2015 S3 Still Misfires after New Coil Packs, New Plugs, Carbon Cleaning. Thoughts?
lordjop
C?ID=306886
Hello Everyone and Happy New Year! Back on the board with my 2015 S3, the same one that had transmission issues that you guys helped me out with, and AOA ended up replacing under goodwill.
Now I have been having misfires for the last few months. Let me list the issues // problems in proper (or as close to) JPPSG:
1. 2015 Audi S3
2. Car is modified - Unitronic Stage 2 ECU Tune and Stage 2 DSG Tune as of 60,000 miles. Aftermarket catted downpipe with O2 Sensor still in place, and cold air intake.
3. Problems started around 73,000 miles. Here's the latest scan:
 Monday,07,January,2019,21:19:18:63824
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
VIN: WAUBFGFF3F1083628   License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 42 44 47 52 55 5F A9 BB
          BC
VIN: WAUBFGFF3F1083628   Mileage: 124744km-77512miles
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 E    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 0A1D00122426000E3004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259E 001002
   ROD: EV_ECM20TFS0208V0906259E_AU37.rod
   VCID: 42DE43C884004417C81-8016
15125 - Cylinder 1
          P0301 00 [236] - Misfire Detected
                    Mileage: 123794 km
                    Date: 2018.12.18
                    Time: 05:55:44
                    Engine speed: 3125.50 /min
                    Normed load value: 16.9 %
                    Vehicle speed: 26 km/h
                    Coolant temperature: 43 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 13.789 V
                    Engine: operating status: PL
                    N_TOOTH: 3152 /min
                    T_AST_SAE: 33 s
                    Engine oil temperature: 22.0 °C
                    STATE_LS_SAE[1]: CL
                    FUP_H_SAE: 7970.0 kPa
                    FUP_EFP_MES: 11000.8 hPa
15131 - Cylinder 3
          P0303 00 [236] - Misfire Detected
                    Mileage: 123794 km
                    Date: 2018.12.18
                    Time: 05:55:44
                    N_TOOTH: 3152 /min
                    T_AST_SAE: 33 s
                    STATE_LS_SAE[1]: CL
15134 - Cylinder 4
          P0304 00 [236] - Misfire Detected
                    Mileage: 123794 km
                    Date: 2018.12.18
                    Time: 05:55:44
                    N_TOOTH: 3152 /min
                    T_AST_SAE: 33 s
                    STATE_LS_SAE[1]: CL
15128 - Cylinder 2
          P0302 00 [100] - Misfire Detected
                    Mileage: 123794 km
                    Date: 2018.12.18
                    Time: 05:55:44
                    N_TOOTH: 3152 /min
                    T_AST_SAE: 33 s
                    STATE_LS_SAE[1]: CL
15137 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [096] - -
                    Mileage: 123794 km
                    Date: 2018.12.18
                    Time: 05:55:44
                    Engine speed: 3017.75 /min
                    Normed load value: 15.3 %
                    Vehicle speed: 25 km/h
                    Coolant temperature: 42 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 13.652 V
                    N_TOOTH: 3021 /min
                    T_AST_SAE: 40 s
                    Engine oil temperature: 23.0 °C
                    STATE_LS_SAE[1]: CL
                    FUP_H_SAE: 7880.0 kPa
15271 - EVAP System
          P0456 00 [096] - Very Small Leak Detected
Readiness: 0010 0001
   Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H54 4521
   Revision: 06354004    Serial number: TFK01609010381
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1F18EABC573249FF87F-804A
   Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
   Component: ESC           H42 0610
   Revision: 00000000    Serial number: 62944000003909
   Coding: 31FF6B9254280A6F017D030241CB698CD62A5080C08296B6024100588208
   ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
   VCID: 48CA51E0A23C6E47165-801C
   Revision: 00021000    Serial number: 0352076171
   Coding: 030C0C
   VCID: 3A2E3B28ECD00CD7901-806E
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000487739
   Coding: 03000014010000000000000000001400
   VCID: 3330160CCBBAFD9F537-8066
   Serial number: EFF80A57000000000001
328964 - Motor for Front Air Distribution Flap
          B1091 71 [008] - Actuator stuck
                    Reset counter: 31
                    Mileage: 123972 km
                    Date: 2018.12.19
                    Time: 19:34:06
                    Voltage terminal 30: 13.8 V
                    Interior temperature: 28.6 °C
                    Outside air temperature: 24 °C
                    Front air distribution flap: actual value: 0
                    Front air distribution flap: actual value: 95.5 %
                    Front air distribution flap: specified value: 92
328967 - Position Sensor for Front Air Distribution Flap Motor
