Greetings to all! Not new to VAG, but new to hex-net and still learning how to use it. This is a scan off a 2005 A6 3.2 saloon.
Cleared faults on 1-6-2019 with a OBD11, which explains that date. Can read what I found and think, or skip to scan.
07: 01964 - Control Module for Seat & Steering Column Memory (J136)
Memory in drivers seat 1, 2 work. Not sure what steering column means, it's manual to adjust.
08: 00256 - A/C Pressure/Temperature Sensor (G395)
Low on freon I would assume? Can it be checked by vcds?
09: Address 0F: Digital Radio Cannot be reached
Is this the tuner/radio? It works fine.
15: 2 Faults Found:
01221 - Crash Sensor Side Airbag; Driver Side (G179)
007 - Short to Ground - Intermittent - MIL ON
008 - Implausible Signal - Intermittent - MIL ON
I've come to the conclusion that this is most likely a broken wire between the body and door? This error started last couple of weeks.
19: 2 Faults Found: 01044 - Control Module Incorrectly Coded
02230 - Digital Radio (DAB) (R147) 004 - No Signal/Communication
I'm lost on this one, for real.
61: 4 Faults Found 02273, 02274, 02276, 02277
This was a new battery installed prior to me getting the car. Don't think it was ever adapted to the car by seller, but the problem I'm having is slow battery drain.
The MMI Car version is
SW: C6-HU 6360 10.7.0 0437
HW: c6-HU 6360D2.0
FC SW: 041144AFC6AB320010
FC PS:0010 FC HW: h07
3.2 had the following work done to it past summer before seller/friend (who did the work due to failed tensioner) sold it to me for a tenth of what they were new. New exhaust, intake valves, machined and cleaned cylinder heads, head gasket kit, head bolts, timing kit, camshaft adjusters, camshaft oil control actuators, O.E. spark plugs, ignition coils, rear main seal. Don't know if this info pertains to the faults, but added it just in case. Friend does not have a vcds, but rather a snap-on verus european software.
So that's where I stand. Sorry for the long rant, and thanks for taking the time to read this. Any help or direction would be appreciated. I wrench on my all machines, so not afraid to tackle a task.
15: 2 Faults Found:
HW: c6-HU 6360D2.0
Sunday,13,January,2019,16:03:09:45417
VCDS Version: 18.9.0.4 (x64) HEX-NET CB: 0.4437.4
Data version: 20181017 DS296.0
VIN: WAUDG74F35N094886 License Plate:
Mileage: 182750km-113555mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 72 77
VIN: WAUDG74F35N094886 Mileage: 182750km-113555miles
0F-Digital Radio -- Status: Cannot be reached 1100
37-Navigation -- Status: Not registered 0001
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F1 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0050
Revision: --H15--- Serial number:
Coding: 01050106190F0120
Shop #: WSC 02325 785 00200
VCID: 2A1805CE854E401AA5-807E
Part No SW: 4F1 910 156 H HW: 09L 927 156
Component: AG6 09L 3.2 FSI USA 0020
Revision: --H01--- Serial number: 0092061
Coding: 0000002
Shop #: WSC 02327 785 00200
VCID: 291AFAC280484B02AC-807C
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Coding: 0020895
VCID: 2D120ED2B4A0572240-8078
Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
Component: FBSAUDIC6 ELV H05 0130
Revision: 00H05000 Serial number: 10602901714383
Coding: 0000011
Shop #: WSC 06158 444 105036
VCID: 2502F6F2EC506F6288-8070
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H43 0070
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H36 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 730 E HW: 4E0 035 729
Component: Interfacebox H43 1070
Revision: 00000000 Serial number: 360AB057515420
Coding: 0000003
Shop #: WSC 12345 111 45725
VCID: 2306E8EAE2649152E6-8076
Subsystem 1 - Part No: 4F0 910 609 B
Component: Bedienteil MMIC6H07 0010
Subsystem 2 - Serial number: 00000000099393
Subsystem 3 - Serial number: 0119.01.050000000100010155ÿ
Subsystem 4 - Serial number: 010155ÿ
Reset counter: 84
Mileage: 182611 km
Date: 2019.01.06
Time: 12:02:34
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 J
Component: KLIMABETAETIGUNGH11 0150
