New ABS module. How do I code new module?????
nickw698
C?ID=221721
I just bought a replacement ABS module as my original module is on the fritz. Can somebody please help/guide me on how to code new module? I have a log of the original module coding with fault codes. Im a rookie when it comes to vag-com and know nothing except how to read codes with my ross-tech. BTW i have a 2009 GTI and bought a brand new module from Jim Ellis VW in Atlanta for $577. P.S.....I pulled module/pump assembly 4 months ago and sent off to BBA reman and ABS light came back on 300 miles later.
Please post the scan that includes data from the original module, as well as a new scan with the new module installed.
nickw698
C?ID=221721
OK. Here is the latest auto scan of the original ABS module. This scan was performed when the module and cluster where going hay wire. EPC, check engine, steering wheel, ABS, Brake light were all on.
Monday,17,November,2014,17:45:12:45486
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WVWEV71K29W012483   License Plate:
Mileage: 158620km-98561mi   Repair Order: 11-17-14
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 55 56 65
VIN: WVWEV71K29W012483   Mileage: 158620km/98561miles
55-Xenon Range -- Status: Malfunction 0010
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 1K0 907 115 AE    HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0030
   Revision: AAH03---    Serial number: VWX7Z0H43NL82Z
   Coding: 0403010A18070160
   Shop #: WSC 01279 785 00200
   VCID: 69F7524D40C84C562C9-803C
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - Intermittent
                    Mileage: 158583 km
                    Time: 16:33:24
                    RPM: 785 /min
                    Load: 22.0 %
                    Temperature: 79.0°C
                    Temperature: 9.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 14.097 V
               U1017 - 000 -  - Intermittent
                    Mileage: 158592 km
                    Time: 16:47:51
                    RPM: 2886 /min
                    Load: 38.8 %
                    Speed: 124.0 km/h
                    Temperature: 86.0°C
                    Temperature: 10.0°C
                    Voltage: 14.097 V
               U1017 - 015 -  - Intermittent
                    Fault Status: 00101111
                    Mileage: 158592 km
                    Time: 16:47:51
                    RPM: 2871 /min
                    Load: 32.1 %
                    Speed: 124.0 km/h
                    Temperature: 86.0°C
                    Temperature: 10.0°C
                    Voltage: 13.970 V
050197 - Implausible Data Received from ABS Control Module
               U0415 - 004 -  - Intermittent
                    Mileage: 158595 km
                    Time: 16:49:05
                    RPM: 2440 /min
                    Load: 69.8 %
                    Speed: 255.0 km/h
                    Temperature: 84.0°C
                    Temperature: 9.0°C
                    Voltage: 13.970 V
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 113B600D492300FC880F06EC921C00413000
   Shop #: WSC 01316 785 00200
   VCID: 74C93339D70A81BE8FF-8021
10 Faults Found:
                    Reset counter: 227
                    Date: 2056.12.11
                    Time: 00:04:06
                    Count: 1
                    Count: 243
                    Count: 256
                    Count: 89
                    Count: 4275
                    Count: 1
                    Count: 2275
                    Count: 1552
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                    Reset counter: 227
                    Mileage: 158595 km
                    Count: 7
                    Count: 4608
                    Count: 41
                    Count: 65280
                    Count: 63232
                    Reset counter: 227
                    Mileage: 657668 km
                    Date: 2002.00.01
                    Time: 00:20:13
                    Count: 769
                    Count: 22
                    Count: 47872
                    Count: 73
                    Count: 6144
                    Count: 24577
                    Count: 104
                    Count: 47906
00538 - Reference Voltage
                    Fault Status: 00101100
                    Fault Frequency: 22
                    Reset counter: 227
                    Mileage: 158583 km
                    Count: 7
                    Count: 12800
                    Count: 131
                    Count: 46117
                    Count: 65280
                    Reset counter: 227
                    Mileage: 158592 km
                    Count: 7
                    Count: 32768
                    Count: 4608
                    Count: 57
                    Count: 36728
                    Count: 64512
                    Reset counter: 227
                    Mileage: 158612 km
                    Count: 7
                    Count: 12800
                    Count: 4275
                    Count: 70
                    Count: 63232
                    Reset counter: 227
                    Mileage: 158595 km
                    Count: 7
                    Count: 4608
                    Count: 128
                    Count: 65280
                    Count: 63232
                    Reset counter: 227
                    Mileage: 158595 km
                    Count: 7
                    Count: 4608
                    Count: 4279
                    Count: 65280
                    Count: 63232
                    Fault Status: 00101110
                    Fault Frequency: 34
