Setting Readiness - UDS controllers
DrPeter
16.4905° S, 151.7375° W
Setting readiness with VCDS when working with a UDS Engine controller can be done with a few simple steps,
(This is a basic guide, some of the Advanced Measuring Values maybe different or not available on all controllers)
[Automatic test sequence] - Readiness Tests for UDS Engine controllers
Prerequisites:
- All Electrical consumers off
- (May need to open / close fuel cap)
- Engine coolant temperature needs to be above 80°C
- ECM should be fault free (no returning fault codes)
Select [01-Engine]
- Check and clear fault codes, even if there are none.
Start engine
- Select [Basic settings]
Now choose these Advanced Measuring Values by pressing [Show Measuring Data] | (definitions)
- [Operating Instructions] - (As is says, follow instructions)
- [Currently running routine] - (Current test being performed)
- [Status of actuator test] - (Current status)
- [Test steps still to be performed] - (This should count down to 0)
- [Engine speed] - (Follow instructions, above)
- [Coolant temperature] - (Should be at least 80'C)
Press [Go] for the Basic Settings [Automatic test sequence]
Press and hold brake/accelerator pedal (The ECM should have control of the engine speed at this time) wait until the test has finished or there is an error.
Note: It maybe necessary to cycle the ignition Off and the Start the Basic Settings and then Re-start the engine to get the tests to start.
When the system has finished you should get the message "System OK" in the [Operating Instructions] field.
Last thought... It is possible on some vehicles, the Automatic test sequence may complete without faults and the Evaporative Emissions readiness bit has not been set.
Some feedback from customers would seem to indicate the vehicle needs to be driven for a while and the test completes/finishes on it's own. Running the readiness tests with the factory tool also seems to produce the same results with all the readiness bits competed, except the Evaporative Emissions, this maybe normal?
Comments are welcome if anyone has ideas about what it takes or why the Evaporative Emissions fails to complete.
Hope this helps,
drpeter
Gone But Not Forgotten
Hope this helps,
drpeter
Let's ask some questions.....
Always determine during a "Drive Cycle" ( DCY ) what test in stack you are using when setting readiness monitors and have you conflicted tests or performed them out of order?
Are you doing a force readiness test & "non moving" or "while driving" force test procedure?
Vacuum changes from atmospheric change over or in comparison to idle & some cars for who knows "why" only run an LDP test during an actual steady load in low gear and high enough sufficient vacuum to run a calibration & complete it?
Are you missing an AUX vacuum pump brake booster calibration or adaption?
Are you doing the readiness tests in 0x33 & EVAP mode test or in 0x01 & IDE mode?
When readiness tests are being performed for UDS and these aforementioned report an incomplete EVAP bit status, are you doing all three shared tests for the bit and within the same shared DCY?
In this case EVAP, LDP and PSI tank vent controller adaption, are they all completed within the DCY & did you do them successfully before a CAT or rear OXS TEST & IAT before being latent with above ambient heat?
Nice post Peter
jyoung8607
FoRT
Garrettsville, OH
C?ID=25607
I can confirm this happens on both my 2018 Atlas (3.6L VR6 / CDVC) and my 2018 Golf R (2.0T / DJJA). The automated test sequence doesn't set EVAP readiness.
I was bored tonight, chaperoning a gaming lock-in, and kind of got nerd-sniped trying to figure this one out. I think it's vehicles that are using new leak detection methods, other than the traditional vacuum-driven LDP, to comply with Tier 3 evaporative emissions standards.
VW Generic Scan Tool Documentation said:
2.2 Evaporative Emission System
The evaporative emission system has been designed to minimize the release of hydrocarbons from the fuel system into the atmosphere. The evaporative emission system components all work together with the ECM to prevent fuel vapor from escaping and route it to the intake manifold to be burned during normal combustion. The leak detection system checks the integrity of the evaporative emission system by pressurizing the system. There are 3 different types of evaporative emission systems used. These systems are explained below.
2.2.1 Leak Detection Pump (LDP) EVAP System
The leak detection pump (LDP) is integrated into the EVAP system and can have two functions. The LDP can:
♦ Pressurize the EVAP system and detect a drop in pressure that would indicate a leak.
♦ Function as the EVAP Canister Vent on vehicles that do not have a separate EVAP Canister Vent.
The LDP is a vacuum-driven, ECM controlled, diaphragm pump. In order to operate, the engine must be running and vacuum applied to the Vacuum Switch.
2.2.2 Tank Leak Diagnostic Module (DM - TL) EVAP System
The canister purge valve can be actively checked using the Tank Leak Diagnostic Module (DM - TL). For this purpose the electric pump is shortly activated while the combustion engine is running, to build up a minor pressure in the fuel tank and monitor the pressure decay after opening the canister purge valve. Optionally as a quick pass method, the monitoring can be carried out by passively monitoring the fuel mixture deviation when the canister purge valve is opened. If a significant fuel mixture deviation is detected, the purge valve monitor passes. The Tank Leak Diagnostic Module (DM - TL) consists of an electrically operated air pump, an orifice with a defined diameter serving as a reference leak, and a change-over valve switching the air flow between the reference leak and the tank. If neither the pump nor the changeover valve is activated, the tank is ventilated through a bypass in the module.
2.2.3 Natural Vacuum Leak Detection (NVLD) EVAP System
The system utilizes an engine-off natural vacuum evaporative system integrity check that tests for leaks with a diameter of 0.020 inch while the engine is off and the ignition is off. The natural vacuum leak detection (NVLD) evaporative system integrity check uses a pressure switch to detect evaporative system leaks. The correlation between the pressure and the temperature in a sealed
system is used to generate a vacuum in the tank when the temperature drops. If a sufficient temperature drop is detected for a minimum time period, the vacuum level in a sealed system will
exceed the threshold to close the NVLD pressure switch. Therefore, if the switch does not close under these conditions, a leak is detected. If the switch closes, the system is considered to be leakfree
For my 2018 Golf R, looking at the Generic Scan Tool DTC tables for P0456, you can see a switchover from traditional LDP to NVLD happen between model-years 2015 and 2016. This corresponds with the Early compliance period for Tier 3. So the answer to this one is easy: you can't set EVAP readiness during the automated test sequence because NVLD doesn't work with the engine running, by design. The ignition has to be off, and the vehicle has to be allowed to cool for a while, and some other prerequisites have to be met:
• Ignition off
• Fuel level < 85.10 %
• Fuel temperature drop >= 6 K
• For time > 1 h
• AAT >= 4° C
• Barometric pressure > 73.00 kPa
• Diff. barometric pressure @ stop and barometric pressure @ start < 0.65 kPa
• Time since ignition off > 90 [min] ; < 600 min
For my 2018 Atlas, I don't have previous model-years to compare to, but looking at the Generic Scan Tool DTC tables for P0456, I can see it's using the DMTL method. Documentation conflicts on whether this one should work with the engine running. The intro paragraphs say yes, the prereqs imply maybe no. It does have quite a stack of prerequisites, which I don't fully understand yet, and wants to run for a very long time. I may experiment with this later.
• Engine temperature @ engine start >= 4° C
• Difference between ECT @ start and AAT not calibrated
• propulsion off time previous dcy >= 21,600.0s
• AAT < 35; > 4° C
• Barometric pressure > 73.0 kPa
• Time since engine start in preceding DCY>= 600.0 s
• Change in battery voltage during monitoring < 1.0 V
• Engine off time >= 3.0 s
• Vehicle speed 0 km/h
EVAP purge adaptation < 5.0
• No sudden change in EVAP pump current (filling event) < 1.5 and > -0.5 mA
• Deviation of filtered EVAP pump current during reference measurement within range <= 3.0 mA
• Change in relative evap pump current during monitoring n.a.
• Within time n.a. s
• (During ECM keep alive-time after ignition off, max. time) < 800.0 s
EVAP vent valve n.a.
• Airbag not activated
Tier 3 emissions info: https://www.epa.gov/sites/production/files/2016-12/documents/tier3-evap-obd-summary.pdf
Both the DMTL and NVLD methods appear to get rid of the P0445 Large Leak and P0442 Small Leak tests entirely, focusing entirely on P0456 Very Small Leak.
Interesting reading on NVLD: https://www.searchautoparts.com/mot...diagnosing-and-repairing-nvld-systems-can-pre
Interesting reading on DMTL: https://www.autoserviceprofessional...ean-cars-real-world-diagnosis-of-dmtl-systems
NEtech
Denmark
C?ID=56995
Some input, if you are going to do testings on the Golf:
[04-Basic Setting]
IDE04102 Read out system status ctrl module for fuel tank leak diagnost.
[Adv. Meas.]
IDE01986 Contact for tank leak test
IDE00450 Operating Instructions
IDE00451 Currently running routine
IDE05622 Status of tank leak diagnosis with electrical diagnostic pump
IDE07008 Tank leak: number no leak detected
IDE07011 Tank leak: number communication errors to engine control
IDE07014 Tank leak: number very small leaks detected
IDE10922 Pump current of tank leakage diag.: corrected & filtered
ENG104238 STATE_NVLD
Why not just list all the IDE tests numbers related to readiness for UDS for individual testing criteria?
jyoung8607
FoRT
Garrettsville, OH
C?ID=25607
Everything you never wanted to know about NVLD, and you didn't ask:
It looks like Volkswagen is using Continental's NVLD II system (since superseded by NVLD III). This has been used by several other vendors, including BMW, Ford, and Chrysler. I can't find any Continental OEM documentation, or any good Volkswagen documentation like a SSP, but there is some good reading material to be found on BMW and Ford's implementation. Some of the timers and other constants will differ, of course, but it gives you a general sense of the logic involved. Here are some extremely legitimate links:
Ford NVLD II (pages 14-20): https://www.yumpu.com/en/document/r...on-summary-for-fiesta-motorcraftservicecom/17
BMW NVLD II: https://www.e90post.com/forums/attachment.php?attachmentid=1584197&d=1488748985
I appear to have the "basic" variant described in the BMW doc, with the separate temp sensor/controller and pressure switch modules, VW J909 and G400 respectively. The G400 looks identical, and the J909 looks the same except mine has an integral mounting bracket.
I spent entirely too much time playing with this last night and this morning. It looks like these are the only applicable blocks for NVLD outcomes:
IDE00588 Fuel tank fill level (a test precondition according to the Generic OBD2 docs)
IDE01986 Contact for tank leak test closed (not sure if this is the specified or actual state)
IDE07011 Tank leak: number communication errors to engine control (interestingly, I have a lot of these)
IDE07945-MAS00336   Status of intermittent monitoring-Monitoring of tank ventilation system completed successfully (assuming this is the Readiness bit)
The ECU talks to Fuel Tank Leak Detection Control Module J909 using a single-wire serial bus of some form. J909's job is to manage and diagnose the G400 Fuel Tank Pressure Sensor. Ordinarily the ECU could do that alone, but J909 is what stays awake while the car is shut down, monitoring its own temperature and the G400 switch, and gives the result to the ECU next time the car is started. After July 2018, J909 on the Golf R has a two-wire bus to the ECU, possibly CAN but unconfirmed. It might be NVLD III with a combined J909/G400? Mine is not set up this way.
There's some interesting nerd-stuff to see on the serial bus. These blocks show NVLD state-machine and command/response traffic:
ENG102127 STATE_COMC_NVLD
ENG100342 STATE_REQ_NVLD
Bus traffic at shutdown:
Engine at idle, log running all the way until shutdown and the session being dropped. You can see the ECU asking for electrical diagnostic of G400 every 30 seconds. I'm not sure what the rest of the commands mean. You can see a couple of unique ones issued right when I shut down the engine.
Wednesday,02,January,2019,15:38:02:21122-VCID:CDD2285C9C831C22E0-8098,VCDS Version: Release 18.9.0 (x64),Data version: 20181017 DS296.0
8V0 906 259 P,ADVMB,2.0l R4 TFSI  H13 0001,
,,G1129,F0,G1135,F0,G1140,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,
Marker,TIME,Loc. ENG102127,TIME,Loc. ENG104238,TIME,Loc. ENG100342,,,,,,,,,,,,,,,,,,,
,STAMP,STATE_COMC_NVLD,STAMP,STATE_NVLD,STAMP,STATE_REQ_NVLD,,,,,,,,,,,,,,,,,,,
,0.18,Wait,0.04,COMPLETE_DIAG,0.10,NO_REQ,,,,,,,,,,,,,,,,,,,
,0.37,Wait,0.24,COMPLETE_DIAG,0.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,0.56,Wait,0.43,COMPLETE_DIAG,0.49,NO_REQ,,,,,,,,,,,,,,,,,,,
,0.75,Wait,0.62,COMPLETE_DIAG,0.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,0.93,Wait,0.81,COMPLETE_DIAG,0.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,1.12,Wait,0.99,COMPLETE_DIAG,1.05,NO_REQ,,,,,,,,,,,,,,,,,,,
,1.31,Wait,1.18,COMPLETE_DIAG,1.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,1.50,Wait,1.37,COMPLETE_DIAG,1.43,NO_REQ,,,,,,,,,,,,,,,,,,,
,1.71,Wait,1.55,COMPLETE_DIAG,1.63,NO_REQ,,,,,,,,,,,,,,,,,,,
,1.92,Wait,1.77,COMPLETE_DIAG,1.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,2.11,Wait,1.98,COMPLETE_DIAG,2.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,2.31,Wait,2.18,COMPLETE_DIAG,2.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,2.49,Wait,2.37,COMPLETE_DIAG,2.43,NO_REQ,,,,,,,,,,,,,,,,,,,
,2.68,Wait,2.56,COMPLETE_DIAG,2.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,2.89,Wait,2.75,COMPLETE_DIAG,2.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,3.09,Wait,2.96,COMPLETE_DIAG,3.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,3.28,Wait,3.15,COMPLETE_DIAG,3.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,3.47,Wait,3.34,COMPLETE_DIAG,3.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,3.69,Wait,3.54,COMPLETE_DIAG,3.60,NO_REQ,,,,,,,,,,,,,,,,,,,
,3.90,Wait,3.76,COMPLETE_DIAG,3.82,NO_REQ,,,,,,,,,,,,,,,,,,,
,4.10,Wait,3.96,COMPLETE_DIAG,4.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,4.29,Wait,4.15,COMPLETE_DIAG,4.22,NO_REQ,,,,,,,,,,,,,,,,,,,
,4.49,Wait,4.36,COMPLETE_DIAG,4.43,NO_REQ,,,,,,,,,,,,,,,,,,,
,4.68,Wait,4.56,COMPLETE_DIAG,4.63,NO_REQ,,,,,,,,,,,,,,,,,,,
,4.88,Wait,4.75,COMPLETE_DIAG,4.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,5.10,Wait,4.93,COMPLETE_DIAG,5.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,5.29,Wait,5.15,COMPLETE_DIAG,5.22,NO_REQ,,,,,,,,,,,,,,,,,,,
,5.48,Wait,5.36,COMPLETE_DIAG,5.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,5.67,Wait,5.54,COMPLETE_DIAG,5.60,NO_REQ,,,,,,,,,,,,,,,,,,,
,5.89,Wait,5.74,COMPLETE_DIAG,5.82,NO_REQ,,,,,,,,,,,,,,,,,,,
,6.08,Wait,5.96,COMPLETE_DIAG,6.01,NO_REQ,,,,,,,,,,,,,,,,,,,
,6.27,Wait,6.14,COMPLETE_DIAG,6.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,6.54,Wait,6.38,COMPLETE_DIAG,6.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,6.81,Wait,6.60,COMPLETE_DIAG,6.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,7.02,Wait,6.88,COMPLETE_DIAG,6.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,7.20,Wait,7.07,COMPLETE_DIAG,7.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,7.39,Wait,7.26,COMPLETE_DIAG,7.32,NO_REQ,,,,,,,,,,,,,,,,,,,
,7.58,Wait,7.44,COMPLETE_DIAG,7.51,NO_REQ,,,,,,,,,,,,,,,,,,,
,7.78,Wait,7.65,COMPLETE_DIAG,7.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,7.96,Wait,7.84,COMPLETE_DIAG,7.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,8.18,Wait,8.04,COMPLETE_DIAG,8.10,NO_REQ,,,,,,,,,,,,,,,,,,,
,8.38,Wait,8.24,COMPLETE_DIAG,8.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,8.57,Wait,8.45,COMPLETE_DIAG,8.51,NO_REQ,,,,,,,,,,,,,,,,,,,
,8.77,Wait,8.64,COMPLETE_DIAG,8.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,8.98,Wait,8.84,COMPLETE_DIAG,8.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,9.17,Wait,9.04,COMPLETE_DIAG,9.10,NO_REQ,,,,,,,,,,,,,,,,,,,
,9.35,Wait,9.23,COMPLETE_DIAG,9.30,NO_REQ,,,,,,,,,,,,,,,,,,,
,9.55,Wait,9.42,COMPLETE_DIAG,9.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,9.76,Wait,9.61,COMPLETE_DIAG,9.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,10.02,Wait,9.84,COMPLETE_DIAG,9.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,10.19,Wait,10.07,COMPLETE_DIAG,10.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,10.40,Wait,10.26,COMPLETE_DIAG,10.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,10.59,Wait,10.46,COMPLETE_DIAG,10.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,10.78,Wait,10.65,COMPLETE_DIAG,10.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,10.98,Wait,10.85,COMPLETE_DIAG,10.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,11.17,Wait,11.04,COMPLETE_DIAG,11.10,NO_REQ,,,,,,,,,,,,,,,,,,,
,11.38,Wait,11.24,COMPLETE_DIAG,11.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,11.56,Wait,11.44,COMPLETE_DIAG,11.49,NO_REQ,,,,,,,,,,,,,,,,,,,
,11.76,Wait,11.63,COMPLETE_DIAG,11.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,11.95,Wait,11.82,COMPLETE_DIAG,11.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,12.15,Wait,12.01,COMPLETE_DIAG,12.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,12.35,Wait,12.22,COMPLETE_DIAG,12.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,12.54,Wait,12.42,COMPLETE_DIAG,12.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,12.74,Wait,12.60,COMPLETE_DIAG,12.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,12.93,Wait,12.79,COMPLETE_DIAG,12.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,13.12,Wait,13.00,COMPLETE_DIAG,13.05,NO_REQ,,,,,,,,,,,,,,,,,,,
,13.30,Wait,13.17,COMPLETE_DIAG,13.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,13.47,Wait,13.35,COMPLETE_DIAG,13.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,13.65,Wait,13.52,COMPLETE_DIAG,13.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,13.84,Wait,13.71,COMPLETE_DIAG,13.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,14.05,Wait,13.91,COMPLETE_DIAG,13.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,14.25,Wait,14.12,COMPLETE_DIAG,14.18,NO_REQ,,,,,,,,,,,,,,,,,,,
,14.44,Wait,14.30,COMPLETE_DIAG,14.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,14.65,Wait,14.53,COMPLETE_DIAG,14.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,14.84,Wait,14.72,COMPLETE_DIAG,14.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,15.05,Wait,14.91,COMPLETE_DIAG,14.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,15.26,Wait,15.13,COMPLETE_DIAG,15.18,NO_REQ,,,,,,,,,,,,,,,,,,,
,15.46,Wait,15.32,COMPLETE_DIAG,15.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,15.64,Wait,15.51,COMPLETE_DIAG,15.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,15.85,Wait,15.71,COMPLETE_DIAG,15.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,16.05,Wait,15.91,COMPLETE_DIAG,15.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,16.24,Wait,16.10,COMPLETE_DIAG,16.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,16.44,Wait,16.30,COMPLETE_DIAG,16.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,16.64,Wait,16.51,COMPLETE_DIAG,16.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,16.84,Wait,16.70,COMPLETE_DIAG,16.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,17.03,Wait,16.90,COMPLETE_DIAG,16.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,17.23,Wait,17.10,COMPLETE_DIAG,17.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,17.49,Wait,17.29,COMPLETE_DIAG,17.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,17.70,Wait,17.56,COMPLETE_DIAG,17.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,17.90,Wait,17.76,COMPLETE_DIAG,17.82,NO_REQ,,,,,,,,,,,,,,,,,,,
,18.09,Wait,17.96,COMPLETE_DIAG,18.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,18.27,Wait,18.16,COMPLETE_DIAG,18.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,18.48,Wait,18.33,COMPLETE_DIAG,18.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,18.66,Wait,18.54,COMPLETE_DIAG,18.60,NO_REQ,,,,,,,,,,,,,,,,,,,
,18.87,Wait,18.73,COMPLETE_DIAG,18.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,19.07,Wait,18.93,COMPLETE_DIAG,19.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,19.28,Wait,19.15,COMPLETE_DIAG,19.22,NO_REQ,,,,,,,,,,,,,,,,,,,
,19.62,Wait,19.35,COMPLETE_DIAG,19.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,19.81,Wait,19.69,COMPLETE_DIAG,19.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,19.99,Wait,19.87,COMPLETE_DIAG,19.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,20.19,Wait,20.06,COMPLETE_DIAG,20.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,20.39,Wait,20.26,COMPLETE_DIAG,20.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,20.57,Wait,20.45,COMPLETE_DIAG,20.51,NO_REQ,,,,,,,,,,,,,,,,,,,
,20.76,Wait,20.63,COMPLETE_DIAG,20.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,20.96,Wait,20.83,COMPLETE_DIAG,20.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,21.17,Wait,21.02,COMPLETE_DIAG,21.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,21.37,Wait,21.25,COMPLETE_DIAG,21.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,21.57,Wait,21.44,COMPLETE_DIAG,21.51,NO_REQ,,,,,,,,,,,,,,,,,,,
,21.78,Wait,21.63,COMPLETE_DIAG,21.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,21.97,Wait,21.83,COMPLETE_DIAG,21.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,22.17,Wait,22.05,COMPLETE_DIAG,22.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,22.38,Wait,22.24,COMPLETE_DIAG,22.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,22.57,Wait,22.44,COMPLETE_DIAG,22.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,22.75,Wait,22.63,COMPLETE_DIAG,22.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,23.00,Wait,22.86,COMPLETE_DIAG,22.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,23.20,Wait,23.06,COMPLETE_DIAG,23.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,23.40,Wait,23.26,COMPLETE_DIAG,23.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,23.61,Wait,23.48,COMPLETE_DIAG,23.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,23.81,Wait,23.68,COMPLETE_DIAG,23.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,24.03,Wait,23.88,COMPLETE_DIAG,23.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,24.22,Wait,24.10,COMPLETE_DIAG,24.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,24.42,Wait,24.29,COMPLETE_DIAG,24.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,24.62,Wait,24.47,COMPLETE_DIAG,24.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,24.83,Wait,24.69,COMPLETE_DIAG,24.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,25.03,Wait,24.90,COMPLETE_DIAG,24.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,25.21,Wait,25.08,COMPLETE_DIAG,25.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,25.44,Wait,25.29,COMPLETE_DIAG,25.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,25.66,Wait,25.51,COMPLETE_DIAG,25.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,25.88,Wait,25.73,COMPLETE_DIAG,25.80,NO_REQ,,,,,,,,,,,,,,,,,,,
,26.08,Wait,25.94,COMPLETE_DIAG,26.01,NO_REQ,,,,,,,,,,,,,,,,,,,
,26.26,Wait,26.14,COMPLETE_DIAG,26.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,26.47,Wait,26.33,COMPLETE_DIAG,26.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,26.67,Wait,26.54,COMPLETE_DIAG,26.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,26.85,Wait,26.74,COMPLETE_DIAG,26.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,27.06,Wait,26.91,COMPLETE_DIAG,27.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,27.24,REQ,27.12,COMPLETE_DIAG,27.18,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,27.44,REQ,27.30,COMPLETE_DIAG,27.40,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,27.90,RESP,27.52,COMPLETE_DIAG,27.58,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,28.20,RESP,28.04,COMPLETE_DIAG,28.12,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,28.40,RESP,28.27,COMPLETE_DIAG,28.32,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,28.61,RESP,28.47,COMPLETE_DIAG,28.54,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,28.80,Wait,28.67,COMPLETE_DIAG,28.73,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,29.01,Wait,28.87,COMPLETE_DIAG,28.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,29.23,Wait,29.08,COMPLETE_DIAG,29.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,29.41,Wait,29.29,COMPLETE_DIAG,29.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,29.60,Wait,29.48,COMPLETE_DIAG,29.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,29.86,Wait,29.67,COMPLETE_DIAG,29.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,30.04,Wait,29.91,COMPLETE_DIAG,29.99,NO_REQ,,,,,,,,,,,,,,,,,,,
,30.23,Wait,30.11,COMPLETE_DIAG,30.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,30.44,Wait,30.30,COMPLETE_DIAG,30.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,30.67,Wait,30.52,COMPLETE_DIAG,30.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,30.86,Wait,30.73,COMPLETE_DIAG,30.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,31.07,Wait,30.94,COMPLETE_DIAG,31.01,NO_REQ,,,,,,,,,,,,,,,,,,,
