Troubleshooting V10 TDI Cam Sensor
Lgibson
C?ID=41716
Here is the intermittent 012295 that's showing up occasionally while driving. After a trip to the carwash recently there was no signal at all for awhile. Would there be a MVB for this EDC16 where I could watch and do some wiggle tests?
Sunday,16,December,2018,12:01:36:34689
VCDS Version: 18.9.0.1
VIN: WVGPT77L46D062013   License Plate:
Mileage: 200360km-124497mi   Repair Order:
Chassis Type: 7L (LG1 - My VW Touareg)
Scan: 01 02 03 05 06 08 09 11 15 16 17 18 19 1C 22 29 34 36 37 39
          46 47 56 68 69 6C 6E 76
VIN: WVGPT77L46D062013   Mileage: 200360km-124497miles
   Part No SW: 070 906 016 CQ    HW: 028 101 196 2
   Component: V10 5,0L EDCG000AGMª8472
   Revision: --H02---    Serial number: VWZ3Z0F6455356
   Coding: 0060575
   Shop #: WSC 31414 000 00000
   VCID: 61C2339FBBCE2B42B9-5102
012295 - Camshaft Position Sensor (G40)
               P3007 - 000 - No Signal - Intermittent
                    Fault Status: 00110000
                    Mileage: 197722 km
                    RPM: 1764 /min
                    Speed: 103.5 km/h
                    Load: 32.5 %
                    Voltage: 13.60 V
                    Bin. Bits: 00101000
                    Idle Stabilization: 0.0°KW
                    (no units): 48.0
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 DP    HW: 09D 927 750 DP
   Component: AL 750 6A           0856
   Revision: 00H37000    Serial number:
   Coding: 0004200
   VCID: 7F0695E72D7AFDB2AF-5120
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0022786
   VCID: 3D7AAFEF67F62FA2FD-5102
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 137 A    HW: 5WK 485 02
   Component: 29 Kessy            6700
   Revision: 67005915    Serial number: VWZ3Z0F6455356
   Coding: 0147688
   VCID: 316283DFABAEDBC269-5120
Address 06: Seat Mem. Pass        Labels: None
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: 77F67DC7054AC5F2E7-5120
   Part No: 7L6 907 044 T
   Component: CLIMAtronic 2+2     4222
   Coding: 0020030
   VCID: 458AC70F0F266762A5-5120
   Subsystem 1 - Part No: 7L6 907 049 E
   Component: CLIMAtronic FOND    0400
02600 - Rear Right Temperature Flap Motor (V314)
            000 -  -  - Intermittent
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 N
   Component:                     3002
   Coding: 0111836
   VCID: 4796CD07352A757257-5120
            000 -  -
Address 11: Engine II        Labels: Redir Fail!
   Component: V10 5,0L EDCG000AGSª8472
   Coding: 0060575
   VCID: 61C2339FBBCE2B42B9-5120
   Part No: 3D0 909 601 H
   Component: 05 Airbag 8.4E++H01 0562
   Revision: BB38727     Serial number: 0007379>
   Coding: 0012341
   VCID: 28546EBB98749A0ABE-5120
   Subsystem 1 - Part No: 7L0 959 339 C
   Component: BF-Gewichtsens. 006 0008
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 H
   Coding: 0010032
   VCID: 448CDA0B041C5E6AB2-5120
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 981 R
   Component: KOMBIINSTRUMENT RB8 3211
   Coding: 0005231
   VCID: 4894CE3B38347A0A5E-5102
Address 18: Aux. Heat        Labels: 7L6-819-008.clb
   Part No: 7L6 819 008 G
   Component: Standheizung E1MAC
   VCID: 3A70A4F376D8189AD8-5120
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70E446DB602492CA26-5120
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879 A
   Component: JCI PathPoint       2200
   Part No: 0AD 927 755 AT
   Component: TRANSFERCASE        0114
   VCID: 0D1A3F2F17D6DF22AD-5120
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  0001
   Coding: 0000003
   VCID: 66C8208352E04C7A4C-513C
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 F
   Component: LUFTFDR.-CDC- 3C3P1 3081
   Coding: 0015521
   VCID: 3668B0C342C0FCFA3C-5102
   Component: Sitzverstellung     0703
Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
   Part No: 7L6 919 887 M
   Component:      Navigation     0047
   Coding: 0000101
   VCID: 50A4E65BC064B2CA06-5120
Address 39: Right Light        Labels: 3D0-909-158.lbl
   Part No: 3D0 909 158
   Component: EVG GDL+AutoLWR(r)  0001
   Coding: 0000003
   VCID: 67D62D8755EA557277-5120
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L0 959 933 J
   Component:    HSG              5115
   Coding: 0000085
   VCID: 438ED917011259528B-4AE6
   Subsystem 1 - Part No: 7L0 959 701 H
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 H
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 D
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 D
   Component: Tuersteuergeraet HR 0201
00927 - Terminal 30 (Right)
01516 - Terminal 30; Left
00926 - Terminal 30
            000 -  -
01737 - Potentiometer for Mirror Adj. Vertical; Pass. Side
   Part No: 7L6 035 456
   Component: 08K Audioverst.     0105
   Subsystem 1 - Part No: 7L6 035 456
No Faults Found
Address 56: Radio        Labels: 7L6-035-186-DVD.lbl
   Part No: 7L6 035 186 E
   Component:        Radio        0047
   Coding: 0014042
   VCID: 356AB7CF5FC6F7E235-5120
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L0 955 119 K
   Component: Front Wiper         4027
   Coding: 0000341
   Shop #: WSC 31414 000 376832
   VCID: 3C7CA2EB7CEC26AACA-5120
   Component: RLS     010510 054  0403
   Coding: 00133665
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
   Component: ANHAENGERELEKTRONIK 8854
   Coding: 0000002
   VCID: 3874BEFB48D40A8A2E-5120
   Part No SW: 7L6 907 441     HW: 7L6 907 441
   Component: J772__Rearview      0051
   Revision: 00H07000    Serial number:    PA8 J620685
   Coding: 0000101
   VCID: 72E04CD36E28A0DAD0-5120
Address 6E: Ctrl Head Roof        Labels: None
   Part No: 7L6 919 044 J
   Component: DACHDISPLAY         0538
   Revision: 00700538    Serial number: 2009266.06
   VCID: 3E78A8E36AF034BAE4-5120
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
   VCID: 3972BBFF73DE1382D1-5120
End-------------------------(Elapsed Time: 06:19)--------------------------
Address 01: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 46: DTCs cleared
While engine is running, the camshaft RPM should be in Group 051.2. This should be half the engine speed.