                    Reset counter: 187
                    Mileage: 157446 km
                    Count: 16391
                    Count: 12800
                    Count: 104
                    Count: 50451
                    Count: 64761
                    Count: 256
16352 - Control Module - Electrical Error
            014 - Defective
                    Fault Status: 01101110
                    Fault Frequency: 24
                    Reset counter: 187
                    Mileage: 158583 km
                    Count: 7
                    Count: 12800
                    Count: 96
                    Count: 46117
                    Count: 65280
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   VCID: 7CD91B193F5AC9FEC7F-8029
   Revision: 00H54000    Serial number: 00000008367702
   Coding: 178D8F214004150047140000001400000018770B5C000100000000000000
   Shop #: WSC 00000 785 00200
   VCID: 71C73A2D6818B496649-8024
   Component: Wischer 160508 021  0501
   Coding: 00038805
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0322839
   Coding: 0000000
   VCID: 334BF0255284C686565-8066
00003 - Control Module
                    Reset counter: 100
                    Mileage: 43712 km
                    Time: 18:02:25
                    Reset counter: 156
                    Mileage: 157356 km
                    Time: 03:24:17
01304 - Radio
                    Fault Frequency: 68
                    Reset counter: 227
                    Mileage: 158629 km
                    Time: 17:15:09
   Component: 6K AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0B8KSE
   Coding: 0013899
   Shop #: WSC 01269 785 00200
   VCID: 6CF92B594F3A597E57F-8039
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 6332MSME2905191DB
   Subsystem 3 - Serial number: 6342MSME290336779
   Subsystem 4 - Serial number: 6352QSME680C21118
   Subsystem 5 - Serial number: 6362QSME6838185BS
   Subsystem 6 - Serial number: 63727SME15574D3FD
   Subsystem 7 - Serial number: 63827SME15575C455
   Part No SW: 1K0 953 549 BP    HW: 1K0 953 549 BP
   Coding: 0002022
   VCID: 8127EAEDD8B82416149-80D4
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No SW: 1K6 920 974 H    HW: 1K6 920 974 H
   Component: KOMBIINSTRUMENT VDD 2416
   Revision: V0003000    Serial number: VWX7Z0H43NL82Z
   Coding: 0007204
   VCID: 3957C20D70E83CD69C9-806C
                    Reset counter: 227
                    Mileage: 158583 km
                    Time: 16:33:24
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 130508F2000908
   Coding: E9811F071013020000
   VCID: 354FCE3D5CF0D8B6781-8060
                    Fault Status: 00110100
                    Reset counter: 227
                    Mileage: 158583 km
                    Time: 16:33:25
01304 - Radio
                    Fault Frequency: 48
                    Reset counter: 227
                    Mileage: 157359 km
                    Time: 04:38:28
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1225223T3DL103
   VCID: FDDF961DA44040F6701-80A8
   Component: IMMO            VDD 2416
   Component: Tuer-SG         006 1207
   Coding: 0001077
   VCID: 3851C7094BE225DE637-806D
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
00625 - Vehicle Speed Signal
                    Mileage: 158570 km
                    Temperature: 11.0°C
                    Voltage: 14.30 V
                    Voltage: 14.10 V
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 139006885103281B0904058FB0080A04889C00
   VCID: 8429E3F9C7AA313E3FF-80D1
Address 47: Sound System        Labels: 3C0-035-456.lbl
   Part No SW: 1K6 035 456 B    HW: 1K6 035 456 B
   Component: 08K Audioverst.     0006
   Revision: 00004000    Serial number: 00000008147193
   VCID: 2B7BE8458AB49E461E5-807E
   Coding: 0001076
Address 55: Xenon Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: F4C9B339970A01BE0FF-80A1
   Coding: 0100101
                    Fault Status: 00111000
                    Reset counter: 227
                    Mileage: 158597 km
                    Time: 16:50:26
nickw698
C?ID=221721
I will be installing new module tonight and will post auto scan as soon as I get it installed.
Gone But Not Forgotten
Here are some tips.
Make sure same and correct part #
Same coding should be the result with a copy and paste if that is the case.
Don't shut off ignition at this point and I recommend it be done while engine is running.
Perform broadcast and erase DTC's...........see what's left on installed list for DTC's as a reference save.
Verify coding has been taken in ABS module by ending COM with it and then enter back into the controller showing it still displayed in 0x03-07 showing the coding.
In this case
If it does..........Immediately preform the adaptions in 0x44- basic settings after clearing DTC and login which is displayed in VCDS menus and wiki here.
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist
Then go back to ABS verify again that the Long string is not lost, clear DTC memory and preform all these tests and adaptions basic settings here.
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Brake_Electronics_(MK60)#Basic_Setting
When you have multiple faults like this and the ADP is out of bounds........if you turn off the key until all is preformed, the module will jump to all zeros.
nickw698
C?ID=221721
wow, seems like alot. This might be over my head. I will try to give it a shot though. I have the same part# that is listed in the auto scan but the last two letters AN. So the original part# is Part No SW: 1K0 907 379 AD and I bought a 1K0 907 379 AN. I just hoping its an updated unit or so.
