Timing Chain stretch.
Brian422
C?ID=301473
I recently discovered an article indicating that it is possible to use VCDS to indicate amount of Timing Chain stretch using Measuring Blocks 208 and 209.
Please can you advise on which Advanced Measuring Values I should select to perform the same test, and expected results, on my 2013 1.2 (CGPB) Polo 6R?
Regards and Thanks
Brian.
Is it safe to assume you're referring to this car?
Brian422
C?ID=301473
Yep ... that's the one.
TBAx
DE
C?ID=287144
Well, this car has no classic measuring blocks, but rather adv. measurements. I am not perfectly sure, if the timing stretch can be read there, but since VCDS includes a good search function you can just look at these.
Brian422
C?ID=301473
Thanks for the advice but after running a block scan which produced a listed approximately 940 Codes and Descriptions of Advance Measuring Values in Excel. Unfortunately I could not identify any similar description to those mentioned in Measuring Blocks 208 or 209.
Don't think Forum Administrator would like me copying 940 lines of text and I don't know how to attach documents :rolleyes:
Actually, he has no problem with that. :cool:
Ideally, you'd put the text between [CODE] and [/CODE] tags.
Brian422
C?ID=301473
Hopefully this link will work but ... :rolleyes:
Link removed to avoid possible conflict with other users :banghead:
DrPeter
16.4905° S, 151.7375° W
Some UDS Engine controllers will have the following Advanced Measuring Values:
- Chain_elongation_MAX_drive_chain_1
- Chain_elongation_MAX_drive_chain_2
Some may have a [Basic Setting] for [Test for chain elongation]
However it does not look like this engine controller supports these values.
Hop this helps,
drpeter
Brian422
C?ID=301473
Apologies for being unable to align myself with modern technology but once passed a certain point, everything gets more complicated; why is there no option for attaching documents? :confused:
Thanks for the advice and guidance but decided just to bite the bullet and copy results in manually.
Any thoughts or advice gratefully received :)
;seeSW:03E-906-019-AK   HW:03E-906-019-B ---  Engine
;Component:SIMOS11.1     H03 7103	 Coding:00110016002400080000
;EV_ECM12MPI02103E906019AK	1006	EV_ECM12MPI.rod
Group	                                                     Description        Actual
IDE00019	                         Voltage terminal 30        13.593	 V
IDE00021	                         Engine speed        840	 /min
IDE00025	                         Coolant temperature        88°C
IDE00075	                         Vehicle speed        0	 km/h
IDE00078	                         Time since engine start        217           s
IDE00083	                         Throttle valve position (absolute)        12.2	 %
IDE00084	                         Absolute load value        17	         %
IDE00085	                         Normed load value        14.9	 %
IDE00086	                         Accelerator position        15	         %
IDE00100	                         Engine torque        16.0625	 Nm
IDE00149-ENG102932	 Ignition angle of current cylinder: actual value-Ignition angle: actual        4.125	         °
IDE00155-ENG111064	Timing angle retardation cylinder 1-IGA_CYL_FAST_KNK[0]        0	         °
IDE00156-ENG111065	Timing angle retardation cylinder 2-IGA_CYL_FAST_KNK[1]        0	         °
IDE00157-ENG111066	Timing angle retardation cylinder 3-IGA_CYL_FAST_KNK[2]        0	         °
IDE00167	                        Exhaust temperature 1 bank 1        562.5	 °C
