SEAT LEON 5F P1647 ENGINE FAULT
Bartekseat
Poland
C?ID=353371
Hello, welcome everyone.
I have a problem with my Seat module gateway has completely stopped working. I bought the gateway by suggesting the old numbers. I was on the SEAT ASO service, the service of blocking the component and on-line coding. An error P1647 has appeared in the ECU controller. The indicator lamp flashes on the counter and the ACC cruise control and the Mode button of the variable driving modes do not work.
There is a mistake in the electronics of information systems - the software driver is incompatible (B200087), but it is from the beginning since I have a car and it does not bother me at all.
Please help.
Monday,14,January,2019,20:44:10:11523
VCDS Version: 18.9.0.4  HEX-V2 CB: 0.4437.4
Data version: 20181017 DS296.0
VIN: VSSZZZ5FZER035938   License Plate: ANG
Mileage: 81044km-50358mi   Repair Order:
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: VSSZZZ5FZER035938   Mileage: 81044km-50358miles
Address 01: Engine (J623-CKFC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 8127
   Revision: 83H22---
   Coding: 011D0012032401090000
   Shop #: WSC 99999 123 12345
   ASAM Dataset: EV_ECM20TDI01104L906021DT 002008
   ROD: EV_ECM20TDI01104L906021DT_002.rod
   VCID: 7AADF0D78C5D89E7D0F-802E
5188 - Diesel Particle Filter
          P2463 00 [167] - Excessive Soot Accumulation
                    Mileage: 81044 km
                    Date: 2019.01.13
                    Time: 21:09:48
                    Engine speed: 0.00 /min
                    Coolant temperature: 21 °C
                    Intake air temperature: 15 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 11.940 V
                    Counter for regeneration time of diesel particle filter: 0.00 s
                    Particle filter: kilometers since last regeneration: 1421951 m
                    Particle filter: soot mass measured: -1.08 g
                    Particle filter: soot mass calculated: 46.65 g
                    Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: -3 hPa
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
          [Checking coding/versions ofcontrol modules in drivetrain]
                    Mileage: 81044 km
                    Date: 2019.01.13
                    Time: 21:09:49
                    Voltage terminal 30: 11.920 V
                    ACC variants-Bits 0-7: 0
                    CCS Switch-Bits 0-7: 1
                    Cruise control switch actuation-Bits 0-7: 32
                    Cruise control switch actuation-Bits 0-7: 0
                    ACC variants (coding)-Bits 0-7: 1
                    Acceleration: 0.000 m/s˛
   Part No SW: 0D9 300 040 K    HW: 02E 927 770 AN
   Component: DQ250-6F MQB  H52 4028
   Revision: 05652104    Serial number: TFK01307232314
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1F1BE143773F0CCF871-804A
   Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
   Component: EMB8 EHCB     H31 0356
   Revision: 00000000    Serial number: 62413000000264
   Coding: 20EE6292242309710080060341CB240446249000608224F200610070C002
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033.rod
   VCID: 4BC365139347C06F3B9-801E
   Part No SW: 5F0 907 044 D    HW: 5F0 907 044 D
   Component: Climatronic   H03 0705
   Revision: 00001K07
   Coding: 04000104200100011005000000101000
   Shop #: WSC 00049 770 00103
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   VCID: 270BF9A32F6FC40FFF1-8072
   Air quality sensor:
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011324301578
   Coding: 08101A42424102FB4BE44000400403681000000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 77ABE9E3BF4F948FAF1-8022
   Subsystem 1 - Part No SW: 5F1 955 119     HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130808  041 0574
   Serial number:         130817061928
   Coding: 0BC5FD
   Component: RLHS  037 0059
   Serial number: S3Y15M11D27H22M24S44
   Coding: 028877
   Sun Roof:
   Subsystem 3 - Part No SW: 6R0 959 591 B    HW: 6R0 959 591 B
   Component: J245 PS72.023  H02 0007
   Serial number:     WOO2344112Y
   Coding: 180102
   Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H02 0033
   Revision: --------    Serial number: 94231324200602
   Coding: 0031051051
   Shop #: WSC 53054 002 104857
   ASAM Dataset: EV_EPHVA18AU3700000 002019
   VCID: 3B2335D3C3E770EF8B9-806E
   Part No SW: 3Q0 959 655 AB    HW: 3Q0 959 655 AB
   Component: Airbag VW20   011 0189
   Revision: --------    Serial number: 003P3P3PEVQQ
   Coding: 98FCC000000000005C0000CC000800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7EA5FCC79075A5C7EC7-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 109 13
   Serial number: 3576U000000B036D6D0H
   Subsystem 2 - Part No SW: -----------    HW: 454 000 509 13
   Serial number: 3586U0000004BC788D0T
   Subsystem 3 - Part No SW: -----------    HW: 454 802 708 13
   Serial number: 3516RDA05C001000000/
   Subsystem 4 - Part No SW: -----------    HW: 454 803 108 13
   Serial number: 3526RDF61E301000000A
   Subsystem 5 - Part No SW: -----------    HW: 454 802 307 13
   Serial number: 3556V0B4D9901000000B
   Part No SW: 5Q0 953 507 AG    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 25031308490108
