VW passat parking brake fault 2012
jimmyq
C?ID=139879
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 61 62
          65 72
VIN: WVWZZZ3CZCP014439   Mileage: 387350km-240688miles
08-Auto HVAC -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Malfunction 1010
Address 01: Engine (J623-CFGB)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 BH    HW: 03L 907 309 N
   Component: R4 2.0l TDI   H24 9977
   Revision: 47H24---    Serial number: VWZCZ000000000
   Coding: 00190012042501080000
   Shop #: WSC 77019 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906018BH 003005
   ROD: EV_ECM20TDI01103L906018BH.rod
   VCID: 71AA3C8DA0C6ACC229-8024
7 Faults Found:
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [040] - -
                    Fault Frequency: 14
                    Mileage: 387261 km
                    Date: 2019.01.14
                    Time: 15:00:15
                    Engine speed: 2086.50 /min
                    Normed load value: 41.6 %
                    Vehicle speed: 18 km/h
                    Coolant temperature: 75 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 13.020 V
                    ACC target acceleration: 0.000 m/s²
                    ACC control module received status-Bits 0-7: 4
                    Status of ACC/CCS acceleration interface-Bits 0-7: 0
                    Acceleration: 0.435 m/s²
                    Engine status: COENG_RUNNING
4984 - Cylinder 1 Glow Plug Circuit (Q10)
          P0671 00 [109] - Electrical Fault
                    Mileage: 387198 km
                    Date: 2019.01.12
                    Time: 14:33:36
                    Engine speed: 858.00 /min
                    Normed load value: 65.5 %
                    Vehicle speed: 1 km/h
                    Coolant temperature: 27 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 14.840 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 20
                    Electric auxiliary heater: relay activation-Bits 0-7: 0
                    Preheat time: 0 ms
                    Glow status-Bits 0-7: 0
                    Glow status-Bits 0-7: 176
                    Glow cycles above temperature threshold-Bits 0-7: 10
                    Glow cycles above temperature threshold-Bits 0-7: 58
                    Glow cycles below temperature threshold-Bits 0-7: 0
                    Glow cycles below temperature threshold-Bits 0-7: 3
                    Outside air temperature: 9.0 °C
4986 - Cylinder 3 Glow Plug Circuit (Q12)
          P0673 00 [109] - Electrical Fault
                    Mileage: 387198 km
                    Date: 2019.01.12
                    Time: 14:33:36
                    Preheat time: 0 ms
11841 - No Communications with HVAC Control Module (J301)
          U0164 00 [039] - -
                    Mileage: 387350 km
                    Date: 2019.01.17
                    Time: 14:08:27
                    Engine speed: 0.00 /min
                    Coolant temperature: 29 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 12.180 V
                    Limitation: accelerator pedal: 126.7 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 40
                    selected gear-Bits 0-7: 0
4685 - Implausible Data Received from Parking Brake Control Module
          U0417 00 [032] - -
                    Mileage: 387276 km
                    Date: 2019.01.14
                    Time: 16:39:31
                    Engine speed: 2309.00 /min
                    Normed load value: 23.1 %
                    Vehicle speed: 37 km/h
                    Coolant temperature: 84 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 14.740 V
                    Unlearning counter according OBD: 35
                    Limitation: accelerator pedal: 63.8 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 8
                    selected gear-Bits 0-7: 2
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [039] - -
                    Mileage: 387350 km
                    Date: 2019.01.17
                    Time: 14:08:23
                    Coolant temperature: 28 °C
                    Voltage terminal 30: 12.280 V
4716 - No Communications with Parking Brake Control Module
          U0128 00 [046] - -
                    Fault Frequency: 248
                    Mileage: 387261 km
                    Date: 2019.01.14
                    Time: 15:00:14
                    Engine speed: 2013.50 /min
                    Normed load value: 43.1 %
                    Vehicle speed: 17 km/h
                    Limitation: accelerator pedal: 69.8 Nm
                    selected gear-Bits 0-7: 3
   Part No SW: 3AA 614 109 AB    HW: 3AA 614 109 AB
   Component: J104   C2 450M V465 0022
   Revision: --H07---    Serial number: 00000004522409
   Coding: 0003001
   Shop #: WSC 00028 028 00001
   VCID: 6D9220FD74FE48220D-8038
02779 - Databus for Electric Parking Brake
                    Fault Status: 00101110
                    Reset counter: 141
                    Mileage: 387206 km
                    Date: 2013.06.04
                    Time: 14:48:34
