Support for using VCDA after new Clock Spring Installation
VDoubleYall
C?ID=348951
Support for using VCDS after new Clock Spring Installation
Dear Support,
I have just recently purchased Hex Net and really looking forward to using it. I'm a newbie to VCDS and Diagnostics but have reasonable repair experience.
The Car in question is a SEAT Alhambra N7 chasis 2011
After the installation of a new clock spring I get the the various lights you would expect coming up on the Dashboard.
Previously, the horn and the steering wheel control bottons (left and right didnt work) and I had the airbag warning light on. After the new installation of a valeo clock spring the buttons and horn are now operational.
Ive done autoscan on the car and have the report. see below. (Is it ok to copy the code in the thread or are you supposed to upload it?)
Can I just clear the faults - if so how do I do that or do I need to code the new clock spring to the vehicle before clearing any faults and setting the SAS.
Many thanks in advance.
Chassis Type: 7N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 20 25 2E 37 42 44 46 4F 52 53
          56 61 62 6C 72
VIN: VSSZZZ7NZBVXXXXXX Mileage: 110180km-68462miles
18-Aux. Heat -- Status: Malfunction 1010
   Part No SW: 03L 906 018 HL    HW: 03L 906 018 M
   Component: R4 2,0L EDC   H23 9959
   Revision: 44H23---    Serial number:
   Coding: 0019001A042501080000
   Shop #: WSC 47696 696 92242
   ASAM Dataset: EV_ECM20TDI01103L906018HL 003008
   ROD: EV_ECM20TDI01103L906018F.rod
   VCID: FBB6728772E3729203-80AE
4332 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [175] - -
          [Checking coding/versions ofcontrol modules in drivetrain]
                    Mileage: 110083 km
                    Date: 2019.01.18
                    Time: 00:01:29
                    Engine speed: 0.00 /min
                    Coolant temperature: 46 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 11.760 V
                    ACC target acceleration: 0.000 m/s²
                    ACC control module received status-Bits 0-7: 6
                    Active brake system error status-Bits 0-7: 0
                    Status of ACC/CCS acceleration interface-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_READY
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 M    HW: 7N0 614 109 H
   Component: J104   C3 450M VDDF 0009
   Revision: --H07---    Serial number: 00000003174862
   Coding: 0024187
   Shop #: WSC 47696 476 82776
   VCID: B73EAEB7C64B96F2A7-80E2
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 219
                    Mileage: 106825 km
                    Date: 2013.03.06
                    Time: 11:00:32
                    Speed: 85.0 km/h
                    Hex Value: 0x0001
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.25 V
                    Bin. Bits: 00011111
                    Count: 185
                    Hex Value: 0x0000
                    Fault Frequency: 63
                    Reset counter: 223
                    Mileage: 110083 km
                    Date: 2013.06.10
                    Time: 00:01:39
                    Hex Value: 0x0000
                    Voltage: 11.75 V
                    Bin. Bits: 00011110
                    Count: 191
                    Hex Value: 0x0000
                    Fault Status: 01101000
                    Fault Frequency: 65
                    Reset counter: 219
                    Mileage: 110083 km
                    Date: 2013.06.10
                    Time: 00:03:58
                    Speed: 18.0 km/h
                    Hex Value: 0x0001
                    Voltage: 14.25 V
                    Bin. Bits: 00011110
                    Count: 245
                    Hex Value: 0x0001
                    Reset counter: 5
                    Mileage: 110117 km
                    Date: 2013.06.10
                    Time: 07:31:20
                    Hex Value: 0x0100
                    Voltage: 14.25 V
                    Bin. Bits: 00011110
                    Count: 277
                    Hex Value: 0x0000
                    Fault Frequency: 65
                    Reset counter: 219
                    Mileage: 110083 km
