Mmi shut down by battery energy management
   #41
The battery definitely shuts things down as it loses power, but if those things are functioning properly, they come back up with the battery manager decided the battery has sufficient power again.
Deeski
C?ID=218821
Hi Jack, just registered to this(Erwin) but all documents seem to be in deutsch!!
   #43
Deeski
C?ID=218821
How long does the battery take to do this or is this a silly question?
   #45
jakematic
NC USA
C?ID=129085
That's interesting jakematic, you definitely know your stuff. The optical loop should be delivered tomorrow hopefully. Sorry, when I said nothing wrong with the amp, I meant fuse. I feel like a right idiot, I'm learning something new on every post
I'm practically the lone VCDS diagnostician on AudiWorld so have seen a few things here and there ;)
Every day we learn something is not a wasted day....
Did you happen to have any water incursion in the boot ?
Have seen Q5/7 amps and some convertibles fail due to that.
07, 47 and 77 are an all or nothing proposition in my experience.
   #46
Deeski
C?ID=218821
Jack, got it now, had to go into setting to amend to UK. Am I correct in saying you have to purchase a flat rate and then you can print documents, is it possible to save them to you PC as PDF rather than print. I'm guessing this will save time and allow you to get more for your money?
   #47
Deeski
C?ID=218821
Not that I know of, other than the sound issues previously, everything was working fine until the dead battery?
   #48
jakematic
NC USA
C?ID=129085
Yes. Right click on them in the list and click 'save as'.
I'd get every one from all categories for your vehicle (and any other Audi you own) as long as you are in there...
Good to know on the settings - been hearing about that issue a lot lately but didn't know the resolution.
   #49
Deeski
C?ID=218821
How long do you think it will take to save them all? Just winding which flat rate to purchase
   #50
jakematic
NC USA
C?ID=129085
Mine for the D4 total 535.3 MB for 71 files to give you an idea.
   #51
Deeski
C?ID=218821
Hi guys, very interesting update. All by itself, the mmi has turned itself back on, I am assuming it is the battery manager that has decided that the battery is fully restored. I'm so happy. Now I am left with the no sound issue that I had initially and a different fault code has come up that was not there before. I will post the new codes and optical result
   #52
Deeski
C?ID=218821
Wednesday,19,November,2014,13:03:41:61853
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: WAUZZZ8T08A045085   License Plate:
Mileage: 169030km-105030mi   Repair Order:
Chassis Type: 8T (8T0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 42 46
          47 52 53 55 56 57 77
VIN: WAUZZZ8T08A045085   Mileage: 169030km-105030miles
Address 01: Engine (J623-CAUA)       Labels: 079-907-560-CAU.clb
   Part No SW: 8T0 907 560 C    HW: 8T0 907 560
   Component: 4.2l V8/4V    H10 0002
   Revision: 76H10---
   Coding: 01140003190F0120
   Shop #: WSC 06325 000 00000
   VCID: 3A7B287BB5AE04F161F-806F
001431 - Thermostat for Mapped Engine Cooling (F265)
               P0597 - 004 - Open Circuit - Intermittent
                    Mileage: 168963 km
                    Date: 2008.02.22
                    Time: 21:06:43
                    RPM: 437 /min
                    Load: 69.8 %
                    Temperature: 10.0°C
                    Temperature: 11.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 10.922 V
049489 - No Communications with Airbag Control Module
               U0151 - 008 -  - Intermittent
                    Mileage: 169004 km
                    Date: 2008.02.23
                    Time: 08:54:27
                    Temperature: 87.0°C
                    Temperature: 72.0°C
                    Voltage: 12.192 V
Readiness: 0010 1000
Address 02: Auto Trans (J217)       Labels: 0B6-927-156.clb
   Part No SW: 8K0 927 158 B    HW: 0B6 927 156
   Component: 0B6 42 FSIRdW H04 0030
   Revision: --H04---
   Coding: 001001
   ASAM Dataset: EV_TCMAL651 A01001
   ROD: EV_TCMAL651.rod
