2012 VW Touareg - Blue Motion - 3.0L V6 Diesel - RHD - Retrofit tow bar (Fuses checked )
Hi All, We purchased a used Touareg last year and at the time of purchase the fob range was poor, however we thought it just needed new fob batteries. We got it home and swapped the batteries for Duracell ones (tested at 3.2v). Unfortunately the fob range is still very poor. Also at time of purchase the drivers side speaker wasn't working (this was due to two broken wires at the door shut connector) and it was obvious the car had sustained damage around the front drivers side wing and had been repaired (unsure it thats relevant to later points)
So I've scanned the car, ignore the low fob batt code as thats now been replaced and door warning light code as the scan was done with the driver side rear door card off.
The two codes that concern me are 00193 and 02981. Would the 00193 cause poor fob range? not too fussed with KESSEY, at the moment is works on all handles intermittently barr the broken one, but will replace the handle if theres a chance it will sort the fob range issue. The fob range is about 1m max (best near the drivers door) and improves slightly with new fob batteries. If i open the drivers side door and press the fob buttons in line of sight the range increases to about 5-6 meters so am guessing there could well be an issue with the J393 module antenna? would that tie in with the 02981 code? I understand the earlier Touaregs have issues with the central locking antenna but can't see much relating to the T3's. I tested the car battery with VCDS a few months ago and IIRC it was around 75%. Also if its relevant the radio reception seems ok. Keyless start range is also poor. The keys need to be either on your lap, sitting in the middle of the centre console on onto of the dash to start via the button.
Would it be possible to make up a home made antenna to try? or use VCDS to test the antenna? Im guessing the OE antenna is integral to a larger harness as i can't find one listed on ETKA.
Many thanks
Peter
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 42 46 52 53 55 56 5F 62
69 6C 6D 72
VIN: WVGZZZ7PZDD003798 Mileage: 214902km-133533miles
Address 01: Engine (J623-CRCA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0002
Revision: 53H37---
Coding: 292A401A232601020000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0117P0907401F 001003
ROD: EV_ECM30TDI0117P0907311C.rod
VCID: 3261E30A65EC2EDA13-8066
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 BK HW: 0C8 927 750 BK
Component: AL1000 AISIN 001 2268
Coding: 001568
Shop #: WSC 50940 002 1048576
ASAM Dataset: EV_TCMAL991031 002114
ROD: EV_TCMAL991031_002.rod
VCID: 76E91F1AC90472FAFF-8022
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 M HW: 7P0 907 379 A
Component: MK25A H36 0436
Revision: -------- Serial number: 414620010EC815
Coding: 5B6B13C309242556DAFBC89C90DAA450F700
ASAM Dataset: EV_MK25AXT 008001
ROD: EV_ESPMK25A00800.rod
VCID: 4797A2DEFE6EBB7254-8012
Part No SW: 4H0 907 064 BH HW: 4H0 907 064 BH
Component: BCM2 2.0 H32 0333
Coding: 05B60016000000000000
VCID: 70E52902A3605CCA25-8024
Subsystem 1 - Part No SW: 7P6 959 754 AB HW: 7P6 959 754 AB
Component: FBSTOUAREGIDG H06 0051
Serial number: 0812000030271013
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Serial number: 2312000108756011
00193 - Rear Right Door Handle Touch Sensor (G418)
Reset counter: 79
Mileage: 214892 km
Date: 2018.12.17
Time: 13:46:20
00955 - Key 1
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 79
Mileage: 214892 km
Date: 2018.12.17
Time: 13:55:45
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BM HW: 7P6 907 040 BM
Component: Klima 2 Zonen H20 1305
Coding: 36B6000810
VCID: 000579C29BC04C4AD5-8054
0243 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 119
Mileage: 214894 km
Date: 2018.12.17
Time: 14:04:25
Part No SW: 4H0 907 063 BL HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0111
Revision: 15012002 Serial number: 00000001339551
Coding: 26001010D1345D010021000300005D0C431D470807010241000000020000
VCID: 73EF260ED27667D2D8-8026
Subsystem 1 - Part No SW: 7P0 955 120 HW: 7P0 955 120
Component: WWS 120510 31 0020
Serial number: 90243401120521203919
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10390484
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 HW: 7P6 941 431
Component: E1 - LDS H04 0031
Serial number: 00000000003105120196
01856 - Temperature Sensor for Heated Seat; Front Right (G345)
Fault Status: 00101100
Reset counter: 119
Mileage: 214894 km
Date: 2018.12.17
Time: 14:04:00
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 B HW: 7N0 919 475
Component: PARKHILFE 8K H05 0021
Revision: -------- Serial number: 28261215203107