                    Date: 2013.06.10
                    Time: 00:03:58
                    Speed: 18.0 km/h
                    Hex Value: 0x0001
                    Voltage: 14.25 V
                    Bin. Bits: 00011110
                    Count: 245
                    Hex Value: 0x0001
   Part No SW: 5K0 907 044 F    HW: 5K0 907 044 F
   Component: Clima-Sharan  H11 0103
   Coding: 0000000009
   Shop #: WSC 00020 999 00000
   VCID: AE108BD3F111573AF4-80FA
9601321 - Humidity sensor
          B1281 29 [008] - Signal Implausible
                    Reset counter: 1
                    Mileage: 109815 km
                    Date: 2019.01.11
                    Time: 08:25:08
9485974 - Air Blower
          B10BE 96 [008] - Component internal failure
          [ZSB Gebläse/Regler vorne - Gebläsreglercode (Impuls) Nr.6 - Unterbrechung/ Kurschluss gegen Plus (+ Ltgs. Regler/Motor)]
                    Fault Frequency: 46
                    Reset counter: 8
                    Mileage: 109493 km
                    Date: 2018.12.24
                    Time: 18:15:40
   Part No SW: 5K0 937 086 F    HW: 5K0 937 086 F
   Component: BCM PQ35 M    011 0035
   Revision: BC011001
   Coding: 40180A3B8925F1C0400800C81400812443519288436DA1626480C70000C1
   Shop #: WSC 00020 790 00000
   VCID: B73EAEB7064B96F2A7-80E2
   Subsystem 1 - Part No SW: 7N2 955 119 A    HW: 7N2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    110628  31  0032
   Serial number:         110723030838
   Coding: 000D9D
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0022
   Serial number: Y10M09D11h12m21s03S1
   Coding: 0380DD
   Subsystem 3 - Part No: 7N0 951 171
   Component: DWA-Sensor 00  002 0205
   Component: LIN BACKUP HO  H11 9004
                    Fault Status: 00101001
                    Reset counter: 0
                    Mileage: 109764 km
                    Date: 2013.05.31
                    Time: 15:05:48
                        Term 15 Off
                    Voltage: 12.00 V
                    Fault Status: 00101010
                    Reset counter: 3
                    Mileage: 106017 km
                    Date: 2013.02.20
                    Time: 10:03:35
                    Voltage: 14.30 V
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 7N0 919 475     HW: 7N0 919 475
   Component: PARKHILFE 8K  H04 0010
   Revision: --------    Serial number: 80231024702540
   Coding: 308002
   ASAM Dataset: EV_EPHVA18VW4280000 001005
   ROD: EV_EPHVA18VW4280000.rod
   VCID: F8BC6D8B43D5598A6E-80AC
   Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
   Component: VW10Airbag01V H07 0013
   Serial number: 003GFPJSM2YZ
   Coding: 003156
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: BE30BB932171A7BA64-80EA
   Serial number: 3493ETS60E792E012DD%
   Serial number: 3503ETS608C56EB129D/
   Serial number: 3513ETS60AC92E012DD-
   Serial number: 3523ETS60176FEB12DD1
   Serial number: 35540TS60C2F3D612DDV
          B1000 1B [136] - Resistance Too High
                    Mileage: 109738 km
                    Date: 2019.01.06
                    Time: 15:25:31
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20181106200829
   Coding: 7982A00000
   Shop #: WSC 01286 386 08256
   VCID: 82480F631509035A40-80D6
   Subsystem 1 - Part No SW: 1P0 959 538 D    HW: 1P0 959 538 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP  H02 0102
   Serial number: 00000000000000160553
   Coding: E20000
13 Faults Found:
0516 - Databus
                    Fault Frequency: 8
                    Reset counter: 223
                    Mileage: 110083 km
                    Date: 2019.01.18
                    Time: 00:01:29
147462 - Terminal 15
          B1148 12 [009] - Short to Plus
226827 - Turn Signal Switch
          B1144 13 [008] - Open Circuit
226839 - Turn Signal Switch
          B1144 11 [009] - Short to Ground
                    Fault Frequency: 64
                    Reset counter: 223
227339 - Windshield Wiper Switch
          B1145 13 [008] - Open Circuit
          B1149 13 [009] - Open Circuit
                    Reset counter: 223
229127 - Cruise Control Switch
          B1154 11 [008] - Short to Ground
                    Reset counter: 4
229147 - Cruise Control Switch