Revision: 00000025 Serial number: 00000000106531
Coding: 0524326
VCID: 5BF6900A9A94E992EE-800E
Reset counter: 79
Mileage: 182620 km
Date: 2019.01.06
Time: 14:05:27
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Coding: 0013123
Shop #: WSC 02335 785 00200
VCID: 6680B1FE51D6A47A41-8032
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBD7107320
VCID: 1B76D00ADA14A9922E-804E
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 B HW: 4F0 959 655 A
Component: 56 AIRBAG AUDI8RH29 0310
Revision: 10H29000 Serial number: 00359D086M3Q
Coding: 0013622
Shop #: WSC 06158 444 83892
VCID: 2600F1FE9156647A81-8072
Subsystem 1 - Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
Subsystem 2 - Serial number: 633 SME
Subsystem 3 - Serial number: 6342CSME077646091
Subsystem 4 - Serial number: 6351HSME057B1775A
Subsystem 5 - Serial number: 6361HSME0623740E4
Subsystem 6 - Serial number: 6371VSME05761A11E
Subsystem 7 - Serial number: 6381VSME060301284
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026050150270
Coding: 0002041
Shop #: WSC 02323 785 00200
Component: Lenkradmodul H06 0080
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H10 0570
Revision: 00200000 Serial number: 4R814WJ15
Coding: 2113203
VCID: 1E70D91EC906BCBAC9-804A
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 08008051230175
Coding: 6CFE73CC1B1904
Shop #: WSC 11111 123 12345
VCID: 271EFCFA965C7D72BA-8072
Reset counter: 34
Mileage: 182587 km
Date: 2019.01.05
Time: 15:17:50
Reset counter: 34
Mileage: 182587 km
Date: 2019.01.05
Time: 15:18:45
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082946
VCID: 618AA2E2B8F8C342B4-8034
Part No SW: 4E0 910 888 F HW: 4E0 919 887 M
Component: MNS US H51 0990
Revision: 00000000 Serial number: 395AU087508408
VCID: 312A12A2A89833C264-8064
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H11 0040
Revision: 00-00000
Coding: 0035563
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H15 0100
Revision: 01000015 Serial number: 01002508770000
Coding: 0423997
VCID: 2C1403D68FBA5E2A57-8078
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F5 910 223 D HW: 4F5 035 223 E
Component: DSP-High C6 H14 0310
Revision: PROD_01 Serial number: 00000000021668
Coding: 0000016
VCID: 2404EBF6E76A966A9F-8070
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000059538
Coding: 0001114
VCID: 5EF0991E8986FCBA89-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H11 0040
Revision: 00-00000
Coding: 0035563
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
Shop #: WSC 02334 785 00200
VCID: 5DF29E128480E7A290-8008
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Coding: 0000016
Subsystem 1 - Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Subsystem 2 - Part No: 4F0 941 329 A
Component: AFS-Modul rechtsH05 0010
Part No SW: 4E0 910 541 F HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 394AO057512627
Coding: 0000002
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0470
Revision: 00000000 Serial number: 00000000008308
Shop #: WSC 06158 444 58780
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 2501260391
Coding: 344630393135313035432056413032353031323630333931
Shop #: WSC 00000 384 00290
02273 - Quiescent Current Stage 2
Fault Frequency: 11
Mileage: 182611 km
Date: 2019.01.06
Time: 05:29:50
02276 - Quiescent Current Stage 5
Mileage: 182611 km
Date: 2019.01.06
Time: 05:30:01
02274 - Quiescent Current Stage 3
Mileage: 182611 km
Date: 2019.01.06
Time: 05:30:11
02277 - Quiescent Current Stage 6
Mileage: 182611 km
Date: 2019.01.06
Time: 05:30:21
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H09 0010
Coding: 0035370
VCID: 699ABAC240C88B026C-803C
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H09 0010
Coding: 0035370
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 A HW: 4E0 862 335
Component: Handyvorb2 H10 0120
Revision: 00000000 Serial number: 00000007513912
Coding: 0010900
Shop #: WSC 02313 785 00200
VCID: 210AE2E2F8788342F4-8074
End----------(Elapsed Time: 01:46, VBatt start/end: 14.1V/14.1V)-----------