          B1099 15 [008] - Open or Short to Plus
                    Reset counter: 57
                    Mileage: 122983 km
                    Date: 2018.12.09
                    Time: 09:58:26
                    Voltage terminal 30: 14.4 V
                    Interior temperature: 27.4 °C
                    Outside air temperature: 23.5 °C
                    Front air distribution flap: actual value: 768
                    Front air distribution flap: actual value: 0.0 %
                    Front air distribution flap: specified value: 934
   Part No SW: 5Q0 937 085 AC    HW: 5Q0 937 085 AC
   Component: BCM MQBAB HNA H18 0137
   Serial number: 01011430701262
   Coding: 04151A46C04122F541C04004511807A00800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7AAEFB28AC50CCD7D01-802E
   Component: WWS371 141009  042 0585
   Serial number:         141108082028
   Coding: 0A47F7
   Serial number: 23391689
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Serial number: 10 09 2014  00001191
   Serial number: 00000000000060929188
   Sun Roof:
   Component: J245 PS73.404  H02 0003
   Serial number: 0000FST0000ZE5I00000
   Coding: 101F00
   Serial number: 003GCR00YML6
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47C852DCAF22613F1FF-8012
   Belt Pretensioner left:
   Serial number: 34178311B13111470353
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34178312B11111470450
   Coding: 333135
   Occupant Detection:
   Serial number: 6940000Y1400018DCA0G
   Coding: 303230
   Subsystem 4 - Part No SW: -----------    HW: 480 000 611 14
   Serial number: 357000000008AC10811D
   Subsystem 5 - Part No SW: -----------    HW: 480 000 611 14
   Serial number: 358000000008EB10811H
   Subsystem 6 - Part No SW: -----------    HW: 480 403 010 14
   Serial number: 3510002A11860BC2A0B/
   Subsystem 7 - Part No SW: -----------    HW: 480 403 010 14
   Serial number: 35200029F1860BC1F0AE
   Subsystem 8 - Part No SW: -----------    HW: 480 400 910 14
   Serial number: 3550002A9175A921D062
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 400 910 14
   Serial number: 3560002A9175A92490EA
   Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 11111408490509
   Coding: A018
   ROD: EV_SMLSKLOMQB_012_AU37.rod
   VCID: 0A4EABE8FCB0DC57C01-805E
   Part No SW: 8V0 920 970 S    HW: 8V0 920 970 S
   Component: KOMBI         H02 4291
   Coding: 0BED181B2B80D7050201A8001800000000000000
   VCID: 4CC26DF0B644826732D-8018
   Revision: --------    Serial number: 21101410802153
   Coding: 0101000830085A005B00022C180B00000001010000000000000000000000
   ROD: EV_GatewConti_011_VW37.rod
   VCID: 72BED308F420B497981-8026
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 01 11 2014  F0001478
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00007.10.14
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   VCID: 46D65FD8A8287837E49-8012
   Revision: 00000000    Serial number: 14000294069005
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34321510CEB4FAA74AD-8060
   Serial number: 22101401101049
   Coding: 00511F204000048000000002
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Coding: 8102
   VCID: 3728221CDFC211BF6FF-8062
   Part No SW: 8V0 035 465 C    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0410
   Serial number: AUZ8ZAEN900T2KA
   Coding: 01030300AAAA2AAA01
   ASAM Dataset: EV_AMPMst16C1ALPI 004024
   ROD: EV_AMPMst16C1ALPI_004_AU37.rod
   VCID: 382A2120D2DC1EC7665-806C
   Serial number: 29101401101712
   Coding: 005117204000048000000002
   VCID: 41DC4CC481065F0FD1B-8014
   Coding: 012A000101000000
   VCID: 75B4E814854EA3AFBD3-8020
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 844     HW: 8V0 035 844
   Component: MU-S-S-US     013 0626
   Serial number: A7A00411140352
   Coding: 017301000000000021220002001A00002F0002240100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 76B6EF189848A8B7B49-8022
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0013
   Serial number: AUZ8Z9EY307904
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
   Component: ControlUnit_B  H41 0054
   Serial number: C1000011071400020161
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 140925200908
   VCID: 7DA4F034BD7EFBEFF53-8028
   Part No SW: 5Q0 959 395 D    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0028
   Serial number: 03111403111856
   Coding: 004117204000048000000002
   Component: TSG HBFS      020 0028
   Serial number: 03111402081849
End----------(Elapsed Time: 01:41, VBatt start/end: 12.2V/12.2V)-----------
4. Once again the CEL went on and i ran a scan. I got the above misfire codes and a "small EVAP leak" code. So i changed the N80 valve, spark plugs and coil packs, all parts were OEM and stock to car (S3). Cleared the codes and was good to go for about 73,000 miles. The CEL went on again with misfire codes. This time i went with "upgraded" coils (RS3) and plugs (colder RS7), reset the code and was good to go for a few miles. Then AGAIN i got a CEL.