Jef
HQ
When going with used parts and the part numbers DO NOT MATCH UP 100%....
Get the 1K0 907 379 AD.
nickw698
C?ID=221721
anybody know the difference between these two part #'s? The AN is the part # that came up when using my vin at the dealer.
Enriquez
Poland
C?ID=72075
if part # it's from Your dealer, then You should be fine with performing basic settings
Prepare to be patient - it's a lot of things to do, sometimes not easy, but it's possible to do. You should not to drive with non-adapted module, because the calibration of the sensors is for YOUR SAFETY.
Don't worry about engine is running or not, You can switch the ignition key as long You need. The ABS unit coding is zeroing, when You physically break the connection between ABS and instrument cluster, because inside the coding it is saved Your VIN No.
Oh boy..............Get the correct part #.
Will it work maybe....most likely it will.
Losing communication for the cluster is not the only reason a module will reset coding to zero, when first being coded.
If the adaption sequence isn't completed the coding will vacate to zero just as if the cluster was removed after the next key cycle.
I have verified this.............
nickw698
C?ID=221721
I just verified with VW that the AD part # has not been made since 2009. AN is the new updated part #. So here is my plan of action. Please tell anything else I should add.
1. Swap modules and manually bleed brakes.
2. Connect to ECU and clear codes.
3. Activate/bleed ABS pump.
4. Manually bleed brakes again.
5. Copy and paste this old module coding to new module 113B600D492300FC880F06EC921C00413000
6. Perform the adaption and basic settings.
Yes and no maybe........
That part # is different and requires I believe one of these codings for that VIN #
114b600d092300fc880f06ec901c00413000
113b600d092300fc880f06ec901c00413000
Try the old coding just to see if it will take it.
nickw698
C?ID=221721
OK. I will try that code first Jack
Enriquez
Poland
C?ID=72075
Jack, I can see - this is academic discussion with you. I've verified it as well, during more than 10 swaps od ABS controllers, so maybe we have different experience, but the difference between You and me is that You have no luck.
Well that is absolutely true ..............My luck is not so good.
Depends on what else is going on in the car........
Recently it was about a fire in the car..........Customer installed used cluster and key, then had dealer program an incorrect VIN into the Immobilizer block of ecu with the used cluster.
They failed inspection.............for wrong VIN.
Wrong VIN was coded to ABS by dealer.
I had to sort through the paper trail, and reprogrammed everything, because dealer then stated all parts must be changed in the car for new identity......... is what they call it.
Pretty lame and expensive....... I saved that customer a heap of money.
The coding of ABS was and would not stick until all the adaptions were completed, then a key cycle.
I forced it to zero and duplicated many times just to see.
Really this was done to stop swapping used parts by the OEM and no other reason.
My 2009 TDI actually would display a DTC within engine controller that would cause it to fail SMOG if the ABS coding went to zero.
Funny how an SGO flash update was done to the controller to remove that DTC.........when I reported it to the EPA.
Enriquez
Poland
C?ID=72075
Heh, what to do. I'm unlucky today - but this is another story :)
nickw698
C?ID=221721
Quick question guys. I got the module in and brakes bleed. I connected to abs module and it showed all zeros for coding. I put in the original coding from original module and it took it. I can disconnect from car and reconnect and the code is still in there. Now my question. How do you know it is the right code or if it will stay? The fact that the module accepted code is my answer im hoping. Im getting ready to do the adaptation and basic settings in a little while
The only way would be to match the PR codes and build data from vehicle manually or using the SVM system that VW-AUDI uses at the dealer.
Jef
HQ
As best I know, the ABS coding for a given car should not change when the correct replacement part is installed. If the coding is wrong, one would expect a 01042 - Control Module; Not Coded or something to that effect to be flagged. Thus, so far, so good.
I have to disagree...........some controllers will code incorrect attributes and not display a DTC.
The fact remains that an incorrect module or correct module with incorrect settings for sizes of wheels/brakes can in fact be coded wrong for any of the cars in addition to other stupid options.
To know for sure is to verify it.......
To just base it on a prior aforementioned part # and old coding is not advised because the config could be different and that includes old scans.
What if someone tampered it?
I have been experimenting with them for a while and seeing what data it will allow for writes to an off road unit.
My goal is to write Off road VIN configs for upgraded brake sizes, and race controllers, matched to the systems which still need to see a specific chassis or data string from the VIN......... being intertwined with a checksum/byte swap etc...
So far if you know how to calculate the VIN and the option which is selectable as a table stored in the controller......... it seems to take it.
That doesn't mean it is correct!
