Sticky VCDScripter for automating coding tasks
Sticky
   #41
hadez16
C?ID=289891
Hello
You program is very interesting
It possible to translate into french (for VCDS French)
May be I could help ??
Creating support for even another VCDS localization would take a lot of time. I cannot afford this, sorry.
titou43
France
C?ID=291365
Hello
Yes for the time support ... I can understanding this...
Is the vcdscripter function only with a vcds EN or DE ? or in a vcds FR there is into the program the same command in EN language ?
I have seen too that vcdscripter not find install of vcds FR in the laptop and it explain by the file directory of intall :
vcds FR : file directory like c:\....VCDS-FRM
vcds EN : file directory like c:\....VCDS
I have test if rename file directory VCDS-FRM to VCDS and the vcdscripter find vcds but ...are the internal commands are the same ?
If not I know it possible to install the two soft (EN and FR....)
   #43
hadez16
C?ID=289891
It would be cool if it was that simple.
No. Completely different.
The automation library relies on text (labels) displayed in the VCDS Software, that are totally different in a french version.
VCDScripter supports german and english VCDS version.
hadez16
C?ID=289891
FWIW, English and German together are about 80% of the market for VCDS.
Yeah...but the french, you know, refuse to use the english language. No matter if its tourism or VCDS...
   #46
#NotAll
:D
nirvananils
C?ID=289109
But most of them, Nico is living near by french border.....
   #48
langers2k
C?ID=224085
@hadez16 - does this support the current 20.4.2 VCDS release?
I only ask as your blog states: Version 1.8 - Mandatory requirement: VCDS version 19.6.1
Thanks!
   #50
hadez16
C?ID=289891
Thanks!
It should work.
Sorry for the delayed answer.
wojciech300
Poland
C?ID=147841
Hi, its possible to send manual UDS command after connect to ECU ?
for example like 22 / 2E etc ?
   #52
There is no provision in VCDS for that, so I don't see how VCDScripter could do it.
c-gar
C?ID=538286
i can't believe this part of the forum isn't more popular. i haven't downloaded VCDScripter yet but plan on it when i find the time.
THANKS, hadez16!
   #54
c-gar
C?ID=538286
the antivirus software i use (bitdefender) gave me all kinds of grief when i tried to download it the first few times. it would give a warning and save a corrupted zip folder that couldn't be opened. so... i reported it to them as a false positive. they reviewed it and added it to the next update.
downloaded with no issue after that. :)
   #55
mattft86
C?ID=525197
I cannot get VCDScripter to even run.
   #56
hadez16
C?ID=289891
Hi all,
in the meantime, the code ownership of VCDScripter went over to the guys of Auto-Intern with @AINils and the guys.
I became the father of two wonderful kids and I didn't see any time to keep on maintaining the tool.
Cheers
   #57
AINils
Germany (AIB)
C?ID=56975
Maybe you could explain your Problem with more details, and also what kind of Interface you own. Also OS and some other information as "cannot run" isnt a real fault
   #58
He has a HEX-V2, purchased within that last year.
AINils
Germany (AIB)
C?ID=56975
Then it would be helpful if he wrote more details about problem
   #60
mattft86
C?ID=525197
Sorry I've not replied been mad busy I've sorted it now my firewall was stopping it.