With my mileage i suspected carbon buildup. I went to a reputable car repair shop (not sure if i can post their name) and they ran a diagnostic. I DID not tell them i suspected carbon buildup so as to get a "transparent" diagnosis. They said the car needed a carbon cleaning and showed me photos of what appeared to be a bat cave (probe photos via intake manifold). I went ahead with the carbon cleaning and i noticed a MUCH smoother idle and acceleration. These guys also replaced the injector gasket and the intake manifold gasket as well as replaced the water pump (had a small leak and they gave me a GREAT deal on replacing it since they were in there already).
That was about 3,000 - 4,000 miles ago and here we are with MORE misfires. The above scan is the latest.
5. Here is what i am thinking about doing: flash car back to stock. Perform a smoke test and find the cause of the EVAP leak (need to buy a decent smoke machine that won't break the bank, opinions are welcome). I was thinking it might be the PCV also? Maybe replace that?
Thanks for any help!
Gone But Not Forgotten
1. 2015 Audi S3
Vehicle Identification No.WAUBFGFF3F1083628
ModelAudi S3 sal. Qu. 2.0
A3
Date of production24.11.2014
Year2015
Sales type8VS51L
Engine CodeCYFB
Transmission CodeQSP
Nice post..........
Is sump with fuel contamination or clean?
Don't you think you should Un-modify car and observe coil packs, plugs and ignition system connectivity + HPP for leak into sump thinning oil & verify the spray pattern, injector hold or replace injectors and you don't need a smoke machine, use a mighty vac and trims in VCDS to guide the test path and isolate for false air?
Did you verify G28 isn't a dirty signal?
Is CAT plugged or part blocked?
OP can you post mode 9 data for this car in VCDS OBD2 mode in main screen please?
lordjop
C?ID=306886
Thanks for your help. I work some crazy hours so i am limited in what i can do with the car at this point. However, i was able to get the Mode 9 info you requested:
 Wednesday,09,January,2019,11:01:02:63824
VIN: WAUBFGFF3F1083628   License Plate: MOD 9 OFF
Type 02 - VIN : WAUBFGFF3F1083628 (Address E8)
Type 04 - Calibration ID : 8V0259E 0001AVCK (Address E8)
Type 04 - Calibration ID : 0D9300012L  4521 (Address E9)
Type 06 - Calibration Verification Number : 77749A10 (Address E8)
Type 06 - Calibration Verification Number : 0000AFEB (Address E9)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 526
    Ignition cycle count : 1273
         Catalyst monitor bank 1 : 0 / 334
         Catalyst monitor bank 2 : 0 / 0
         O2 Sensor monitor bank 1 : 0 / 337
         O2 Sensor monitor bank 2 : 0 / 0
         EGR-VVT monitor : 1007 / 525
         AIR monitor : 0 / 0
         EVAP monitor : 78 / 198
         Secondary O2 Sensor monitor bank 1 : 0 / 334
         Secondary O2 Sensor monitor bank 2 : 0 / 0
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
You mentioned a possible dirty signal from the G28? I believe that is the engine speed sensor? It shows an RPM value of around 3,000 RPM and that is exactly when the misfire occurred. I live in a warm climate and the day the CEL went on i was driving down my block and felt a hesitation as i slowly accelerated. Once the car warmed up and got to operating temperature there were ZERO issues. It appears that it is a cold start misfire issue.
