6R Polo with MFSW almost working
nugentp
C?ID=353561
I have an MY13 6R Polo here with factory fitted telephone/media kit and factory fitted MFSW buttons which are only on the LEFT side of the steering wheel - seemingly this is a normal thing for cars that did not get optioned with the 'MFD' trip computer which uses a button panel on the right side of the steering wheel.
The buttons for controlling the radio volume and channel selection work fine.
The button for answering/hanging up a phone call does NOT work.
The button for 'push to talk' (PTT) also does NOT work.
The module in question appears to be this one, but VCDS does not give any advise on coding options for this component. I did try a bunch of different codes in a semi-logical fashion, but they all got denied and I can only get the original '020000' code to stick.
Subsystem 4 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0033
Serial number: 0285424
Coding: 020000
I have googled furiously for a while across various VW forums without success, so if anyone has any insight on coding options to correct this it would be great.
I did verify on the RADIO coding that MFSW is enabled - otherwise, none of the buttons work. I also found another coding option on the RADIO module which transformed the PTT button into a MUTE function so I know that button is physically working.
Maybe there is a particular combination of codes required across the MFL, Radio & Media Player modules for all buttons to work as expected ?
Friday,04,January,2019,11:33:10:30756
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(Parallels)
VCDS Version 18.9.0.4  HEX-NET CB: 0.4437.4
Data version: 20181017 DS296.0
VIN: WVWZZZ6RZDYxxxxxx   License Plate:
Mileage: 91930km-57122mi   Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZDYxxxxxx   Mileage: 91930km-57122miles
Address 01: Engine (J0000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 AK    HW: 03P 907 425 A
   Component: R3 1.2 DCM3.7 H09 3317
   Revision: 11002001    Serial number:
   Coding: 00114014000500080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TDI03103P906021AK 001005
   ROD: EV_ECM12TDI03103P906021AJ.rod
   VCID: 71AAD168A0D13EC224-8025
Readiness: 1110 1000
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 230224E3416D00B9C42924E282D400821300
   VCID: 02488EA49977355ACD-8057
   Component: LENKW.SENSOR  H06 0060
   Serial number: 090465LJ5000ZR
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EB0FA54E18F51BAA9-802B
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 393A2948B021B682DC-806D
   Part No SW: 6R0 937 087 K    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0254
   Revision: BF046001    Serial number: 0434 266121636
   Coding: 25B029BF08A10000012808002D2B0ED90000410F60060000200000000000
   Shop #: WSC 12469 483 00190
   VCID: 45C255B8CCD9C262A8-8011
   Component: RLS 210912 05  54  0403
   Coding: 03302D
   Subsystem 2 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  008 1621
   Serial number: KU0KU020091200018422
   Coding: 18BC30
   Subsystem 3 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  008 1621
   Serial number: KU0KU017091200010077
   Coding: 18BC30
   Coding: 020000
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10Airbag01X H10 0020
   Revision: --------    Serial number: 003GX01EFA8E
   Coding: 003158
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4AD86684EDC72D1A45-801F
   Serial number: 3575HRB40511KADSGHBT
   Serial number: 3585HRB404T1KADSF0UF
   Serial number: 3515RRB405H1GLOM6HSP
   Serial number: 3525RRB401C4UHC45H7L
   Part No SW: 6R0 920 961 K    HW: 6R0 920 961 K
   Component: KOMBI         H05 0605
   Coding: 440A01
   VCID: 3E303A54A10F91BAE9-806B
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H46 0254
   Revision: BF046001
   Coding: 002100
   VCID: 70ACD46CA3DB37CA2B-8025
   Component: IMMO          H05 0605
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A98C6048D07CD1A65-803F
   Revision: A1001003    Serial number: 7663521386
   Coding: 010100
   VCID: 2A18060445870D1AA5-807F
   Part No: 6R0 423 156 C
   Component: LenkhilfeTRW        V278
   Coding: 11230
   Shop #: WSC 00788
   VCID: 302C146CF75B77CA6B-8065
   Part No SW: 5M0 035 186 L    HW: 5M0 035 186 L
   Component: Radio RCD310  004 0119
   Revision: 01000001    Serial number: VWZ1Z2M2186438
   Coding: 01000400020001
   VCID: 352225789C3952E238-8061
End----------(Elapsed Time: 01:06, VBatt start/end: 14.2V/14.1V)-----------
nugentp
C?ID=353561
So after a lot more digging, I am starting to believe the lack of button functionality is a shortcoming of the integration with RCD310 radio and handsfree TPK module. When I attempt to code the radio with phone or phone preparation there is a clue this is expecting CAN bus connectivity to some other Bluetooth module which is why it fails to accept that code.
The best I can do is get the 'PTT' button working as a mute function for the radio, unless the car is equipped with voice recognition system.
I think the factory TPK module only has analog connectivity with the radio (for mute function and line level audio) so I am now forming the view that the phone button on the left MFSW panel will only work with a Bluetooth adapter which is integrated via CANBus.
Unless someone else has better knowledge ?
siLc
Tallinn, Estonia
C?ID=330192
This MDI interface you have in this car is only a media interface in the wired form - there is no Bluetooth on this part number (5N0 035 342F) of MDI. You can get Bluetooth with part number 5N0 035 729E or adding a seperate dedicated Bluetooth module.
Or you have something akin to a Parrot Bluetooth system, which is not on the CAN bus?
iichel
Eindhoven, NB, NL
C?ID=284912
i think the problem is the compatibilty of the TPK handsfree with the MFSW. Your coding all seems fine. However there is no adress 77 (telephone) to send any commands to, I think that's the problem...
nugentp
C?ID=353561
Thanks for that folks - all consistent with my new found understanding. The reason why the Radio rejects any attempt to code with telephone is the non existence of a suitable controller at address 77. This entry level TPK module does not integrate with the phone & PTT buttons on the left MFSW panel - slightly annoying but such is life!