IDE00186-ENG100489	Fuel low pressure: actual value-Fuel pump: actual fuel pressure        0	        hPa
IDE00187	                        Coolant temperature at engine start        93	         °C
IDE00188-ENG101818	Fuel high pressure: actual value-Actual fuel rail pressure        5004.24	 hPa
IDE00191-ENG100310	Charge air pressure: actual value-PUT_MES	1004.63	 hPa
IDE00192-ENG99707	        Coolant temperature at radiator outlet: actual value-TCO_2_MES        140.25	 °C
IDE00194-ENG101525	Coolant temperature at radiator output: specified value-Coolant temperature: specified	                                                            90	 °C
IDE00195-ENG104029	Coolant temperature difference between engine and radiator-TCO_1_2        0	 °C
IDE00199	                        Mean engine air mass        0	 kg/h
IDE00200-ENG103857	Median vehicle speed-Mean vehicle speed        0	 km/h
IDE00201-ENG100409	High fuel pressure: specified value-Fuel rail pressure: specified        5004.24	 hPa
IDE00202-ENG100413	Low fuel pressure: specified value-FUP_EFP_SP        0	 hPa
IDE00304-ENG101210	Fuel level-FTL_CAN        24	 l
IDE00347-ENG102523	Air mass: actual value:-MAF        82.89	 mg/stroke
IDE00348	                        Intake air temperature        38	 °C
IDE00349	                        Throttle valve position: normed        2	 %
IDE00350-ENG99216	        Air mass: specified value-Air mass integral: specified        0	 kg
IDE00357-ENG99842	        Fuel temperature-TFU        20.25	 °C
IDE00371-ENG104260	Fuel consumption-FCO_VS        0	 l/100km
IDE00380-ENG102782	Coolant fan 1: activation-Radiator fan 1: activation        9.8	 %
IDE00381-ENG101514	Coolant fan 2: activation-Radiator fan 2: activation        0	 %
IDE00392-ENG103226	Accelerator pedal: sensor voltage 1-Accelerator pedal sender 1: voltage ratio        0.752	 V
IDE00393-ENG103029	Accelerator pedal: sensor voltage 2-Accelerator pedal sender 2: voltage ratio        0.391	 V
IDE00474	                        Ambient air pressure        101	 kPa abs
IDE00556	                        Outside air temperature        10	 °C
IDE00557	                        Oxygen sensor bank 1 sensor 1 (jump sensor)        0.255 V / 6.25 %(rich)
IDE00560	                        Oxygen sensor bank 1 sensor 2 (jump sensor)        0.18	 V
IDE00582	                        Equivalence ratio target value	1	 Lambda
IDE00583	                        Throttle valve specified value	2        %
IDE00585	                        Dist. driven with exh. Malfunction Indicator Lamp activated        0	 km
IDE00592	                        Oxygen sensor control status	Closed loop	  / using O2 sensors
IDE00593	                        Ignition timing adjustment cylinder 1        4.5	 Degrees
IDE00594	                        Absolute intake pressure        29	 kPa abs
IDE00595	                        Allocation of oxygen sensors	B1S1 B1S2
IDE00597	                        Long term adaptation of mixture formation bank 1        6.3	 %
IDE00604	                        Short term adaptation of mixture formation bank 1        3.9	 %
IDE01266-ENG104168	Coolant shut-off valve-STATE_VLV_HEAT_TM        2
IDE01649-ENG103893	Throttle valve position 1-TPS_AV_1        2.721	 °
IDE01650	                        Throttle valve position 2        12	 %
IDE01773-ENG102335	Misfire sum counter-Misfires all cylinders per 1000 rpm        0
IDE01775-ENG103503	Misfires per 1000 revolutions of cylinder 1-Misfires cylinder 1 per 1000 rpm        0
IDE01776-ENG102032	Misfires per 1000 revolutions of cylinder 2-Misfires cylinder 4 per 1000 rpm        0