,31.26,Wait,31.14,COMPLETE_DIAG,31.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,31.47,Wait,31.32,COMPLETE_DIAG,31.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,31.66,Wait,31.53,COMPLETE_DIAG,31.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,31.86,Wait,31.73,COMPLETE_DIAG,31.80,NO_REQ,,,,,,,,,,,,,,,,,,,
,32.04,Wait,31.92,COMPLETE_DIAG,31.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,32.23,Wait,32.11,COMPLETE_DIAG,32.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,32.43,Wait,32.30,COMPLETE_DIAG,32.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,32.62,Wait,32.50,COMPLETE_DIAG,32.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,32.84,Wait,32.68,COMPLETE_DIAG,32.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,33.04,Wait,32.92,COMPLETE_DIAG,32.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,33.23,Wait,33.10,COMPLETE_DIAG,33.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,33.43,Wait,33.29,COMPLETE_DIAG,33.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,33.61,Wait,33.49,COMPLETE_DIAG,33.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,33.81,Wait,33.68,COMPLETE_DIAG,33.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,34.00,Wait,33.87,COMPLETE_DIAG,33.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,34.20,Wait,34.07,COMPLETE_DIAG,34.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,34.40,Wait,34.26,COMPLETE_DIAG,34.32,NO_REQ,,,,,,,,,,,,,,,,,,,
,34.60,Wait,34.46,COMPLETE_DIAG,34.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,34.80,Wait,34.67,COMPLETE_DIAG,34.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,35.01,Wait,34.88,COMPLETE_DIAG,34.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,35.22,Wait,35.08,COMPLETE_DIAG,35.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,35.40,Wait,35.28,COMPLETE_DIAG,35.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,35.61,Wait,35.47,COMPLETE_DIAG,35.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,35.79,Wait,35.67,COMPLETE_DIAG,35.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,35.99,Wait,35.86,COMPLETE_DIAG,35.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,36.20,Wait,36.07,COMPLETE_DIAG,36.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,36.38,Wait,36.27,COMPLETE_DIAG,36.32,NO_REQ,,,,,,,,,,,,,,,,,,,
,36.58,Wait,36.45,COMPLETE_DIAG,36.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,36.81,Wait,36.67,COMPLETE_DIAG,36.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,37.00,Wait,36.87,COMPLETE_DIAG,36.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,37.21,Wait,37.08,COMPLETE_DIAG,37.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,37.41,Wait,37.28,COMPLETE_DIAG,37.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,37.61,Wait,37.46,COMPLETE_DIAG,37.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,37.79,Wait,37.67,COMPLETE_DIAG,37.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,38.02,Wait,37.86,COMPLETE_DIAG,37.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,38.21,Wait,38.09,COMPLETE_DIAG,38.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,38.43,Wait,38.29,COMPLETE_DIAG,38.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,38.64,Wait,38.50,COMPLETE_DIAG,38.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,38.83,Wait,38.70,COMPLETE_DIAG,38.76,NO_REQ,,,,,,,,,,,,,,,,,,,
,39.05,Wait,38.90,COMPLETE_DIAG,38.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,39.25,Wait,39.12,COMPLETE_DIAG,39.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,39.46,Wait,39.32,COMPLETE_DIAG,39.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,39.65,Wait,39.52,COMPLETE_DIAG,39.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,39.92,Wait,39.73,COMPLETE_DIAG,39.85,NO_REQ,,,,,,,,,,,,,,,,,,,
,40.11,Wait,39.98,COMPLETE_DIAG,40.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,40.29,Wait,40.16,COMPLETE_DIAG,40.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,40.48,Wait,40.35,COMPLETE_DIAG,40.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,40.68,Wait,40.54,COMPLETE_DIAG,40.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,40.90,Wait,40.75,COMPLETE_DIAG,40.82,NO_REQ,,,,,,,,,,,,,,,,,,,
,41.09,Wait,40.96,COMPLETE_DIAG,41.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,41.31,Wait,41.15,COMPLETE_DIAG,41.22,NO_REQ,,,,,,,,,,,,,,,,,,,
,41.51,Wait,41.37,COMPLETE_DIAG,41.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,41.70,Wait,41.58,COMPLETE_DIAG,41.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,41.90,Wait,41.77,COMPLETE_DIAG,41.82,NO_REQ,,,,,,,,,,,,,,,,,,,
,42.10,Wait,41.97,COMPLETE_DIAG,42.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,42.28,Wait,42.15,COMPLETE_DIAG,42.22,NO_REQ,,,,,,,,,,,,,,,,,,,
,42.48,Wait,42.36,COMPLETE_DIAG,42.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,42.65,Wait,42.53,COMPLETE_DIAG,42.60,NO_REQ,,,,,,,,,,,,,,,,,,,
,42.86,Wait,42.72,COMPLETE_DIAG,42.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,43.04,Wait,42.92,COMPLETE_DIAG,42.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,43.24,Wait,43.11,COMPLETE_DIAG,43.18,NO_REQ,,,,,,,,,,,,,,,,,,,
,43.43,Wait,43.31,COMPLETE_DIAG,43.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,43.65,Wait,43.51,COMPLETE_DIAG,43.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,43.86,Wait,43.73,COMPLETE_DIAG,43.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,44.06,Wait,43.92,COMPLETE_DIAG,43.99,NO_REQ,,,,,,,,,,,,,,,,,,,
,44.27,Wait,44.12,COMPLETE_DIAG,44.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,44.47,Wait,44.33,COMPLETE_DIAG,44.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,44.67,Wait,44.54,COMPLETE_DIAG,44.60,NO_REQ,,,,,,,,,,,,,,,,,,,
,44.93,Wait,44.74,COMPLETE_DIAG,44.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,45.15,Wait,45.00,COMPLETE_DIAG,45.05,NO_REQ,,,,,,,,,,,,,,,,,,,
,45.35,Wait,45.21,COMPLETE_DIAG,45.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,45.53,Wait,45.40,COMPLETE_DIAG,45.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,45.72,Wait,45.59,COMPLETE_DIAG,45.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,45.92,Wait,45.79,COMPLETE_DIAG,45.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,46.10,Wait,45.99,COMPLETE_DIAG,46.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,46.30,Wait,46.17,COMPLETE_DIAG,46.24,NO_REQ,,,,,,,,,,,,,,,,,,,
,46.50,Wait,46.37,COMPLETE_DIAG,46.43,NO_REQ,,,,,,,,,,,,,,,,,,,
,46.69,Wait,46.56,COMPLETE_DIAG,46.63,NO_REQ,,,,,,,,,,,,,,,,,,,
,46.93,Wait,46.77,COMPLETE_DIAG,46.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,47.19,Wait,47.02,COMPLETE_DIAG,47.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,47.41,Wait,47.25,COMPLETE_DIAG,47.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,47.60,Wait,47.47,COMPLETE_DIAG,47.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,47.82,Wait,47.67,COMPLETE_DIAG,47.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,48.00,Wait,47.88,COMPLETE_DIAG,47.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,48.21,Wait,48.08,COMPLETE_DIAG,48.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,48.41,Wait,48.28,COMPLETE_DIAG,48.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,48.68,Wait,48.53,COMPLETE_DIAG,48.60,NO_REQ,,,,,,,,,,,,,,,,,,,
,48.91,Wait,48.75,COMPLETE_DIAG,48.82,NO_REQ,,,,,,,,,,,,,,,,,,,
,49.17,Wait,49.03,COMPLETE_DIAG,49.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,49.38,Wait,49.25,COMPLETE_DIAG,49.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,49.57,Wait,49.44,COMPLETE_DIAG,49.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,49.86,Wait,49.67,COMPLETE_DIAG,49.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,50.14,Wait,49.98,COMPLETE_DIAG,50.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,50.33,Wait,50.19,COMPLETE_DIAG,50.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,50.57,Wait,50.43,COMPLETE_DIAG,50.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,50.82,Wait,50.66,COMPLETE_DIAG,50.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,51.04,Wait,50.90,COMPLETE_DIAG,50.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,51.28,Wait,51.14,COMPLETE_DIAG,51.22,NO_REQ,,,,,,,,,,,,,,,,,,,
,51.58,Wait,51.43,COMPLETE_DIAG,51.51,NO_REQ,,,,,,,,,,,,,,,,,,,
,51.93,Wait,51.79,COMPLETE_DIAG,51.85,NO_REQ,,,,,,,,,,,,,,,,,,,
,52.16,Wait,52.01,COMPLETE_DIAG,52.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,52.42,Wait,52.26,COMPLETE_DIAG,52.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,52.66,Wait,52.49,COMPLETE_DIAG,52.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,52.88,Wait,52.71,COMPLETE_DIAG,52.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,53.10,Wait,52.95,COMPLETE_DIAG,53.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,53.32,Wait,53.18,COMPLETE_DIAG,53.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,53.60,Wait,53.40,COMPLETE_DIAG,53.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,53.87,Wait,53.71,COMPLETE_DIAG,53.80,NO_REQ,,,,,,,,,,,,,,,,,,,
,54.09,Wait,53.93,COMPLETE_DIAG,54.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,54.31,Wait,54.15,COMPLETE_DIAG,54.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,54.55,Wait,54.38,COMPLETE_DIAG,54.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,54.77,Wait,54.62,COMPLETE_DIAG,54.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,55.04,Wait,54.91,COMPLETE_DIAG,54.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,55.27,Wait,55.10,COMPLETE_DIAG,55.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,55.52,Wait,55.36,COMPLETE_DIAG,55.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,55.72,Wait,55.59,COMPLETE_DIAG,55.65,NO_REQ,,,,,,,,,,,,,,,,,,,
,55.95,Wait,55.80,COMPLETE_DIAG,55.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,56.18,Wait,56.04,COMPLETE_DIAG,56.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,56.41,Wait,56.25,COMPLETE_DIAG,56.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,58.52,RESP,56.47,COMPLETE_DIAG,58.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,58.72,RESP,58.58,COMPLETE_DIAG,58.64,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,59.14,Wait,58.93,COMPLETE_DIAG,59.01,NO_REQ,,,,,,,,,,,,,,,,,,,
,59.35,Wait,59.21,COMPLETE_DIAG,59.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,59.55,Wait,59.42,COMPLETE_DIAG,59.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,59.75,Wait,59.60,COMPLETE_DIAG,59.68,NO_REQ,,,,,,,,,,,,,,,,,,,
,59.99,Wait,59.81,COMPLETE_DIAG,59.88,NO_REQ,,,,,,,,,,,,,,,,,,,
,60.28,Wait,60.10,COMPLETE_DIAG,60.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,60.47,Wait,60.34,COMPLETE_DIAG,60.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,60.71,Wait,60.55,COMPLETE_DIAG,60.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,60.92,Wait,60.78,COMPLETE_DIAG,60.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,61.13,Wait,60.98,COMPLETE_DIAG,61.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,61.33,Wait,61.18,COMPLETE_DIAG,61.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,61.58,Wait,61.41,COMPLETE_DIAG,61.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,61.79,Wait,61.66,COMPLETE_DIAG,61.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,62.00,Wait,61.85,COMPLETE_DIAG,61.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,62.23,Wait,62.08,COMPLETE_DIAG,62.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,62.47,Wait,62.29,COMPLETE_DIAG,62.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,62.68,Wait,62.53,COMPLETE_DIAG,62.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,62.90,Wait,62.76,COMPLETE_DIAG,62.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,63.10,Wait,62.96,COMPLETE_DIAG,63.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,63.29,Wait,63.17,COMPLETE_DIAG,63.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,63.51,Wait,63.35,COMPLETE_DIAG,63.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,63.70,Wait,63.58,COMPLETE_DIAG,63.63,NO_REQ,,,,,,,,,,,,,,,,,,,
,63.98,Wait,63.80,COMPLETE_DIAG,63.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,64.23,Wait,64.08,COMPLETE_DIAG,64.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,64.45,Wait,64.31,COMPLETE_DIAG,64.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,64.66,Wait,64.53,COMPLETE_DIAG,64.60,NO_REQ,,,,,,,,,,,,,,,,,,,
,64.89,Wait,64.73,COMPLETE_DIAG,64.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,65.10,Wait,64.95,COMPLETE_DIAG,65.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,65.33,Wait,65.19,COMPLETE_DIAG,65.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,65.55,Wait,65.40,COMPLETE_DIAG,65.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,65.78,Wait,65.63,COMPLETE_DIAG,65.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,65.96,Wait,65.83,COMPLETE_DIAG,65.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,66.15,Wait,66.03,COMPLETE_DIAG,66.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,66.37,Wait,66.23,COMPLETE_DIAG,66.30,NO_REQ,,,,,,,,,,,,,,,,,,,
,66.57,Wait,66.45,COMPLETE_DIAG,66.51,NO_REQ,,,,,,,,,,,,,,,,,,,
,66.82,Wait,66.65,COMPLETE_DIAG,66.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,67.04,Wait,66.91,COMPLETE_DIAG,66.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,67.26,Wait,67.10,COMPLETE_DIAG,67.18,NO_REQ,,,,,,,,,,,,,,,,,,,
,67.47,Wait,67.32,COMPLETE_DIAG,67.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,67.66,Wait,67.53,COMPLETE_DIAG,67.60,NO_REQ,,,,,,,,,,,,,,,,,,,
,67.88,Wait,67.73,COMPLETE_DIAG,67.80,NO_REQ,,,,,,,,,,,,,,,,,,,
,68.12,Wait,67.96,COMPLETE_DIAG,68.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,68.33,Wait,68.20,COMPLETE_DIAG,68.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,68.59,Wait,68.45,COMPLETE_DIAG,68.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,68.82,Wait,68.66,COMPLETE_DIAG,68.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,69.03,Wait,68.87,COMPLETE_DIAG,68.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,69.24,Wait,69.11,COMPLETE_DIAG,69.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,69.44,Wait,69.31,COMPLETE_DIAG,69.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,70.92,Wait,69.51,COMPLETE_DIAG,69.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,71.17,Wait,70.99,COMPLETE_DIAG,71.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,71.41,Wait,71.24,COMPLETE_DIAG,71.32,NO_REQ,,,,,,,,,,,,,,,,,,,
,71.61,Wait,71.47,COMPLETE_DIAG,71.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,71.83,Wait,71.69,COMPLETE_DIAG,71.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,72.07,Wait,71.90,COMPLETE_DIAG,71.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,72.31,Wait,72.15,COMPLETE_DIAG,72.22,NO_REQ,,,,,,,,,,,,,,,,,,,
,72.53,Wait,72.40,COMPLETE_DIAG,72.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,72.79,Wait,72.60,COMPLETE_DIAG,72.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,73.00,Wait,72.87,COMPLETE_DIAG,72.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,73.17,Wait,73.06,COMPLETE_DIAG,73.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,73.35,Wait,73.23,COMPLETE_DIAG,73.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,73.54,Wait,73.42,COMPLETE_DIAG,73.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,73.75,Wait,73.62,COMPLETE_DIAG,73.68,NO_REQ,,,,,,,,,,,,,,,,,,,
,73.93,Wait,73.81,COMPLETE_DIAG,73.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,74.12,Wait,74.00,COMPLETE_DIAG,74.05,NO_REQ,,,,,,,,,,,,,,,,,,,
,74.32,Wait,74.18,COMPLETE_DIAG,74.24,NO_REQ,,,,,,,,,,,,,,,,,,,
,74.53,Wait,74.39,COMPLETE_DIAG,74.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,74.76,Wait,74.62,COMPLETE_DIAG,74.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,74.96,Wait,74.82,COMPLETE_DIAG,74.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,75.18,Wait,75.03,COMPLETE_DIAG,75.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,75.37,Wait,75.24,COMPLETE_DIAG,75.32,NO_REQ,,,,,,,,,,,,,,,,,,,
,75.56,Wait,75.44,COMPLETE_DIAG,75.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,75.77,Wait,75.63,COMPLETE_DIAG,75.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,75.96,Wait,75.83,COMPLETE_DIAG,75.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,76.16,Wait,76.03,COMPLETE_DIAG,76.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,76.35,Wait,76.22,COMPLETE_DIAG,76.30,NO_REQ,,,,,,,,,,,,,,,,,,,
,76.57,Wait,76.42,COMPLETE_DIAG,76.49,NO_REQ,,,,,,,,,,,,,,,,,,,
,76.79,Wait,76.65,COMPLETE_DIAG,76.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,76.99,Wait,76.85,COMPLETE_DIAG,76.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,77.20,Wait,77.05,COMPLETE_DIAG,77.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,77.40,Wait,77.26,COMPLETE_DIAG,77.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,77.61,Wait,77.47,COMPLETE_DIAG,77.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,77.80,Wait,77.67,COMPLETE_DIAG,77.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,77.98,Wait,77.86,COMPLETE_DIAG,77.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,78.18,Wait,78.04,COMPLETE_DIAG,78.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,78.41,Wait,78.26,COMPLETE_DIAG,78.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,78.59,Wait,78.47,COMPLETE_DIAG,78.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,78.78,Wait,78.65,COMPLETE_DIAG,78.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,79.00,Wait,78.85,COMPLETE_DIAG,78.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,79.18,Wait,79.06,COMPLETE_DIAG,79.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,79.40,Wait,79.25,COMPLETE_DIAG,79.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,79.64,Wait,79.46,COMPLETE_DIAG,79.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,79.83,Wait,79.71,COMPLETE_DIAG,79.76,NO_REQ,,,,,,,,,,,,,,,,,,,
,80.02,Wait,79.90,COMPLETE_DIAG,79.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,80.21,Wait,80.09,COMPLETE_DIAG,80.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,80.43,Wait,80.27,COMPLETE_DIAG,80.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,80.63,Wait,80.49,COMPLETE_DIAG,80.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,80.84,Wait,80.70,COMPLETE_DIAG,80.76,NO_REQ,,,,,,,,,,,,,,,,,,,
,81.02,Wait,80.90,COMPLETE_DIAG,80.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,81.26,Wait,81.09,COMPLETE_DIAG,81.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,81.46,Wait,81.33,COMPLETE_DIAG,81.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,81.65,Wait,81.52,COMPLETE_DIAG,81.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,81.85,Wait,81.72,COMPLETE_DIAG,81.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,82.03,Wait,81.92,COMPLETE_DIAG,81.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,82.20,Wait,82.08,COMPLETE_DIAG,82.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,82.42,Wait,82.26,COMPLETE_DIAG,82.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,82.60,Wait,82.48,COMPLETE_DIAG,82.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,82.82,Wait,82.67,COMPLETE_DIAG,82.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,83.01,Wait,82.88,COMPLETE_DIAG,82.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,83.19,Wait,83.08,COMPLETE_DIAG,83.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,83.40,Wait,83.27,COMPLETE_DIAG,83.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,83.59,Wait,83.46,COMPLETE_DIAG,83.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,83.77,Wait,83.65,COMPLETE_DIAG,83.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,83.96,Wait,83.84,COMPLETE_DIAG,83.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,84.17,Wait,84.04,COMPLETE_DIAG,84.10,NO_REQ,,,,,,,,,,,,,,,,,,,
,84.37,Wait,84.23,COMPLETE_DIAG,84.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,84.57,Wait,84.43,COMPLETE_DIAG,84.49,NO_REQ,,,,,,,,,,,,,,,,,,,
,84.76,Wait,84.65,COMPLETE_DIAG,84.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,84.94,Wait,84.83,COMPLETE_DIAG,84.88,NO_REQ,,,,,,,,,,,,,,,,,,,
,85.14,Wait,85.01,COMPLETE_DIAG,85.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,85.32,Wait,85.20,COMPLETE_DIAG,85.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,85.51,Wait,85.39,COMPLETE_DIAG,85.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,85.70,Wait,85.57,COMPLETE_DIAG,85.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,85.90,Wait,85.76,COMPLETE_DIAG,85.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,86.10,Wait,85.96,COMPLETE_DIAG,86.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,86.29,Wait,86.15,COMPLETE_DIAG,86.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,86.49,Wait,86.36,COMPLETE_DIAG,86.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,86.71,Wait,86.56,COMPLETE_DIAG,86.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,86.90,Wait,86.77,COMPLETE_DIAG,86.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,87.10,Wait,86.97,COMPLETE_DIAG,87.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,87.29,Wait,87.17,COMPLETE_DIAG,87.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,87.48,REQ,87.36,COMPLETE_DIAG,87.42,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,87.71,REQ,87.55,COMPLETE_DIAG,87.63,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,87.91,REQ,87.77,COMPLETE_DIAG,87.82,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,88.12,RESP,88.00,COMPLETE_DIAG,88.06,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,88.32,RESP,88.19,COMPLETE_DIAG,88.27,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,88.52,RESP,88.39,COMPLETE_DIAG,88.44,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,88.70,RESP,88.57,COMPLETE_DIAG,88.63,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,88.90,ready,88.77,COMPLETE_DIAG,88.83,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,89.10,Wait,88.97,COMPLETE_DIAG,89.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,89.28,Wait,89.15,COMPLETE_DIAG,89.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,89.47,Wait,89.34,COMPLETE_DIAG,89.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,89.69,Wait,89.54,COMPLETE_DIAG,89.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,89.88,Wait,89.75,COMPLETE_DIAG,89.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,90.05,Wait,89.94,COMPLETE_DIAG,89.99,NO_REQ,,,,,,,,,,,,,,,,,,,
,90.25,Wait,90.12,COMPLETE_DIAG,90.18,NO_REQ,,,,,,,,,,,,,,,,,,,
,90.44,Wait,90.30,COMPLETE_DIAG,90.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,90.63,Wait,90.51,COMPLETE_DIAG,90.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,90.82,Wait,90.69,COMPLETE_DIAG,90.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,91.01,Wait,90.88,COMPLETE_DIAG,90.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,91.20,Wait,91.07,COMPLETE_DIAG,91.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,91.41,Wait,91.27,COMPLETE_DIAG,91.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,91.63,Wait,91.47,COMPLETE_DIAG,91.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,91.84,Wait,91.68,COMPLETE_DIAG,91.76,NO_REQ,,,,,,,,,,,,,,,,,,,
,92.03,Wait,91.90,COMPLETE_DIAG,91.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,92.21,Wait,92.09,COMPLETE_DIAG,92.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,92.41,Wait,92.27,COMPLETE_DIAG,92.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,92.60,Wait,92.48,COMPLETE_DIAG,92.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,92.79,Wait,92.67,COMPLETE_DIAG,92.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,92.97,Wait,92.86,COMPLETE_DIAG,92.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,93.18,Wait,93.06,COMPLETE_DIAG,93.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,93.40,Wait,93.24,COMPLETE_DIAG,93.32,NO_REQ,,,,,,,,,,,,,,,,,,,
,93.60,Wait,93.47,COMPLETE_DIAG,93.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,93.90,Wait,93.77,COMPLETE_DIAG,93.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,94.09,Wait,93.96,COMPLETE_DIAG,94.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,94.27,Wait,94.16,COMPLETE_DIAG,94.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,94.47,Wait,94.34,COMPLETE_DIAG,94.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,94.65,Wait,94.53,COMPLETE_DIAG,94.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,94.85,Wait,94.73,COMPLETE_DIAG,94.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,95.04,Wait,94.91,COMPLETE_DIAG,94.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,95.24,Wait,95.12,COMPLETE_DIAG,95.18,NO_REQ,,,,,,,,,,,,,,,,,,,
,95.43,Wait,95.31,COMPLETE_DIAG,95.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,95.62,Wait,95.49,COMPLETE_DIAG,95.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,95.81,Wait,95.68,COMPLETE_DIAG,95.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,95.99,Wait,95.88,COMPLETE_DIAG,95.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,96.19,Wait,96.06,COMPLETE_DIAG,96.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,96.40,Wait,96.25,COMPLETE_DIAG,96.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,96.58,Wait,96.46,COMPLETE_DIAG,96.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,96.80,Wait,96.65,COMPLETE_DIAG,96.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,97.01,Wait,96.87,COMPLETE_DIAG,96.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,97.19,Wait,97.07,COMPLETE_DIAG,97.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,97.53,Wait,97.27,COMPLETE_DIAG,97.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,97.71,Wait,97.58,COMPLETE_DIAG,97.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,97.90,Wait,97.77,COMPLETE_DIAG,97.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,98.14,Wait,97.99,Wait,98.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,98.57,Wait,98.22,Wait,98.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,98.83,Wait,98.68,Wait,98.76,NO_REQ,,,,,,,,,,,,,,,,,,,