                    Speed: 38.0 km/h
                    Hex Value: 0x0001
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.75 V
                    Bin. Bits: 00010001
                    Count: 228
                    Hex Value: 0x0000
                    Reset counter: 141
                    Mileage: 387206 km
                    Date: 2013.06.04
                    Time: 14:48:34
                    Speed: 38.0 km/h
                    Hex Value: 0x0001
                    Voltage: 14.75 V
                    Bin. Bits: 00010001
                    Count: 228
                    Hex Value: 0x0000
                    Reset counter: 136
                    Mileage: 387261 km
                    Date: 2013.06.06
                    Time: 15:03:14
                    Speed: 3.0 km/h
                    Hex Value: 0x0100
                    Voltage: 12.75 V
                    Bin. Bits: 00010001
                    Count: 246
                    Hex Value: 0x0000
                    Reset counter: 136
                    Mileage: 387261 km
                    Date: 2013.06.06
                    Time: 15:03:14
                    Speed: 3.0 km/h
                    Hex Value: 0x0100
                    Voltage: 12.75 V
                    Bin. Bits: 00010001
                    Count: 250
                    Hex Value: 0x0000
                    Reset counter: 136
                    Mileage: 387261 km
                    Date: 2013.06.06
                    Time: 15:03:14
                    Speed: 4.0 km/h
                    Hex Value: 0x0100
                    Voltage: 12.75 V
                    Bin. Bits: 00010001
                    Count: 238
                    Hex Value: 0x0000
            013 - Check DTC Memory
                    Fault Status: 00101101
                    Fault Frequency: 23
                    Reset counter: 101
                    Mileage: 387294 km
                    Date: 2013.06.07
                    Time: 15:17:59
                    Hex Value: 0x0000
                    Voltage: 14.50 V
                    Bin. Bits: 00010001
                    Count: 254
                    Hex Value: 0x0000
Address 08: Auto HVAC
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 D    HW: 3AA 937 087 D
   Component: BCM PQ47 H    413 0455
   Revision: BB413001
   Coding: 000000000000000000180080140081E403516488406C81606480C7200041
   VCID: 3B36DEA5BA0A1692C3-806E
   Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 06071  26  0612
   Coding: 00B795
   Component: RLS 190711 05  54  0403
   Coding: 0230ED
                    Fault Frequency: 115
                    Reset counter: 139
                    Mileage: 387206 km
                    Date: 2013.06.04
                    Time: 14:48:43
                    Voltage: 14.95 V
                    Reset counter: 101
                    Mileage: 387350 km
                    Date: 2013.06.09
                    Time: 13:44:13
                        Term 15 Off
                    Voltage: 12.35 V
                    Fault Status: 00101010
                    Reset counter: 138
                    Mileage: 387298 km
                    Date: 2013.06.07
                    Time: 16:42:47
                    Voltage: 10.25 V
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__102 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PDJU1SA
   Coding: 0012338
   VCID: 4CD48D792FA4A12A7A-8018
   Subsystem 1 - Serial number: 6332MTS654621811
   Subsystem 2 - Serial number: 6342MTS639381801
   Subsystem 3 - Serial number: 6351HTS6U1BV8AKR
   Subsystem 4 - Serial number: 6361HTS6K8ET8AKJ
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - MIL ON
                    Fault Status: 11101001
                    Mileage: 387350 km
                    Date: 2013.06.09
                    Time: 14:08:25
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
   Revision: FF010040    Serial number: 20110711200746
   Coding: 0182250000
   Shop #: WSC 00028 028 00021
   VCID: 72A83381A5C097DAD0-8026
   Coding: E20000
   Part No SW: 3AA 920 970 E    HW: 3AA 920 970 E
   Coding: 460F00
   VCID: 3522C89D942EC0E235-8060
12658688 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für elektrische Parkbremse: keine Kommunikation]
                    Fault Frequency: 240
                    Reset counter: 139
                    Mileage: 387206 km
                    Date: 2019.01.12
                    Time: 14:48:41
   Part No SW: 7N0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway H41 1620
   Revision:   H41       Serial number: 150711F2001221
   Coding: 461007
   VCID: 393AC4ADB0362482D1-806C
                    Reset counter: 101
                    Mileage: 387350 km
                    Date: 2013.06.09
                    Time: 13:44:11
                    Fault Status: 00110100
                    Fault Frequency: 247
                    Reset counter: 140
                    Mileage: 387206 km
                    Date: 2013.06.04
                    Time: 14:48:43