IDE01777-ENG101730	Misfires per 1000 revolutions of cylinder 3-Misfires cylinder 3 per 1000 rpm        0
IDE01869-ENG102708	Long-term fuel trim bank 1 at idle-MFF_ADD_LAM_AD_OUT[1]        0.45	 mg/stroke
IDE01873-ENG99703	        Test of catalytic converter: measured value-EFF_CAT_DIAG_OBD[1]        0
IDE01875-ENG102289	Required torque adjustment by idling regulator-Idling speed stabilisation: idling speed controller	                                               -0.375	 Nm
IDE01878-ENG99608	        Adaptation of throttle valve-Throttle valve adjuster: adaption status	ST_CHK_END
IDE01883-ENG99084	        Tests completed-Cycle flags: (completed cycles): cat: lambda probe heater        25
IDE01885-ENG101381	Shut off of oxygen sensor control-Lambda probe 1: bank 1: status        1
IDE01901-ENG101472	Lost torque adaptation: idle-Idling speed stabilisation: learned value        1.375	 Nm
IDE01912-ENG100365	Oxygen sensor bank 1 sensor 1: specified value-Lambda probes specification: bank 1        1
IDE02115-ENG101902	Adjustment requirements for basic setting-LF_STATE_COND_BASIC_ADJ        223
IDE02116-ENG110437	Exhaust gas temperature before catalytic converter-TEG_DYN_LS_UP[1]        463.78751 °C
IDE02118-ENG99353	        Oxygen sensor bank 1 sensor 1: voltage-Lambda probe voltage: bank 1: probe 1 (broadband probe)	                                        0.781 V
IDE02119	                        Long term adaptation of oxygen sensor control: bank 1        -4.7	%
IDE03262-ENG100421	Adapt of angle sensor 1 f throttle valve-VP_TPS_AD_EL_BOL_1        0.5	 V
IDE03263-ENG103444	Adapt of angle sensor 2 f throttle valve-VP_TPS_AD_EL_BOL_2        4.5	 V
IDE03264-ENG101674	Adaptation of angle sensor 1 throttle valve: emerg. air gap-VP_TPS_AD_LIH_1        0.8496	 V
IDE03265-ENG99507	        Adaptation of angle sensor 2 throttle valve: emerg. air gap-VP_TPS_AD_LIH_2        4.1406	 V
IDE03377-ENG101995	Coolant temp at radiator output: unconditioned voltage-V_TCO_2        0	 V
IDE03582-ENG102532	Temperature sensor for engine temperature management-TCYLH_OUT_TM        89.3	 °C
IDE03767-ENG102783	Engine status-Engine: operating status        IS
IDE03806-ENG103233	Oxygen sensor bank 1 sensor 1: status-Lambda probe readiness: bank 1: probe 1: short trip result	                                                1
IDE03807-ENG101214	Oxygen sensor bank 1 sensor 2: status-Lambda probe readiness: bank 1: probe 2: short trip result	                                                1
IDE03818-ENG102380	Heated oxygen sensor bank 1: sensor 2: resistance-Lambda probe heater: resistance: bank 1: probe 2	                                    304	 Ohm
IDE03819-ENG104048	Heated oxygen sensor bank 1: sensor 2: activation-LSHPWM_DOWN[1]        98.046875	 %
IDE03820-ENG102717	Heated oxygen sensor bank 1: sensor 1: resistance-Lambda probe heater: resistance: bank 1: probe 1	                                    103	 Ohm
IDE03821-ENG101813	Heated oxygen sensor bank 1: sensor 1: activation-Lambda probe heater: bank 1: probe 1: short trip result	                                0
IDE03919-ENG102347	Oxygen regulation operability and status-STATE_LAM[1]        NEG_I
IDE03920-ENG99603	Oxygen adaptation status-STATE_LAM_AD_MPL[1]        CDN_ADD
IDE03921-ENG103296	Mixture adaptation factor at partial load-FAC_LAM_AD_LAM_OUT[1]        -0.204	 %
IDE03922-ENG102170	Mixture adaptation factor at idle speed-Lambda probes learned values: bank 1: probe 1: idle	                                                        6.946	 %
IDE03925-ENG103305	Coolant (pump) change-over valve: status-LV_CWP_MAIN_ACT        1