Coding: 508501
ASAM Dataset: EV_VW526ParkiAssis2 001011
ROD: EV_VW526ParkiAssis2.rod
VCID: 4281B3CAD54C9E5A83-8016
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 C HW: 7P0 959 655 C
Component: VW10Airbag00K H05 0025
Revision: -------- Serial number: 003L0003J8U+
Coding: 00000000000000000000000000000000304B
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 4183BCC6D04A85429A-8014
Serial number: 3575LRB404R1C4LGA0LR
Serial number: 3585LRB404T1CAIC1P3R
Serial number: 3515RRB406317O0OKP4P
Serial number: 3525RRB405L19KCU91L+
Serial number: 3555NRB400I4UH2679CG
Serial number: 3565NRB400K4UH26S1AU
Part No SW: 4H0 953 568 H HW: 7P6 953 507 M
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815LF50001E
Coding: 000C35
VCID: 3875D1228B90C48A2D-806C
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0188671
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 981 M HW: 7P6 920 981 M
Component: Kombi H13 0318
Revision: 13240077 Serial number: 658110612592002
Coding: 332733002A00260001000C
ASAM Dataset: EV_KombiUDSRBVW526 001017
ROD: EV_KombiUDSRBVW526.rod
Address 18: Aux. Heat (J364) Labels:. 8R0-265-105.clb
Part No SW: 7P0 963 272 D HW: 7P0 963 272 D
Component: Standheizung H23 0243
Revision: 56005006 Serial number: 20120427212703
Coding: 594200
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7P6 907 530 F HW: 7P6 907 530 F
Component: GW-CAN-L-MOST H10 6028
Revision: -------- Serial number: 00000000555462
Coding: 000D077500
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
VCID: 3B7FCE2EB2A6EF92C0-806E
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650419072
Voltage stabilizer:
Subsystem 2 - Part No SW: 7PP 959 663 E HW: 7PP 959 663 E
Component: J532_DCDCStab H17 0042
Serial number: 12153001731011200181
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4H0 959 793 N HW: 4H0 959 793 F
Component: TSG FA H07 0166
Revision: -------- Serial number: 0000127615613
Coding: 011D1620D001451005080002
VCID: 448DB5D2C758906AB1-8010
Revision: 00002001 Serial number: 0177719413
Coding: 011B1E2228B9108183200620010000000000000000000000000000000000
Subsystem 1 - Part No: 7P6 951 171
Component: DWA-Sensor 002 0204
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0166
Revision: -------- Serial number: 0000127689375
Coding: 011D1620D001451005080000
VCID: 3B7FCE2EBAA6EF92C0-806E
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1252900993
Coding: 01040100
ROD: EV_ParkbA7.rod
VCID: 3669DF1A898432FA3F-8062
Slave 3:
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Coding: 018E00000F000200
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS_VW52.rod
VCID: 7CFD0D32F72828AA89-8028
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 130000
Part No SW: 4G0 035 061 N HW: 4G0 035 061
Component: Radio U DAB H60 0139
Revision: AB001007 Serial number: 109F50C7566857
Coding: 010105020100000003
VCID: 285501625B30540ABD-807C
02981 - Connection between Radio and Impedance Converter 1
Reset counter: 79
Mileage: 214892 km
Date: 2018.12.17
Time: 13:04:26
Voltage: 11.80 V
Part No SW: 7P6 035 670 F HW: 7P6 035 670
Component: H-BNT-EU H47 0816
Revision: -------- Serial number: 478E80C7582288
Coding: 010101050040C3EF01000B0E00000003F00401030000000000
Subsystem 1 - Part No: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Component: DU8 SV Touch H26 0045
Serial number: VWZ8Z9M7801FAZ
Subsystem 3 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Subsystem 4 - Part No: 8R0 060 961 C
Component: CD-Database 3638
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0167
Revision: -------- Serial number: 0000127949136
Coding: 011C14200001251005080000
VCID: 3A71CB2AB59CD69ADB-806E
Address 69: Trailer (J345) Labels:. 4H0-907-383-V2.clb
Part No SW: 4G8 907 383 B HW: 4G8 907 383 B
Component: ConWys Trailer H07 0072
Revision: 7B001002 Serial number: 00000133243642
Coding: 0100000000000000
VCID: 336FE60E92F627D218-8066
Address 6C: Back-up Cam. (J928) Labels:| 7P6-907-441-V1.clb
Part No SW: 7P6 907 441 E HW: 7P6 907 441 D
Component: TopView H05 0100
Revision: 11001001 Serial number: 82330JF0045481
Coding: 0100000001000000010102000000
ASAM Dataset: EV_CamerSysteTopViewVW 001014
ROD: EV_CamerSysteTopViewVW.rod
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 A HW: 7P6 959 107
Component: HDSG-Modul H10 0620
Revision: 22010001 Serial number: 137201401
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202137
ROD: EV_HeckkTouar.rod
VCID: 3D7BC036ACB2E1A2FE-8068
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H09 0167
Revision: -------- Serial number: 0000127952701
02123 - Door Warning Light / Entry Light
Fault Status: 01101100
Reset counter: 79
Mileage: 214892 km
Date: 2018.12.17
Time: 13:04:16
End
Many thanks
Peter
