Hello Everyone and Happy New Year! Back on the board with my 2015 S3, the same one that had transmission issues that you guys helped me out with, and AOA ended up replacing under goodwill.
Now I have been having misfires for the last few months. Let me list the issues // problems in proper (or as close to) JPPSG:
1. 2015 Audi S3
2. Car is modified - Unitronic Stage 2 ECU Tune and Stage 2 DSG Tune as of 60,000 miles. Aftermarket catted downpipe with O2 Sensor still in place, and cold air intake.
3. Problems started around 73,000 miles. Here's the latest scan:
4. Once again the CEL went on and i ran a scan. I got the above misfire codes and a "small EVAP leak" code. So i changed the N80 valve, spark plugs and coil packs, all parts were OEM and stock to car (S3). Cleared the codes and was good to go for about 73,000 miles. The CEL went on again with misfire codes. This time i went with "upgraded" coils (RS3) and plugs (colder RS7), reset the code and was good to go for a few miles. Then AGAIN i got a CEL.
With my mileage i suspected carbon buildup. I went to a reputable car repair shop (not sure if i can post their name) and they ran a diagnostic. I DID not tell them i suspected carbon buildup so as to get a "transparent" diagnosis. They said the car needed a carbon cleaning and showed me photos of what appeared to be a bat cave (probe photos via intake manifold). I went ahead with the carbon cleaning and i noticed a MUCH smoother idle and acceleration. These guys also replaced the injector gasket and the intake manifold gasket as well as replaced the water pump (had a small leak and they gave me a GREAT deal on replacing it since they were in there already).
That was about 3,000 - 4,000 miles ago and here we are with MORE misfires. The above scan is the latest.
5. Here is what i am thinking about doing: flash car back to stock. Perform a smoke test and find the cause of the EVAP leak (need to buy a decent smoke machine that won't break the bank, opinions are welcome). I was thinking it might be the PCV also? Maybe replace that?
Thanks for any help!
1. 2015 Audi S3
Monday,07,January,2019,21:19:18:63824
VIN: WAUBFGFF3F1083628 License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 42 44 47 52 55 5F A9 BB
BC
VIN: WAUBFGFF3F1083628 Mileage: 124744km-77512miles
Address 01: Engine (J623-CYFB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 E HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 0A1D00122426000E3004
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208V0906259E 001002
ROD: EV_ECM20TFS0208V0906259E_AU37.rod
VCID: 42DE43C884004417C81-8016
15125 - Cylinder 1
P0301 00 [236] - Misfire Detected
Mileage: 123794 km
Date: 2018.12.18
Time: 05:55:44
Engine speed: 3125.50 /min
Normed load value: 16.9 %
Vehicle speed: 26 km/h
Coolant temperature: 43 °C
Intake air temperature: 25 °C
Voltage terminal 30: 13.789 V
Engine: operating status: PL
N_TOOTH: 3152 /min
T_AST_SAE: 33 s
Engine oil temperature: 22.0 °C
STATE_LS_SAE[1]: CL
FUP_H_SAE: 7970.0 kPa
FUP_EFP_MES: 11000.8 hPa
15131 - Cylinder 3
P0303 00 [236] - Misfire Detected
Mileage: 123794 km
Date: 2018.12.18
Time: 05:55:44
N_TOOTH: 3152 /min
T_AST_SAE: 33 s
STATE_LS_SAE[1]: CL
15134 - Cylinder 4
P0304 00 [236] - Misfire Detected
Mileage: 123794 km
Date: 2018.12.18
Time: 05:55:44
N_TOOTH: 3152 /min
T_AST_SAE: 33 s
STATE_LS_SAE[1]: CL
15128 - Cylinder 2
P0302 00 [100] - Misfire Detected
Mileage: 123794 km
Date: 2018.12.18
Time: 05:55:44
N_TOOTH: 3152 /min
T_AST_SAE: 33 s
STATE_LS_SAE[1]: CL
15137 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
Mileage: 123794 km
Date: 2018.12.18
Time: 05:55:44
Engine speed: 3017.75 /min
Normed load value: 15.3 %
Vehicle speed: 25 km/h
Coolant temperature: 42 °C
Intake air temperature: 26 °C
Voltage terminal 30: 13.652 V
N_TOOTH: 3021 /min
T_AST_SAE: 40 s
Engine oil temperature: 23.0 °C
STATE_LS_SAE[1]: CL
FUP_H_SAE: 7880.0 kPa
15271 - EVAP System
Readiness: 0010 0001
Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ
Component: DQ250-6A MQB H54 4521
Revision: 06354004 Serial number: TFK01609010381
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1F18EABC573249FF87F-804A
Part No SW: 3Q0 907 379 Q HW: 3Q0 907 379 F
Component: ESC H42 0610
Revision: 00000000 Serial number: 62944000003909
Coding: 31FF6B9254280A6F017D030241CB698CD62A5080C08296B6024100588208
VCID: 48CA51E0A23C6E47165-801C
Revision: 00021000 Serial number: 0352076171
Coding: 030C0C
VCID: 3A2E3B28ECD00CD7901-806E
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0060
Revision: 20027000 Serial number: 00000000487739
VCID: 3330160CCBBAFD9F537-8066
Serial number: EFF80A57000000000001
328964 - Motor for Front Air Distribution Flap