IDE03926-ENG100681	Coolant (pump) change-over valve: spec. value-PWM_CWP_MAIN_TM        99.8	 %
IDE03956-ENG101462	Temperature difference over charge air cooler: actual value-TIA_DIF_ICO        -142.5	 °C
IDE03957-ENG99274	        Throttle valve angle: specified value-TPS_SP        2.852	 °
IDE04404-ENG101495	Reduced_throttle valve surface_active_total correction-AR_RED_SUM_COR_ACT_REL	                                                             -24.7833252	 %
IDE04405-ENG101627	Mixture deviation in adapted partial load range 1-FAC_MPL_LAM_AD[1][0]        -1.865	 %
IDE04406-ENG103765	Mixture deviation in adapted partial load range 2-FAC_MPL_LAM_AD[1][1]        -2.261	 %
IDE04407-ENG103348	Mixture deviation in adapted partial load range 3-FAC_MPL_LAM_AD[1][2]        -5.423	 %
IDE04408-ENG99641	        Mixture deviation in adapted partial load range 4-FAC_MPL_LAM_AD[1][3]        0.008	 %
IDE04409-ENG101499	Intake manifold pressure: corrected-map        291.37	 hPa
IDE04410-ENG103225	Intake manifold pressure: target value-MAP_SP        294.94	 hPa
IDE04412-ENG99813	        Pressure before throttle valve: corrected-PUT        1004.63	 hPa
IDE04415-ENG101262	Oxygen ctrl factor with precontrol correction-FAC_LAM_COR[1]        3.571	 %
IDE04557-ENG100131	ECM system status-ECU_STATE        SYN_ENG_IGK_ON
IDE04558-ENG103862	Heater signal: uncond voltage-V_HEAT_RAW        0	 V
IDE04604-ENG103719	Accelerator pedal travel-Accelerator position        0	 %
IDE04613-ENG103129	Oil dilution under cold start conditions: counter-CTR_STOP_FSD        177
IDE04614-ENG103891	Heated oxygen sensor 2 bank 1: status-STATE_LSH_DOWN[1]        LSH_POW_CTL
IDE04615-ENG99445	         Segment adaptation for rough running: status-LV_SEG_AD_AVL_ER        1
IDE04616-ENG104180	Segment adaptation for rough running: limit value correction-THD_AD_ER        0	 µs
IDE04637-ENG100681	Engine temperature management actuator-PWM_CWP_MAIN_TM        99.8	 %
IDE04673-ENG103030	O2 sensor 1 bank 1: duty cycle O2 heater-LSHPWM_UP[1]        69.921875	 %
IDE05281-ENG99299	        Compression test status-STATE_CYL_CMP_TEST        0
IDE05438-ENG110436	Rear cat conv temp main cat conv model value-TEG_DYN_LS_DOWN[1]        356.66251	 °C
IDE06006-ENG99273	        Idle speed specified value-Engine speed: specified        840	 /min
IDE06050-ENG99891	        Exhaust temp on O2 sensor behind cat conv from model: filtered-Lambda probe ageing: bank 1: probe 2: short trip result	               491.60001	 °C
IDE06098-ENG102144	Sensor control factor: output value-Lambda control value: bank 1        4.059	 %
IDE06136-ENG110423	Fuel volume correction refer val. for evaporation detect-MFF_OIL_VAP_REF[1]        0	 mg/stroke
IDE06142-ENG101905	Reduced opening surface of throttle valve-AR_RED_BAS        0.101	 cm²
IDE06143-ENG110404	Reduced opening surface of throttle valve: actual value-AR_RED        0.0751	 cm²
IDE06144-ENG101473	Adaptation of reduced opening surface of throttle valve-AR_RED_AD_ADD_MMV        -0.0143	 cm²
IDE06145-ENG102845	Reduced opening surface of throttle valve: I rate-Throttle valve deviation        -0.656	 %
IDE06147-ENG110420	Air mass at throttle valve: angle sensor 1-MAF_THR_TPS_AV_1        0	 kg/h
IDE06148-ENG110421	Air mass at throttle valve: angle sensor 2-MAF_THR_TPS_AV_2        0	 kg/h
IDE06154-ENG101972	Catalytic converter heater: function status-STATE_CH        CH_OFF
IDE06155-ENG99931	        Cold start counter: dew point end of rear lambda probe-CTR_COLD_ST_LS_DOWN        0
IDE06156-ENG102690	Cold start counter: dew point end of front lambda probe-CTR_COLD_ST_LS_UP        0