          B1154 13 [008] - Open Circuit
                    Reset counter: 4
332660 - Databus
                    Reset counter: 4
342020 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0011 00 [008] - Performance
365080 - Controls in Steering Wheel
          U108E 00 [008] - No Communications
                    Reset counter: 5
617736 - Selector Lever Park Position Lock Switch
          B1162 29 [008] - Signal Implausible
1140738 - Steering angle sensor
                    UBat: 13.30 V
                    MC1 interner Fehlercode: 0
                    MC2 interner Fehlercode: 0
   Part No SW: 7N5 920 970 A    HW: 7N5 920 970 A
   Component: KOMBI         H17 0404
   Coding: 440B00
   VCID: B620A3B309416FFABC-80E2
   Part No: 5K0 963 271 C
   Component: Zuheizer        051 2606
   Revision: 00051000    Serial number: 09021535000000
   Coding: 0000041
   VCID: AF2E96D73E1B5E32FF-80FA
00664 - Fuel gauge
                    Reset counter: 0
                    Mileage: 108478 km
                    Date: 2013.04.15
                    Time: 09:55:05
01444 - Under-Voltage Shut-Off (Automatic)
            000 -  -  - Intermittent
                    Reset counter: 5
                    Mileage: 108500 km
                    Date: 2013.04.16
                    Time: 08:10:60
   Part No SW: 7N0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H25 5603
   Revision:   H25       Serial number: 160910F2002035
   Coding: F9A07F06404A5304008203
   VCID: AE108BD33911573AF4-80FA
                    Fault Status: 00110100
                    Reset counter: 4
                    Mileage: 71198 km
                    Date: 2011.01.16
                    Time: 19:49:54
   Part No SW: 7N0 857 511 F    HW: 8P0 857 511 C
   Component: FLA           H04 0006
   Revision: AA001002
   Coding: 0102816B74745D545420363E00
   VCID: B620A3B301416FFABC-80E2
   Component: IMMO          H17 0404
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: EA9847C30D79FB1AE8-80BE
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Revision: A1001003    Serial number: 7668593732
   Coding: 020000
   VCID: A71E7EF7D6EB067237-80F2
   Part No SW: 5P0 035 191 D    HW: 5P0 035 191 D
   Component: RNS315        H03 0007
   Serial number: SEZAZ2K9106199
   Coding: 040004110400000000021000
   ASAM Dataset: EV_RNS315SeatEUV1UDS A01005
   ROD: EV_RNS315SeatEUV1UDS.rod
   VCID: AC1481DBC70D252ADA-80F8
   Part No SW: 7N0 959 793 C    HW: 7N0 959 793 A
   Component: TSG FA        H04 0360
   Revision:             Serial number: 0000108128591
   Coding: 01110620D001411011
   VCID: C2C8CF635D89C35A00-8096
   Part No: 7N0 909 144 L
   Component: EPS_ZFLS Kl. 260    3102
   Revision: 00H17000
   VCID: BC34B19BFF6DB5AA4A-80E8
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 219
                    Mileage: 110083 km
                    Date: 2013.06.10
                    Time: 00:01:31
                    Battery Volts: 11.8 V
                        DD
                    Temperature: 13.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng Init
01312 - Powertrain Data Bus
                    Fault Status: 00101110
                    Reset counter: 5
                    Mileage: 110117 km
                    Date: 2013.06.10
                    Time: 07:31:24
                    Voltage: 14.50 V
                        DU
                    Temperature: 24.0°C
                    RPM: 2458 /min
                    Speed: 43.0 km/h
                    Speed: 20.0 km/h
                    Count: 3
   Component: EZE_2         H25 5603
   Coding: 050B0500
   VCID: EFAE56D73E9B1E32BF-80BA
   Component: J245EE20SKB13  H02 0220
02071 - Local Databus
                    Fault Status: 00101100
                    Fault Frequency: 151
                    Reset counter: 4
                    Mileage: 72187 km
                    Date: 2011.01.22
                    Time: 15:31:55
   Part No SW: 7N0 959 792 C    HW: 7N0 959 792 A
   Component: TSG BF        H04 0360
   Revision:             Serial number: 0000108132034
   Coding: 01110420DE01411011
   VCID: C1CAC06F588FD84219-8094
   Part No SW: 3AA 907 801 D    HW: 3AA 907 801 D
   Component: J540 EPB4  VW-53083 0006