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0400
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 76A00F9101A88BFAFC-8022
   Revision: A1001003    Serial number: 7660421655
   Coding: 020000
   VCID: 291A14ED40969402A1-807C
   Part No SW: 3C0 035 279 B    HW: 3C0 035 279 B
   Component: RNS315-EU   H33 0263
   Serial number: VWZAZ2L3385583
   Coding: 040004010400100000019002
   ASAM Dataset: EV_RNS315EUV2UDS A01004
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 220803C135A0475AE0-8076
   Component: EUR_W_0031  0031
1048632 - Antenna 1 for Radio
          B1119 13 [008] - Open Circuit
                    Reset counter: 140
                    Mileage: 387227 km
                    Date: 2019.01.13
                    Time: 15:50:31
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0534
   Revision: 12110009    Serial number: 0003219597
   Coding: 0202B7
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0408
   Serial number: 00000002345468
   Coding: 000290
66304 - Switch for Drivers Side Window Regulator
          B11F0 29 [008] - Signal Implausible
                    Reset counter: 136
                    Mileage: 387273 km
                    Date: 2019.01.14
                    Time: 15:25:00
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 196    3201
   Revision: 00H20000
   VCID: 3424F5995754D9EA02-8060
   Component:    KSG PQ47 ELV 043 0634
   Coding: 01910A0002860E76300494157C085FCE105C01
   Component: Neigungssensor  004 0611
                    Reset counter: 101
                    Mileage: 387350 km
                    Date: 2013.06.09
                    Time: 13:56:59
   Component: EZE_2         H41 1620
   Coding: 00000008
   VCID: 6FAE3AF5BEF2BA323F-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0534
   Revision: 14110009    Serial number: 0003212106
   Coding: 0202B6
   ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
   VCID: 3620CF918928CBFA3C-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0408
   Serial number: 00000002337091
   Coding: 000290
   Revision:   H19       Serial number: 00000000638861
   Coding: 0022167
   Shop #: WSC 05311 000 00000
   VCID: 3620CF914128CBFA3C-8062
                    Reset counter: 136
                    Mileage: 387206 km
                    Date: 2013.06.04
                    Time: 14:48:42
                    Voltage: 14.80 V
                    Count: 62
                    Hex Value: 0x1260
                    Hex Value: 0x0082
                    Hex Value: 0x0101
                    Fault Frequency: 9
                    Reset counter: 139
                    Mileage: 387206 km
                    Date: 2013.06.04
                    Time: 14:48:42
                    Voltage: 14.70 V
                    Count: 63
                    Hex Value: 0x1270
                    Hex Value: 0x0082
                    Hex Value: 0x0101
00576 - Terminal 15
                    Fault Status: 01111000
                    Fault Frequency: 41
                    Reset counter: 101
                    Mileage: 387217 km
                    Date: 2013.06.04
                    Time: 15:14:40
                    Voltage: 10.60 V
                    Count: 52
                    Hex Value: 0x12E0
                    Hex Value: 0x0001
                    Hex Value: 0x0202
   Component: Batt.regelung H41 1620
   Coding: 030B185A
   VCID: 71AA3C8DA8C6ACC229-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900907523
   Part No SW: 3AA 907 273 B    HW: 3AA 907 273 B
   Component: RDKBERU30     H08 0008
   Serial number: 10000000049424
   ASAM Dataset: EV_RDKBERU30 003010
   ROD: EV_RDKBERU30_003.rod
   VCID: 3326F6859A5ADED21B-8066
End----------(Elapsed Time: 01:29, VBatt start/end: 12.2V/12.2V)-----------
Saturday,19,January,2019,15:20:09:28598
VCDS Version: 18.9.0.1  HEX-NET CB: 0.4436.4
VIN: WVWZZZ3CZCP014439   License Plate:
Mileage: 387350km-240688mi   Repair Order:
          65 72
9 Faults Found:
4815 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [032] - -
          [Software Incompatibility with Anti-Lockplease read DTC]
                    Mileage: 387350 km
                    Date: 2019.01.17
                    Time: 15:28:19
                    Engine speed: 975.50 /min
                    Normed load value: 40.4 %
                    Coolant temperature: 20 °C
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 14.660 V
                    Requested transmission torque: 1000.0 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 10
                    Transmission torque intervention status-Bits 0-7: 0
                    Calculated reducing transmission intervention torque: 1000.0 Nm
14413 - Implausible Data Received from ABS Control Module
          U0415 00 [032] - -
          [Invalid Data Received FromAnti-Lock Brake System Control Module]
                    Mileage: 387350 km
                    Date: 2019.01.17
                    Time: 15:28:14
                    Engine speed: 905.00 /min
                    Normed load value: 43.5 %
                    Voltage terminal 30: 14.780 V
