2013 Golf Intermittent Power loss
Jonesy
Ireland
C?ID=236509
Hi guys,
Ive a 2013 golf, drives fine most of the time but every now and again it loses power and the glow plug light comes on. Cycle the ign once and it runs away again fine. This can happen at any time. twice in one day and it might not happen again for weeks.....
Ive cleared all faults and drove the car again until it happened and ran autoscan below
VIN: WVWZZZAUZEW001560
Mileage: 187246km
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEW001560   Mileage: 187246km-116349miles
Address 01: Engine (J623-CLHA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1,6L EDC   X22 5517
   Revision: 84X22---
   Coding: 01110012030511092000
   ASAM Dataset: EV_ECM16TDI01104L906021M 002009
   ROD: EV_ECM16TDI01104L997021.rod
   VCID: 2F6D759976CCDF3966-807A
19225 - Boost Pressure Regulation
          P0299 00 [096] - Control Range Not Reached
                    Mileage: 186691 km
                    Date: 2019.01.12
                    Time: 21:47:51
                    Engine speed: 2227.00 /min
                    Normed load value: 78.0 %
                    Vehicle speed: 114 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 114 °C
                    Voltage terminal 30: 13.340 V
                    Unlearning counter according OBD: 34
                    Charge air pressure specified value: 2467 hPa
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 2030.2 hPa
                    Mass airflow sensor 1 bank 1 airflow: raw value: 626.7 mg/stroke
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.00 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
                    Turbine actuator 1 bank 1: posit.feedback - Act.value: 82.81 %
                    Mean injection quantity: 30.63 mg/stroke
20558 - Heater Support Pump
          P16C6 00 [032] - Running Dry
Readiness: 0 0 0 0 X
   Revision: 00000000    Serial number: 61183000000582
   Coding: 01FA8AA12420096D037C060641C32580512490C06082A4F300400074C002
   VCID: 7BF591C9F234F3999A-802E
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5G0 907 426 M    HW: 5G0 907 426 M
   Component: AC Manuell    H01 0705
   Revision: 00001K06
   Coding: 00120104202100001000000000000000
   ROD: EV_ACManueBHBVW37X_SK48.rod
   VCID: 356147F19490E5E92C-8060
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [008] - -
                    Fault Frequency: 60
                    Reset counter: 60
                    Mileage: 172211 km
                    Date: 2018.09.03
                    Time: 06:35:01
                    Voltage terminal 30: 13.8 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
                    Auxiliary heater: in stages-Act.value: 3
                    Auxiliary heater: in stages-Specified value: 3
                    Auxiliary heater: in stages-Specified value for control: 3
   Part No SW: 5Q0 937 084 R    HW: 5Q0 937 084 R
   Component: BCM MQBAB B   H14 0111
   Serial number: 00011312200334
   Coding: 03000842C20100530BA44000000403081000000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 479D3D39FE7C67794E-8012
   Component: WWS    130429  042 0551
   Serial number:         130503154715
   Coding: 0E4DD5
          B1263 01 [009] - Electrical Failure
                    Fault Frequency: 68
                    Reset counter: 14
                    Mileage: 179593 km
                    Date: 2018.11.10
                    Time: 08:44:09
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H02 0033
   Revision: --------    Serial number: 94231311901968
   Coding: 0031051001
   ASAM Dataset: EV_EPHVA18AU3700000 002019
   ROD: EV_EPHVA18AU3700000_VW37.rod
   VCID: 3B7551C9B2B43399DA-806E
   Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
   Component: AirbagVW20    011 0361
   Serial number: 003F5R04XUSG
   VCID: 408F2625DB5250418F-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 000 705 13
   Serial number: 35767000000880DC2D0+
   Subsystem 2 - Part No SW: -----------    HW: 480 000 705 13
   Serial number: 358670000005DA940D0/
   Subsystem 3 - Part No SW: -----------    HW: 480 401 005 13
   Serial number: 3516502C71050653218T
   Subsystem 4 - Part No SW: -----------    HW: 480 401 005 13
   Serial number: 3526502AD1050650917.
   Subsystem 5 - Part No SW: -----------    HW: 480 400 205 13
   Serial number: 3556502C31050653F1F6
   Part No SW: 5Q0 953 507 AB    HW: 5Q0 953 549
   Revision: --------    Serial number: 03051304401708
   Coding: 0600
   Shop #: WSC 40195 333 37120
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 76E380FDC916AEF1E5-8022
   Part No SW: 5G0 920 951 A    HW: 5G0 920 951 A
   Component: KOMBI         104 3350
   Coding: 27A41A002300260001080800000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 008011
   ROD: EV_DashBoardJCIMQBAB_008.rod
   VCID: 275D9DB95E3C8779AE-8072
   Part No SW: 5Q0 907 530 K    HW: 5Q0 907 530 D
   Component: GW MQB Low    123 1144
   Revision: --------    Serial number: 0000545479
   Coding: 030000040B087300EF000048080E00010001000000000000000000000000
   ROD: EV_GatewLear_009.rod
   VCID: 39794BC1B8880189C8-806C
   Subsystem 2 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 8597130403
   Part No SW: 5Q0 959 393 A    HW: 5Q0 959 393
   Component: TSG FS        012 0006
   Serial number: 26041304081010
   Coding: 003002208001040100001000
   VCID: 3D715FD1ACA03DA9E4-8068
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 01
   ROD: EV_SteerAssisMQB_008.rod
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 22041302090515
   Coding: 003000208E01040100801000
   VCID: 3E7358DDA1A626B1FD-806A
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
   Part No SW: 5G0 035 820 A    HW: 5G0 035 820 A
   Component: MU-S-D-ER     040 0407
   Serial number: V5C03004130831
   Coding: 02730000FF00000021111201002800001F0100060100010001
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 1F4D8559066C4FB9D6-804A
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H44 0020
   Serial number: VWZ8Z9N2402Z0K
Any help appreciated....
Jef
HQ
http://wiki.ross-tech.com/wiki/index.php/16683/P0299/000665
Have you verified there are no leaks with the charge pipes? Looks like there is a "vacuum unit for turbocharger", if you manually pull vacuum with it, is the linear actuator movement smooth with applied vacuum? Is the engine generating a good supply vacuum and have proper control of it to the vacuum unit for turbocharger?
Jonesy
Ireland
C?ID=236509
Thanks Jef il get a look at it in yhe coming days and il report back 👍
akersgarage
C?ID=179893
Thanks Jef il get a look at it in yhe coming days and il report back ��
Hello
Did you manage to fix this issue.
I have same issue with Octavia VRS tdi. Car drives fine but light comes on intermittently.
Same fault logged as above.
The vacuum unit is working as it should.
Jonesy
Ireland
C?ID=236509
Hello
Hi I'm waiting on the car to come back to me so I haven't got looking at it yet. Il post back when I get looking at it.
If you get yours sorted in the mean time please share 👍
wiki38andy
C?ID=311243
Soot built up in variable geometry. Take the turbocharger out and clean it. You can find the procedure on youtube.