IDE06158-ENG109356	Coolant temperature longterm model value-TCO_SUB_OBD        33	 °C
IDE06159-ENG109355	Coolant temperature model value-TCO_SUB        93	 °C
IDE06166-ENG103346	Fuel quantity correction offset: target value-MFF_ADD_LAM_AD[1]        0.47	 mg/stroke
IDE06168-ENG110414	Ignition angle: corrected base value: bank 1-IGA_BAS_COR_1        23.625	 °
IDE06169-ENG110415	Ignition angle minimum-IGA_MIN        -12	 °
IDE06170-ENG110442	Injection quantity correction factor-TI_FAC_MFF_BAS_COR_VAR_FUEL        1
IDE06171-ENG110443	Injection time limit minimum-TI_MIN        0.9	 ms
IDE06172-ENG110417	Knock detection: adapted amplifier offset: cylinder 2-KNKS_CMD_GAIN_AD[1]        1
IDE06174-ENG110440	Intake air temperature at engine start-TIA_ST        36	 °C
IDE06175-ENG110441	Intake air temperature before throttle valve: actual value-TIA_THR_UP	39	 °C
IDE06185-ENG110446	Air mass flow: integral error: sensor 1-TPS_MAF_ERR_INT_1        0
IDE06186-ENG110447	Air mass flow: integral error: sensor 2-TPS_MAF_ERR_INT_2        0
IDE06187-ENG110412	Knock control adaptation factor-FAC_AD_KNK        0
IDE06188-ENG110416	Knock detection: adapted amplifier offset: cylinder 1-KNKS_CMD_GAIN_AD[0]        2
IDE06189-ENG110418	Knock detection: adapted amplifier offset: cylinder 3-KNKS_CMD_GAIN_AD[2]        -1
IDE06192-ENG102735	Knock sensor: cylinder 2: voltage-Knock control: knock sensor voltage: cyl. 4        0.36552	 V
IDE06193-ENG102129	Knock sensor: cylinder 3: voltage-Knock control: knock sensor voltage: cyl. 3        0.73822	 V
IDE06195-ENG103876	Knock sensor: cylinder 1: voltage-Knock control: knock sensor voltage: cyl. 1        0.40306	 V
IDE06196-ENG101929	Throttle valve position: position sensor 1: raw value-VP_TPS_1        0.6299	 V
IDE06197-ENG102985	Throttle valve position: position sensor 2: raw value-VP_TPS_2        4.3604	 V
IDE06205-ENG103484	Air mass per cylinder: calculated-MAF_CYL        6.28125	 kg/h
IDE06211-ENG101411	Throttle valve position: actual value-Throttle valve angle        2.823	 °
IDE06223-ENG99743	        Multipoint injection status-STATE_MPLH_MOD        MPLH_OFF
IDE06224-ENG110445	Throttle valve position: position control deviation-TPS_DIF        -0.007	 °
IDE06225-ENG110444	Block of adaptation of throttle valve-TPS_AD_CDN_MIS        0
IDE06228-ENG110433	Pressure before throttle valve: actuation ratio filtered-PUT_MDL_DIF_MMV_REL        -0.418	 %
IDE06249-ENG101009	Turbine temperature-TEMP_TUR[1]        -0.025	 °C
IDE06250-ENG110405	Misfire detection: counter in driving cycle-CTR_MIS_TOT_DC        0
IDE06251-ENG110424	Misfire sum counter: carb A-MIS_SUM_A        0
IDE06253-ENG110434	Status: monitoring of indicated errors-STATE_ERR_ABC_PRED        14
IDE06296-ENG111998	Activation of oxygen control after main cat-LV_LAM_ADJ_ACT_MES        0
ENG101785	                Cat. temperature: bank 1        560.85001	 °C
ENG103229	                Cycle flags: (completed tests): camshaft adj.: knock sensors        128
ENG99495	                        Cycle flags: (completed tests): lambda adaption:        136
ENG103597	                Cycle flags:(completed cycles):lambda probes:sec.air sys.        2
ENG99752	                        Error flags: (completed cycles): cat: lambda probe heater        24
ENG101275	                Error flags: (completed cycles): lambda probes: EGR        0
ENG104132	                Error flags: (completed cycles): lambda probes:sec.air sys.        2
ENG99715            	        Fuel pump: activation        0 %