   VCID: 35613B4794B0EB898CD-8060
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
   Part No SW: 8K0 907 379 S    HW: 8K0 907 379 S
   Component: ESP8 quattro  H04 0210
   Coding: 124500
   VCID: 499947B7E0489F69F85-801C
   Part No SW: 8K0 907 064 AD    HW: 8K0 907 064 AD
   Component: BCM2 1.1      H71 0134
   Coding: 051000
   VCID: 72EBC05BAD5EBCB169F-8027
   Component: ELVAUDIB8  H35 0039
Address 06: Seat Mem. Pass (J521)       Labels: 8T0-959-760.clb
   Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
   Component: MEM-BFS       H09 0043
   Revision: AA000000    Serial number: 00001001086864
   Coding: 00217025002C44440000
   VCID: 428B509BDD7E4C3139F-8017
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 P    HW: 4E0 035 729 A
   Component: Interfacebox    H43 5170
   Revision: 00000000    Serial number: 331DP087523647
   Coding: 0025002
   VCID: 46834C8B31567011157-8013
   Subsystem 1 - Part No: 8T0 919 609 C
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000076567
   Subsystem 3 - Serial number: 0123.04.080000000100010025ÿ
   Subsystem 4 - Serial number: 010025ÿ
   Part No SW: 8T2 820 043 N    HW: 8T2 820 043 N
   Component: KLIMA 3 ZONEN H05 0120
   Revision: D1000000    Serial number: 0128.03.080237
   Coding: 48060000
   VCID: 3D712367A48033C944D-8068
   Component: BCM1 1.0      H21 0253
   Revision: 05021001    Serial number: 00000000034398
   Coding: 260050914014AF211709000300005D5D0F9D434800010141000000
   VCID: 306F0A5363D2CEA1DFB-8065
   Subsystem 1 - Part No SW: 8T2 955 119 C    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 090408  H11 0040
   Coding: 00FD11
   Component: RLS  H04 0003
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
03207 - Charisma Switch Module
                    Reset counter: 42
                    Mileage: 169035 km
                    Date: 2008.02.19
                    Time: 12:57:00
   Part No SW: 8T2 035 110 C    HW: 8T2 035 110 C
   Component: MP3-Changer     H42 0390
   Revision: 00042001    Serial number: AUZ5ZBH8387945
   VCID: 2B551D3F8AF4AD79EA9-807E
Address 0F: Digital Radio        Labels: None
   Part No SW: 4E0 910 563 C    HW: 4E0 035 563
   Component: DAB-Tuner       H41 0830
   Revision: 00000001    Serial number: KE1276V8200116
   Coding: 0000001
   VCID: 2447F603E72A62012B3-8071
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 B    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0010
   Revision: 11001001    Serial number: 75330812600965
   Coding: 000102
   VCID: 387F32738BA216E197B-806D
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD154CAW
   Coding: 30323433363030303030554A305238543053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 3C772E63B79A3AC1733-8069
   Serial number: 6334MSME381171363
   Serial number: 6344MSME31351531$
   Serial number: 6352QSME632E0D63O
   Serial number: 6362QSME66560B37M
   Serial number: 63732SME624C0B3D7
   Serial number: 63832SME662F2203-
   Component: Lenks.Modul   H12 0013
   Revision: --------    Serial number: 90315HE5000F2
   Coding: 000036
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8T0 920 981 C    HW: 8T0 920 981 C
   Component: KOMBIINSTR.   H28 0221
   Revision: 00000000    Serial number: 72026PR48
   Coding: 2F0F01000A002600010000
   VCID: 3C772E63BF9A3AC1733-8069
   Part No SW: 8T0 907 468 K    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0092
   Revision: EB302042    Serial number: 4200E084188217
   Coding: 000303
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H03 0150
                    Reset counter: 42
                    Mileage: 169035 km
                    Date: 2008.02.19
                    Time: 12:58:05
Address 1E: Media Player 2 (R199)       Labels: 4E0-035-785.lbl
   Part No SW: 4E0 035 785 D    HW: 4E0 035 785
   Component: SG ext.Player H15 0830
   Revision: 00000000
   VCID: 2959E7374008BF69185-807C
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Component: MEM-FS        H09 0043
   Revision: AA000000    Serial number: 00001001086403
   Coding: 00397B25002C44440000
   Part No SW: 4E0 910 888 E    HW: 4E0 919 887 M