Today i had to run an errand in the morning and the car felt like it misfired upon startup, but ran fine after warming up. After my errand I connected the VCDS while the car was running and logged for any potential misfires (about 5 minutes) and saw NONE.
I also want to mention the shop ran a compression test on each cylinder and everything looked good, i.e a consistent 135 PSI for cylinders 1 - 4. So it doesn't sound like weak valve springs or sticky valves, although i'm sure the shop would've mentioned that.
I have a hunch the small EVAP leak is the culprit and when i have off (Monday) i want to run some more tests and trace down the leak. Just to be sure i will also check the injectors, and the HPFP and try to troubleshoot things. I will keep you all posted and thanks again for your help so far !!
Larry Manton
C?ID=112505
Would appear a lean burn as somewhat goes away once warm, also misses at 3,000 so pushing it a bit.
Would be curious to watch fuel pressure when this happens and what the fuel trim, is at that point?
But as JACK stated with tuning all bets off.
LARIMORE.
lordjop
C?ID=306886
Hello Everyone. Hope you're all safe and HEALTHY. I took my vehicle to an independent VAG specialist and at that time they stated i needed an ECU upgrade which they performed. Car ran great for a while after that.
However. I am getting cold start misfires AGAIN. Car has about 150,000 miles on it and runs / pulls like a champ. I brought my car in to the same shop and they performed another carbon clean (which i knew i needed badly since i replaced the water pump myself).
Here's my latest scan:
Thursday,22,July,2021,12:07:56:63824
Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 42 44 52 55 5F A9 BB BC
VIN: WAUBFGFF3F1083628   Mileage: 240931km-149707miles
   Revision: --H13---
   ROD: EV_ECM20TFS0208V0906259E.rod
   VCID: 42DE43C88400441BD97-8016
15131 - Cylinder 3
          P0303 00 [172] - Misfire Detected
                    Mileage: 240190 km
                    Date: 2021.07.15
                    Time: 11:12:05
                    Engine RPM: 1113.00 /min
                    Normed load value: 23.5 %
                    Coolant temperature: 37 °C
                    Intake air temperature: 35 °C
                    Voltage terminal 30: 13.535 V
                    Engine: operating status: IS
                    N_TOOTH: 1098 /min
                    T_AST_SAE: 23 s
                    Engine oil temperature: 33.0 °C
                    STATE_LS_SAE[1]: CL
                    FUP_H_SAE: 7960.0 kPa
15134 - Cylinder 4
          P0304 00 [036] - Misfire Detected
                    Mileage: 240190 km
                    Date: 2021.07.15
                    Time: 11:12:05
                    N_TOOTH: 1098 /min
                    T_AST_SAE: 23 s
                    STATE_LS_SAE[1]: CL
          P0300 00 [032] - -
                    Mileage: 240190 km
                    Date: 2021.07.15
                    Time: 11:12:05
                    Unlearning counter according OBD: 30
                    N_TOOTH: 1098 /min
                    T_AST_SAE: 23 s
                    STATE_LS_SAE[1]: CL
   VCID: 1F18EABC573249F3969-804A
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
          P1734 00 [002] - -
   VCID: 48CA51E0A23C6E4B073-801C
4190 - Terminal 31
          C1142 01 [008] - Electrical Failure
                    Reset counter: 113
                    Mileage: 240187 km
                    Date: 2021.07.14
                    Time: 18:05:56
   Coding: 030C0C
   VCID: 3A2E3B28ECD00CDB817-806E
   VCID: 3330160CCBBAFD93421-8066
   Humidity sensor: exterior:
328963 - Motor for Front Air Distribution Flap
          B1091 13 [008] - Open Circuit
                    Reset counter: 160
                    Mileage: 240627 km
                    Date: 2021.07.18
                    Time: 13:36:15
                    Voltage terminal 30: 13.6 V
                    Inside temperature: 36.8 °C
                    Outside temperature: 29 °C
                    Front air distribution flap: actual value: 98.0 %
                    Air distribution door front - Specified value: 124
                    Reset counter: 160
