O2 Sensor Fault Code
classexa
Sweden
C?ID=346547
Hello
I've an Allroad 2.7t -04 and I've fault code "P0131 - Oxygen (Lambda) Sensor B1 S1: Signal too Low". Is it a bad sensor? I've checked the resistance at the sensor connector and it's 10 ohms so that's fine. The wires from the ECU to the sensor seems fine.
I logged this in VCDS. Don't know if that tells you something. Yes, this was last year but it's still the same:
Saturday,22,September,2018,17:02:37:02198
VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.2
                Address 01: Engine  (4Z7 907 551 N)
17:02:25 Group 031: Lambda Control
  0.010 V  Bank 1 Sensor 1 (actual)
  0.450 V  Bank 1 Sensor 1 (specified)
  0.680 V  Bank 2 Sensor 1 (actual)
  0.455 V  Bank 2 Sensor 1 (specified)
17:02:25 Group 032: Lambda Control (Mixture Adaptation)
  9.9 %  Adaptation (Idle) Bank 1 Sensor 1
  -0.8 %  Adaptation (Partial) Bank 1 Sensor 1
  -0.8 %  Adaptation (Idle) Bank 2 Sensor 1
  -2.3 %  Adaptation (Partial) Bank 2 Sensor 1
17:02:25 Group 033: Lambda Control
  25.0 %  Lambda Control Bank 1 Sensor 1
  0.010 V  Sensor Voltage Bank 1 Sensor 1
  -16.4 %  Lambda Control Bank 2 Sensor 1
  0.630 V  Sensor Voltage Bank 2 Sensor 1
Jef
HQ
Hey hey!
Please include a full Auto-Scan when asking for help:
https://forums.ross-tech.com/showthread.php?101-How-to-post-an-Auto-Scan
[/CODE]
Looking very lean there. Check out our page on fuel trim:
http://wiki.ross-tech.com/wiki/index.php/Fuel_Trim_Info
Post the full Auto-Scan!
classexa
Sweden
C?ID=346547
Sorry about that. Here you go:
Saturday,12,January,2019,11:44:59:02198
VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4437.4
Data version: 20181017 DS296.0
VIN: WAUZZZ4B44N041931   License Plate:
Chassis Type: 4B (01 - Allroad)
Scan: 01 02 03 08 15 17 25 34 35 55 56
VIN: WAUZZZ4B44N041931   Mileage: 269080km-167198miles
Address 01: Engine        Labels: 078-907-551-AZA.lbl
   Part No: 4Z7 907 551 N
   Component: 2.7L V6/5VT     G   0003
   Coding: 11755
   Shop #: WSC 01120
   VCID: 4EC592D8E9C7AC175C7-5160
   WAUZZZ4B44N041931     AUZ7Z0C2464255
16515 - Oxygen (Lambda) Sensor B1 S1
            P0131 - 35-10 - Signal too Low - Intermittent
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 4Z7 927 156 L
   Component: AG5 01V 2.7l5VT RdW 2122
   Coding: 00001
   VCID: 4FFB8FDCEECDA51F571-5184
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 4Z7 907 389 A
   Component: ABS/ESP allrad      D56
   Coding: 06497
   Shop #: WSC 40967
   VCID: 4ACD9EC815AF803700F-5184
Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
   Part No: 4B0 820 043 AP
   Component: A6-Klimavollautomat 0208
   Coding: 00000
   VCID: 688944406B53522736B-258E
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4Z7 959 655 H
   Component: Airbag 8.4EP        3000
   Coding: 0001706
   Shop #: WSC 02334 785 00200
   VCID: 54F180B0C2EBC6C76A3-5184
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4B0 920 933 P
   Component: KOMBI+WEGFAHRS. VDO D14
   Coding: 04164
   Shop #: WSC 01120
   VCID: 3039EC209333DAE72EB-5160
01304 - Radio
            49-00 - No Communications
Address 34: Level Control        Labels: 4Z7-907-553.lbl
   Part No: 4Z7 907 553 F
   Component:  - 2C1A1          X060
   Coding: 25500
   Shop #: WSC 02334
   VCID: 48C9A4C00BA3722716B-5160
01772 - Signal from Level Control Pressure Sensor (G291)
Address 35: Centr. Locks        Labels:. 4B0-962-258.lbl
   Part No: 4B0 962 258 L
   Component: Zentralverriegelung D38
   Coding: 06721
   Shop #: WSC 02334
   VCID: 323DE6289D0FE8F758F-4F0C
01561 - Rear left door
            59-10 - Can't Unlock - Intermittent
01562 - Rear right door
            61-00 - Won't De-Safe
            61-10 - Won't De-Safe - Intermittent
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00030
   Shop #: WSC 02334
   VCID: 045170F0773B9647BA3-4B5C
End----------(Elapsed Time: 01:50, VBatt start/end: 13.8V/13.7V)-----------
So reading that link you gave me and looking at the numbers, I might have a vakuum leak somewhere? But is that related to the fault code? I also have misfires on Cyl 4 but the plug and ignition coil are fine. I've swithced them around and checked. There's no code on this. I checked the measuring blocks in VCDS. It also appears that it's only noticable when idling, not when driving. Could these 2 things be related?
Larry Manton
C?ID=112505
   Coding: 11755
   Shop #: WSC 01120
   Coding: 00001
   Coding: 06497
   Shop #: WSC 40967
   Coding: 00000
   Coding: 0001706
   Coding: 04164
   Shop #: WSC 01120
01304 - Radio
   Coding: 25500
   Shop #: WSC 02334
   Coding: 06721
   Shop #: WSC 02334
   Coding: 00030
   Shop #: WSC 02334
At idle usually indicative of smaller intake leak as under larger throttle opening small leak is insignificant at speeds.
Could swap sensors as a test if they are the same but would spray intake in all areas while at idle and see if numbers change on bank 1. What to use there are various opinions such as WD40.
LARIMORE
NostraJackAss
The miss is either from a small isolated multiplicative vacuum leak, carbon build up, weak cylinder ( check compression ), burned valve, bad injector spray pattern at idle ( most likely ), bad ground to coil pack or trigger or B+ connectivity issue.
OXS sensor might just be plain contaminated with carbon deposits or bad.
classexa
Sweden
C?ID=346547
Thanks for all the answers. Looks like there could be many things. I'll start by doing a compression test tomorrow and go from there
