / warning triangle1T0Without first-aid material, without warning triangle
Telephone / telematics9W0Without car phone preparation/ installation
LongLife Service RegimeQG1LongLife Service Regime
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GFWindshield in heat-insulating glass
Washer fluid level indicator8W0without washer water level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TAwithout floor mats
Additional child seat anchors3B4Child seat anchors for child seat system ISOFIX
Auxiliary heating system9M0Without auxiliary heater/parking heater
Jim Beagley
C?ID=349735
I will have a look at the level sensor and see if I can sort the problem - I suspect a problem with the plug or wiring. Am I right in thinking it's unlikely that errors stored in susp electrical would affect the ABS module coding?
Jim Beagley
C?ID=349735
I'm still battling with the ABS module coding on this Scirocco. I have checked all the PR codes against the data sticker and reveiwed the instalation list on the CAN gateway, and all appears to be okay.
I have replaced the front right level sensor and that has resolved that issue.
Maybe I am being a bit thick? I am logging in to the controller using access code 40168, which is accepted. I am the inputting the code in the long coding. I have tried the code above, and a few other options given to me by Auotlogic, but each time it rejects the coding with an 'error 31 - out of range'. Am I missing something?
Jim Beagley
C?ID=349735
These are my data sticker codes;
Special editions E0A Without special action equipment
Emission standard 0GG Emission standard EU4
Trailer hitch 1D0 without trailer towing
airbag 4UF Airbag for driver and front passenger with front passenger airbag deactivation
Left exterior mirror 5SJ Left exterior mirror, convex
Right exterior mirror 5RV Right exterior mirror, aspherical
Equipment levels A8I Sports equipment
batteries J1D Battery 380 A (72 Ah)
Brake type, front 1LJ Disc brakes in front
Component part sets with country-specific design requirements B0N Component parts set, complying with vehicle type for Great Britain, various parts
Brake systems 1AT Electronic stability control (ESC)
Roof insert/convertible top 3FA roof without cut out
Alternators 8GU Alternator 140 A
Luggage compartment cover 3U1 Folding trunk cover
Transmission specifications G0K 6-speed manual transmission
Headlamps 8BK Twin headlamps for driving on the left, with integrated high beam
Instrument clusters U5B Instrument insert, mph speedometer Great Britain
steering 1N3 Speed-related variable steering assist (Servotronic)
steering wheels 2FN Leather-wrapped multi-function steering wheel with decorative aluminum inserts
Speaker installation 8RM 8 speakers (passive)
Engine specifications D2L 4-cylinder petrol engine 2.0 L/147 KW (16 V) Turbo FSI, homogeneous Basic engine is: T59/T61/TQ2/TU2/TD6/TN6
Wheels C9T Alloy wheels 8J x 18
Radios 8AY Radio navigation system
tire HV3 Tires 235/40 R18 95Y xl
Tire suppliers V0A Tires without specification of tire brand
Spare wheel/breakdown kit 1G6 Space-saving spare wheel
Side airbag 4X3 Side airbag in front, with curtain airbag
seat covers N1A Seat trim covers in leather
Seat adjustment 3L3 Manual height adjustment for front seats
seat heater 4A3 seat heating for front seats separat controlable
Bumper 2JC Comfort bumpers
Windshield wiper intermittent control/ light/rain sensor 8N3 intermittent windscreen wiper with rain sensor
Door and lid locking system 4K3 Central locking w/ radio remote control, interior controls and SAFELOCK
LongLife Service Regime QG1 LongLife Service Regime
Out of range is probably the wrong coding. I suspect someone was tinkering with it before you received this car because
.. are the VIN Bytes only. Lost coding always reverts to zeros.
Either way, I believe the factory coding was:
763B60F5092200FD6E0B06EB901D00813000
See if the module accepts that. If so, make sure G85 calibrated before exiting the module to prevent the coding form zeroing.
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Brake_Electronics_(MK60EC1)
Edit. Whoops, I haven't refreshed this thread for a while. I'll leave my post if the OP wants to try both of our suggestions.
Nerd notes
76006000090000006E000600900000813000
Jim Beagley
C?ID=349735
Success! Well partial success anyway...
Thankyou NEtech and Dana for your help. Both the codes supplied were accepted by the module, but I am still getting the '01044 - Control Module Incorrectly Coded' fault that will not clear. I carried out a sucessfull G85 calibration at the same time.