,99.06,Wait,98.91,Wait,98.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,99.26,Wait,99.13,Wait,99.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,99.47,Wait,99.33,Wait,99.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,99.67,Wait,99.56,Wait,99.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,99.84,Wait,99.73,Wait,99.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,100.02,Wait,99.91,Wait,99.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,100.22,Wait,100.08,Wait,100.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,100.41,Wait,100.28,Wait,100.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,100.60,Wait,100.46,Wait,100.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,100.78,Wait,100.65,Wait,100.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,100.96,Wait,100.84,Wait,100.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,101.16,Wait,101.03,Wait,101.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,101.36,Wait,101.23,Wait,101.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,101.53,Wait,101.42,Wait,101.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,101.72,Wait,101.59,Wait,101.65,NO_REQ,,,,,,,,,,,,,,,,,,,
,101.92,Wait,101.80,Wait,101.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,102.12,Wait,101.98,Wait,102.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,102.31,Wait,102.18,Wait,102.24,NO_REQ,,,,,,,,,,,,,,,,,,,
,102.49,Wait,102.38,Wait,102.43,NO_REQ,,,,,,,,,,,,,,,,,,,
,102.70,Wait,102.56,Wait,102.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,102.88,Wait,102.76,Wait,102.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,103.10,Wait,102.96,Wait,103.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,103.29,Wait,103.16,Wait,103.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,103.48,Wait,103.36,Wait,103.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,103.67,Wait,103.54,Wait,103.60,NO_REQ,,,,,,,,,,,,,,,,,,,
,103.87,Wait,103.74,Wait,103.80,NO_REQ,,,,,,,,,,,,,,,,,,,
,104.05,Wait,103.93,Wait,103.99,NO_REQ,,,,,,,,,,,,,,,,,,,
,104.23,Wait,104.12,Wait,104.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,104.42,Wait,104.30,Wait,104.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,104.60,Wait,104.48,Wait,104.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,104.79,Wait,104.67,Wait,104.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,105.00,Wait,104.86,Wait,104.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,105.21,Wait,105.09,Wait,105.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,105.40,Wait,105.28,Wait,105.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,105.61,Wait,105.46,Wait,105.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,105.80,Wait,105.67,Wait,105.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,106.00,Wait,105.87,Wait,105.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,106.21,Wait,106.07,Wait,106.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,106.58,Wait,106.39,Wait,106.51,NO_REQ,,,,,,,,,,,,,,,,,,,
,106.82,Wait,106.68,Wait,106.76,NO_REQ,,,,,,,,,,,,,,,,,,,
,107.17,Wait,106.90,Wait,107.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,107.37,Wait,107.23,Wait,107.30,NO_REQ,,,,,,,,,,,,,,,,,,,
,107.58,Wait,107.43,Wait,107.51,NO_REQ,,,,,,,,,,,,,,,,,,,
,107.79,Wait,107.65,Wait,107.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,108.01,Wait,107.86,Wait,107.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,108.22,Wait,108.08,Wait,108.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,108.41,Wait,108.28,Wait,108.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,108.60,Wait,108.48,Wait,108.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,108.79,Wait,108.67,Wait,108.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,109.00,Wait,108.87,Wait,108.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,109.21,Wait,109.08,Wait,109.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,109.42,Wait,109.28,Wait,109.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,109.60,Wait,109.48,Wait,109.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,109.95,Wait,109.68,Wait,109.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,110.15,Wait,110.01,Wait,110.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,110.33,Wait,110.21,Wait,110.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,110.54,Wait,110.40,Wait,110.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,110.73,Wait,110.60,Wait,110.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,110.93,Wait,110.79,Wait,110.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,111.15,Wait,111.01,Wait,111.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,111.34,Wait,111.22,Wait,111.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,111.52,Wait,111.40,Wait,111.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,111.73,Wait,111.59,Wait,111.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,111.94,Wait,111.81,Wait,111.88,NO_REQ,,,,,,,,,,,,,,,,,,,
,112.14,Wait,112.01,Wait,112.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,112.32,Wait,112.20,Wait,112.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,112.55,Wait,112.42,Wait,112.49,NO_REQ,,,,,,,,,,,,,,,,,,,
,112.74,Wait,112.63,Wait,112.68,NO_REQ,,,,,,,,,,,,,,,,,,,
,112.93,Wait,112.80,Wait,112.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,113.13,Wait,113.00,Wait,113.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,113.34,Wait,113.18,Wait,113.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,113.55,Wait,113.41,Wait,113.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,113.74,Wait,113.60,Wait,113.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,113.96,Wait,113.81,Wait,113.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,114.20,Wait,114.05,Wait,114.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,114.45,Wait,114.26,Wait,114.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,114.65,Wait,114.51,Wait,114.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,114.96,Wait,114.73,Wait,114.88,NO_REQ,,,,,,,,,,,,,,,,,,,
,115.18,Wait,115.04,Wait,115.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,115.38,Wait,115.23,Wait,115.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,115.58,Wait,115.45,Wait,115.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,115.77,Wait,115.64,Wait,115.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,115.97,Wait,115.82,Wait,115.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,116.19,Wait,116.05,Wait,116.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,116.38,Wait,116.26,Wait,116.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,116.57,Wait,116.44,Wait,116.51,NO_REQ,,,,,,,,,,,,,,,,,,,
,116.76,Wait,116.63,Wait,116.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,116.94,Wait,116.83,Wait,116.88,NO_REQ,,,,,,,,,,,,,,,,,,,
,117.16,Wait,117.02,Wait,117.10,NO_REQ,,,,,,,,,,,,,,,,,,,
,117.35,Wait,117.22,Wait,117.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,117.54,REQ,117.42,Wait,117.49,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,117.83,REQ,117.62,Wait,117.76,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,118.02,REQ,117.88,Wait,117.95,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,118.23,RESP,118.09,Wait,118.16,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,118.42,RESP,118.29,Wait,118.35,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,118.61,RESP,118.48,Wait,118.54,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,118.94,RESP,118.81,Wait,118.89,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,119.14,Wait,119.01,Wait,119.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,119.32,Wait,119.20,Wait,119.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,119.52,Wait,119.39,Wait,119.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,119.73,Wait,119.57,Wait,119.65,NO_REQ,,,,,,,,,,,,,,,,,,,
,119.93,Wait,119.80,Wait,119.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,120.13,Wait,120.00,Wait,120.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,120.33,Wait,120.21,Wait,120.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,120.51,Wait,120.38,Wait,120.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,120.72,Wait,120.57,Wait,120.63,NO_REQ,,,,,,,,,,,,,,,,,,,
,120.92,Wait,120.79,Wait,120.85,NO_REQ,,,,,,,,,,,,,,,,,,,
,121.11,Wait,120.98,Wait,121.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,121.31,Wait,121.16,Wait,121.24,NO_REQ,,,,,,,,,,,,,,,,,,,
,121.50,Wait,121.37,Wait,121.43,NO_REQ,,,,,,,,,,,,,,,,,,,
,121.69,Wait,121.57,Wait,121.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,121.88,Wait,121.76,Wait,121.82,NO_REQ,,,,,,,,,,,,,,,,,,,
,122.08,Wait,121.95,Wait,122.01,NO_REQ,,,,,,,,,,,,,,,,,,,
,122.31,Wait,122.16,Wait,122.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,122.51,Wait,122.38,Wait,122.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,122.69,Wait,122.57,Wait,122.63,NO_REQ,,,,,,,,,,,,,,,,,,,
,122.93,Wait,122.76,Wait,122.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,123.15,Wait,123.00,Wait,123.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,123.36,Wait,123.23,Wait,123.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,123.56,Wait,123.43,Wait,123.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,123.78,Wait,123.63,Wait,123.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,123.96,Wait,123.84,Wait,123.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,124.16,Wait,124.02,Wait,124.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,124.35,Wait,124.21,Wait,124.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,124.53,Wait,124.40,Wait,124.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,124.74,Wait,124.58,Wait,124.68,NO_REQ,,,,,,,,,,,,,,,,,,,
,124.93,Wait,124.81,Wait,124.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,125.13,Wait,125.00,Wait,125.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,125.32,Wait,125.19,Wait,125.24,NO_REQ,,,,,,,,,,,,,,,,,,,
,125.53,Wait,125.39,Wait,125.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,125.72,Wait,125.59,Wait,125.65,NO_REQ,,,,,,,,,,,,,,,,,,,
,125.91,Wait,125.78,Wait,125.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,126.09,Wait,125.96,Wait,126.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,126.30,Wait,126.16,Wait,126.24,NO_REQ,,,,,,,,,,,,,,,,,,,
,126.52,Wait,126.39,Wait,126.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,126.70,Wait,126.58,Wait,126.63,NO_REQ,,,,,,,,,,,,,,,,,,,
,126.89,Wait,126.77,Wait,126.82,NO_REQ,,,,,,,,,,,,,,,,,,,
,127.07,Wait,126.94,Wait,127.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,127.26,Wait,127.13,Wait,127.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,127.45,Wait,127.33,Wait,127.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,127.64,Wait,127.52,Wait,127.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,127.83,Wait,127.69,Wait,127.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,128.02,Wait,127.89,Wait,127.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,128.19,Wait,128.07,Wait,128.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,128.39,Wait,128.26,Wait,128.32,NO_REQ,,,,,,,,,,,,,,,,,,,
,128.57,Wait,128.44,Wait,128.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,128.76,Wait,128.64,Wait,128.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,128.95,Wait,128.83,Wait,128.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,129.22,Wait,129.08,Wait,129.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,129.41,Wait,129.27,Wait,129.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,129.58,Wait,129.47,Wait,129.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,129.79,Wait,129.65,Wait,129.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,129.98,Wait,129.86,Wait,129.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,130.20,REQ,130.05,Wait,130.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,130.39,REQ,130.27,COMPLETE_DIAG,130.32,SWI_PSN,,,,,,,,,,,,,,,,,,,
,130.57,REQ,130.44,COMPLETE_DIAG,130.52,SWI_PSN,,,,,,,,,,,,,,,,,,,
,130.77,REQ,130.64,COMPLETE_DIAG,130.69,SWI_PSN,,,,,,,,,,,,,,,,,,,
,130.94,RESP,130.82,COMPLETE_DIAG,130.88,SWI_PSN,,,,,,,,,,,,,,,,,,,
,131.14,RESP,131.01,COMPLETE_DIAG,131.07,SWI_PSN,,,,,,,,,,,,,,,,,,,
,131.33,RESP,131.19,COMPLETE_DIAG,131.27,SWI_PSN,,,,,,,,,,,,,,,,,,,
,131.53,RESP,131.39,COMPLETE_DIAG,131.45,SWI_PSN,,,,,,,,,,,,,,,,,,,
,131.71,ready,131.58,COMPLETE_DIAG,131.66,SWI_PSN,,,,,,,,,,,,,,,,,,,
,131.91,Wait,131.77,COMPLETE_DIAG,131.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,132.10,Wait,131.98,COMPLETE_DIAG,132.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,132.30,Wait,132.17,COMPLETE_DIAG,132.24,NO_REQ,,,,,,,,,,,,,,,,,,,
,132.49,Wait,132.37,COMPLETE_DIAG,132.43,NO_REQ,,,,,,,,,,,,,,,,,,,
,132.69,Wait,132.55,COMPLETE_DIAG,132.63,NO_REQ,,,,,,,,,,,,,,,,,,,
,132.89,Wait,132.74,COMPLETE_DIAG,132.80,NO_REQ,,,,,,,,,,,,,,,,,,,
,133.07,Wait,132.95,COMPLETE_DIAG,133.01,NO_REQ,,,,,,,,,,,,,,,,,,,
,133.26,Wait,133.14,COMPLETE_DIAG,133.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,133.47,Wait,133.32,COMPLETE_DIAG,133.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,133.66,Wait,133.53,COMPLETE_DIAG,133.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,133.85,Wait,133.74,COMPLETE_DIAG,133.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,134.05,Wait,133.91,COMPLETE_DIAG,133.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,134.24,Wait,134.11,COMPLETE_DIAG,134.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,134.44,Wait,134.31,COMPLETE_DIAG,134.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,134.63,Wait,134.51,COMPLETE_DIAG,134.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,134.83,Wait,134.69,COMPLETE_DIAG,134.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,135.02,Wait,134.88,COMPLETE_DIAG,134.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,135.24,Wait,135.08,COMPLETE_DIAG,135.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,135.46,Wait,135.31,COMPLETE_DIAG,135.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,135.70,Wait,135.58,COMPLETE_DIAG,135.63,NO_REQ,,,,,,,,,,,,,,,,,,,
,135.89,Wait,135.77,COMPLETE_DIAG,135.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,136.08,Wait,135.94,COMPLETE_DIAG,136.01,NO_REQ,,,,,,,,,,,,,,,,,,,
,136.27,Wait,136.14,COMPLETE_DIAG,136.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,136.45,Wait,136.32,COMPLETE_DIAG,136.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,136.65,Wait,136.51,COMPLETE_DIAG,136.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,136.83,Wait,136.71,COMPLETE_DIAG,136.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,137.03,Wait,136.91,COMPLETE_DIAG,136.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,137.21,Wait,137.08,COMPLETE_DIAG,137.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,137.41,Wait,137.28,COMPLETE_DIAG,137.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,137.58,Wait,137.46,COMPLETE_DIAG,137.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,137.79,Wait,137.64,COMPLETE_DIAG,137.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,137.99,Wait,137.86,COMPLETE_DIAG,137.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,138.18,Wait,138.05,COMPLETE_DIAG,138.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,138.40,Wait,138.25,COMPLETE_DIAG,138.30,NO_REQ,,,,,,,,,,,,,,,,,,,
,138.59,Wait,138.46,COMPLETE_DIAG,138.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,138.87,Wait,138.65,COMPLETE_DIAG,138.80,NO_REQ,,,,,,,,,,,,,,,,,,,
,139.06,Wait,138.93,COMPLETE_DIAG,139.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,139.23,Wait,139.12,COMPLETE_DIAG,139.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,139.40,Wait,139.28,COMPLETE_DIAG,139.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,139.60,Wait,139.46,COMPLETE_DIAG,139.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,139.84,Wait,139.68,COMPLETE_DIAG,139.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,140.02,Wait,139.91,COMPLETE_DIAG,139.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,140.21,Wait,140.08,COMPLETE_DIAG,140.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,140.43,Wait,140.28,COMPLETE_DIAG,140.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,140.63,Wait,140.49,COMPLETE_DIAG,140.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,140.83,Wait,140.71,COMPLETE_DIAG,140.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,141.02,Wait,140.91,COMPLETE_DIAG,140.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,141.22,Wait,141.08,COMPLETE_DIAG,141.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,141.44,Wait,141.29,COMPLETE_DIAG,141.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,141.65,Wait,141.51,COMPLETE_DIAG,141.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,141.87,Wait,141.71,COMPLETE_DIAG,141.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,142.06,Wait,141.93,COMPLETE_DIAG,142.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,142.25,Wait,142.13,COMPLETE_DIAG,142.18,NO_REQ,,,,,,,,,,,,,,,,,,,
,142.45,Wait,142.33,COMPLETE_DIAG,142.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,142.63,Wait,142.52,COMPLETE_DIAG,142.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,142.85,Wait,142.71,COMPLETE_DIAG,142.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,143.05,Wait,142.93,COMPLETE_DIAG,143.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,143.26,Wait,143.13,COMPLETE_DIAG,143.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,143.47,Wait,143.33,COMPLETE_DIAG,143.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,143.65,Wait,143.53,COMPLETE_DIAG,143.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,143.84,Wait,143.71,COMPLETE_DIAG,143.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,144.04,Wait,143.91,COMPLETE_DIAG,143.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,144.23,Wait,144.10,COMPLETE_DIAG,144.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,144.44,Wait,144.30,COMPLETE_DIAG,144.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,144.63,Wait,144.49,COMPLETE_DIAG,144.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,144.82,Wait,144.69,COMPLETE_DIAG,144.76,NO_REQ,,,,,,,,,,,,,,,,,,,
,145.03,Wait,144.90,COMPLETE_DIAG,144.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,145.23,Wait,145.09,COMPLETE_DIAG,145.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,145.42,Wait,145.29,COMPLETE_DIAG,145.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,145.62,Wait,145.49,COMPLETE_DIAG,145.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,145.81,Wait,145.68,COMPLETE_DIAG,145.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,146.01,Wait,145.88,COMPLETE_DIAG,145.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,146.20,Wait,146.08,COMPLETE_DIAG,146.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,146.41,Wait,146.27,COMPLETE_DIAG,146.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,146.61,Wait,146.47,COMPLETE_DIAG,146.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,146.82,Wait,146.68,COMPLETE_DIAG,146.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,147.00,Wait,146.87,COMPLETE_DIAG,146.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,147.22,Wait,147.07,COMPLETE_DIAG,147.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,147.45,Wait,147.29,COMPLETE_DIAG,147.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,149.42,REQ,147.52,COMPLETE_DIAG,147.58,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,149.64,Wait,149.49,COMPLETE_DIAG,149.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,149.83,Wait,149.70,COMPLETE_DIAG,149.76,NO_REQ,,,,,,,,,,,,,,,,,,,
,150.03,Wait,149.89,COMPLETE_DIAG,149.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,150.21,Wait,150.09,COMPLETE_DIAG,150.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,150.40,Wait,150.27,COMPLETE_DIAG,150.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,150.59,Wait,150.47,COMPLETE_DIAG,150.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,150.79,Wait,150.65,COMPLETE_DIAG,150.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,151.04,Wait,150.85,COMPLETE_DIAG,150.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,151.23,Wait,151.11,COMPLETE_DIAG,151.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,151.42,Wait,151.30,COMPLETE_DIAG,151.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,151.60,Wait,151.48,COMPLETE_DIAG,151.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,151.79,Wait,151.67,COMPLETE_DIAG,151.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,151.99,Wait,151.85,COMPLETE_DIAG,151.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,152.18,Wait,152.06,COMPLETE_DIAG,152.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,152.38,Wait,152.25,COMPLETE_DIAG,152.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,152.55,Wait,152.43,COMPLETE_DIAG,152.49,NO_REQ,,,,,,,,,,,,,,,,,,,
,152.75,Wait,152.63,COMPLETE_DIAG,152.68,NO_REQ,,,,,,,,,,,,,,,,,,,
,152.97,Wait,152.83,COMPLETE_DIAG,152.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,153.18,Wait,153.03,COMPLETE_DIAG,153.10,NO_REQ,,,,,,,,,,,,,,,,,,,
,153.38,Wait,153.24,COMPLETE_DIAG,153.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,153.55,Wait,153.44,COMPLETE_DIAG,153.49,NO_REQ,,,,,,,,,,,,,,,,,,,
,153.74,Wait,153.62,COMPLETE_DIAG,153.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,153.93,Wait,153.81,COMPLETE_DIAG,153.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,154.12,Wait,154.00,COMPLETE_DIAG,154.05,NO_REQ,,,,,,,,,,,,,,,,,,,
,154.30,Wait,154.19,COMPLETE_DIAG,154.24,NO_REQ,,,,,,,,,,,,,,,,,,,
,154.49,Wait,154.37,COMPLETE_DIAG,154.43,NO_REQ,,,,,,,,,,,,,,,,,,,
,154.69,Wait,154.56,COMPLETE_DIAG,154.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,154.91,Wait,154.77,COMPLETE_DIAG,154.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,155.10,Wait,154.98,COMPLETE_DIAG,155.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,155.29,Wait,155.18,COMPLETE_DIAG,155.24,NO_REQ,,,,,,,,,,,,,,,,,,,
,155.49,Wait,155.36,COMPLETE_DIAG,155.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,155.68,Wait,155.55,COMPLETE_DIAG,155.60,NO_REQ,,,,,,,,,,,,,,,,,,,
,155.86,Wait,155.72,COMPLETE_DIAG,155.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,156.05,Wait,155.92,COMPLETE_DIAG,155.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,156.22,Wait,156.10,COMPLETE_DIAG,156.18,NO_REQ,,,,,,,,,,,,,,,,,,,
,156.40,Wait,156.27,COMPLETE_DIAG,156.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,156.60,Wait,156.46,COMPLETE_DIAG,156.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,156.79,Wait,156.67,COMPLETE_DIAG,156.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,157.01,Wait,156.86,COMPLETE_DIAG,156.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,157.20,Wait,157.07,COMPLETE_DIAG,157.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,157.44,Wait,157.28,COMPLETE_DIAG,157.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,157.62,Wait,157.50,COMPLETE_DIAG,157.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,157.82,Wait,157.69,COMPLETE_DIAG,157.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,158.03,Wait,157.89,COMPLETE_DIAG,157.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,159.49,Wait,158.10,COMPLETE_DIAG,159.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,159.82,Wait,159.57,COMPLETE_DIAG,159.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,160.02,Wait,159.91,COMPLETE_DIAG,159.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,160.21,Wait,160.09,COMPLETE_DIAG,160.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,160.41,Wait,160.28,COMPLETE_DIAG,160.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,160.63,Wait,160.48,COMPLETE_DIAG,160.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,160.82,Wait,160.69,COMPLETE_DIAG,160.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,161.03,Wait,160.91,COMPLETE_DIAG,160.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,161.22,Wait,161.09,COMPLETE_DIAG,161.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,163.91,Wait,161.28,COMPLETE_DIAG,161.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,164.11,Wait,163.97,COMPLETE_DIAG,164.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,164.34,Wait,164.18,COMPLETE_DIAG,164.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,164.53,Wait,164.40,COMPLETE_DIAG,164.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,164.71,Wait,164.59,COMPLETE_DIAG,164.65,NO_REQ,,,,,,,,,,,,,,,,,,,
,164.91,Wait,164.78,COMPLETE_DIAG,164.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,165.10,Wait,164.97,COMPLETE_DIAG,165.05,NO_REQ,,,,,,,,,,,,,,,,,,,
,165.29,Wait,165.16,COMPLETE_DIAG,165.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,165.49,Wait,165.35,COMPLETE_DIAG,165.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,165.68,Wait,165.56,COMPLETE_DIAG,165.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,165.89,Wait,165.74,COMPLETE_DIAG,165.82,NO_REQ,,,,,,,,,,,,,,,,,,,
,166.08,Wait,165.95,COMPLETE_DIAG,166.01,NO_REQ,,,,,,,,,,,,,,,,,,,
,166.28,Wait,166.15,COMPLETE_DIAG,166.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,166.47,Wait,166.34,COMPLETE_DIAG,166.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,166.66,Wait,166.53,COMPLETE_DIAG,166.60,NO_REQ,,,,,,,,,,,,,,,,,,,