          U1113 00 [047] - -
                    Fault Frequency: 19
                    Mileage: 387261 km
                    Date: 2019.01.14
                    Time: 15:00:15
          P0671 00 [047] - Electrical Fault
                    Mileage: 387198 km
                    Date: 2019.01.12
                    Time: 14:33:36
                    Preheat time: 0 ms
          P0673 00 [047] - Electrical Fault
                    Mileage: 387198 km
                    Date: 2019.01.12
                    Time: 14:33:36
                    Preheat time: 0 ms
          U0164 00 [038] - -
                    Mileage: 387357 km
                    Date: 2019.01.19
                    Time: 14:19:04
                    Engine speed: 1302.50 /min
                    Coolant temperature: 2 °C
                    Intake air temperature: 3 °C
          U0417 00 [032] - -
                    Mileage: 387276 km
                    Date: 2019.01.14
                    Time: 16:39:31
          U0164 00 [038] - -
                    Mileage: 387357 km
                    Date: 2019.01.19
                    Time: 14:18:56
                    Intake air temperature: 2 °C
                    Voltage terminal 30: 11.640 V
          U0128 00 [046] - -
                    Fault Frequency: 252
                    Mileage: 387261 km
                    Date: 2019.01.14
                    Time: 15:00:14
   Coding: 0003001
                    Reset counter: 141
                    Mileage: 387356 km
                    Date: 2013.06.09
                    Time: 16:51:41
                    Speed: 25.0 km/h
                    Hex Value: 0x0001
                    Voltage: 14.75 V
                    Bin. Bits: 00010001
                    Count: 228
                    Hex Value: 0x0000
                    Reset counter: 141
                    Mileage: 387356 km
                    Date: 2013.06.09
                    Time: 16:51:41
                    Speed: 25.0 km/h
                    Hex Value: 0x0001
                    Voltage: 14.75 V
                    Bin. Bits: 00010001
                    Count: 228
                    Hex Value: 0x0000
                    Fault Frequency: 9
                    Reset counter: 101
                    Mileage: 387357 km
                    Date: 2013.06.10
                    Time: 13:48:29
                    Hex Value: 0x0000
                    Voltage: 12.50 V
                    Bin. Bits: 00010001
                    Count: 254
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 ER    HW: 5K0 907 044 ER
   Component: Climatronic   H18 1112
   Revision: 00001003
   Coding: 0004001803
   VCID: 7F4EEAB5E692CAB2AF-802A
9 Faults Found:
9475093 - Position Sensor for Left Temperature Flap Motor
          B1094 15 [008] - Open or Short to Plus
                    Reset counter: 141
                    Mileage: 387357 km
                    Date: 2019.01.19
                    Time: 15:14:16
9475349 - Position Sensor for Right Temperature Flap Motor
          B1095 15 [008] - Open or Short to Plus
                    Reset counter: 141
                    Mileage: 387357 km
                    Date: 2019.01.19
                    Time: 15:14:16
9476117 - Position Sensor for Defrost Flap Motor
          B1098 15 [008] - Open or Short to Plus
                    Reset counter: 141
                    Mileage: 387357 km
                    Date: 2019.01.19
                    Time: 15:14:16
9476373 - Position Sensor for Front Air Distribution Flap Motor
          B1099 15 [008] - Open or Short to Plus
                    Reset counter: 141
                    Mileage: 387357 km
                    Date: 2019.01.19
                    Time: 15:14:16
9476885 - Position Sensor for Fresh/Recirculated Flap Motor
          B109B 15 [008] - Open or Short to Plus
                    Reset counter: 141
                    Mileage: 387357 km
                    Date: 2019.01.19
                    Time: 15:14:16
9470741 - Temperature Sensor for Left Footwell Vent
          B1083 15 [008] - Open or Short to Plus
                    Reset counter: 141
                    Mileage: 387357 km
                    Date: 2019.01.19
                    Time: 15:14:08
9470997 - Temperature Sensor for Right Footwell Vent
          B1084 15 [008] - Open or Short to Plus
                    Reset counter: 141
                    Mileage: 387357 km
                    Date: 2019.01.19
                    Time: 15:14:08
9472533 - Temperature Sensor for Evaporator Vent
          B108A 15 [008] - Open or Short to Plus
                    Reset counter: 141
                    Mileage: 387357 km
                    Date: 2019.01.19
                    Time: 15:14:08
9478421 - Diagnostic Line for Front Air Blower
          B10A1 15 [008] - Open or Short to Plus
                    Reset counter: 141
                    Mileage: 387357 km
                    Date: 2019.01.19
                    Time: 15:14:29
   Revision: BB413001
   Coding: 00B795
   Coding: 0230ED