   Revision:   H18       Serial number: 00000000087444
   Coding: 0024067
   VCID: B2289FA32D2973DA90-80E6
                    Fault Status: 00110010
                    Reset counter: 250
                    Mileage: 106139 km
                    Date: 2013.02.22
                    Time: 09:08:50
                    Voltage: 9.30 V
                    Count: 52
                    Hex Value: 0x12E0
                    Hex Value: 0x0001
                    Hex Value: 0x0202
                    Fault Frequency: 8
                    Reset counter: 229
                    Mileage: 104563 km
                    Date: 2013.01.23
                    Time: 11:59:17
                    Voltage: 14.30 V
                    Count: 10
                    Hex Value: 0x12E1
                    Hex Value: 0x0001
                    Hex Value: 0x0808
   Component: Batt.regelung H25 5603
   Coding: 030B185A
   VCID: F1AA50AF28AF08C2A9-80A4
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370050045
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 C    HW: 7N0 959 795 A
   Component: TSG HL        H03 0360
   Revision:             Serial number: 0000107576468
   Coding: 010004200001411001
   VCID: C3C6CA674293CA520B-8096
                    Fault Frequency: 11
                    Reset counter: 1
                    Mileage: 108475 km
                    Date: 2013.04.15
                    Time: 09:16:12
   Part No SW: 7N0 907 441     HW: 7N0 907 441
   Component: J772__Rearview      0020
   Revision: 00H08000    Serial number: 525PA8-J080526
   Coding: 0020011
   VCID: EE904BD3F991173AB4-80BA
   Component: TSG HR        H03 0360
   Revision:             Serial number: 0000108172843
End----------(Elapsed Time: 02:08, VBatt start/end: 14.7V/14.8V)-----------
golfi_vend
Tartu, Estonia
C?ID=195131
You need to copy coding from old module to new.
VDoubleYall
C?ID=348951
Does the old code already exist in the Current scan? Can I copy the old code after the installation of the new module even if the old one has been removed?
South Molton, UK
If you did a VCDS scan with the old module fitted then the scan will have been saved automatically by VCDS, so you can open that scan in any text editor and see the old coding.
VDoubleYall
C?ID=348951
If I have already installed the new module is it possible to obtain the old code without putting the old module back in again? Model number for old module is 5K0.953.569.B the new one is 5K0.953.569.AL as you can see from the autoscan its picked this up and also there is a CODE value 7982A00000
Is there anyway to get the code for the old module based on the part number?
VDoubleYall
C?ID=348951
Thanks Dave, unfortunately I didn’t do an autoscan. I just purchased Hex net after installing the new module. So the only autoscan I’ve done is with the new module installed. It works as the horn and steering wheel buttons for radio etc function as normal. Question is if I need the old code what is the current code? Does it change at all when you install the new module.
Jef
HQ
VIN: VSSZZZ7NZBVXXXXXX :banghead:
Well, kind of makes it impossible for me to look up any real info to take a guess as to what coding should be.
Often times the Steering Wheel Electronics module (J527) comes with some odd ball type coding in them right out of the box. I would suggest you plug the original J527 back up and scan it so you can get the original coding, then apply that to the new module.
raf0468
C?ID=120244
yes they would work..
you could try coding from here and there, that would be trial and error,a hit and miss situation,
to be certain about the correct coding i would copy from old module ..
VDoubleYall
C?ID=348951
Update. So lucklily I remembered before agreeing to buy the car from a dealer 2 years ago I Asked they for a diagnostic report. This report has the original correct coding for the module. Changed the code in vcds, cleared all the faults, had to do a SAS basic settings procedure and voala! All sorted.
langers2k
C?ID=224085
Can you post a new autoscan as it might help others with similar vehicles/circumstances :)
VDoubleYall
C?ID=348951
Sure, Still got a few faults to go through once Ive cleared them all with replaced components will update with autoscan