,166.85,Wait,166.71,COMPLETE_DIAG,166.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,167.05,Wait,166.91,COMPLETE_DIAG,166.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,167.24,Wait,167.10,COMPLETE_DIAG,167.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,167.42,Wait,167.29,COMPLETE_DIAG,167.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,167.64,Wait,167.48,COMPLETE_DIAG,167.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,167.83,Wait,167.71,COMPLETE_DIAG,167.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,168.04,Wait,167.91,COMPLETE_DIAG,167.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,168.25,Wait,168.11,COMPLETE_DIAG,168.18,NO_REQ,,,,,,,,,,,,,,,,,,,
,169.48,Wait,168.32,COMPLETE_DIAG,169.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,169.68,Wait,169.54,COMPLETE_DIAG,169.60,NO_REQ,,,,,,,,,,,,,,,,,,,
,169.88,Wait,169.75,COMPLETE_DIAG,169.82,NO_REQ,,,,,,,,,,,,,,,,,,,
,170.07,Wait,169.95,COMPLETE_DIAG,170.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,170.26,Wait,170.14,COMPLETE_DIAG,170.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,170.48,Wait,170.32,COMPLETE_DIAG,170.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,170.67,Wait,170.54,COMPLETE_DIAG,170.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,170.86,Wait,170.74,COMPLETE_DIAG,170.80,NO_REQ,,,,,,,,,,,,,,,,,,,
,171.08,Wait,170.94,COMPLETE_DIAG,171.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,171.26,Wait,171.14,COMPLETE_DIAG,171.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,171.48,Wait,171.36,COMPLETE_DIAG,171.43,NO_REQ,,,,,,,,,,,,,,,,,,,
,171.68,Wait,171.54,COMPLETE_DIAG,171.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,171.88,Wait,171.74,COMPLETE_DIAG,171.82,NO_REQ,,,,,,,,,,,,,,,,,,,
,172.09,Wait,171.95,COMPLETE_DIAG,172.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,172.30,Wait,172.16,COMPLETE_DIAG,172.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,172.52,Wait,172.37,COMPLETE_DIAG,172.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,172.70,Wait,172.58,COMPLETE_DIAG,172.63,NO_REQ,,,,,,,,,,,,,,,,,,,
,172.94,Wait,172.77,COMPLETE_DIAG,172.85,NO_REQ,,,,,,,,,,,,,,,,,,,
,173.13,Wait,173.00,COMPLETE_DIAG,173.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,173.33,Wait,173.19,COMPLETE_DIAG,173.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,173.55,Wait,173.40,COMPLETE_DIAG,173.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,173.75,Wait,173.60,COMPLETE_DIAG,173.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,173.95,Wait,173.81,COMPLETE_DIAG,173.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,174.17,Wait,174.02,COMPLETE_DIAG,174.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,174.36,Wait,174.24,COMPLETE_DIAG,174.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,174.59,Wait,174.47,COMPLETE_DIAG,174.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,174.79,Wait,174.66,COMPLETE_DIAG,174.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,175.02,Wait,174.85,COMPLETE_DIAG,174.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,175.22,Wait,175.09,COMPLETE_DIAG,175.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,175.40,Wait,175.28,COMPLETE_DIAG,175.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,175.59,Wait,175.46,COMPLETE_DIAG,175.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,175.79,Wait,175.66,COMPLETE_DIAG,175.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,175.97,Wait,175.85,COMPLETE_DIAG,175.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,176.18,Wait,176.04,COMPLETE_DIAG,176.10,NO_REQ,,,,,,,,,,,,,,,,,,,
,176.40,Wait,176.25,COMPLETE_DIAG,176.32,NO_REQ,,,,,,,,,,,,,,,,,,,
,176.62,Wait,176.47,COMPLETE_DIAG,176.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,176.90,Wait,176.69,COMPLETE_DIAG,176.82,NO_REQ,,,,,,,,,,,,,,,,,,,
,177.11,Wait,176.98,COMPLETE_DIAG,177.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,177.33,Wait,177.19,COMPLETE_DIAG,177.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,177.54,Wait,177.41,COMPLETE_DIAG,177.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,177.75,REQ,177.61,COMPLETE_DIAG,177.69,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,178.00,REQ,177.84,COMPLETE_DIAG,177.90,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,178.18,REQ,178.05,COMPLETE_DIAG,178.12,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,178.41,RESP,178.26,COMPLETE_DIAG,178.32,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,178.60,RESP,178.47,COMPLETE_DIAG,178.53,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,178.78,RESP,178.65,COMPLETE_DIAG,178.72,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,181.41,RESP,178.84,COMPLETE_DIAG,178.90,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,181.59,Wait,181.48,COMPLETE_DIAG,181.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,181.79,Wait,181.66,COMPLETE_DIAG,181.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,182.00,Wait,181.86,COMPLETE_DIAG,181.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,182.21,Wait,182.07,COMPLETE_DIAG,182.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,182.40,Wait,182.27,COMPLETE_DIAG,182.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,182.57,Wait,182.44,COMPLETE_DIAG,182.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,182.78,Wait,182.65,COMPLETE_DIAG,182.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,182.99,Wait,182.85,COMPLETE_DIAG,182.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,183.18,Wait,183.04,COMPLETE_DIAG,183.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,183.38,Wait,183.25,COMPLETE_DIAG,183.32,NO_REQ,,,,,,,,,,,,,,,,,,,
,183.62,Wait,183.46,COMPLETE_DIAG,183.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,183.86,Wait,183.73,COMPLETE_DIAG,183.80,NO_REQ,,,,,,,,,,,,,,,,,,,
,184.07,Wait,183.93,COMPLETE_DIAG,184.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,184.25,Wait,184.12,COMPLETE_DIAG,184.18,NO_REQ,,,,,,,,,,,,,,,,,,,
,184.43,Wait,184.32,COMPLETE_DIAG,184.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,184.63,Wait,184.49,COMPLETE_DIAG,184.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,184.82,Wait,184.69,COMPLETE_DIAG,184.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,185.02,Wait,184.89,COMPLETE_DIAG,184.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,185.22,Wait,185.09,COMPLETE_DIAG,185.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,185.41,Wait,185.28,COMPLETE_DIAG,185.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,185.61,Wait,185.48,COMPLETE_DIAG,185.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,185.82,Wait,185.67,COMPLETE_DIAG,185.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,186.01,Wait,185.87,COMPLETE_DIAG,185.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,186.22,Wait,186.09,COMPLETE_DIAG,186.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,186.42,Wait,186.30,COMPLETE_DIAG,186.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,186.63,Wait,186.49,COMPLETE_DIAG,186.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,186.82,Wait,186.69,COMPLETE_DIAG,186.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,187.03,Wait,186.89,COMPLETE_DIAG,186.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,187.22,Wait,187.10,COMPLETE_DIAG,187.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,187.40,Wait,187.28,COMPLETE_DIAG,187.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,187.60,Wait,187.47,COMPLETE_DIAG,187.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,187.82,Wait,187.67,COMPLETE_DIAG,187.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,188.01,Wait,187.87,COMPLETE_DIAG,187.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,188.24,Wait,188.08,COMPLETE_DIAG,188.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,188.44,Wait,188.31,COMPLETE_DIAG,188.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,188.63,Wait,188.50,COMPLETE_DIAG,188.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,188.82,Wait,188.69,COMPLETE_DIAG,188.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,189.01,Wait,188.87,COMPLETE_DIAG,188.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,189.22,Wait,189.08,COMPLETE_DIAG,189.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,190.53,Wait,190.41,COMPLETE_DIAG,190.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,190.72,Wait,190.59,COMPLETE_DIAG,190.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,190.94,Wait,190.79,COMPLETE_DIAG,190.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,191.13,Wait,191.00,COMPLETE_DIAG,191.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,191.30,Wait,191.19,COMPLETE_DIAG,191.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,191.50,Wait,191.37,COMPLETE_DIAG,191.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,191.69,Wait,191.56,COMPLETE_DIAG,191.63,NO_REQ,,,,,,,,,,,,,,,,,,,
,191.88,Wait,191.75,COMPLETE_DIAG,191.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,192.06,Wait,191.94,COMPLETE_DIAG,192.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,192.24,Wait,192.12,COMPLETE_DIAG,192.18,NO_REQ,,,,,,,,,,,,,,,,,,,
,192.43,Wait,192.32,COMPLETE_DIAG,192.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,192.64,Wait,192.50,COMPLETE_DIAG,192.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,192.86,Wait,192.72,COMPLETE_DIAG,192.80,NO_REQ,,,,,,,,,,,,,,,,,,,
,193.07,Wait,192.93,COMPLETE_DIAG,193.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,193.26,Wait,193.14,COMPLETE_DIAG,193.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,193.44,Wait,193.32,COMPLETE_DIAG,193.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,193.63,Wait,193.51,COMPLETE_DIAG,193.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,193.83,Wait,193.70,COMPLETE_DIAG,193.76,NO_REQ,,,,,,,,,,,,,,,,,,,
,194.03,Wait,193.89,COMPLETE_DIAG,193.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,194.23,Wait,194.11,COMPLETE_DIAG,194.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,194.42,Wait,194.29,COMPLETE_DIAG,194.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,194.61,Wait,194.49,COMPLETE_DIAG,194.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,194.79,Wait,194.67,COMPLETE_DIAG,194.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,194.98,Wait,194.85,COMPLETE_DIAG,194.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,195.17,Wait,195.04,COMPLETE_DIAG,195.10,NO_REQ,,,,,,,,,,,,,,,,,,,
,195.39,Wait,195.23,COMPLETE_DIAG,195.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,195.57,Wait,195.45,COMPLETE_DIAG,195.51,NO_REQ,,,,,,,,,,,,,,,,,,,
,195.76,Wait,195.64,COMPLETE_DIAG,195.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,195.95,Wait,195.83,COMPLETE_DIAG,195.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,196.15,Wait,196.02,COMPLETE_DIAG,196.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,196.36,Wait,196.22,COMPLETE_DIAG,196.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,196.57,Wait,196.43,COMPLETE_DIAG,196.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,196.80,Wait,196.67,COMPLETE_DIAG,196.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,197.01,Wait,196.88,COMPLETE_DIAG,196.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,197.21,Wait,197.07,COMPLETE_DIAG,197.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,197.41,Wait,197.27,COMPLETE_DIAG,197.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,197.61,Wait,197.47,COMPLETE_DIAG,197.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,197.78,Wait,197.67,COMPLETE_DIAG,197.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,197.97,Wait,197.85,COMPLETE_DIAG,197.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,198.16,Wait,198.03,COMPLETE_DIAG,198.10,NO_REQ,,,,,,,,,,,,,,,,,,,
,198.35,Wait,198.22,COMPLETE_DIAG,198.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,198.56,Wait,198.43,COMPLETE_DIAG,198.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,198.75,Wait,198.62,COMPLETE_DIAG,198.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,198.93,Wait,198.81,COMPLETE_DIAG,198.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,199.13,Wait,199.00,COMPLETE_DIAG,199.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,199.32,Wait,199.19,COMPLETE_DIAG,199.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,201.97,Wait,199.39,COMPLETE_DIAG,201.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,202.15,Wait,202.03,COMPLETE_DIAG,202.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,202.35,Wait,202.23,COMPLETE_DIAG,202.30,NO_REQ,,,,,,,,,,,,,,,,,,,
,202.57,Wait,202.43,COMPLETE_DIAG,202.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,202.75,Wait,202.63,COMPLETE_DIAG,202.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,202.95,Wait,202.83,COMPLETE_DIAG,202.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,203.17,Wait,203.03,COMPLETE_DIAG,203.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,203.35,Wait,203.24,COMPLETE_DIAG,203.30,NO_REQ,,,,,,,,,,,,,,,,,,,
,203.58,Wait,203.43,COMPLETE_DIAG,203.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,203.78,Wait,203.64,COMPLETE_DIAG,203.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,203.98,Wait,203.86,COMPLETE_DIAG,203.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,204.17,Wait,204.04,COMPLETE_DIAG,204.10,NO_REQ,,,,,,,,,,,,,,,,,,,
,204.42,Wait,204.27,COMPLETE_DIAG,204.32,NO_REQ,,,,,,,,,,,,,,,,,,,
,204.60,Wait,204.48,COMPLETE_DIAG,204.54,NO_REQ,,,,,,,,,,,,,,,,,,,
1,204.87,Wait,204.67,COMPLETE_DIAG,204.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,205.05,Wait,204.93,COMPLETE_DIAG,205.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,205.24,Wait,205.13,COMPLETE_DIAG,205.18,NO_REQ,,,,,,,,,,,,,,,,,,,
,205.44,Wait,205.30,COMPLETE_DIAG,205.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,205.64,Wait,205.51,COMPLETE_DIAG,205.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,205.83,Wait,205.69,COMPLETE_DIAG,205.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,206.03,Wait,205.88,COMPLETE_DIAG,205.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,206.23,Wait,206.09,COMPLETE_DIAG,206.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,206.42,Wait,206.29,COMPLETE_DIAG,206.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,206.61,Wait,206.49,COMPLETE_DIAG,206.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,206.79,Wait,206.67,COMPLETE_DIAG,206.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,206.99,Wait,206.85,COMPLETE_DIAG,206.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,207.17,Wait,207.05,COMPLETE_DIAG,207.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,207.36,Wait,207.22,COMPLETE_DIAG,207.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,207.55,Wait,207.42,COMPLETE_DIAG,207.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,207.75,REQ,207.60,COMPLETE_DIAG,207.68,NO_REQ,,,,,,,,,,,,,,,,,,,
,207.93,REQ,207.81,COMPLETE_DIAG,207.88,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,208.13,REQ,207.99,COMPLETE_DIAG,208.08,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,208.33,REQ,208.21,COMPLETE_DIAG,208.27,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,208.54,RESP,208.41,COMPLETE_DIAG,208.47,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,208.74,RESP,208.62,COMPLETE_DIAG,208.69,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,208.94,RESP,208.81,COMPLETE_DIAG,208.88,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,209.13,RESP,209.01,COMPLETE_DIAG,209.08,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,209.32,ready,209.20,COMPLETE_DIAG,209.27,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,209.52,Wait,209.39,COMPLETE_DIAG,209.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,209.72,Wait,209.58,COMPLETE_DIAG,209.65,NO_REQ,,,,,,,,,,,,,,,,,,,
,209.94,Wait,209.79,COMPLETE_DIAG,209.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,210.17,Wait,210.01,COMPLETE_DIAG,210.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,210.38,Wait,210.22,COMPLETE_DIAG,210.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,210.61,Wait,210.46,COMPLETE_DIAG,210.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,210.81,Wait,210.68,COMPLETE_DIAG,210.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,211.00,Wait,210.87,COMPLETE_DIAG,210.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,211.20,Wait,211.08,COMPLETE_DIAG,211.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,211.42,Wait,211.28,COMPLETE_DIAG,211.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,211.61,Wait,211.49,COMPLETE_DIAG,211.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,211.80,Wait,211.67,COMPLETE_DIAG,211.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,212.00,Wait,211.87,COMPLETE_DIAG,211.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,212.20,Wait,212.08,COMPLETE_DIAG,212.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,212.41,Wait,212.28,COMPLETE_DIAG,212.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,212.59,Wait,212.47,COMPLETE_DIAG,212.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,212.79,Wait,212.67,COMPLETE_DIAG,212.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,213.03,Wait,212.87,COMPLETE_DIAG,212.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,213.22,Wait,213.09,COMPLETE_DIAG,213.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,213.42,Wait,213.29,COMPLETE_DIAG,213.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,213.60,Wait,213.48,COMPLETE_DIAG,213.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,213.82,Wait,213.68,COMPLETE_DIAG,213.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,214.02,Wait,213.88,COMPLETE_DIAG,213.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,214.21,Wait,214.08,COMPLETE_DIAG,214.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,214.41,Wait,214.28,COMPLETE_DIAG,214.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,214.62,Wait,214.48,COMPLETE_DIAG,214.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,214.81,Wait,214.69,COMPLETE_DIAG,214.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,215.00,Wait,214.87,COMPLETE_DIAG,214.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,215.18,Wait,215.05,COMPLETE_DIAG,215.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,215.40,Wait,215.27,COMPLETE_DIAG,215.32,NO_REQ,,,,,,,,,,,,,,,,,,,
,215.58,Wait,215.47,COMPLETE_DIAG,215.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,215.78,Wait,215.66,COMPLETE_DIAG,215.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,216.00,Wait,215.88,COMPLETE_DIAG,215.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,216.21,Wait,216.09,COMPLETE_DIAG,216.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,216.41,Wait,216.28,COMPLETE_DIAG,216.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,216.61,Wait,216.48,COMPLETE_DIAG,216.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,216.80,Wait,216.67,COMPLETE_DIAG,216.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,217.10,Wait,216.87,COMPLETE_DIAG,216.99,NO_REQ,,,,,,,,,,,,,,,,,,,
,217.31,Wait,217.18,COMPLETE_DIAG,217.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,217.49,Wait,217.37,COMPLETE_DIAG,217.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,217.71,Wait,217.57,COMPLETE_DIAG,217.63,NO_REQ,,,,,,,,,,,,,,,,,,,
,217.91,Wait,217.77,COMPLETE_DIAG,217.85,NO_REQ,,,,,,,,,,,,,,,,,,,
,218.11,Wait,217.98,COMPLETE_DIAG,218.05,NO_REQ,,,,,,,,,,,,,,,,,,,
,218.32,Wait,218.21,COMPLETE_DIAG,218.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,218.50,Wait,218.39,COMPLETE_DIAG,218.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,218.71,Wait,218.58,COMPLETE_DIAG,218.65,NO_REQ,,,,,,,,,,,,,,,,,,,
,218.92,Wait,218.79,COMPLETE_DIAG,218.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,219.13,Wait,218.98,COMPLETE_DIAG,219.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,219.35,Wait,219.19,COMPLETE_DIAG,219.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,219.53,Wait,219.40,COMPLETE_DIAG,219.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,219.72,Wait,219.59,COMPLETE_DIAG,219.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,219.92,Wait,219.78,COMPLETE_DIAG,219.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,220.11,Wait,219.98,COMPLETE_DIAG,220.05,NO_REQ,,,,,,,,,,,,,,,,,,,
,220.30,Wait,220.17,COMPLETE_DIAG,220.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,220.50,Wait,220.36,COMPLETE_DIAG,220.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,220.69,Wait,220.56,COMPLETE_DIAG,220.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,220.98,Wait,220.77,COMPLETE_DIAG,220.88,NO_REQ,,,,,,,,,,,,,,,,,,,
,221.22,Wait,221.09,COMPLETE_DIAG,221.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,221.41,Wait,221.27,COMPLETE_DIAG,221.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,221.60,Wait,221.46,COMPLETE_DIAG,221.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,221.80,Wait,221.67,COMPLETE_DIAG,221.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,222.01,Wait,221.86,COMPLETE_DIAG,221.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,222.19,Wait,222.07,COMPLETE_DIAG,222.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,222.37,Wait,222.25,COMPLETE_DIAG,222.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,222.56,Wait,222.43,COMPLETE_DIAG,222.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,222.75,Wait,222.63,COMPLETE_DIAG,222.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,223.00,Wait,222.86,COMPLETE_DIAG,222.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,223.22,Wait,223.07,COMPLETE_DIAG,223.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,223.41,Wait,223.28,COMPLETE_DIAG,223.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,223.61,Wait,223.49,COMPLETE_DIAG,223.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,223.79,Wait,223.67,COMPLETE_DIAG,223.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,224.01,Wait,223.85,COMPLETE_DIAG,223.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,224.19,Wait,224.07,COMPLETE_DIAG,224.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,224.40,Wait,224.27,COMPLETE_DIAG,224.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,224.60,Wait,224.48,COMPLETE_DIAG,224.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,224.80,Wait,224.68,COMPLETE_DIAG,224.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,224.99,Wait,224.86,COMPLETE_DIAG,224.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,225.21,Wait,225.07,COMPLETE_DIAG,225.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,225.45,Wait,225.27,COMPLETE_DIAG,225.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,225.65,Wait,225.51,COMPLETE_DIAG,225.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,225.93,Wait,225.80,COMPLETE_DIAG,225.85,NO_REQ,,,,,,,,,,,,,,,,,,,
,226.13,Wait,225.99,COMPLETE_DIAG,226.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,226.34,Wait,226.19,COMPLETE_DIAG,226.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,226.54,Wait,226.41,COMPLETE_DIAG,226.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,226.74,Wait,226.63,COMPLETE_DIAG,226.68,NO_REQ,,,,,,,,,,,,,,,,,,,
,226.93,Wait,226.82,COMPLETE_DIAG,226.88,NO_REQ,,,,,,,,,,,,,,,,,,,
,227.14,Wait,227.00,COMPLETE_DIAG,227.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,227.35,Wait,227.21,COMPLETE_DIAG,227.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,227.53,Wait,227.41,COMPLETE_DIAG,227.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,227.74,Wait,227.59,COMPLETE_DIAG,227.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,227.94,Wait,227.80,COMPLETE_DIAG,227.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,228.14,Wait,228.00,Wait,228.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,228.34,Wait,228.20,Wait,228.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,228.53,Wait,228.41,Wait,228.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,228.74,Wait,228.60,Wait,228.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,228.94,REQ,228.81,Wait,228.88,T_SMT_1,,,,,,,,,,,,,,,,,,,
,229.16,REQ,229.00,Wait,229.09,T_SMT_1,,,,,,,,,,,,,,,,,,,
,229.36,REQ,229.22,Wait,229.29,T_SMT_1,,,,,,,,,,,,,,,,,,,
,229.57,RESP,229.42,Wait,229.49,T_SMT_1,,,,,,,,,,,,,,,,,,,
,229.77,RESP,229.64,Wait,229.69,T_SMT_1,,,,,,,,,,,,,,,,,,,
,229.97,RESP,229.84,Wait,229.90,T_SMT_1,,,,,,,,,,,,,,,,,,,
,230.18,RESP,230.04,Wait,230.11,T_SMT_1,,,,,,,,,,,,,,,,,,,
,230.39,REQ,230.26,Wait,230.33,T_SMT_2,,,,,,,,,,,,,,,,,,,
,230.58,REQ,230.45,Wait,230.52,T_SMT_2,,,,,,,,,,,,,,,,,,,
,230.78,REQ,230.63,Wait,230.70,T_SMT_2,,,,,,,,,,,,,,,,,,,
,231.00,RESP,230.87,Wait,230.93,T_SMT_2,,,,,,,,,,,,,,,,,,,
,231.21,RESP,231.07,Wait,231.14,T_SMT_2,,,,,,,,,,,,,,,,,,,
,231.41,RESP,231.27,Wait,231.34,T_SMT_2,,,,,,,,,,,,,,,,,,,
,231.60,RESP,231.47,Wait,231.54,T_SMT_2,,,,,,,,,,,,,,,,,,,
,231.82,RESP,231.67,Wait,231.75,T_SMT_2,,,,,,,,,,,,,,,,,,,
,232.01,Wait,231.89,Wait,231.94,T_SMT_2,,,,,,,,,,,,,,,,,,,
,232.19,Wait,232.07,Wait,232.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,232.39,Wait,232.27,Wait,232.32,NO_REQ,,,,,,,,,,,,,,,,,,,
,232.58,Wait,232.44,Wait,232.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,232.77,Wait,232.66,Wait,232.72,NO_REQ,,,,,,,,,,,,,,,,,,,
Bus traffic at next startup:
Startup the next day. Went ignition on, opened a diagnostic session and started a log, and then started the engine a little over a minute later. You can see the ECU do a few different things with J909, what appears to be initialization and readback of the overnight test results. None of that happened until the engine was actually started.