ENG107032-ENG101679	Injection_time_puls1_Cyl_1_measured_value-TI_1_MES[0]        3.112	 ms
ENG107033-ENG103892	Injection_time_puls1_Cyl_2_measured_value-TI_1_MES[1]        3.072	 ms
ENG107034-ENG99805	Injection_time_puls1_Cyl_3_measured_value-TI_1_MES[2]        3.112	 ms
ENG103143	                Kilometres driven with MIL        0	 min
ENG102863	                Lambda probe voltage: bank 1: probe 2        0.142	 V
ENG100484	                LV_INH_LOAD_MIN_DET_MIS        100
ENG99855	                        LV_INH_N_MAX_DET_MIS        0
ENG103195	                LV_INH_N_MIN_DET_MIS        0
ENG107737-ENG102260	NC_NR_DIAG_RBM-IdentDec        31
ENG109090-ENG101799	STATE_SW_MVB-Param to DOP	SB3D6010 CBD4090
ENG101072	                T_DTC_CLR        17445	 min
ENG99381	                        TCO_2        140.25	 °C
ENG109428-ENG103547	Throttle Position Sensor 2-TPS_AV_2        2.823	 °
ENG110150-ENG103113	X_Corrected_setpoint_fuel_mass_flow_at_CPS-FLOW_COR_CPS        0	 kg/h
ENG110158-ENG103589	X_Cycles_during_start_and_afterstart_counter-CYC_CAST        5123
ENG110159-ENG99344	X_Cycles_during_start_counter-CYC_ST	0
ENG110160-ENG99152	X_Downstream_OS_ceramic_temperature_actual_value-TTIP_MES_LS_DOWN[1]        568.4375	 °C
ENG110167-ENG101724	X_End_of_injection_time_Injection_puls1_Cyl1_measured_value-EOI_1_MES[0]        224.25	 °
ENG110168-ENG100835	X_End_of_injection_time_Injection_puls1_Cyl2_measured_value-EOI_1_MES[1]        224.25	 °
ENG110169-ENG101101	X_End_of_injection_time_Injection_puls1_Cyl3_measured_value-EOI_1_MES[2]        224.25	 °
ENG110185-ENG102693	X_Exhaust_gas_mass_flow-MEF_CBK_TEG[1]        87.83	 mg/stroke
ENG110187-ENG100850	X_Exhaust_gas_temperature_1_modelled_value-TEG[1]        482.975	 °C
ENG110188-ENG100920	X_Exhaust_gas_temperature_2_modelled_value-TEG[2]        464.5375	 °C
ENG110189-ENG102442	X_Exhaust_gas_temperature_3_modelled_value-TEG[3]        488.5375	 °C
ENG110190-ENG100308	X_Exhaust_gas_temperature_4_modelled_value-TEG[4]        356.6625	 °C
ENG110200-ENG103402	X_Fuel_mass_flow_commanded_value-MFF_SP[1]        6.08	 mg/stroke
ENG110214-ENG100608	X_Injection_time_Injection_puls2_Cyl1_measured_value-TI_2_MES[0]        0	 ms
ENG110215-ENG99129	X_Injection_time_Injection_puls2_Cyl2_measured_value-TI_2_MES[1]        0	 ms
ENG110216-ENG102396	X_Injection_time_Injection_puls2_Cyl3_measured_value-TI_2_MES[2]        0	 ms
ENG110230-ENG103543	X_Intake_mass_air_flow_integral_for_CatHeating-MAF_INT_CH        0	 g
ENG110232-ENG102416	X_Lambda_correction_total_filtered_relative_value-LAMB_CTL_COR_ACT_REL_MMV_CLC	                                                              8.136	 %
ENG110233-ENG100286	X_Lambda_for_overheating_protection_setpoint-LAMB_OHP[1]        1.0498
ENG110253-ENG103791	X_Reduced_opening_area_throttle_control_deviation-AR_RED_DIF_REL        -0.529	 %
ENG110261-ENG101303	X_Start_of_injection_time_Inject_puls1_Cyl1_measured_value-SOI_1_MES[0]        239.625	 °
ENG110262-ENG103102	X_Start_of_injection_time_Inject_puls1_Cyl2_measured_value-SOI_1_MES[1]        239.25	 °
ENG110263-ENG101019	X_Start_of_injection_time_Inject_puls1_Cyl3_measured_value-SOI_1_MES[2]        239.25	 °
ENG110275-ENG102149	X_Stop ban as long as inclination sensor not verified-LV_STATE_NEUT_GEAR_STST_INH        1
ENG110283-ENG103397	X_Time_after_engine_shut_off-T_OFF_ENG        0	 s
ENG110284-ENG102039	X_Time_after_first_start_of_driving_cycle-T_AST_DC        244.9	 s
ENG110285-ENG99463	X_Time_in_engine_state_shut_off-T_ES_H        0	 s
Brian422
C?ID=301473
Hi Uwe
Thank you for editing QUOTE CODE.
Regards
Brian.