B1091 71 [008] - Actuator stuck
Reset counter: 31
Mileage: 123972 km
Date: 2018.12.19
Time: 19:34:06
Voltage terminal 30: 13.8 V
Interior temperature: 28.6 °C
Outside air temperature: 24 °C
Front air distribution flap: actual value: 0
Front air distribution flap: actual value: 95.5 %
Front air distribution flap: specified value: 92
328967 - Position Sensor for Front Air Distribution Flap Motor
B1099 15 [008] - Open or Short to Plus
Fault Frequency: 6
Reset counter: 57
Mileage: 122983 km
Date: 2018.12.09
Time: 09:58:26
Voltage terminal 30: 14.4 V
Interior temperature: 27.4 °C
Outside air temperature: 23.5 °C
Front air distribution flap: actual value: 768
Front air distribution flap: actual value: 0.0 %
Front air distribution flap: specified value: 934
Part No SW: 5Q0 937 085 AC HW: 5Q0 937 085 AC
Component: BCM MQBAB HNA H18 0137
Serial number: 01011430701262
Coding: 04151A46C04122F541C04004511807A00800000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 7AAEFB28AC50CCD7D01-802E
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 141009 042 0585
Serial number: 141108082028
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 23391689
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AD HW: 8V0 941 531 AD
Serial number: 10 09 2014 00001191
Serial number: 00000000000060929188
Sun Roof:
Component: J245 PS73.404 H02 0003
Serial number: 0000FST0000ZE5I00000
Coding: 101F00
Component: AirbagVW20 009 0825
Serial number: 003GCR00YML6
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 47C852DCAF22613F1FF-8012
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34178311B13111470353
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34178312B11111470450
Coding: 333135
Occupant Detection:
Serial number: 6940000Y1400018DCA0G
Coding: 303230
Subsystem 4 - Part No SW: ----------- HW: 480 000 611 14
Serial number: 357000000008AC10811D
Subsystem 5 - Part No SW: ----------- HW: 480 000 611 14
Serial number: 358000000008EB10811H
Subsystem 6 - Part No SW: ----------- HW: 480 403 010 14
Serial number: 3510002A11860BC2A0B/
Subsystem 7 - Part No SW: ----------- HW: 480 403 010 14
Serial number: 35200029F1860BC1F0AE
Subsystem 8 - Part No SW: ----------- HW: 480 400 910 14
Serial number: 3550002A9175A921D062
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 400 910 14
Serial number: 3560002A9175A92490EA
Part No SW: 8V0 953 521 CP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 11111408490509
Coding: A018
VCID: 0A4EABE8FCB0DC57C01-805E
Part No SW: 8V0 920 970 S HW: 8V0 920 970 S
Component: KOMBI H02 4291
Coding: 0BED181B2B80D7050201A8001800000000000000
VCID: 4CC26DF0B644826732D-8018
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 21101410802153
Coding: 0101000830085A005B00022C180B00000001010000000000000000000000
VCID: 72BED308F420B497981-8026
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Serial number: 01 11 2014 F0001478
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7082
Serial number: HA1-00007.10.14
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
VCID: 46D65FD8A8287837E49-8012
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000294069005
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 34321510CEB4FAA74AD-8060
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 22101401101049
Coding: 00511F204000048000000002
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 8102
VCID: 3728221CDFC211BF6FF-8062
Part No SW: 8V0 035 465 C HW: 8V0 035 465
Component: MIBAMP1ALPINE H11 0410
Serial number: AUZ8ZAEN900T2KA
Coding: 01030300AAAA2AAA01
VCID: 382A2120D2DC1EC7665-806C
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 29101401101712
Coding: 005117204000048000000002
VCID: 41DC4CC481065F0FD1B-8014
Component: LWR-ECU 005 0080
Coding: 012A000101000000
VCID: 75B4E814854EA3AFBD3-8020
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 844 HW: 8V0 035 844
Component: MU-S-S-US 013 0626
Serial number: A7A00411140352
Coding: 017301000000000021220002001A00002F0002240100010002
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 76B6EF189848A8B7B49-8022
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0013
Serial number: AUZ8Z9EY307904
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 Q HW: 8V0 919 614 Q
Component: ControlUnit_B H41 0054
Serial number: C1000011071400020161
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 140925200908
VCID: 7DA4F034BD7EFBEFF53-8028
Part No SW: 5Q0 959 395 D HW: 5Q0 959 395 B
Component: TSG HFS 020 0028
Serial number: 03111403111856
Coding: 004117204000048000000002
Component: TSG HBFS 020 0028
Serial number: 03111402081849
End----------(Elapsed Time: 01:41, VBatt start/end: 12.2V/12.2V)-----------