Disclaimer: I had not cleared codes, I already had readiness set, my fuel level was slightly over the documented max, and my IDE07008 didn't increment, so this log might not show exactly what happens during a successful monitoring attempt.
Thursday,03,January,2019,09:38:03:21122-VCID:CDD2285C9C831C22E0-8098,VCDS Version: Release 18.9.0 (x64),Data version: 20181017 DS296.0
8V0 906 259 P,ADVMB,2.0l R4 TFSI  H13 0001,
,,G1129,F0,G1135,F0,G1140,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,
Marker,TIME,Loc. ENG102127,TIME,Loc. ENG104238,TIME,Loc. ENG100342,,,,,,,,,,,,,,,,,,,
,STAMP,STATE_COMC_NVLD,STAMP,STATE_NVLD,STAMP,STATE_REQ_NVLD,,,,,,,,,,,,,,,,,,,
,0.00,Wait,0.03,READ_INI,0.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,0.09,Wait,0.13,READ_INI,0.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,0.20,Wait,0.23,READ_INI,0.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,0.29,Wait,0.33,READ_INI,0.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,0.40,Wait,0.43,READ_INI,0.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,0.50,Wait,0.53,READ_INI,0.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,0.61,Wait,0.64,READ_INI,0.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,0.70,Wait,0.74,READ_INI,0.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,0.83,Wait,0.86,READ_INI,0.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,0.92,Wait,0.96,READ_INI,0.99,NO_REQ,,,,,,,,,,,,,,,,,,,
,1.03,Wait,1.06,READ_INI,1.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,1.12,Wait,1.15,READ_INI,1.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,1.21,Wait,1.25,READ_INI,1.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,1.31,Wait,1.34,READ_INI,1.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,1.41,Wait,1.45,READ_INI,1.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,1.53,Wait,1.56,READ_INI,1.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,1.62,Wait,1.66,READ_INI,1.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,1.72,Wait,1.75,READ_INI,1.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,1.81,Wait,1.85,READ_INI,1.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,1.92,Wait,1.96,READ_INI,1.99,NO_REQ,,,,,,,,,,,,,,,,,,,
,2.03,Wait,2.06,READ_INI,2.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,2.12,Wait,2.15,READ_INI,2.18,NO_REQ,,,,,,,,,,,,,,,,,,,
,2.21,Wait,2.27,READ_INI,2.30,NO_REQ,,,,,,,,,,,,,,,,,,,
,2.33,Wait,2.36,READ_INI,2.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,2.44,Wait,2.47,READ_INI,2.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,2.54,Wait,2.59,READ_INI,2.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,2.65,Wait,2.69,READ_INI,2.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,2.77,Wait,2.81,READ_INI,2.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,2.88,Wait,2.92,READ_INI,2.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,3.00,Wait,3.03,READ_INI,3.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,3.09,Wait,3.13,READ_INI,3.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,3.20,Wait,3.23,READ_INI,3.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,3.30,Wait,3.33,READ_INI,3.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,3.39,Wait,3.42,READ_INI,3.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,3.49,Wait,3.51,READ_INI,3.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,3.58,Wait,3.61,READ_INI,3.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,3.67,Wait,3.72,READ_INI,3.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,3.79,Wait,3.83,READ_INI,3.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,3.89,Wait,3.92,READ_INI,3.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,3.99,Wait,4.03,READ_INI,4.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,4.09,Wait,4.12,READ_INI,4.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,4.19,Wait,4.21,READ_INI,4.24,NO_REQ,,,,,,,,,,,,,,,,,,,
,4.28,Wait,4.31,READ_INI,4.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,4.37,Wait,4.41,READ_INI,4.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,4.49,Wait,4.53,READ_INI,4.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,4.59,Wait,4.62,READ_INI,4.68,NO_REQ,,,,,,,,,,,,,,,,,,,
,4.72,Wait,4.75,READ_INI,4.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,4.83,Wait,4.88,READ_INI,4.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,4.94,Wait,4.96,READ_INI,5.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,5.03,Wait,5.06,READ_INI,5.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,5.13,Wait,5.17,READ_INI,5.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,5.23,Wait,5.26,READ_INI,5.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,5.32,Wait,5.36,READ_INI,5.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,5.42,Wait,5.45,READ_INI,5.49,NO_REQ,,,,,,,,,,,,,,,,,,,
,5.53,Wait,5.56,READ_INI,5.60,NO_REQ,,,,,,,,,,,,,,,,,,,
,5.62,Wait,5.67,READ_INI,5.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,5.74,Wait,5.79,READ_INI,5.82,NO_REQ,,,,,,,,,,,,,,,,,,,
,5.86,Wait,5.90,READ_INI,5.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,5.97,Wait,6.00,READ_INI,6.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,6.06,Wait,6.09,READ_INI,6.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,6.16,Wait,6.19,READ_INI,6.22,NO_REQ,,,,,,,,,,,,,,,,,,,
,6.25,Wait,6.28,READ_INI,6.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,6.34,Wait,6.37,READ_INI,6.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,6.45,Wait,6.49,READ_INI,6.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,6.56,Wait,6.59,READ_INI,6.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,6.66,Wait,6.68,READ_INI,6.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,6.75,Wait,6.78,READ_INI,6.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,6.84,Wait,6.87,READ_INI,6.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,6.94,Wait,6.97,READ_INI,6.99,NO_REQ,,,,,,,,,,,,,,,,,,,
,7.04,Wait,7.08,READ_INI,7.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,7.14,Wait,7.17,READ_INI,7.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,7.24,Wait,7.28,READ_INI,7.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,7.34,Wait,7.37,READ_INI,7.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,7.44,Wait,7.47,READ_INI,7.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,7.53,Wait,7.56,READ_INI,7.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,7.63,Wait,7.66,READ_INI,7.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,7.72,Wait,7.75,READ_INI,7.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,7.81,Wait,7.85,READ_INI,7.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,7.91,Wait,7.94,READ_INI,7.99,NO_REQ,,,,,,,,,,,,,,,,,,,
,8.03,Wait,8.06,READ_INI,8.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,8.12,Wait,8.16,READ_INI,8.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,8.22,Wait,8.24,READ_INI,8.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,8.29,Wait,8.33,READ_INI,8.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,8.39,Wait,8.42,READ_INI,8.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,8.49,Wait,8.53,READ_INI,8.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,8.59,Wait,8.63,READ_INI,8.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,8.70,Wait,8.74,READ_INI,8.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,8.82,Wait,8.86,READ_INI,8.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,8.94,Wait,8.97,READ_INI,9.01,NO_REQ,,,,,,,,,,,,,,,,,,,
,9.04,Wait,9.09,READ_INI,9.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,9.17,Wait,9.21,READ_INI,9.24,NO_REQ,,,,,,,,,,,,,,,,,,,
,9.28,Wait,9.31,READ_INI,9.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,9.37,Wait,9.41,READ_INI,9.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,9.47,Wait,9.49,READ_INI,9.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,9.54,Wait,9.58,READ_INI,9.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,9.64,Wait,9.67,READ_INI,9.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,9.74,Wait,9.78,READ_INI,9.82,NO_REQ,,,,,,,,,,,,,,,,,,,
,9.86,Wait,9.89,READ_INI,9.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,9.95,Wait,9.98,READ_INI,10.01,NO_REQ,,,,,,,,,,,,,,,,,,,
,10.04,Wait,10.08,READ_INI,10.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,10.15,Wait,10.19,READ_INI,10.22,NO_REQ,,,,,,,,,,,,,,,,,,,
,10.25,Wait,10.28,READ_INI,10.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,10.34,Wait,10.37,READ_INI,10.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,10.44,Wait,10.47,READ_INI,10.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,10.53,Wait,10.57,READ_INI,10.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,10.66,Wait,10.69,READ_INI,10.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,10.74,Wait,10.77,READ_INI,10.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,10.83,Wait,10.86,READ_INI,10.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,10.92,Wait,10.95,READ_INI,10.99,NO_REQ,,,,,,,,,,,,,,,,,,,
,11.03,Wait,11.06,READ_INI,11.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,11.12,Wait,11.15,READ_INI,11.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,11.22,Wait,11.24,READ_INI,11.30,NO_REQ,,,,,,,,,,,,,,,,,,,
,11.32,Wait,11.36,READ_INI,11.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,11.42,Wait,11.45,READ_INI,11.49,NO_REQ,,,,,,,,,,,,,,,,,,,
,11.53,Wait,11.56,READ_INI,11.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,11.62,Wait,11.66,READ_INI,11.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,11.72,Wait,11.75,READ_INI,11.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,11.83,Wait,11.86,READ_INI,11.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,11.92,Wait,11.95,READ_INI,11.99,NO_REQ,,,,,,,,,,,,,,,,,,,
,12.03,Wait,12.06,READ_INI,12.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,12.12,Wait,12.15,READ_INI,12.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,12.21,Wait,12.24,READ_INI,12.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,12.29,Wait,12.32,READ_INI,12.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,12.39,Wait,12.42,READ_INI,12.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,12.49,Wait,12.53,READ_INI,12.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,12.61,Wait,12.64,READ_INI,12.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,12.70,Wait,12.73,READ_INI,12.76,NO_REQ,,,,,,,,,,,,,,,,,,,
,12.79,Wait,12.83,READ_INI,12.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,12.90,Wait,12.94,READ_INI,12.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,13.00,Wait,13.03,READ_INI,13.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,13.09,Wait,13.13,READ_INI,13.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,13.19,Wait,13.22,READ_INI,13.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,13.28,Wait,13.31,READ_INI,13.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,13.38,Wait,13.40,READ_INI,13.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,13.46,Wait,13.50,READ_INI,13.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,13.56,Wait,13.59,READ_INI,13.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,13.66,Wait,13.70,READ_INI,13.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,13.77,Wait,13.81,READ_INI,13.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,13.87,Wait,13.90,READ_INI,13.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,13.97,Wait,14.00,READ_INI,14.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,14.07,Wait,14.11,READ_INI,14.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,14.17,Wait,14.21,READ_INI,14.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,14.28,Wait,14.31,READ_INI,14.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,14.37,Wait,14.41,READ_INI,14.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,14.49,Wait,14.53,READ_INI,14.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,14.59,Wait,14.62,READ_INI,14.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,14.69,Wait,14.72,READ_INI,14.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,14.78,Wait,14.82,READ_INI,14.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,14.89,Wait,14.92,READ_INI,14.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,14.98,Wait,15.02,READ_INI,15.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,15.09,Wait,15.12,READ_INI,15.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,15.19,Wait,15.22,READ_INI,15.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,15.28,Wait,15.31,READ_INI,15.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,15.37,Wait,15.41,READ_INI,15.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,15.50,Wait,15.54,READ_INI,15.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,15.61,Wait,15.64,READ_INI,15.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,15.70,Wait,15.74,READ_INI,15.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,15.83,Wait,15.88,READ_INI,15.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,15.95,Wait,15.98,READ_INI,16.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,16.05,Wait,16.07,READ_INI,16.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,16.14,Wait,16.17,READ_INI,16.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,16.25,Wait,16.28,READ_INI,16.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,16.35,Wait,16.37,READ_INI,16.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,16.46,Wait,16.49,READ_INI,16.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,16.56,Wait,16.59,READ_INI,16.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,16.66,Wait,16.71,READ_INI,16.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,16.79,Wait,16.82,READ_INI,16.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,16.89,Wait,16.92,READ_INI,16.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,16.98,Wait,17.02,READ_INI,17.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,17.09,Wait,17.12,READ_INI,17.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,17.20,Wait,17.25,READ_INI,17.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,17.31,Wait,17.34,READ_INI,17.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,17.42,Wait,17.45,READ_INI,17.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,17.52,Wait,17.58,READ_INI,17.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,17.68,Wait,17.74,READ_INI,17.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,17.81,Wait,17.84,READ_INI,17.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,17.91,Wait,17.94,READ_INI,17.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,18.00,Wait,18.04,READ_INI,18.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,18.13,Wait,18.16,READ_INI,18.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,18.22,Wait,18.25,READ_INI,18.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,18.31,Wait,18.34,READ_INI,18.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,18.42,Wait,18.45,READ_INI,18.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,18.54,Wait,18.59,READ_INI,18.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,18.65,Wait,18.69,READ_INI,18.76,NO_REQ,,,,,,,,,,,,,,,,,,,
,18.80,Wait,18.83,READ_INI,18.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,18.90,Wait,18.93,READ_INI,18.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,19.00,Wait,19.03,READ_INI,19.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,19.11,Wait,19.14,READ_INI,19.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,19.21,Wait,19.25,READ_INI,19.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,19.32,Wait,19.36,READ_INI,19.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,19.44,Wait,19.47,READ_INI,19.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,19.53,Wait,19.57,READ_INI,19.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,19.64,Wait,19.67,READ_INI,19.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,19.73,Wait,19.76,READ_INI,19.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,19.83,Wait,19.87,READ_INI,19.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,19.94,Wait,19.96,READ_INI,19.99,NO_REQ,,,,,,,,,,,,,,,,,,,
,20.03,Wait,20.07,READ_INI,20.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,20.14,Wait,20.17,READ_INI,20.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,20.24,Wait,20.28,READ_INI,20.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,20.35,Wait,20.37,READ_INI,20.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,20.43,Wait,20.47,READ_INI,20.49,NO_REQ,,,,,,,,,,,,,,,,,,,
,20.54,Wait,20.57,READ_INI,20.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,20.64,Wait,20.67,READ_INI,20.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,20.73,Wait,20.77,READ_INI,20.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,20.83,Wait,20.86,READ_INI,20.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,20.94,Wait,20.97,READ_INI,21.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,21.03,Wait,21.06,READ_INI,21.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,21.13,Wait,21.17,READ_INI,21.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,21.23,Wait,21.27,READ_INI,21.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,21.33,Wait,21.36,READ_INI,21.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,21.42,Wait,21.45,READ_INI,21.49,NO_REQ,,,,,,,,,,,,,,,,,,,
,21.53,Wait,21.57,READ_INI,21.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,21.64,Wait,21.67,READ_INI,21.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,21.74,Wait,21.78,READ_INI,21.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,21.84,Wait,21.87,READ_INI,21.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,21.94,Wait,21.97,READ_INI,22.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,22.03,Wait,22.06,READ_INI,22.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,22.12,Wait,22.15,READ_INI,22.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,22.22,Wait,22.25,READ_INI,22.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,22.31,Wait,22.35,READ_INI,22.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,22.44,Wait,22.47,READ_INI,22.49,NO_REQ,,,,,,,,,,,,,,,,,,,
,22.53,Wait,22.57,READ_INI,22.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,22.64,Wait,22.67,READ_INI,22.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,22.74,Wait,22.78,READ_INI,22.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,22.84,Wait,22.87,READ_INI,22.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,22.95,Wait,22.99,READ_INI,23.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,23.06,Wait,23.09,READ_INI,23.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,23.16,Wait,23.19,READ_INI,23.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,23.29,Wait,23.32,READ_INI,23.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,23.40,Wait,23.44,READ_INI,23.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,23.49,Wait,23.59,READ_INI,23.63,NO_REQ,,,,,,,,,,,,,,,,,,,
,23.67,Wait,23.73,READ_INI,23.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,23.80,Wait,23.83,READ_INI,23.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,23.89,Wait,23.92,READ_INI,23.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,23.98,Wait,24.03,READ_INI,24.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,24.10,Wait,24.14,READ_INI,24.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,24.20,Wait,24.23,READ_INI,24.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,24.29,Wait,24.32,READ_INI,24.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,24.39,Wait,24.42,READ_INI,24.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,24.48,Wait,24.51,READ_INI,24.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,24.58,Wait,24.61,READ_INI,24.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,24.68,Wait,24.73,READ_INI,24.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,24.81,Wait,24.85,READ_INI,24.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,24.90,Wait,24.93,READ_INI,24.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,25.00,Wait,25.03,READ_INI,25.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,25.09,Wait,25.12,READ_INI,25.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,25.19,Wait,25.21,READ_INI,25.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,25.29,Wait,25.33,READ_INI,25.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,25.39,Wait,25.42,READ_INI,25.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,25.48,Wait,25.52,READ_INI,25.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,25.58,Wait,25.61,READ_INI,25.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,25.67,Wait,25.70,READ_INI,25.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,25.77,Wait,25.79,READ_INI,25.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,25.89,Wait,25.92,READ_INI,25.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,26.00,Wait,26.04,READ_INI,26.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,26.11,Wait,26.14,READ_INI,26.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,26.20,Wait,26.24,READ_INI,26.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,26.31,Wait,26.35,READ_INI,26.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,26.42,Wait,26.45,READ_INI,26.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,26.53,Wait,26.56,READ_INI,26.60,NO_REQ,,,,,,,,,,,,,,,,,,,
,26.63,Wait,26.66,READ_INI,26.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,26.72,Wait,26.75,READ_INI,26.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,26.81,Wait,26.84,READ_INI,26.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,26.90,Wait,26.94,READ_INI,26.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,27.01,Wait,27.04,READ_INI,27.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,27.11,Wait,27.14,READ_INI,27.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,27.21,Wait,27.25,READ_INI,27.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,27.33,Wait,27.37,READ_INI,27.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,27.44,Wait,27.48,READ_INI,27.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,27.55,Wait,27.58,READ_INI,27.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,27.64,Wait,27.67,READ_INI,27.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,27.73,Wait,27.77,READ_INI,27.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,27.84,Wait,27.87,READ_INI,27.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,27.94,Wait,27.97,READ_INI,28.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,28.03,Wait,28.06,READ_INI,28.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,28.12,Wait,28.15,READ_INI,28.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,28.22,Wait,28.25,READ_INI,28.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,28.31,Wait,28.34,READ_INI,28.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,28.41,Wait,28.44,READ_INI,28.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,28.50,Wait,28.53,READ_INI,28.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,28.59,Wait,28.62,READ_INI,28.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,28.68,Wait,28.71,READ_INI,28.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,28.77,Wait,28.81,READ_INI,28.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,28.87,Wait,28.90,READ_INI,28.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,28.97,Wait,29.00,READ_INI,29.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,29.08,Wait,29.11,READ_INI,29.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,29.17,Wait,29.20,READ_INI,29.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,29.26,Wait,29.29,READ_INI,29.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,29.36,Wait,29.39,READ_INI,29.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,29.45,Wait,29.49,READ_INI,29.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,29.57,Wait,29.61,READ_INI,29.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,29.67,Wait,29.71,READ_INI,29.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,29.78,Wait,29.81,READ_INI,29.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,29.87,Wait,29.91,READ_INI,29.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,29.97,Wait,30.00,READ_INI,30.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,30.06,Wait,30.09,READ_INI,30.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,30.16,Wait,30.18,READ_INI,30.22,NO_REQ,,,,,,,,,,,,,,,,,,,
,30.25,Wait,30.28,READ_INI,30.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,30.34,Wait,30.37,READ_INI,30.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,30.44,Wait,30.46,READ_INI,30.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,30.55,Wait,30.60,READ_INI,30.63,NO_REQ,,,,,,,,,,,,,,,,,,,
,30.66,Wait,30.69,READ_INI,30.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,30.75,Wait,30.79,READ_INI,30.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,30.89,Wait,30.92,READ_INI,30.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,30.98,Wait,31.02,READ_INI,31.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,31.08,Wait,31.11,READ_INI,31.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,31.17,Wait,31.20,READ_INI,31.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,31.27,Wait,31.31,READ_INI,31.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,31.37,Wait,31.41,READ_INI,31.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,31.47,Wait,31.50,READ_INI,31.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,31.56,Wait,31.59,READ_INI,31.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,31.65,Wait,31.69,READ_INI,31.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,31.75,Wait,31.78,READ_INI,31.80,NO_REQ,,,,,,,,,,,,,,,,,,,
