Greetings, I just joined and this is my first post.
I bought my first Audi a few months ago. It is a 2006 A6 Avant (C6 platform). I've purchased a VCDS License and Interface and am still figuring out how to use it. I'll paste in an Auto-Scan at the bottom is this message.
This is my problem.
I updated the software for the MMI system to version 4610. I followed TSB 2019334/2. I was able to restore "seat position memory via key" (07- Display> Adaptation Channel 1> old value was 5402, added up all options and got value of 5434, used that value and it worked). I restored the Instrument Cluster menu item in CAR Menu (TSB 2020250). And I restored Battery charge status in the CAR Menu via the MMI Hidden Menu.
I later realized that the climate control via MMI was not working. It used to be that if you touched a button on the climate control unit like fan, the display showed a big dial and the MMI knob could be used to make adjustments. I found that safer while driving than using the climate control unit. TSB 2017424/3 seems to cover that problem but the solution described is to "perform guided fault finding / guided function" and run "J523 Front Info Display Ctrl. Head, adaptation (RG.91)." I could not figure out how to do that in VCDS. Is that something that one can do in VCDS??
I went hunting in the MMI hidden menu and under Diag Settings > APK 0x01, 0x0B, 0x0C I found an unchecked item called "Air Condition." I checked that item. Now when you push a button on the climate control unit, a visual image appears on the Display but you still can only make changes on the climate control unit. I don’t think the display is the same as it was with MMI control.
I next checked 07-Display > Adaptation Channel 11 and noted that the current value is 52. From the list of values in the VCDS pop-up window it appears that "32 Climate Control Comfort installed" is selected (I'm guessing that, if one can only get to 52 by including a 32, then it is selected).
Anyone have any suggestions?
Thanks!
Bruce Newton PS - Should I worry about the DTC’s in 61- Battery Regulator?
This is my problem.
Thanks!
Tuesday,18,November,2014,11:31:28:33848
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: WAUKH74F26N100067 License Plate:
Mileage: 133920km-83214mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 65 67 6D 72 76 77
VIN: WAUKH74F26N100067 Mileage: 133920km-83214miles
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F1 910 559 E HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0050
Revision: --H15--- Serial number:
Coding: 010D0109190F0120
Shop #: WSC 02325 785 00200
VCID: 2D5129D9B4950649F4D-8078
Part No SW: 4F2 910 156 D HW: 09L 927 156 A
Component: AG6 09L 3,2 FSI USA 0010
Revision: --H01--- Serial number: 4100727
Coding: 0000002
VCID: 2643D6F591633511357-8073
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H04 0090
Coding: 0020895
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0180
Revision: 30070501 Serial number: 10600700269927
Coding: 0000143
Shop #: WSC 23190 444 53268
VCID: 63C58FE1A2D18039129-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0070
Component: FBSAUDIC6 KSG H27 0080
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 732 Q HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 303JV057509926
Coding: 0001003
Shop #: WSC 02323 785 00200
VCID: 316935A9A8AD62A9D05-8064
Component: Bedienteil MMIC6H08 0050
Subsystem 2 - Serial number: 00000000257377
Subsystem 3 - Serial number: 0119.10.050000000100010405ÿ
Subsystem 4 - Serial number: 010405ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 S
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000030065182
Coding: 0524582
VCID: 5BB5B7019AA1B8F95A9-800E
Part No SW: 4F0 910 279 D HW: 4F0 907 279
Component: ILM Fahrer H15 0190
Coding: 0014123
Shop #: WSC 02335 785 00200
VCID: 2A5B22C5857B117111F-807F
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7254024
VCID: 1C37F41DDF2FFFC1933-8049
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7E1017516
VCID: 285FD8CD9B77236107B-807D