Dana - 763B60F5092200FD6E0B06EB901D00813000
NEtech - 763B60F5092200FD6E0B06EB901D0081B000
I am also now getting a '01486 - System Function Test Activated' code, but I have watched the VCDS video on this an I can see it will probably clear once the procedure is carried out, so not worried about this.
I realised that I left 4R4 off my list of PR codes from data sticker. Not sure if this matters.
Could it be a coding issue in the CAN Gateway?
Attached is today's Autoscan;
Friday,01,February,2019,16:06:06:06582
VIN: WVWZZZ13Z9V003074   License Plate: SG58WVE
Mileage: 133850km-83170mi   Repair Order:
VIN: WVWZZZ13Z9V003074   Mileage: 133850km-83170miles
   Revision: 00H35001
   Coding: 763B60F5092200FD6E0B06EB901D0081B000
            000 -  -
                    Reset counter: 9
                    Mileage: 133853 km
                    Count: 3
                    Count: 12800
                    Count: 320
                    Count: 49920
                    Count: 65024
            000 -  -
                    Reset counter: 9
                    Mileage: 133853 km
                    Count: 3
                    Count: 12800
                    Count: 8192
                    Count: 49920
                    Count: 65024
01487 - System Function Test
            000 -  -
                    Reset counter: 9
                    Mileage: 133854 km
                    Count: 2
                    Count: 12800
                    Count: 321
                    Count: 50432
   Coding: 00038805
   Shop #: WSC 00020
   Coding: 00208936
   Shop #: WSC 00020
   Coding: 100001
   Coding: 000180
   Coding: 0012360
   Coding: 0002002
   Coding: 0003403
   Coding: 0016949
   Component: EPS_ZFLS Kl. 184    2301
   Revision: 00H15000
                    Fault Frequency: 9
                    Reset counter: 7
                    Mileage: 133800 km
                    Time: 04:13:27
   Coding: 0016948
End----------(Elapsed Time: 01:16, VBatt start/end: 14.0V/14.1V)-----------
Gateway Installation List:  1K0 907 530 Q
Thnakyou for you help - much appreciated!
Revision: 00H35001
Coding: 763B60F5092200FD6E0B06EB901D00813000 PLA GEN 2
Coding: 763B60F5092200FD6E0B06EB901D00813001 PLA GEN 1
Try those adding PLA!
Jim Beagley
C?ID=349735
Interesting! Does PLA refer to park assist (parking sensors) which it DOES have?!? Would these have been retrofitted?
I'll give it a try and let you know...
Jim,
I believe you are absolutely correct. L0R (Right-hand drive) is NOT enabled in the 19 coding. That will cause an incorrectly coded ABS DTC.
Jack,
I believe the PLA type (7X1 Park distance control) is OK. I'll double check that now.
Edit, confirmed. The 7X1 Park distance control bits are OK in my opinion. The difference between my coding and NEtech's original suggestion is likely due to a minor difference between DSG auto and manual transmissions. This is my baseline info on a MT Great Britain model (RHD) with 7X1:
1379W22009CAWBMT/6L0R1K0 907 379 AD @ 010476006000090000006E000600900000813000766009006E069000813000G0K0YA1N3J250/G03/UB71AT1LJ/1KD
Baseline info on a DSG Auto Great Britain and New Zealand models (RHD) also with 7X1:
1379W32009CAWBAT/02EL0R1K0 907 379 AE @ 010676006000090000006E00060090000081B100766009006E06900081B100G1A0YA1N3J250/G03/UB71AT1LJ/1KD
1379W32009CAWBAT/02EL0R1K0 907 379 AE @ 010676006000090000006E00060090000081B100766009006E06900081B100G1A0YB1N3J250/G03/UB71AT1LJ/1KD
Jack,
Cool I was just looking at discrepancies I saw and just checking at possibilities..........
Jim,
I thought it was setup as RHD?
Absolutely Jack, the more eyes the better!
I should have checked that. We receive emails like this all of the time when 03 is coded correctly (with an incorrectly coded DTC) but 19 is not coded to the same drive-side. Changing 19 from E9A81F064002120002 -to- E9A81F064002120003 should sort the drive side conflict.