,31.83,Wait,31.86,READ_INI,31.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,31.92,Wait,31.95,READ_INI,31.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,32.01,Wait,32.04,READ_INI,32.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,32.12,Wait,32.16,READ_INI,32.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,32.22,Wait,32.26,READ_INI,32.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,32.33,Wait,32.36,READ_INI,32.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,32.43,Wait,32.45,READ_INI,32.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,32.51,Wait,32.54,READ_INI,32.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,32.62,Wait,32.65,READ_INI,32.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,32.72,Wait,32.75,READ_INI,32.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,32.83,Wait,32.87,READ_INI,32.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,33.00,Wait,33.04,READ_INI,33.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,33.11,Wait,33.14,READ_INI,33.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,33.20,Wait,33.24,READ_INI,33.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,33.31,Wait,33.35,READ_INI,33.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,33.40,Wait,33.45,READ_INI,33.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,33.51,Wait,33.54,READ_INI,33.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,33.61,Wait,33.64,READ_INI,33.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,33.70,Wait,33.73,READ_INI,33.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,33.79,Wait,33.83,READ_INI,33.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,33.92,Wait,33.95,READ_INI,33.99,NO_REQ,,,,,,,,,,,,,,,,,,,
,34.02,Wait,34.05,READ_INI,34.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,34.11,Wait,34.14,READ_INI,34.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,34.20,Wait,34.23,READ_INI,34.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,34.30,Wait,34.33,READ_INI,34.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,34.40,Wait,34.43,READ_INI,34.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,34.52,Wait,34.55,READ_INI,34.60,NO_REQ,,,,,,,,,,,,,,,,,,,
,34.64,Wait,34.67,READ_INI,34.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,34.73,Wait,34.77,READ_INI,34.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,34.83,Wait,34.86,READ_INI,34.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,34.92,Wait,34.95,READ_INI,34.99,NO_REQ,,,,,,,,,,,,,,,,,,,
,35.03,Wait,35.06,READ_INI,35.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,35.16,Wait,35.19,READ_INI,35.22,NO_REQ,,,,,,,,,,,,,,,,,,,
,35.26,Wait,35.30,READ_INI,35.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,35.37,Wait,35.40,READ_INI,35.43,NO_REQ,,,,,,,,,,,,,,,,,,,
,35.46,Wait,35.50,READ_INI,35.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,35.56,Wait,35.59,READ_INI,35.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,35.66,Wait,35.69,READ_INI,35.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,35.75,Wait,35.78,READ_INI,35.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,35.84,Wait,35.87,READ_INI,35.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,35.94,Wait,35.97,READ_INI,36.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,36.03,Wait,36.06,READ_INI,36.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,36.13,Wait,36.16,READ_INI,36.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,36.22,Wait,36.26,READ_INI,36.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,36.33,Wait,36.36,READ_INI,36.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,36.42,Wait,36.45,READ_INI,36.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,36.51,Wait,36.54,READ_INI,36.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,36.61,Wait,36.64,READ_INI,36.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,36.70,Wait,36.73,READ_INI,36.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,36.80,Wait,36.83,READ_INI,36.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,36.89,Wait,36.92,READ_INI,36.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,36.99,Wait,37.03,READ_INI,37.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,37.11,Wait,37.14,READ_INI,37.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,37.20,Wait,37.24,READ_INI,37.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,37.31,Wait,37.35,READ_INI,37.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,37.44,Wait,37.47,READ_INI,37.51,NO_REQ,,,,,,,,,,,,,,,,,,,
,37.54,Wait,37.58,READ_INI,37.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,37.65,Wait,37.69,READ_INI,37.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,37.76,Wait,37.79,READ_INI,37.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,37.86,Wait,37.89,READ_INI,37.93,NO_REQ,,,,,,,,,,,,,,,,,,,
,37.97,Wait,38.00,READ_INI,38.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,38.06,Wait,38.10,READ_INI,38.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,38.17,Wait,38.20,READ_INI,38.24,NO_REQ,,,,,,,,,,,,,,,,,,,
,38.29,Wait,38.32,READ_INI,38.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,38.39,Wait,38.43,READ_INI,38.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,38.50,Wait,38.53,READ_INI,38.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,38.60,Wait,38.63,READ_INI,38.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,38.69,Wait,38.72,READ_INI,38.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,38.78,Wait,38.81,READ_INI,38.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,38.87,Wait,38.90,READ_INI,38.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,38.98,Wait,39.02,READ_INI,39.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,39.08,Wait,39.11,READ_INI,39.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,39.17,Wait,39.20,READ_INI,39.24,NO_REQ,,,,,,,,,,,,,,,,,,,
,39.28,Wait,39.31,READ_INI,39.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,39.37,Wait,39.40,READ_INI,39.43,NO_REQ,,,,,,,,,,,,,,,,,,,
,39.47,Wait,39.50,READ_INI,39.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,39.56,Wait,39.59,READ_INI,39.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,39.66,Wait,39.69,READ_INI,39.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,39.77,Wait,39.81,READ_INI,39.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,39.87,Wait,39.90,READ_INI,39.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,39.99,Wait,40.03,READ_INI,40.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,40.13,Wait,40.22,READ_INI,40.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,40.29,Wait,40.33,READ_INI,40.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,40.41,Wait,40.44,READ_INI,40.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,40.50,Wait,40.53,READ_INI,40.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,40.59,Wait,40.62,READ_INI,40.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,40.69,Wait,40.71,READ_INI,40.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,40.78,Wait,40.81,READ_INI,40.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,40.87,Wait,40.91,READ_INI,40.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,40.99,Wait,41.03,READ_INI,41.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,41.09,Wait,41.12,READ_INI,41.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,41.19,Wait,41.22,READ_INI,41.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,41.28,Wait,41.31,READ_INI,41.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,41.37,Wait,41.41,READ_INI,41.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,41.49,Wait,41.53,READ_INI,41.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,41.60,Wait,41.65,READ_INI,41.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,41.72,Wait,41.75,READ_INI,41.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,41.81,Wait,41.84,READ_INI,41.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,41.90,Wait,41.93,READ_INI,41.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,42.00,Wait,42.03,READ_INI,42.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,42.09,Wait,42.12,READ_INI,42.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,42.19,Wait,42.22,READ_INI,42.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,42.28,Wait,42.31,READ_INI,42.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,42.39,Wait,42.42,READ_INI,42.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,42.48,Wait,42.52,READ_INI,42.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,42.59,Wait,42.63,READ_INI,42.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,42.70,Wait,42.73,READ_INI,42.76,NO_REQ,,,,,,,,,,,,,,,,,,,
,42.79,Wait,42.83,READ_INI,42.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,42.89,Wait,42.92,READ_INI,42.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,42.98,Wait,43.01,READ_INI,43.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,43.09,Wait,43.13,READ_INI,43.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,43.21,Wait,43.25,READ_INI,43.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,43.31,Wait,43.34,READ_INI,43.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,43.40,Wait,43.44,READ_INI,43.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,43.50,Wait,43.54,READ_INI,43.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,43.61,Wait,43.65,READ_INI,43.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,43.73,Wait,43.76,READ_INI,43.80,NO_REQ,,,,,,,,,,,,,,,,,,,
,43.83,Wait,43.86,READ_INI,43.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,43.92,Wait,43.95,READ_INI,43.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,44.02,Wait,44.04,READ_INI,44.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,44.11,Wait,44.14,READ_INI,44.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,44.20,Wait,44.23,READ_INI,44.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,44.31,Wait,44.34,READ_INI,44.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,44.41,Wait,44.44,READ_INI,44.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,44.51,Wait,44.54,READ_INI,44.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,44.63,Wait,44.66,READ_INI,44.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,44.73,Wait,44.77,READ_INI,44.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,44.83,Wait,44.86,READ_INI,44.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,44.93,Wait,44.97,READ_INI,45.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,45.03,Wait,45.06,READ_INI,45.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,45.12,Wait,45.15,READ_INI,45.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,45.22,Wait,45.25,READ_INI,45.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,45.31,Wait,45.34,READ_INI,45.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,45.41,Wait,45.44,READ_INI,45.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,45.50,Wait,45.53,READ_INI,45.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,45.59,Wait,45.62,READ_INI,45.65,NO_REQ,,,,,,,,,,,,,,,,,,,
,45.69,Wait,45.72,READ_INI,45.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,45.78,Wait,45.81,READ_INI,45.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,45.87,Wait,45.91,READ_INI,45.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,45.98,Wait,46.02,READ_INI,46.05,NO_REQ,,,,,,,,,,,,,,,,,,,
,46.08,Wait,46.11,READ_INI,46.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,46.17,Wait,46.21,READ_INI,46.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,46.28,Wait,46.30,READ_INI,46.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,46.36,Wait,46.39,READ_INI,46.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,46.45,Wait,46.49,READ_INI,46.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,46.55,Wait,46.60,READ_INI,46.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,46.67,Wait,46.70,READ_INI,46.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,46.76,Wait,46.79,READ_INI,46.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,46.86,Wait,46.89,READ_INI,46.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,46.95,Wait,46.98,READ_INI,47.01,NO_REQ,,,,,,,,,,,,,,,,,,,
,47.04,Wait,47.08,READ_INI,47.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,47.14,Wait,47.17,READ_INI,47.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,47.27,Wait,47.30,READ_INI,47.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,47.35,Wait,47.39,READ_INI,47.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,47.45,Wait,47.49,READ_INI,47.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,47.61,Wait,47.64,READ_INI,47.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,47.70,Wait,47.73,READ_INI,47.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,47.81,Wait,47.84,READ_INI,47.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,47.91,Wait,47.94,READ_INI,47.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,48.00,Wait,48.03,READ_INI,48.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,48.09,Wait,48.12,READ_INI,48.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,48.19,Wait,48.23,READ_INI,48.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,48.29,Wait,48.33,READ_INI,48.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,48.40,Wait,48.44,READ_INI,48.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,48.50,Wait,48.53,READ_INI,48.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,48.59,Wait,48.62,READ_INI,48.65,NO_REQ,,,,,,,,,,,,,,,,,,,
,48.69,Wait,48.71,READ_INI,48.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,48.78,Wait,48.82,READ_INI,48.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,48.89,Wait,48.92,READ_INI,48.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,48.99,Wait,49.03,READ_INI,49.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,49.11,Wait,49.14,READ_INI,49.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,49.20,Wait,49.25,READ_INI,49.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,49.31,Wait,49.35,READ_INI,49.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,49.42,Wait,49.45,READ_INI,49.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,49.51,Wait,49.54,READ_INI,49.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,49.61,Wait,49.64,READ_INI,49.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,49.70,Wait,49.73,READ_INI,49.76,NO_REQ,,,,,,,,,,,,,,,,,,,
,49.79,Wait,49.85,READ_INI,49.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,49.92,Wait,49.95,READ_INI,49.99,NO_REQ,,,,,,,,,,,,,,,,,,,
,50.04,Wait,50.07,READ_INI,50.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,50.14,Wait,50.17,READ_INI,50.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,50.23,Wait,50.27,READ_INI,50.30,NO_REQ,,,,,,,,,,,,,,,,,,,
,50.34,Wait,50.37,READ_INI,50.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,50.43,Wait,50.47,READ_INI,50.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,50.53,Wait,50.56,READ_INI,50.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,50.62,Wait,50.66,READ_INI,50.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,50.72,Wait,50.76,READ_INI,50.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,50.83,Wait,50.87,READ_INI,50.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,50.94,Wait,50.97,READ_INI,51.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,51.03,Wait,51.06,READ_INI,51.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,51.12,Wait,51.16,READ_INI,51.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,51.22,Wait,51.25,READ_INI,51.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,51.31,Wait,51.34,READ_INI,51.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,51.41,Wait,51.44,READ_INI,51.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,51.50,Wait,51.53,READ_INI,51.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,51.59,Wait,51.62,READ_INI,51.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,51.70,Wait,51.74,READ_INI,51.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,51.81,Wait,51.84,READ_INI,51.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,51.91,Wait,51.94,READ_INI,51.99,NO_REQ,,,,,,,,,,,,,,,,,,,
,52.02,Wait,52.04,READ_INI,52.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,52.13,Wait,52.15,READ_INI,52.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,52.22,Wait,52.25,READ_INI,52.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,52.31,Wait,52.34,READ_INI,52.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,52.41,Wait,52.44,READ_INI,52.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,52.50,Wait,52.53,READ_INI,52.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,52.59,Wait,52.62,READ_INI,52.65,NO_REQ,,,,,,,,,,,,,,,,,,,
,52.69,Wait,52.72,READ_INI,52.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,52.78,Wait,52.81,READ_INI,52.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,52.87,Wait,52.92,READ_INI,52.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,52.99,Wait,53.03,READ_INI,53.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,53.12,Wait,53.15,READ_INI,53.18,NO_REQ,,,,,,,,,,,,,,,,,,,
,53.22,Wait,53.27,READ_INI,53.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,53.33,Wait,53.36,READ_INI,53.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,53.42,Wait,53.45,READ_INI,53.49,NO_REQ,,,,,,,,,,,,,,,,,,,
,53.52,Wait,53.54,READ_INI,53.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,53.65,Wait,53.69,READ_INI,53.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,53.75,Wait,53.78,READ_INI,53.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,53.85,Wait,53.89,READ_INI,53.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,53.95,Wait,53.98,READ_INI,54.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,54.05,Wait,54.08,READ_INI,54.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,54.14,Wait,54.17,READ_INI,54.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,54.25,Wait,54.28,READ_INI,54.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,54.35,Wait,54.37,READ_INI,54.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,54.45,Wait,54.48,READ_INI,54.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,54.56,Wait,54.59,READ_INI,54.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,54.66,Wait,54.69,READ_INI,54.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,54.77,Wait,54.81,READ_INI,54.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,54.87,Wait,54.91,READ_INI,54.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,54.97,Wait,55.00,READ_INI,55.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,55.08,Wait,55.11,READ_INI,55.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,55.17,Wait,55.20,READ_INI,55.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,55.27,Wait,55.30,READ_INI,55.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,55.36,Wait,55.40,READ_INI,55.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,55.47,Wait,55.50,READ_INI,55.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,55.57,Wait,55.61,READ_INI,55.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,55.67,Wait,55.70,READ_INI,55.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,55.77,Wait,55.80,READ_INI,55.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,55.86,Wait,55.89,READ_INI,55.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,55.95,Wait,55.99,READ_INI,56.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,56.07,Wait,56.12,READ_INI,56.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,56.20,Wait,56.23,READ_INI,56.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,56.29,Wait,56.33,READ_INI,56.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,56.42,Wait,56.45,READ_INI,56.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,56.51,Wait,56.54,READ_INI,56.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,56.61,Wait,56.64,READ_INI,56.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,56.70,Wait,56.74,READ_INI,56.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,56.80,Wait,56.84,READ_INI,56.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,56.90,Wait,56.94,READ_INI,56.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,57.00,Wait,57.03,READ_INI,57.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,57.09,Wait,57.12,READ_INI,57.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,57.19,Wait,57.22,READ_INI,57.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,57.29,Wait,57.33,READ_INI,57.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,57.38,Wait,57.41,READ_INI,57.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,57.47,Wait,57.51,READ_INI,57.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,57.59,Wait,57.63,READ_INI,57.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,57.70,Wait,57.74,READ_INI,57.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,57.81,Wait,57.85,READ_INI,57.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,57.94,Wait,57.97,READ_INI,58.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,58.03,Wait,58.06,READ_INI,58.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,58.12,Wait,58.15,READ_INI,58.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,58.21,Wait,58.25,READ_INI,58.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,58.31,Wait,58.34,READ_INI,58.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,58.40,Wait,58.44,READ_INI,58.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,58.50,Wait,58.52,READ_INI,58.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,58.58,Wait,58.61,READ_INI,58.65,NO_REQ,,,,,,,,,,,,,,,,,,,
,58.69,Wait,58.72,READ_INI,58.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,58.78,Wait,58.81,READ_INI,58.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,58.88,Wait,58.91,READ_INI,58.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,58.97,Wait,59.00,READ_INI,59.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,59.06,Wait,59.09,READ_INI,59.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,59.15,Wait,59.19,READ_INI,59.22,NO_REQ,,,,,,,,,,,,,,,,,,,
,59.25,Wait,59.28,READ_INI,59.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,59.34,Wait,59.37,READ_INI,59.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,59.44,Wait,59.47,READ_INI,59.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,59.53,Wait,59.56,READ_INI,59.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,59.62,Wait,59.66,READ_INI,59.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,59.71,Wait,59.74,READ_INI,59.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,59.82,Wait,59.87,READ_INI,59.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,59.94,Wait,59.97,READ_INI,60.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,60.03,Wait,60.06,READ_INI,60.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,60.13,Wait,60.17,READ_INI,60.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,60.23,Wait,60.28,READ_INI,60.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,60.34,Wait,60.38,READ_INI,60.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,60.45,Wait,60.48,READ_INI,60.51,NO_REQ,,,,,,,,,,,,,,,,,,,
,60.54,Wait,60.58,READ_INI,60.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,60.64,Wait,60.67,READ_INI,60.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,60.75,Wait,60.78,READ_INI,60.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,60.84,Wait,60.87,READ_INI,60.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,60.94,Wait,60.97,READ_INI,61.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,61.03,Wait,61.06,READ_INI,61.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,61.12,Wait,61.16,READ_INI,61.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,61.21,Wait,61.25,READ_INI,61.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,61.31,Wait,61.34,READ_INI,61.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,61.41,Wait,61.44,READ_INI,61.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,61.50,Wait,61.54,READ_INI,61.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,61.61,Wait,61.64,READ_INI,61.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,61.70,Wait,61.74,READ_INI,61.76,NO_REQ,,,,,,,,,,,,,,,,,,,
,61.79,Wait,61.83,READ_INI,61.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,61.89,Wait,61.94,READ_INI,61.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,62.00,Wait,62.03,READ_INI,62.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,62.09,Wait,62.12,READ_INI,62.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,62.19,Wait,62.21,READ_INI,62.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,62.29,Wait,62.33,READ_INI,62.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,62.40,Wait,62.44,READ_INI,62.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,62.50,Wait,62.53,READ_INI,62.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,62.59,Wait,62.62,READ_INI,62.65,NO_REQ,,,,,,,,,,,,,,,,,,,
,62.69,Wait,62.72,READ_INI,62.76,NO_REQ,,,,,,,,,,,,,,,,,,,