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 66 AIRBAG AUDI8RH29 0300
Revision: 12H29000 Serial number: 00359D0A65GO
Coding: 0013878
Shop #: WSC 23190 444 61386
Subsystem 1 - Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Subsystem 2 - Serial number: 6332CSME0C7E1F50F
Subsystem 3 - Serial number: 6342CSME0C7E1F36K
Subsystem 4 - Serial number: 6352QSME024C26159
Subsystem 5 - Serial number: 6362QSME0243344B9
Subsystem 6 - Serial number: 63734SME06662D61+
Subsystem 7 - Serial number: 63834SME06161C77%
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90025052870543
Coding: 0002042
VCID: 66C396F551E3F511F57-8033
Component: Lenkradmodul H07 0080
Part No SW: 4F0 910 930 A HW: 4F0 920 980 N
Component: KOMBIINSTR. M73 H16 0630
Revision: 00200000 Serial number: 4PY390LA5
Coding: 2129263
Shop #: WSC 46471 000 1048576
VCID: 2149C5E9F84DD229405-8074
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 1300805A218307
Coding: ECFE73CD1B7906
VCID: 275DDBF196692C190E1-8072
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
Shop #: WSC 02334 785 00200
VCID: 61C985E9B8CD9229005-8034
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H45 1100
Revision: 00000000 Serial number: 355J3057555969
VCID: 387F088D4BD7B3E197B-806D
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0080
Revision: 00-00000
Coding: 0052971
Shop #: WSC 02327 785 00200
VCID: 2C5724DD8F8F0F41E33-8079
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 B HW: 4F0 907 289 B
Component: Komfortgeraet H18 0130
Revision: 01300018 Serial number: 01007799940000
Coding: 7764541
VCID: 2959DDC9807D1A69185-807C
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H09 0240
Revision: PROD_01 Serial number: 00000000701842
Coding: 0000156
Shop #: WSC 23190 444 84591
VCID: 2541D1F9EC653E093CD-8070
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000009266
Coding: 0002114
VCID: 5EB3BE1589B3ADD13D7-800B
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0080
Revision: 00-00000
Coding: 0052971
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
VCID: 5DB1B91984B5B6C924D-8008
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0030
Coding: 0000016
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Part No SW: 4E0 910 541 T HW: 4E0 035 541 T
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394J%057629654
Coding: 0000002
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000140163
Shop #: WSC 23190 444 53531
VCID: 2345CFE1E251C039529-8076
Subsystem 1 - Part No: 4F0 915 105 E
Component: von VA0 0386995264
Coding: 344630393135313035452056413030333836393935323634
Shop #: WSC 23190 444 185023
02272 - Quiescent Current Stage 1
Mileage: 132983 km
Date: 2014.10.14
Time: 15:27:48
02273 - Quiescent Current Stage 2
Mileage: 133426 km
Date: 2014.10.30
Time: 09:55:25
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0052778
VCID: 2E532ED5B9937D51CD7-807B
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 HW: 4F0 907 273
Component: Reifendruck 3 H04 0080
Revision: 00040080 Serial number: 00000700011902
Coding: 0062221
VCID: 60CF80EDB3C79B210FB-8035
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000510120087
Shop #: WSC 12336 024 394758
VCID: 34673CBD57BF5781BB3-8061
Address 6D: Trunk Elect. Labels: Redir Fail!
Part No SW: 4F9 910 591 HW: 4F9 827 851 B
Component: ValeoHeckdeckel H18 0280
Revision: --H18001 Serial number: E5030000B
Shop #: WSC 23250 431 715754
VCID: 6CD7E4DD4F0FCF41A33-8039
Subsystem 1 - Part No: 4F9 910 592
Component: ValeoHeckdeckel H25 0290
Subsystem 3 - Serial number: RD18.12.13--H25001001B0031ÿ
Subsystem 4 - Serial number: 1B0031ÿ
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0052778
Part No SW: 4F0 910 283 B HW: 4F0 919 283 B
Component: Parkhilfe 4-Kan H09 0030
Revision: 00H09000 Serial number: 11720528704177
Coding: 0001216
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H11 1130
Revision: 00000000 Serial number: 00000007520835
Coding: 0010900
End-------------------------(Elapsed Time: 03:42)--------------------------