   Component: MNS ECE         H51 1050
   Revision: 00000000    Serial number: 333ES087564354
   Shop #: WSC 00483 483 54238
   VCID: 306F0A53A3D2CEA1DFB-8065
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793     HW: 8K0 959 793
   Component: TSG FA        H09 0149
   Revision:             Serial number: –p
   Coding: 011C12225E012201
   VCID: 7DF1E367E400F3C904D-8028
   Revision: 00002001    Serial number: 0110741585
   Coding: 011B0E8200390481003000
Address 47: Sound System
   Part No SW: 8K0 959 792     HW: 8K0 959 792
   Component: TSG BF        H09 0149
   Revision:             Serial number: y
   VCID: 7CF7EE63FF1AFAC1333-8029
   Part No SW: 8K0 907 801 D    HW: 8K0 907 801 D
   Component: EPB Audi B8   H04 0050
   Revision: 00000003    Serial number: 10000000022044
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 A    HW: 8H0 907 357
   Coding: 0000017
   Shop #: WSC 06324 000 00000
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 336ER087557150
   Coding: 0000001
   VCID: 2E53142BB9E6D851CD7-807B
Address 57: TV Tuner        Labels: None
   Part No SW: 4E0 910 148 D    HW: 4E0 919 148
   Component: R78 TVHybridDVB     0440
   Revision: R0H06000    Serial number: 76300801492301
   Coding: 0000203
Address 77: Telephone        Labels: 4F1-910-336.lbl
   Part No SW: 4F1 910 336 C    HW: 4F1 862 335
   Component: BTA             H11 0960
   Revision: 00H11000    Serial number: 00000007572909
   Coding: 0010021
End-------------------------(Elapsed Time: 03:55)--------------------------
Deeski
C?ID=218821
So I am now attempting to diagnose what the issue is with the sound. I have carried out another optical test and results are different from before. Here are the results.
http://s9.postimg.org/sn63qo3pr/optical.jpg
I have now recieved my optical loop and have tried to use it in place of the amp and stuff. Could someone advise on what is supposed to happen when I plug it in place of something?
   #54
golfi_vend
Tartu, Estonia
C?ID=195131
It's supposed to close the circle if one device isn't able to carry optics.
To me it seems like your amp is bad, but i think it needs further investigation.
Deeski
C?ID=218821
I am confused as I thought that if I unplugged the optical cable out of say the radio as an example and replaced it with the optical loop test cable and carried out an optical test, if the radio was what caused a break, the results would mean that the optical test would show that it is ok. I may have made this sound confusing but could someone give me a step by step guide on how to test the amp?
   #56
B5NUT
C?ID=30047
You would get an optic error on the device you have it looped out, the loop cable is there to bypass a dead / faulty module. The fault on your MMI system is the dead AMP, it's not showing up in your VCDS scan and it's showing electric & optic error in your bus scan. Check the fuse for the AMP and see if you getting power at the harness, if you are getting power and then your AMP will most likely need replacing. You should be able to find a used one on ebay for a lot less than the dealer prices, but you will need to have component protection removed which can only be done at dealers or garages that have a licensed version of VAS.
Deeski
C?ID=218821
Thanks B5NUT for your reply, please excuse the fact that I am not very tech savy but a quick learner. I was previously advised to check the sound system module fuse which was in the right hand compartment of the boot and that was fine. Is this the same fuse for the amp or is it somewhere else?
   #58
golfi_vend
Tartu, Estonia
C?ID=195131
Sound system or the amp(lifier) is the same thing.
Deeski
C?ID=218821
Thanks golfi_vend. Can you advise of a good tool I can use to test the power to the harness? Would it be one of these electrical pen testers? If I am to buy one, I would like to get a recommended one than just a random device
   #60
golfi_vend
Tartu, Estonia
C?ID=195131
If you just want to test volatage to amp pins, multimeter does also work, or any pen light tester.
But for correct testing you would want to put a load on the wire to see the wire integrity.