,62.79,Wait,64.24,READ_INI,64.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,64.31,Wait,64.34,READ_INI,64.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,64.40,Wait,64.44,READ_INI,64.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,64.50,Wait,64.53,READ_INI,64.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,64.59,Wait,64.62,READ_INI,64.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,64.68,Wait,64.72,READ_INI,64.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,64.80,Wait,64.83,READ_INI,64.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,64.90,Wait,64.94,READ_INI,64.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,65.00,Wait,65.03,READ_INI,65.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,65.09,Wait,65.13,READ_INI,65.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,65.22,Wait,65.25,READ_INI,65.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,65.33,Wait,65.36,READ_INI,65.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,65.42,Wait,65.45,READ_INI,65.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,65.52,Wait,65.56,READ_INI,65.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,65.63,Wait,65.69,READ_INI,65.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,65.76,Wait,65.84,READ_INI,65.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,65.91,Wait,65.94,READ_INI,65.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,66.00,Wait,66.03,READ_INI,66.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,66.09,Wait,66.12,READ_INI,66.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,66.20,Wait,66.24,READ_INI,66.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,66.30,Wait,66.33,READ_INI,66.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,66.39,Wait,66.42,READ_INI,66.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,66.49,Wait,66.53,READ_INI,66.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,66.61,Wait,66.63,READ_INI,66.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,66.70,Wait,66.73,READ_INI,66.76,NO_REQ,,,,,,,,,,,,,,,,,,,
,66.79,Wait,66.83,READ_INI,66.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,66.89,Wait,66.92,READ_INI,66.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,66.98,Wait,67.01,READ_INI,67.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,67.08,Wait,67.11,READ_INI,67.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,67.17,Wait,67.20,READ_INI,67.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,67.27,Wait,67.30,READ_INI,67.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,67.37,Wait,67.41,READ_INI,67.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,67.49,Wait,67.53,READ_INI,67.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,67.61,Wait,67.64,READ_INI,67.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,67.70,Wait,67.74,READ_INI,67.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,67.81,Wait,67.84,READ_INI,67.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,67.91,Wait,67.94,READ_INI,67.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,68.00,Wait,68.03,READ_INI,68.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,68.09,Wait,68.12,READ_INI,68.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,68.19,Wait,68.22,READ_INI,68.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,68.33,Wait,68.36,READ_INI,68.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,68.42,Wait,68.45,READ_INI,68.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,68.52,Wait,68.60,READ_INI,68.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,68.74,Wait,68.77,READ_INI,68.80,NO_REQ,,,,,,,,,,,,,,,,,,,
,68.84,Wait,68.88,READ_INI,68.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,68.94,Wait,68.97,READ_INI,69.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,69.03,Wait,69.06,READ_INI,69.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,69.13,Wait,69.15,READ_INI,69.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,69.21,Wait,69.23,READ_INI,69.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,69.30,Wait,69.33,READ_INI,69.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,69.39,Wait,69.42,READ_INI,69.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,69.48,Wait,69.51,READ_INI,69.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,69.57,Wait,69.61,READ_INI,69.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,69.67,Wait,69.70,READ_INI,69.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,69.77,Wait,69.80,READ_INI,69.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,69.86,Wait,69.89,READ_INI,69.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,69.96,Wait,70.00,READ_INI,70.05,NO_REQ,,,,,,,,,,,,,,,,,,,
,70.07,Wait,70.12,READ_INI,70.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,70.19,Wait,70.22,READ_INI,70.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,70.28,Wait,70.40,READ_INI,70.43,NO_REQ,,,,,,,,,,,,,,,,,,,
,70.46,Wait,70.52,READ_INI,70.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,70.59,Wait,70.63,READ_INI,70.68,NO_REQ,,,,,,,,,,,,,,,,,,,
,70.72,Wait,70.75,READ_INI,70.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,70.81,Wait,70.84,READ_INI,70.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,70.90,Wait,70.94,READ_INI,70.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,71.00,Wait,71.03,READ_INI,71.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,71.10,Wait,71.14,READ_INI,71.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,71.21,Wait,71.25,READ_INI,71.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,71.31,Wait,71.34,READ_INI,71.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,71.41,Wait,71.44,READ_INI,71.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,71.49,Wait,71.51,READ_INI,71.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,71.57,Wait,71.61,READ_INI,71.65,NO_REQ,,,,,,,,,,,,,,,,,,,
,71.69,Wait,71.71,READ_INI,71.76,NO_REQ,,,,,,,,,,,,,,,,,,,
,71.80,Wait,71.83,READ_INI,71.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,71.89,Wait,71.92,READ_INI,71.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,71.98,Wait,72.02,READ_INI,72.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,72.08,Wait,72.11,READ_INI,72.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,72.17,Wait,72.20,READ_INI,72.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,72.26,Wait,72.30,READ_INI,72.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,72.36,Wait,72.39,READ_INI,72.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,72.45,Wait,72.48,READ_INI,72.51,NO_REQ,,,,,,,,,,,,,,,,,,,
,72.54,Wait,72.58,READ_INI,72.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,72.64,Wait,72.68,READ_INI,72.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,72.75,Wait,72.78,READ_INI,72.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,72.84,Wait,72.87,READ_INI,72.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,72.94,Wait,72.98,READ_INI,73.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,73.05,Wait,73.08,READ_INI,73.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,73.14,Wait,73.17,READ_INI,73.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,73.23,Wait,73.27,READ_INI,73.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,73.33,Wait,73.36,READ_INI,73.39,INI_1,,,,,,,,,,,,,,,,,,,
,73.42,REQ,73.45,READ_INI,73.48,INI_1,,,,,,,,,,,,,,,,,,,
,73.51,REQ,73.54,READ_INI,73.58,INI_1,,,,,,,,,,,,,,,,,,,
,73.61,REQ,73.64,READ_INI,73.67,INI_1,,,,,,,,,,,,,,,,,,,
,73.70,REQ,73.73,READ_INI,73.76,INI_1,,,,,,,,,,,,,,,,,,,
,73.79,REQ,73.85,READ_INI,73.89,INI_1,,,,,,,,,,,,,,,,,,,
,73.92,REQ,73.96,READ_INI,74.03,INI_1,,,,,,,,,,,,,,,,,,,
,74.06,RESP,74.09,READ_INI,74.12,INI_1,,,,,,,,,,,,,,,,,,,
,74.16,RESP,74.19,READ_INI,74.21,INI_1,,,,,,,,,,,,,,,,,,,
,74.25,RESP,74.28,READ_INI,74.31,INI_1,,,,,,,,,,,,,,,,,,,
,74.34,RESP,74.37,READ_INI,74.41,INI_1,,,,,,,,,,,,,,,,,,,
,74.43,RESP,74.47,READ_INI,74.50,INI_1,,,,,,,,,,,,,,,,,,,
,74.53,RESP,74.55,READ_INI,74.57,INI_1,,,,,,,,,,,,,,,,,,,
,74.61,RESP,74.64,READ_INI,74.67,INI_1,,,,,,,,,,,,,,,,,,,
,74.70,RESP,74.73,READ_INI,74.77,INI_1,,,,,,,,,,,,,,,,,,,
,74.82,RESP,74.86,READ_INI,74.89,INI_2,,,,,,,,,,,,,,,,,,,
,74.92,REQ,74.96,READ_INI,75.00,INI_2,,,,,,,,,,,,,,,,,,,
,75.03,REQ,75.06,READ_INI,75.09,INI_2,,,,,,,,,,,,,,,,,,,
,75.12,REQ,75.15,READ_INI,75.19,INI_2,,,,,,,,,,,,,,,,,,,
,75.23,REQ,75.27,READ_INI,75.30,INI_2,,,,,,,,,,,,,,,,,,,
,75.33,REQ,75.36,READ_INI,75.39,INI_2,,,,,,,,,,,,,,,,,,,
,75.42,REQ,75.45,READ_INI,75.48,INI_2,,,,,,,,,,,,,,,,,,,
,75.52,REQ,75.56,READ_INI,75.59,INI_2,,,,,,,,,,,,,,,,,,,
,75.62,RESP,75.66,READ_INI,75.70,INI_2,,,,,,,,,,,,,,,,,,,
,75.73,RESP,75.77,READ_INI,75.80,INI_2,,,,,,,,,,,,,,,,,,,
,75.83,RESP,75.87,READ_INI,75.90,INI_2,,,,,,,,,,,,,,,,,,,
,75.94,RESP,75.97,READ_INI,76.00,INI_2,,,,,,,,,,,,,,,,,,,
,76.03,RESP,76.06,READ_INI,76.09,INI_2,,,,,,,,,,,,,,,,,,,
,76.12,RESP,76.16,READ_INI,76.19,INI_2,,,,,,,,,,,,,,,,,,,
,76.24,RESP,76.28,READ_INI,76.31,INI_2,,,,,,,,,,,,,,,,,,,
,76.35,RESP,76.38,READ_INI,76.42,INI_2,,,,,,,,,,,,,,,,,,,
,76.45,ready,76.48,READ_INI,76.54,INI_2,,,,,,,,,,,,,,,,,,,
,76.58,Wait,76.61,READ_INI,76.69,SW_READ_1,,,,,,,,,,,,,,,,,,,
,76.71,REQ,76.75,SW_VERSION,76.78,SW_READ_1,,,,,,,,,,,,,,,,,,,
,76.81,REQ,76.84,SW_VERSION,76.87,SW_READ_1,,,,,,,,,,,,,,,,,,,
,76.90,REQ,76.95,SW_VERSION,76.98,SW_READ_1,,,,,,,,,,,,,,,,,,,
,77.02,REQ,77.05,SW_VERSION,77.09,SW_READ_1,,,,,,,,,,,,,,,,,,,
,77.12,REQ,77.16,SW_VERSION,77.20,SW_READ_1,,,,,,,,,,,,,,,,,,,
,77.23,REQ,77.27,SW_VERSION,77.29,SW_READ_1,,,,,,,,,,,,,,,,,,,
,77.33,RESP,77.36,SW_VERSION,77.39,SW_READ_1,,,,,,,,,,,,,,,,,,,
,77.42,RESP,77.45,SW_VERSION,77.48,SW_READ_1,,,,,,,,,,,,,,,,,,,
,77.51,RESP,77.54,SW_VERSION,77.57,SW_READ_1,,,,,,,,,,,,,,,,,,,
,77.61,RESP,77.64,SW_VERSION,77.67,SW_READ_1,,,,,,,,,,,,,,,,,,,
,77.70,RESP,77.73,SW_VERSION,77.76,SW_READ_1,,,,,,,,,,,,,,,,,,,
,77.79,RESP,77.83,SW_VERSION,77.86,SW_READ_1,,,,,,,,,,,,,,,,,,,
,77.89,RESP,77.92,SW_VERSION,77.95,SW_READ_1,,,,,,,,,,,,,,,,,,,
,77.98,RESP,78.02,SW_VERSION,78.05,SW_READ_1,,,,,,,,,,,,,,,,,,,
,78.08,RESP,78.11,SW_VERSION,78.14,SW_READ_1,,,,,,,,,,,,,,,,,,,
,78.17,RESP,78.20,SW_VERSION,78.23,SW_READ_2,,,,,,,,,,,,,,,,,,,
,78.26,REQ,78.30,SW_VERSION,78.33,SW_READ_2,,,,,,,,,,,,,,,,,,,
,78.36,REQ,78.39,SW_VERSION,78.42,SW_READ_2,,,,,,,,,,,,,,,,,,,
,78.45,REQ,78.48,SW_VERSION,78.52,SW_READ_2,,,,,,,,,,,,,,,,,,,
,78.54,REQ,78.58,SW_VERSION,78.61,SW_READ_2,,,,,,,,,,,,,,,,,,,
,78.64,REQ,78.67,SW_VERSION,78.73,SW_READ_2,,,,,,,,,,,,,,,,,,,
,78.77,REQ,78.81,SW_VERSION,78.84,SW_READ_2,,,,,,,,,,,,,,,,,,,
,78.89,RESP,78.92,SW_VERSION,78.95,SW_READ_2,,,,,,,,,,,,,,,,,,,
,78.98,RESP,79.02,SW_VERSION,79.06,SW_READ_2,,,,,,,,,,,,,,,,,,,
,79.09,RESP,79.12,SW_VERSION,79.15,SW_READ_2,,,,,,,,,,,,,,,,,,,
,79.19,RESP,79.21,SW_VERSION,79.25,SW_READ_2,,,,,,,,,,,,,,,,,,,
,79.28,RESP,79.31,SW_VERSION,79.34,SW_READ_2,,,,,,,,,,,,,,,,,,,
,79.38,RESP,79.42,SW_VERSION,79.45,SW_READ_2,,,,,,,,,,,,,,,,,,,
,79.48,RESP,79.51,SW_VERSION,79.54,SW_READ_2,,,,,,,,,,,,,,,,,,,
,79.58,RESP,79.61,SW_VERSION,79.64,SW_READ_2,,,,,,,,,,,,,,,,,,,
,79.67,RESP,79.71,SW_VERSION,79.76,SW_READ_2,,,,,,,,,,,,,,,,,,,
,79.79,ready,79.83,SW_VERSION,79.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,79.89,Wait,79.92,SW_VERSION,79.96,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,79.99,REQ,80.03,TAM_SWI_DIAG,80.06,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,80.09,REQ,80.12,TAM_SWI_DIAG,80.16,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,80.20,REQ,80.23,TAM_SWI_DIAG,80.26,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,80.30,REQ,80.35,TAM_SWI_DIAG,80.39,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,80.42,REQ,80.46,TAM_SWI_DIAG,80.50,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,80.53,REQ,80.56,TAM_SWI_DIAG,80.59,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,80.62,RESP,80.66,TAM_SWI_DIAG,80.69,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,80.72,RESP,80.76,TAM_SWI_DIAG,80.79,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,80.83,RESP,80.86,TAM_SWI_DIAG,80.89,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,80.92,RESP,80.95,TAM_SWI_DIAG,80.98,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,81.01,RESP,81.04,TAM_SWI_DIAG,81.08,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,81.11,RESP,81.14,TAM_SWI_DIAG,81.17,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,81.20,RESP,81.23,TAM_SWI_DIAG,81.27,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,81.30,RESP,81.33,TAM_SWI_DIAG,81.36,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,81.39,RESP,81.43,TAM_SWI_DIAG,81.46,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,81.50,ready,81.53,TAM_SWI_DIAG,81.56,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,81.59,ready,81.62,TAM_SWI_DIAG,81.66,INI_1,,,,,,,,,,,,,,,,,,,
,81.68,REQ,81.72,TAM_SWI_DIAG,81.75,INI_1,,,,,,,,,,,,,,,,,,,
,81.78,REQ,81.81,TAM_SWI_DIAG,81.84,INI_1,,,,,,,,,,,,,,,,,,,
,81.87,REQ,81.91,TAM_SWI_DIAG,81.94,INI_1,,,,,,,,,,,,,,,,,,,
,81.97,REQ,82.03,TAM_SWI_DIAG,82.06,INI_1,,,,,,,,,,,,,,,,,,,
,82.09,REQ,82.12,TAM_SWI_DIAG,82.16,INI_1,,,,,,,,,,,,,,,,,,,
,82.19,REQ,82.22,TAM_SWI_DIAG,82.26,INI_1,,,,,,,,,,,,,,,,,,,
,82.29,REQ,82.33,TAM_SWI_DIAG,82.36,INI_1,,,,,,,,,,,,,,,,,,,
,82.39,RESP,82.42,TAM_SWI_DIAG,82.45,INI_1,,,,,,,,,,,,,,,,,,,
,82.49,RESP,82.53,TAM_SWI_DIAG,82.56,INI_1,,,,,,,,,,,,,,,,,,,
,82.59,RESP,82.62,TAM_SWI_DIAG,82.65,INI_1,,,,,,,,,,,,,,,,,,,
,82.69,RESP,82.71,TAM_SWI_DIAG,82.75,INI_1,,,,,,,,,,,,,,,,,,,
,82.78,RESP,82.83,TAM_SWI_DIAG,82.86,INI_1,,,,,,,,,,,,,,,,,,,
,82.89,RESP,82.92,TAM_SWI_DIAG,82.95,INI_1,,,,,,,,,,,,,,,,,,,
,82.98,RESP,83.02,TAM_SWI_DIAG,83.05,INI_1,,,,,,,,,,,,,,,,,,,
,83.08,RESP,83.11,TAM_SWI_DIAG,83.17,INI_1,,,,,,,,,,,,,,,,,,,
,83.20,REQ,83.23,TAM_SWI_DIAG,83.27,INI_2,,,,,,,,,,,,,,,,,,,
,83.31,REQ,83.34,TAM_SWI_DIAG,83.38,INI_2,,,,,,,,,,,,,,,,,,,
,83.41,REQ,83.44,TAM_SWI_DIAG,83.47,INI_2,,,,,,,,,,,,,,,,,,,
,83.50,REQ,83.53,TAM_SWI_DIAG,83.56,INI_2,,,,,,,,,,,,,,,,,,,
,83.59,REQ,83.63,TAM_SWI_DIAG,83.65,INI_2,,,,,,,,,,,,,,,,,,,
,83.69,REQ,83.74,TAM_SWI_DIAG,83.77,INI_2,,,,,,,,,,,,,,,,,,,
,83.81,REQ,83.84,TAM_SWI_DIAG,83.87,INI_2,,,,,,,,,,,,,,,,,,,
,83.91,RESP,83.94,TAM_SWI_DIAG,83.97,INI_2,,,,,,,,,,,,,,,,,,,
,84.00,RESP,84.03,TAM_SWI_DIAG,84.06,INI_2,,,,,,,,,,,,,,,,,,,
,84.09,RESP,84.13,TAM_SWI_DIAG,84.16,INI_2,,,,,,,,,,,,,,,,,,,
,84.19,RESP,84.22,TAM_SWI_DIAG,84.25,INI_2,,,,,,,,,,,,,,,,,,,
,84.28,RESP,84.31,TAM_SWI_DIAG,84.34,INI_2,,,,,,,,,,,,,,,,,,,
,84.37,RESP,84.41,TAM_SWI_DIAG,84.44,INI_2,,,,,,,,,,,,,,,,,,,
,84.47,RESP,84.50,TAM_SWI_DIAG,84.53,INI_2,,,,,,,,,,,,,,,,,,,
,84.56,RESP,84.59,TAM_SWI_DIAG,84.62,INI_2,,,,,,,,,,,,,,,,,,,
,84.66,RESP,84.69,TAM_SWI_DIAG,84.71,INI_2,,,,,,,,,,,,,,,,,,,
,84.75,ready,84.78,TAM_SWI_DIAG,84.81,INI_2,,,,,,,,,,,,,,,,,,,
,84.84,Wait,84.87,TAM_SWI_DIAG,84.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,84.94,Wait,84.99,TAM_SWI_DIAG,85.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,85.05,REQ,85.09,SMALL_LEAK_DIAG,85.12,SWI_PSN,,,,,,,,,,,,,,,,,,,
,85.18,REQ,85.22,SMALL_LEAK_DIAG,85.25,SWI_PSN,,,,,,,,,,,,,,,,,,,
,85.28,REQ,85.31,SMALL_LEAK_DIAG,85.34,SWI_PSN,,,,,,,,,,,,,,,,,,,
,85.37,REQ,85.41,SMALL_LEAK_DIAG,85.44,SWI_PSN,,,,,,,,,,,,,,,,,,,
,85.47,REQ,85.50,SMALL_LEAK_DIAG,85.53,SWI_PSN,,,,,,,,,,,,,,,,,,,
,85.56,REQ,85.59,SMALL_LEAK_DIAG,85.63,SWI_PSN,,,,,,,,,,,,,,,,,,,
,85.67,REQ,85.70,SMALL_LEAK_DIAG,85.73,SWI_PSN,,,,,,,,,,,,,,,,,,,
,85.77,RESP,85.81,SMALL_LEAK_DIAG,85.84,SWI_PSN,,,,,,,,,,,,,,,,,,,
,85.88,RESP,85.92,SMALL_LEAK_DIAG,85.95,SWI_PSN,,,,,,,,,,,,,,,,,,,
,86.01,RESP,86.05,SMALL_LEAK_DIAG,86.08,SWI_PSN,,,,,,,,,,,,,,,,,,,
,86.11,RESP,86.14,SMALL_LEAK_DIAG,86.17,SWI_PSN,,,,,,,,,,,,,,,,,,,
,86.20,RESP,86.24,SMALL_LEAK_DIAG,86.28,SWI_PSN,,,,,,,,,,,,,,,,,,,
,86.31,RESP,86.34,SMALL_LEAK_DIAG,86.37,SWI_PSN,,,,,,,,,,,,,,,,,,,
,86.41,RESP,86.44,SMALL_LEAK_DIAG,86.46,SWI_PSN,,,,,,,,,,,,,,,,,,,
,86.50,RESP,86.53,SMALL_LEAK_DIAG,86.56,SWI_PSN,,,,,,,,,,,,,,,,,,,
,86.59,ready,86.64,SMALL_LEAK_DIAG,86.68,NO_REQ,,,,,,,,,,,,,,,,,,,
,86.72,Wait,86.75,SMALL_LEAK_DIAG,86.78,T_CLOSE_RNG,,,,,,,,,,,,,,,,,,,
,86.81,REQ,86.84,SMALL_LEAK_DIAG,86.88,T_CLOSE_RNG,,,,,,,,,,,,,,,,,,,
,86.92,REQ,86.95,SMALL_LEAK_DIAG,86.98,T_CLOSE_RNG,,,,,,,,,,,,,,,,,,,
,87.01,REQ,87.04,SMALL_LEAK_DIAG,87.08,T_CLOSE_RNG,,,,,,,,,,,,,,,,,,,
,87.12,REQ,87.16,SMALL_LEAK_DIAG,87.19,T_CLOSE_RNG,,,,,,,,,,,,,,,,,,,
,87.23,REQ,87.28,SMALL_LEAK_DIAG,87.31,T_CLOSE_RNG,,,,,,,,,,,,,,,,,,,
,87.34,REQ,87.37,SMALL_LEAK_DIAG,87.41,T_CLOSE_RNG,,,,,,,,,,,,,,,,,,,
,87.46,RESP,87.50,SMALL_LEAK_DIAG,87.53,T_CLOSE_RNG,,,,,,,,,,,,,,,,,,,
,87.56,RESP,87.59,SMALL_LEAK_DIAG,87.62,T_CLOSE_RNG,,,,,,,,,,,,,,,,,,,
,87.65,RESP,87.68,SMALL_LEAK_DIAG,87.71,T_CLOSE_RNG,,,,,,,,,,,,,,,,,,,
,87.75,RESP,87.79,SMALL_LEAK_DIAG,87.82,T_CLOSE_RNG,,,,,,,,,,,,,,,,,,,
,87.86,RESP,87.89,SMALL_LEAK_DIAG,87.92,T_CLOSE_RNG,,,,,,,,,,,,,,,,,,,
,87.95,RESP,87.99,SMALL_LEAK_DIAG,88.03,T_CLOSE_RNG,,,,,,,,,,,,,,,,,,,
,88.06,RESP,88.10,SMALL_LEAK_DIAG,88.14,T_CLOSE_RNG,,,,,,,,,,,,,,,,,,,
,88.17,RESP,88.20,SMALL_LEAK_DIAG,88.23,T_CLOSE_RNG,,,,,,,,,,,,,,,,,,,
,88.27,RESP,88.29,SMALL_LEAK_DIAG,88.33,T_CLOSE_RNG,,,,,,,,,,,,,,,,,,,
,88.38,Wait,88.41,SMALL_LEAK_DIAG,88.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,88.47,Wait,88.51,Wait,88.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,88.58,Wait,88.61,Wait,88.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,88.67,Wait,88.70,Wait,88.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,88.77,Wait,88.80,Wait,88.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,88.86,Wait,88.89,Wait,88.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,88.96,Wait,89.00,Wait,89.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,89.05,Wait,89.08,Wait,89.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,89.15,Wait,89.19,Wait,89.22,NO_REQ,,,,,,,,,,,,,,,,,,,
,89.29,Wait,89.33,Wait,89.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,89.39,Wait,89.42,Wait,89.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,89.48,Wait,89.51,Wait,89.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,89.65,Wait,89.69,Wait,89.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,89.75,Wait,89.78,Wait,89.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,89.84,Wait,89.87,Wait,89.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,89.95,Wait,89.98,Wait,90.01,NO_REQ,,,,,,,,,,,,,,,,,,,
,90.05,Wait,90.09,Wait,90.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,90.15,Wait,90.19,Wait,90.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,90.25,Wait,90.28,Wait,90.32,NO_REQ,,,,,,,,,,,,,,,,,,,
,90.36,Wait,90.38,Wait,90.43,NO_REQ,,,,,,,,,,,,,,,,,,,
,90.46,Wait,90.50,Wait,90.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,90.57,Wait,90.61,Wait,90.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,90.67,Wait,90.70,Wait,90.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,90.77,Wait,90.79,Wait,90.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,90.86,Wait,90.90,Wait,90.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,90.97,Wait,91.00,Wait,91.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,91.06,Wait,91.09,Wait,91.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,91.15,Wait,91.19,Wait,91.22,NO_REQ,,,,,,,,,,,,,,,,,,,
,91.25,Wait,91.28,Wait,91.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,91.34,Wait,91.37,Wait,91.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,91.44,Wait,91.47,Wait,91.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,91.53,Wait,91.56,Wait,91.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,91.62,Wait,91.66,Wait,91.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,91.71,Wait,91.75,Wait,91.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,91.81,Wait,91.84,Wait,91.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,91.90,Wait,91.94,Wait,91.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,92.00,Wait,92.03,Wait,92.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,92.10,Wait,92.14,Wait,92.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,92.20,Wait,92.25,Wait,92.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,92.31,Wait,92.35,Wait,92.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,92.40,Wait,92.44,Wait,92.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,92.51,Wait,92.54,Wait,92.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,92.61,Wait,92.65,Wait,92.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,92.71,Wait,92.79,Wait,92.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,92.86,Wait,92.89,Wait,92.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,92.95,Wait,93.00,Wait,93.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,93.07,Wait,93.11,Wait,93.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,93.17,Wait,93.20,Wait,93.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,93.28,Wait,93.31,Wait,93.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,93.39,Wait,93.42,Wait,93.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,93.48,Wait,93.51,Wait,93.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,93.58,Wait,93.61,Wait,93.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,93.67,Wait,93.70,Wait,93.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,93.77,Wait,93.79,Wait,93.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,93.85,Wait,93.89,Wait,93.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,93.96,Wait,94.00,Wait,94.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,94.07,Wait,94.11,Wait,94.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,94.18,Wait,94.21,Wait,94.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,94.29,Wait,94.33,Wait,94.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,94.39,Wait,94.42,Wait,94.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,94.49,Wait,94.53,Wait,94.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,94.60,Wait,94.64,Wait,94.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,94.70,Wait,94.73,Wait,94.76,NO_REQ,,,,,,,,,,,,,,,,,,,
,94.79,Wait,94.83,Wait,94.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,94.89,Wait,94.92,Wait,94.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,94.98,Wait,95.01,Wait,95.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,95.08,Wait,95.13,Wait,95.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,95.19,Wait,95.22,Wait,95.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,95.28,Wait,95.31,Wait,95.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,95.37,Wait,95.41,Wait,95.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,95.46,Wait,95.50,Wait,95.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,95.56,Wait,95.59,Wait,95.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,95.65,Wait,95.72,Wait,95.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,95.78,Wait,95.83,Wait,95.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,95.89,Wait,95.95,Wait,95.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,96.01,Wait,96.04,Wait,96.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,96.11,Wait,96.16,Wait,96.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,96.24,Wait,96.28,Wait,96.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,96.35,Wait,96.39,Wait,96.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,96.46,Wait,96.50,Wait,96.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,96.58,Wait,96.61,Wait,96.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,96.67,Wait,96.70,Wait,96.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,96.77,Wait,96.80,Wait,96.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,96.86,Wait,96.89,Wait,96.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,96.95,Wait,96.98,Wait,97.01,NO_REQ,,,,,,,,,,,,,,,,,,,
,97.04,Wait,97.08,Wait,97.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,97.15,Wait,97.19,Wait,97.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,97.26,Wait,97.29,Wait,97.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,97.36,Wait,97.40,Wait,97.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,97.48,Wait,97.52,Wait,97.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,97.59,Wait,97.62,Wait,97.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,97.70,Wait,97.76,Wait,97.82,NO_REQ,,,,,,,,,,,,,,,,,,,
,97.87,Wait,97.90,Wait,97.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,97.97,Wait,98.00,Wait,98.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,98.06,Wait,98.09,Wait,98.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,98.15,Wait,98.19,Wait,98.22,NO_REQ,,,,,,,,,,,,,,,,,,,
,98.25,Wait,98.28,Wait,98.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,98.34,Wait,98.37,Wait,98.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,98.43,Wait,98.46,Wait,98.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,98.52,Wait,98.56,Wait,98.59,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,98.62,REQ,98.65,Wait,98.69,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,98.72,REQ,98.75,Wait,98.79,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,98.83,REQ,98.86,Wait,98.89,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,98.92,REQ,98.95,Wait,98.98,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,99.01,REQ,99.04,Wait,99.08,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,99.11,REQ,99.14,Wait,99.17,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,99.20,REQ,99.23,Wait,99.27,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,99.30,RESP,99.33,Wait,99.37,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,99.41,RESP,99.44,Wait,99.46,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,99.50,RESP,99.53,Wait,99.56,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,99.59,RESP,99.62,Wait,99.66,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,99.69,RESP,99.71,Wait,99.75,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,99.78,RESP,99.81,Wait,99.84,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,99.87,RESP,99.90,Wait,99.94,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,99.97,RESP,100.01,Wait,100.04,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,100.08,RESP,100.11,Wait,100.14,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,100.17,Wait,100.20,Wait,100.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,100.26,Wait,100.29,Wait,100.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,100.37,Wait,100.41,Wait,100.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,100.50,Wait,100.54,Wait,100.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,100.62,Wait,100.65,Wait,100.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,100.71,Wait,100.75,Wait,100.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,100.81,Wait,100.84,Wait,100.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,100.91,Wait,100.94,Wait,100.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,100.98,Wait,101.02,Wait,101.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,101.09,Wait,101.12,Wait,101.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,101.19,Wait,101.21,Wait,101.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,101.29,Wait,101.33,Wait,101.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,101.39,Wait,101.42,Wait,101.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,101.48,Wait,101.52,Wait,101.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,101.58,Wait,101.61,Wait,101.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,101.67,Wait,101.70,Wait,101.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,101.77,Wait,101.81,Wait,101.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,101.87,Wait,101.90,Wait,101.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,101.97,Wait,102.00,Wait,102.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,102.06,Wait,102.09,Wait,102.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,102.15,Wait,102.19,Wait,102.24,NO_REQ,,,,,,,,,,,,,,,,,,,
