Wanted: VW UP! RCD 215 Radio Long Coding String (Europan Car Please)
3.14nz
New Zealand
C?ID=2171
Hi,
I'm moving a Car from Japan to New Zealand and need to change the FM frequency tuning range.
Thanks!
-Philip
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Start by posting an Auto-Scan from the vehicle in question. A minimum would be the VIN and/or the part number of the control module in question. In most cases, the units are region specific and a coding change isn't gonna help.
3.14nz
New Zealand
C?ID=2171
Hi,
Thanks for the guidance - Auto-Scan follows:
Friday,18,January,2019,12:13:29:49310
VCDS Version: 18.9.1.0 (x64)
VIN: WVWZZZAAZGD107633   License Plate:
Mileage: 680km-422mi   Repair Order:
Chassis Type: AA-VW12 (1S0)
Scan: 01 02 03 09 15 17 19 25 44 56 61 AD
VIN: WVWZZZAAZGD107633   Mileage: 680km-422miles
AD-Brake Sensors -- Status: OK 0000
Address 01: Engine (J623-CHYB)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 020 DR    HW: 04C 907 309 P
   Component: R3 1.0l MPI   H24 2561
   Revision: UNH24---
   Coding: 00140012020401000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM10MPI01104C906020DR 001004
   ROD: EV_ECM10MPI01104C906020DR.rod
   VCID: 6ED8307DB1579B3A3F-803A
5603 - Park/Neutral Switch Input Circuit
          P0851 00 [096] - Short to Ground
                    Mileage: 498 km
                    Date: 2018.10.18
                    Time: 20:36:06
                    Engine speed: 1321.50 /min
                    Normed load value: 28.2 %
                    Coolant temperature: 17 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 11.355 V
                    Unlearning counter according OBD: 13
                    Adaptation status for transmission neutral position sensor-Bits 0-7: 0
                    Engine status: COENG_RUNNING
Address 02: Auto Trans (J514)       Labels:* None
   Part No SW: 0CT 927 750 F    HW: 0CT 927 750 C
   Component: SQ100         H12 0132
   Coding: 030120
   ASAM Dataset: EV_TCMSQ101011 005013
   ROD: EV_TCMSQ101011_005.rod
   VCID: 4B9E99E9E2058E1278-801E
Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
   Part No SW: 1S0 614 517 L    HW: 1S0 614 517 L
   Component: EBC 460 ESP   H16 0023
   Serial number: A016NP8
   Coding: 11BF247129AD02F8880024F894AC409059B200
   ASAM Dataset: EV_Brake1ESPEBC460TRW 002004
   ROD: EV_Brake1ESPEBC460TRW_002_VW25.rod
   VCID: 3874D6258393158A25-806C
   Part No SW: 1S0 937 090 E    HW: 1S0 937 090 E
   Component: PQ25 BCM      H59 0584
   Revision: -D------    Serial number: --------------
   Coding: 62B82B0000010000000001F42C2BACC07340424E7E031420200000460100
   VCID: 356ADF119C81E8E23E-8060
   Part No SW: 1S0 959 655 B    HW: 1S0 959 655 B
   Component: VW10Airbag01S H03 0006
   Revision: --------    Serial number: 003MY00K4J0G
   Coding: 000000000000000000000000000000003153
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   VCID: 3D7AC731ACB130A2F6-8068
   Serial number: 3497ARB405V41DQABPPB
   Serial number: 3507ARB405V41DQADPO4
   Serial number: 3557BRB405L3I0RMGHF2
Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
   Part No SW: 1S0 920 861 G    HW: 1S0 920 861 G
   Component: KOMBI         H52 0405
   Revision: X0052001    Serial number: 00000000000000
   Coding: 1142000000
   ASAM Dataset: EV_KombiUDSMM9RM10 A05803
   ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
   VCID: 356ADF119481E8E23E-8060
   Part No SW: 1S0 909 901     HW: 1S0 937 090 E
   Component: GW-K-CAN TP20 H59 0584
   Revision: -D------
   Coding: 001300
   VCID: 70E42E05A3638DCA2D-8024
   Part No SW: 5K0 953 234     HW: 1S0 920 861 G
   Component: IMMO          H52 0405
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   VCID: 6AD03C6D8DBF771A63-803E
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R2 909 144 AJ    HW: 6R2 909 144 E
   Component: EPS_TRW_ALow  322 3132
   Serial number: CG5C1396
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016029
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 00047EC59BC39D4ADD-8054
Address 56: Radio (J503)       Labels: None
   Part No SW: 1S0 035 156 M    HW: 1S0 035 156 M
   Component: Radio         H10 0022
   Revision: R0000000    Serial number: VWZAZ1R0891828
   Coding: 0000020001
   Part No SW: 1S0 907 534     HW: 1S0 937 090 E
   Component: Batt-regelung H59 0584
   Coding: 032B7864
   Subsystem 1 - Part No SW: 1S0 915 181 B    HW: 1S0 915 181 B
   Component: J367-BDM  H08 0210
Address AD: Brake Sensors (J939)       Labels: 1S0-907-201.clb
   Part No SW: 1S0 907 201 A    HW: 1S0 907 201 A
   Component: CV-SENSOR     H07 0460
   ASAM Dataset: EV_CVSen 001001
   ROD: EV_CVSen.rod
   VCID: 285406655333850AB5-807C
End-------------------------(Elapsed Time: 02:02)--------------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
   Coding: 0000020001
Definitely a special version for the Japanese market, so you'll likely need to replace it with the desired version for the market the car is heading to.
3.14nz
New Zealand
C?ID=2171
Thanks, replacement unit has been sourced from the UK for 40£. Simple and easy solution!!