   Coding: 1400
   Shop #: WSC 37362 001 104857
   ROD: EV_SMLSKLOMQB_012_AU37.rod
   VCID: 7BA3F5D38367B0EFCB9-802E
   Part No SW: 5F0 920 871 A    HW: 5F0 920 871 A
   Component: KOMBI         303 2210
   Coding: 07A402082980000800086A00000000
   Shop #: WSC 00049 770 00106
   ROD: EV_DashBoardVDDMQBAB_008_VW26.rod
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2147
   Revision: --------    Serial number: 02021810802953
   Coding: 030100F40F0873005F000000040F00010001000100000000000000000000
   ASAM Dataset: EV_GatewConti 009011
   ROD: EV_GatewConti_009.rod
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Component: E221__MFL-PR6  H03 0120
   Serial number: 000000000A0467060813
   Coding: 002000
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004051939326
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Component: TSG FS        007 0006
   Serial number: 0000072035266
   Coding: 00100320D000020000001000
   VCID: 025D8837E48DC12788F-8056
   Serial number: 00000000000001937865
   Coding: 110000
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
   Component: EPS_MQB_ZFLS  127 1021
   Coding: 81
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D273BCBDDF37EDFB5D-8068
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0000059157342
   VCID: 015F873BE18BDA3F915-8054
   Serial number: 00000000000001966797
   Coding: 090000
   Coding: 048A000009000000
   VCID: 75B7E3EBA543E69FBDD-8020
   Part No SW: 5F0 035 846 A    HW: 5F0 035 846 A
   Component: MU-S-N-ER     040 0421
   Serial number: E1F00509130571
   Coding: 04730001D70A000021110001000800002F0101040100010046
   ASAM Dataset: EV_MUStd6C1PASE 002030
   ROD: EV_MUStd6C1PASE.rod
   VCID: 2615F4A72865DD07C47-8072
   Subsystem 1 - Part No SW: 5F0 919 603 A    HW: 5F0 919 603 A
   Component: ABTmin_Std_Nv  H51 0022
   Serial number: SEZ8Z9NL400U8H
   Subsystem 2 - Part No SW: 5F0 919 866 E    HW: -----------
   Component:  ECE 2013/14  --- 0034
          B2000 87 [009] - Missing message
                    Reset counter: 2
                    Mileage: 81044 km
                    Date: 2019.01.13
                    Time: 21:09:49
                    Voltage terminal 30: 11.7 V
End----------(Elapsed Time: 01:15, VBatt start/end: 11.9V/12.0V)-----------
golfi_vend
Tartu, Estonia
C?ID=195131
Yet again has service failed to make Can-GW programming fully. They haven't restored FEC in Can-GW.
Bartekseat
Poland
C?ID=353371
hello. so ago I decided to buy a new gateway in the website after coding online again the same.
Bartekseat
Poland
C?ID=353371
how can you restore the FEC in the gateway to get it right. what coding is about
darkchina811
ITALY
C?ID=333184
feel your pain buddy, took me a while to find somebody with the knowledge to fix mine...
Bartekseat
Poland
C?ID=353371
Hello, I have been to 3 seat dealers with 3 gateway modules. I bought the same engine driver. they have been coding the whole car and individual drivers many times. all transmitted coding caused the same error or even more errors such as lack of radar and camera in the front bumper which was never in the car. I am already sitting on it for 6 months. I noticed one reason if it mounts a gateway from another car, everything is ok. after unlocking the component lock and coding the online service aso error p1647 is back.
Bartekseat
Poland
C?ID=353371
recently I bought a new gateway on the site and download the coding on the line but I went back to the old one because there were errors in the gate here coding 000000f0000058000f000000000f00000001000000000000000000000000
South Molton, UK
As already said after correcting the coding the dealer (or someone with ODIS) MUST then reenable all the FEC codes to reenable some optional features - just getting the coding right is NOT enough.
Continuing to change gateway modules and setting only coding will not solve your problem...
golfi_vend
Tartu, Estonia
C?ID=195131
Or removing CP. CP can be only in 1 module. I think it will work with 2 matched GW-s, but it will have signature error when trying to restore FEC, before making CP again. At least this is what i saw in one AUDI.
Dealer needs to use Guided Function to replace Can-GW, if technician isn't able to to 2 extra clicks from Special Feature menu.
Bartekseat
Poland
C?ID=353371
lonu seat.napisze o postepach pozdrawiam
bardzo wam dziekuje za podpowiedzi.oraz uwe za pomoc w rejstracji na waszym forum. skontaktuje sie z kolega ktory ma odis online.jesli sie nie uda bede dzwonil do salonu seat.napisze o postepach pozdrawiam
thank you very much for hints. I am thankful for your help in registering on your forum. I will contact a friend who has odis online. if I fail I will call the salon seat. I will write about the progress greetings
Iffykhan
TBD
Hi,
@ Bartekseat - did you manage to resolve the problem? My Leon which I have recently purchased is behaving exactly in the same manner. CCS and Mode drive ability not working
Logs showing P1647 error. What was the fix?
darkchina811
ITALY
C?ID=333184
Hi,
it's already been answered. go to a dealer and have FeC codes restored to gateway. if they don't know what we're talking about, you need to find somebody who does.
Iffykhan
TBD
Thanks dude