                    Mileage: 240586 km
                    Date: 2021.07.18
                    Time: 13:04:51
                    Voltage terminal 30: 13.7 V
                    Inside temperature: 37.0 °C
                    Outside temperature: 24 °C
                    Front air distribution flap: actual value: 96.0 %
                    Air distribution door front - Specified value: 92
   VCID: 7AAEFB28AC50CCDBC17-802E
   Coding: 0A47F7
   Coding: 00006C
   Sunroof control module:
   Coding: 101F00
          B1263 01 [008] - Electrical Failure
                    Reset counter: 159
                    Mileage: 240262 km
                    Date: 2021.07.15
                    Time: 12:48:00
   VCID: 47C852DCAF2261330E9-8012
   Left seat belt tensioner:
   Coding: 333135
   Right seat belt tensioner:
   Coding: 333135
   Coding: 303230
   Coding: A018
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 0A4EABE8FCB0DC5BD17-805E
   VCID: 4CC26DF0B644826B23B-8018
   ROD: EV_GatewConti_011.rod
   VCID: 72BED308F420B49B897-8026
   Generator:
   Coding: 0001
   VCID: 46D65FD8A828783BF5F-8012
   VCID: 34321510CEB4FAAB5BB-8060
   Coding: 8102
   VCID: 3728221CDFC211B37E9-8062
   VCID: 41DC4CC481065F03C0D-8014
   VCID: 75B4E814854EA3A3AC5-8020
   VCID: 76B6EF189848A8BBA5F-8022
   Multimedia System 1:
          B11CF 53 [009] - Deactivated
                    Reset counter: 112
                    Mileage: 240187 km
                    Date: 2021.07.14
                    Time: 17:44:33
                    Voltage terminal 30: 11.9 V
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   VCID: 7DA4F034BD7EFBE3E45-8028
End----------(Elapsed Time: 01:38, VBatt start/end: 13.4V/13.4V)-----------
lordjop
C?ID=306886
So i tried trouble shooting:
1. Car has fresh spark plugs.
2. Coil packs are about 25,000 miles old
3. Tried swapping coil packs to other cylinders, but it's still #3 misfiring
3. Checked fuel rail pressure via VCDS. Was a constant 60 bar, then i turned car off and it rose to 70+ after a minute or so.
4. Tuned car back to stock. Same issues.
The issue i am running into is checking individual injectors via VCDS. My car runs the UDS protocol and everything i saw on youtube shows CAN. When i try to use advance measuring values i get "Refused by control module" for cylinders 1, 2 and 4 but i get "this output is not supported by control module" for #3 ? I tried this with car running at idle and with just the ignition in the ON position. Any thoughts ?
I don't want to go the "change out everything until you find what's wrong" route. Would love to run some more tests to try to pin point the problem. Car always ran 93 Top Tier gas.
Just for fun i called the local Audi dealership (prior to getting a carbon cleaning) and told them i got a CEL and may need carbon cleaning. Their response was "modern cars don't need carbon cleaning, it's probably a simply fix like an spark plug but you can't do that on your own because you need special tools." I thanked him for his time then hung up ........
Bruce
Near Philadelphia, PA, USA
Did you do a compression test on Cyl 3 and compare it to the others? A leaking valve could cause a misfire.
lordjop
C?ID=306886
Thanks for your quick reply. That is the next step. Waiting for my bro in law to get home, he was a BMW tech for a few years. He suspects it may be a valve gasket leak or a weak valve spring. Note though, misfire ONLY occurs during a cold start. Once the car idles it runs smooth. On the highway it runs like a beast with ZERO issues.
When i took my car in for carbon service two years ago (time flies !) they ran a compression test and everything was reading 184 PSI across all cylinders (if i recall correctly).......
You can even google "S3 cold start misfire" or "golf r cold start misfire" and see there are threads upon threads of this issue. It's crazy......
Again i'll keep you all posted.
lordjop
C?ID=306886
Still waiting for the compression test kit.
In the meantime - how do i test each injector if i have the UDS protocol ? I can do the "old fashioned" oscillometer method but i rather have a more accurate reading for EACH injector so i can compare them.