                    Fault Frequency: 119
                    Reset counter: 141
                    Mileage: 387206 km
                    Date: 2013.06.04
                    Time: 14:48:43
                    Voltage: 14.95 V
                    Reset counter: 141
                    Mileage: 387350 km
                    Date: 2013.06.09
                    Time: 13:44:13
                        Term 15 Off
                    Voltage: 12.35 V
                    Reset counter: 141
                    Mileage: 387298 km
                    Date: 2013.06.07
                    Time: 16:42:47
                    Voltage: 10.25 V
   Coding: 0012338
                    Mileage: 387357 km
                    Date: 2013.06.11
                    Time: 14:18:58
   Coding: 0182250000
   Coding: E20000
   Coding: 460F00
          U1111 00 [008] - -
                    Fault Frequency: 241
                    Reset counter: 141
                    Mileage: 387206 km
                    Date: 2019.01.12
                    Time: 14:48:41
   Coding: 461007
                    Reset counter: 141
                    Mileage: 387350 km
                    Date: 2013.06.09
                    Time: 13:44:11
                    Fault Frequency: 251
                    Reset counter: 141
                    Mileage: 387206 km
                    Date: 2013.06.04
                    Time: 14:48:43
   Coding: 020000
          B1119 13 [009] - Open Circuit
                    Reset counter: 101
                    Mileage: 387227 km
                    Date: 2019.01.13
                    Time: 15:50:31
   Coding: 0202B7
   Slave Driver:
   Coding: 000290
                    Reset counter: 136
                    Mileage: 387273 km
                    Date: 2019.01.14
                    Time: 15:25:00
   Revision: 00H20000
                    Reset counter: 141
                    Mileage: 387350 km
                    Date: 2013.06.09
                    Time: 13:56:59
   Coding: 00000008
   Coding: 0202B6
   Slave Passenger:
   Coding: 000290
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000575378
   Coding: 0022167
   VCID: 383CC1A94B3C3D8A2E-806C
00576 - Terminal 15
                    Fault Frequency: 9
                    Reset counter: 141
                    Mileage: 387356 km
                    Date: 2013.06.09
                    Time: 16:43:08
                    Voltage: 12.80 V
                    Count: 52
                    Hex Value: 0x1263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Reset counter: 141
                    Mileage: 387356 km
                    Date: 2013.06.09
                    Time: 16:51:41
                    Voltage: 14.60 V
                    Count: 63
                    Hex Value: 0x1260
                    Hex Value: 0x0082
                    Hex Value: 0x0101
                    Reset counter: 141
                    Mileage: 387356 km
                    Date: 2013.06.09
                    Time: 16:51:41
                    Voltage: 14.60 V
                    Count: 62
                    Hex Value: 0x1270
                    Hex Value: 0x0082
                    Hex Value: 0x0101
   Coding: 030B185A
End----------(Elapsed Time: 01:32, VBatt start/end: 14.6V/14.6V)-----------
any ideas on this we have changed the parking brake module also but fault comes back possible it can be ABS pump?
jimmyq
C?ID=139879
anyone had this issue?
DrPeter
16.4905° S, 151.7375° W
Have you checked the basics? I would start with checking fuses for the J540-Parking Brake controller, then check the J540's powers and grounds.
With VCDS you can check the Measuring Value Block group [038], field (3) for the 15-Power voltage as reported by the J540. This needs to be actual battery voltage!
We have a Ross-Tech wiki page for the 00576 - Terminal 15: Implausible fault, if an A4 J519 controller sets this code because of a missing fuse, maybe the J540 could do the same?
Hope this helps,
drpeter
TFSI
Maryland, USA
C?ID=66650
Jimmyq
DrPeter is right..try checking power and grounds, your issue looks like supply issue. If all connections and fuses check out, measure voltages Term.30 and Term.15 voltage directly on the J540 socket/connector you should have 12V.
NostraJackAss
No it needs to be actual Voltage + Amperage or actual deliverable Current!
123 load lights .............
jimmyq
C?ID=139879
the J540 has 2 permanent lives both ok all fuses ok also none missing or blown grounds ok too measuring blocks shows terminal 30 12v and terminal 15 shows on and off when key is in and out but also shows error at times going to follow the wire back for terminal 15 will update soon
NostraJackAss
Did you load it & if you did, how?
jimmyq
C?ID=139879
hi sorted the problem did a continuity test for the terminal 15 wire which had 7v same wire goes to parking brake switch and auto hold on them it was 12v chased it up behind the dash was chaffed there behind middle of dash against some metal bracket all sorted now thanks guys appreciated :)
TFSI
Maryland, USA
C?ID=66650
Great Job! You owe all of us beer!:)
