2014 Audi S4 B8.5 - Dynamic Steering Failure
tompapajr
C?ID=155394
Greetings! Was driving the other day and received “Dynamic Steering Issue - Ok to drive” on the MFD. a few miles later then it displayed “Dynamic Steering Failure - Do not drive” at which I completely lost power steering. I ran a VCDS scan. My Audi/VW shop thinks it’s a bad Dynamic Steering control module, however Audi does not sell this part separately and requires the whole steering rack to be replaced. Hoping someone has experience with this particular issue and can provide some insights or other steps that can be taken before replacing the whole rack.
Sunday,06,January,2019,17:50:08:09684
VCDS Version: 18.9.0.4 (x64)
Data version: 20181017 DS296.0
VIN: WAUBGAFL8EA055273   License Plate:
Mileage: 86170km-53543mi   Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 14 15 16 17 19 22 36 42 44 46 47 52 53 56
          5F 62 6C 72 A9
VIN: WAUBGAFL8EA055273   Mileage: 86170km-53543miles
Address 01: Engine (J623-CTUB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 G    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0007
   Revision: --H07---
   Coding: 0A250034052600060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551G 001007
   ROD: EV_ECM30TFS0218K5907551G.rod
   VCID: 3A7BCA32BD7A4D9AD5-806E
   Part No SW: 8K5 927 156 D    HW: 0B5 927 156 K
   Component: 0B5 30TFSINAR H02 0002
   Revision: --H02---
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 291D1A01
   VCID: 091965FEA01C96028C-805C
            000 -  -  - Intermittent
                    Fault Frequency: 145
                    Reset counter: 86
                    Mileage: 82656 km
                    Date: 2018.11.27
                    Time: 16:13:07
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0015
                    Hex Value: 0x1090
                    Hex Value: 0x0000
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 46
                    Mileage: 86177 km
                    Date: 2019.01.05
                    Time: 20:31:43
                    Hex Value: 0x0600
                    Hex Value: 0x4006
                    Hex Value: 0x120C
                    Hex Value: 0xC0B8
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 HM    HW: 8K0 907 064 GM
   Component: BCM2 2.0      H13 0641
   Coding: 0D814040000000000000
   VCID: 020B72D29D2AC55ACD-8056
   Serial number: 0213000310263010
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01220920130980
   Coding: 6600228000
   VCID: 3979D53EB07C4682DC-806C
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000050428202
   Coding: 2600C811813CAFE0290048C300003D0D4F9CD308A2090221000008004000070100000030000000
   Shop #: WSC 06325 123 12345
   VCID: 78FF103ACBF69F8AE3-802C
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA270813  H18 0461
   Serial number: 1308220711576
   Coding: 004577
   Serial number: 21735060
   Coding: 03005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001109131195
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R7N3A03
   Serial number: 5FE88AC6000000000001
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8R0 907 364 C    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H09 0054
   Revision: 00000000    Serial number: 29081302140002
   Coding: 010181
   VCID: 3A7BCA32B57A4D9AD5-806E
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003KJDB0FX9.
   Coding: 303844354730303030304A55304C384B3053
   Shop #: WSC 45442 001 1048576
   VCID: 4A9B9AF2ED9ADD1A45-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R130000ELSD
   Serial number: 6334MSME7F12241AF
   Serial number: 6344MSME7D614303B
   Serial number: 6352QSME7C372550I
   Serial number: 6362QSME38394360E
   Serial number: 63732SME24332F4C1
   Serial number: 63832SME52350F580
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372MIB0006M
   Coding: 000036
   VCID: 4487B4CAC7BE0B6ABF-8010
   Part No SW: 8K0 920 983     HW: 8K0 920 983
   Component: KOMBIINSTR.   H35 0563
   Revision: 00500000    Serial number: WWH555H9E
   Coding: 8BFF09009301D705020000
   VCID: 72EB2212AD8AF5DADD-8026
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0056
   Revision: 1Y070028    Serial number: 2841Y138300B01
   Coding: 80C303FF00
   VCID: 4A9B9AF2E59ADD1A45-801E
   Serial number: 3700401303
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H14 0100
   Serial number: 001109130001300
   VCID: 2F6DEB667638983272-807A
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000073724842
   Coding: 00581B00000000000000
   VCID: 3B75CF36BA407492CE-806E
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011C13204E00410001
   VCID: 56A37E82212289FAD1-8002
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0009127957
   Coding: 000000010001
   Shop #: WSC 06324 123 12345
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3467E40A9F1EBBEA0F-8060
7341600 - Position Sensor for Motor
          C10AD 29 [008] - Signal Implausible
                    Reset counter: 86
                    Mileage: 86151 km
                    Date: 2019.01.05
                    Time: 17:42:16
                    Write only channel
1052420 - Internal Control Module Memory Check Sum Error
          B2000 49 [137] - Internal electronic failure
                    Mileage: 86177 km
                    Date: 2019.01.05
                    Time: 20:31:44
                    Write only channel
7341570 - Position Sensor for Motor
          C10AD 29 [137] - Signal Implausible
                    Mileage: 86176 km
                    Date: 2019.01.05
                    Time: 20:30:40
                    Write only channel
   Revision: 00002001    Serial number: 0314961169
   Coding: 0106063A00FA400583B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000727976
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
   Revision: 00005001    Serial number: 94813020034103
   VCID: 2D51F16E7434EA2240-8078
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   VCID: 55A1798E3C2482E2D8-8000
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 20000000332229
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3979D53EB87C4682DC-806C
   Part No SW: 4G0 035 082 H    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0138
   Revision: AB001007    Serial number: 156I60D7906845
   Coding: 020007010000000001
   VCID: 2541094E2CC4D26288-8070
   Part No SW: 8R1 035 746 K    HW: 8R1 035 746 G
   Component: H-BNT-NA      H44 1040
   Revision: --------    Serial number: 523E50H7625479
   Coding: 110200000206A1EF45028B4E00000403140000000000000000
   Shop #: WSC 65346 001 1048576
   VCID: 3F8DBB26AE5868B2E2-806A
   Subsystem 1 - Part No: 8R0 060 884 DQ
   Component: NAR 2016/2017  1402
   Component: DU7 High  H42 0104
   Serial number: A130IY0D2826149
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001620379
   Component: CD-Database  6890
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0305
   Coding: 010C13204000210001
   VCID: 59B975BE503CA682FC-800C
   Revision: --H08---    Serial number: 525PA8-J37955Q
   Coding: 1000006
   VCID: 387FD03A4B765F8A23-806C
   Component: TSG HR        H07 0305
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 130910201986
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
   VCID: 72EB2212A58AF5DADD-8026
End-------------------------(Elapsed Time: 04:09)--------------------------
NostraJackAss
Greetings! Was driving the other day and received “Dynamic Steering Issue - Ok to drive” on the MFD. a few miles later then it displayed “Dynamic Steering Failure - Do not drive” at which I completely lost power steering. I ran a VCDS scan. My Audi/VW shop thinks it’s a bad Dynamic Steering control module, however Audi does not sell this part separately and requires the whole steering rack to be replaced. Hoping someone has experience with this particular issue and can provide some insights or other steps that can be taken before replacing the whole rack.​
Component: RCEPS H37 0507 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Isn't there or wasn't there several firmware updates for this controller to address this error?
Hey did you check all connections to the 0x44 rack & since a high load circuit or for fuse failures yet?