,102.26,Wait,102.30,Wait,102.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,102.36,Wait,102.39,Wait,102.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,102.45,Wait,102.48,Wait,102.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,102.55,Wait,102.58,Wait,102.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,102.64,Wait,102.67,Wait,102.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,102.73,Wait,102.76,Wait,102.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,102.83,Wait,102.86,Wait,102.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,102.92,Wait,102.95,Wait,102.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,103.01,Wait,103.04,Wait,103.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,103.11,Wait,103.15,Wait,103.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,103.22,Wait,103.25,Wait,103.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,103.33,Wait,103.36,Wait,103.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,103.42,Wait,103.45,Wait,103.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,103.52,Wait,103.55,Wait,103.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,103.61,Wait,103.64,Wait,103.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,103.71,Wait,103.75,Wait,103.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,103.81,Wait,103.84,Wait,103.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,103.90,Wait,103.97,Wait,104.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,104.08,Wait,104.11,Wait,104.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,104.17,Wait,104.20,Wait,104.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,104.26,Wait,104.29,Wait,104.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,104.36,Wait,104.39,Wait,104.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,104.45,Wait,104.48,Wait,104.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,104.54,Wait,104.58,Wait,104.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,104.64,Wait,104.67,Wait,104.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,104.75,Wait,104.78,Wait,104.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,104.84,Wait,104.87,Wait,104.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,104.94,Wait,104.96,Wait,104.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,105.01,Wait,105.05,Wait,105.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,105.11,Wait,105.14,Wait,105.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,105.20,Wait,105.23,Wait,105.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,105.31,Wait,105.34,Wait,105.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,105.41,Wait,105.44,Wait,105.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,105.50,Wait,105.54,Wait,105.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,105.61,Wait,105.64,Wait,105.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,105.70,Wait,105.73,Wait,105.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,105.79,Wait,105.83,Wait,105.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,105.89,Wait,105.92,Wait,105.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,105.98,Wait,106.02,Wait,106.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,106.09,Wait,106.12,Wait,106.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,106.19,Wait,106.21,Wait,106.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,106.28,Wait,106.31,Wait,106.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,106.50,Wait,106.53,Wait,106.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,106.61,Wait,106.64,Wait,106.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,106.70,Wait,106.73,Wait,106.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,106.79,Wait,106.83,Wait,106.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,106.89,Wait,106.92,Wait,106.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,106.98,Wait,107.01,Wait,107.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,107.08,Wait,107.11,Wait,107.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,107.18,Wait,107.20,Wait,107.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,107.27,Wait,107.30,Wait,107.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,107.36,Wait,107.39,Wait,107.43,NO_REQ,,,,,,,,,,,,,,,,,,,
,107.46,Wait,107.50,Wait,107.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,107.56,Wait,107.59,Wait,107.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,107.66,Wait,107.69,Wait,107.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,107.75,Wait,107.78,Wait,107.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,107.84,Wait,107.87,Wait,107.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,107.94,Wait,107.97,Wait,108.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,108.03,Wait,108.06,Wait,108.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,108.12,Wait,108.16,Wait,108.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,108.22,Wait,108.25,Wait,108.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,108.31,Wait,108.34,Wait,108.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,108.41,Wait,108.46,Wait,108.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,108.53,Wait,108.56,Wait,108.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,108.62,Wait,108.66,Wait,108.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,108.74,Wait,108.77,Wait,108.80,NO_REQ,,,,,,,,,,,,,,,,,,,
,108.83,Wait,108.86,Wait,108.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,108.93,Wait,108.97,Wait,109.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,109.03,Wait,109.06,Wait,109.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,109.12,Wait,109.15,Wait,109.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,109.22,Wait,109.25,Wait,109.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,109.31,Wait,109.34,Wait,109.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,109.41,Wait,109.44,Wait,109.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,109.50,Wait,109.53,Wait,109.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,109.59,Wait,109.62,Wait,109.65,NO_REQ,,,,,,,,,,,,,,,,,,,
,109.69,Wait,109.72,Wait,109.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,109.78,Wait,109.81,Wait,109.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,109.87,Wait,109.91,Wait,109.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,109.98,Wait,110.01,Wait,110.05,NO_REQ,,,,,,,,,,,,,,,,,,,
,110.08,Wait,110.11,Wait,110.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,110.17,Wait,110.21,Wait,110.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,110.29,Wait,110.32,Wait,110.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,110.40,Wait,110.44,Wait,110.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,110.50,Wait,110.54,Wait,110.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,110.61,Wait,110.64,Wait,110.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,110.70,Wait,110.73,Wait,110.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,110.79,Wait,110.83,Wait,110.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,110.89,Wait,110.92,Wait,110.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,110.98,Wait,111.01,Wait,111.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,111.08,Wait,111.11,Wait,111.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,111.17,Wait,111.20,Wait,111.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,111.27,Wait,111.31,Wait,111.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,111.37,Wait,111.40,Wait,111.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,111.48,Wait,111.51,Wait,111.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,111.58,Wait,111.61,Wait,111.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,111.67,Wait,111.70,Wait,111.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,111.77,Wait,111.81,Wait,111.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,111.87,Wait,111.91,Wait,111.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,111.97,Wait,112.00,Wait,112.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,112.06,Wait,112.09,Wait,112.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,112.15,Wait,112.19,Wait,112.22,NO_REQ,,,,,,,,,,,,,,,,,,,
,112.25,Wait,112.28,Wait,112.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,112.34,Wait,112.37,Wait,112.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,112.44,Wait,112.47,Wait,112.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,112.53,Wait,112.56,Wait,112.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,112.62,Wait,112.65,Wait,112.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,112.72,Wait,112.75,Wait,112.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,112.83,Wait,112.86,Wait,112.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,112.92,Wait,112.96,Wait,112.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,113.01,Wait,113.04,Wait,113.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,113.11,Wait,113.14,Wait,113.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,113.20,Wait,113.23,Wait,113.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,113.31,Wait,113.34,Wait,113.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,113.40,Wait,113.44,Wait,113.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,113.50,Wait,113.54,Wait,113.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,113.64,Wait,113.67,Wait,113.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,113.73,Wait,113.77,Wait,113.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,113.83,Wait,113.86,Wait,113.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,113.92,Wait,113.95,Wait,113.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,114.02,Wait,114.05,Wait,114.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,114.11,Wait,114.15,Wait,114.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,114.24,Wait,114.28,Wait,114.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,114.34,Wait,114.37,Wait,114.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,114.44,Wait,114.46,Wait,114.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,114.53,Wait,114.56,Wait,114.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,114.63,Wait,114.67,Wait,114.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,114.73,Wait,114.77,Wait,114.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,114.83,Wait,114.86,Wait,114.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,114.92,Wait,114.95,Wait,114.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,115.01,Wait,115.04,Wait,115.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,115.11,Wait,115.14,Wait,115.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,115.20,Wait,115.23,Wait,115.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,115.30,Wait,115.33,Wait,115.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,115.40,Wait,115.44,Wait,115.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,115.50,Wait,115.53,Wait,115.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,115.59,Wait,115.62,Wait,115.65,NO_REQ,,,,,,,,,,,,,,,,,,,
,115.68,Wait,115.71,Wait,115.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,115.78,Wait,115.81,Wait,115.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,115.87,Wait,115.91,Wait,115.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,116.08,Wait,116.22,Wait,116.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,116.51,Wait,116.62,Wait,116.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,116.81,Wait,116.86,Wait,117.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,117.06,Wait,117.09,Wait,117.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,117.20,Wait,117.24,Wait,117.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,117.32,Wait,117.36,Wait,117.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,117.42,Wait,117.45,Wait,117.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,117.52,Wait,117.54,Wait,117.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,117.61,Wait,117.64,Wait,117.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,117.70,Wait,117.74,Wait,117.76,NO_REQ,,,,,,,,,,,,,,,,,,,
,117.79,Wait,117.86,Wait,117.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,117.92,Wait,117.95,Wait,117.99,NO_REQ,,,,,,,,,,,,,,,,,,,
,118.03,Wait,118.07,Wait,118.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,118.12,Wait,118.15,Wait,118.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,118.21,Wait,118.25,Wait,118.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,118.31,Wait,118.34,Wait,118.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,118.41,Wait,118.44,Wait,118.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,118.50,Wait,118.53,Wait,118.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,118.59,Wait,118.63,Wait,118.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,118.70,Wait,118.74,Wait,118.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,118.81,Wait,118.85,Wait,118.88,NO_REQ,,,,,,,,,,,,,,,,,,,
,118.91,Wait,118.94,Wait,118.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,119.01,Wait,119.04,Wait,119.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,119.11,Wait,119.14,Wait,119.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,119.20,Wait,119.23,Wait,119.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,119.30,Wait,119.33,Wait,119.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,119.39,Wait,119.42,Wait,119.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,119.48,Wait,119.52,Wait,119.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,119.58,Wait,119.61,Wait,119.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,119.67,Wait,119.71,Wait,119.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,119.78,Wait,119.81,Wait,119.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,119.87,Wait,119.90,Wait,119.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,119.97,Wait,120.00,Wait,120.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,120.06,Wait,120.09,Wait,120.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,120.16,Wait,120.20,Wait,120.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,120.27,Wait,120.31,Wait,120.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,120.38,Wait,120.42,Wait,120.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,120.49,Wait,120.51,Wait,120.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,120.58,Wait,120.61,Wait,120.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,120.67,Wait,120.70,Wait,120.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,120.77,Wait,120.80,Wait,120.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,120.86,Wait,120.90,Wait,120.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,120.96,Wait,121.00,Wait,121.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,121.06,Wait,121.09,Wait,121.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,121.15,Wait,121.19,Wait,121.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,121.24,Wait,121.26,Wait,121.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,121.33,Wait,121.36,Wait,121.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,121.42,Wait,121.45,Wait,121.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,121.51,Wait,121.54,Wait,121.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,121.61,Wait,121.64,Wait,121.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,121.70,Wait,121.73,Wait,121.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,121.81,Wait,121.84,Wait,121.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,121.91,Wait,121.94,Wait,121.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,122.02,Wait,122.05,Wait,122.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,122.12,Wait,122.15,Wait,122.18,NO_REQ,,,,,,,,,,,,,,,,,,,
,122.21,Wait,122.24,Wait,122.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,122.31,Wait,122.34,Wait,122.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,122.40,Wait,122.43,Wait,122.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,122.50,Wait,122.54,Wait,122.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,122.59,Wait,122.63,Wait,122.65,NO_REQ,,,,,,,,,,,,,,,,,,,
,122.71,Wait,122.75,Wait,122.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,122.81,Wait,122.84,Wait,122.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,122.90,Wait,122.94,Wait,122.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,123.00,Wait,123.03,Wait,123.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,123.09,Wait,123.12,Wait,123.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,123.19,Wait,123.22,Wait,123.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,123.28,Wait,123.31,Wait,123.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,123.37,Wait,123.41,Wait,123.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,123.46,Wait,123.48,Wait,123.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,123.55,Wait,123.58,Wait,123.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,123.64,Wait,123.67,Wait,123.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,123.73,Wait,123.78,Wait,123.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,123.84,Wait,123.87,Wait,123.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,123.94,Wait,123.97,Wait,124.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,124.03,Wait,124.06,Wait,124.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,124.13,Wait,124.15,Wait,124.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,124.22,Wait,124.25,Wait,124.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,124.31,Wait,124.34,Wait,124.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,124.41,Wait,124.44,Wait,124.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,124.50,Wait,124.54,Wait,124.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,124.62,Wait,124.65,Wait,124.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,124.74,Wait,124.78,Wait,124.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,124.84,Wait,124.87,Wait,124.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,124.94,Wait,124.96,Wait,125.01,NO_REQ,,,,,,,,,,,,,,,,,,,
,125.05,Wait,125.08,Wait,125.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,125.14,Wait,125.17,Wait,125.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,125.23,Wait,125.27,Wait,125.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,125.33,Wait,125.36,Wait,125.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,125.42,Wait,125.47,Wait,125.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,125.53,Wait,125.56,Wait,125.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,125.62,Wait,125.66,Wait,125.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,125.72,Wait,125.75,Wait,125.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,125.81,Wait,125.84,Wait,125.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,125.90,Wait,125.94,Wait,125.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,126.00,Wait,126.03,Wait,126.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,126.09,Wait,126.12,Wait,126.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,126.19,Wait,126.21,Wait,126.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,126.28,Wait,126.31,Wait,126.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,126.37,Wait,126.41,Wait,126.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,126.46,Wait,126.49,Wait,126.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,126.57,Wait,126.61,Wait,126.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,126.67,Wait,126.70,Wait,126.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,126.76,Wait,126.79,Wait,126.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,126.87,Wait,126.90,Wait,126.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,126.97,Wait,127.00,Wait,127.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,127.06,Wait,127.09,Wait,127.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,127.16,Wait,127.19,Wait,127.22,NO_REQ,,,,,,,,,,,,,,,,,,,
,127.25,Wait,127.28,Wait,127.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,127.34,Wait,127.36,Wait,127.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,127.44,Wait,127.46,Wait,127.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,127.53,Wait,127.56,Wait,127.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,127.62,Wait,127.66,Wait,127.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,127.71,Wait,127.75,Wait,127.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,127.81,Wait,127.84,Wait,127.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,127.91,Wait,127.94,Wait,127.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,128.01,Wait,128.04,Wait,128.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,128.11,Wait,128.14,Wait,128.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,128.20,Wait,128.24,Wait,128.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,128.31,Wait,128.35,Wait,128.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,128.42,Wait,128.45,Wait,128.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,128.51,Wait,128.54,Wait,128.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,128.61,Wait,128.65,Wait,128.69,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,128.71,REQ,128.75,Wait,128.78,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,128.81,REQ,128.84,Wait,128.87,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,128.91,REQ,128.94,Wait,128.96,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,129.00,REQ,129.03,Wait,129.06,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,129.09,REQ,129.12,Wait,129.15,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,129.19,REQ,129.22,Wait,129.25,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,129.28,REQ,129.31,Wait,129.34,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,129.37,RESP,129.41,Wait,129.44,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,129.47,RESP,129.51,Wait,129.54,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,129.58,RESP,129.61,Wait,129.64,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,129.67,RESP,129.70,Wait,129.73,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,129.77,RESP,129.79,Wait,129.81,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,129.85,RESP,129.89,Wait,129.92,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,129.95,RESP,129.98,Wait,130.02,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,130.05,RESP,130.09,Wait,130.12,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,130.15,RESP,130.19,Wait,130.22,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,130.25,Wait,130.28,Wait,130.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,130.34,Wait,130.37,Wait,130.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,130.45,Wait,130.49,Wait,130.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,130.58,Wait,130.60,Wait,130.63,NO_REQ,,,,,,,,,,,,,,,,,,,
,130.66,Wait,130.69,Wait,130.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,130.75,Wait,130.78,Wait,130.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,130.84,Wait,130.87,Wait,130.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,130.94,Wait,130.97,Wait,131.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,131.03,Wait,131.06,Wait,131.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,131.12,Wait,131.16,Wait,131.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,131.22,Wait,131.25,Wait,131.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,131.31,Wait,131.34,Wait,131.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,131.41,Wait,131.44,Wait,131.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,131.50,Wait,131.53,Wait,131.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,131.59,Wait,131.62,Wait,131.65,NO_REQ,,,,,,,,,,,,,,,,,,,
,131.69,Wait,131.71,Wait,131.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,131.81,Wait,131.84,Wait,131.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,131.90,Wait,131.94,Wait,131.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,132.00,Wait,132.07,Wait,132.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,132.14,Wait,132.17,Wait,132.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,132.23,Wait,132.26,Wait,132.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,132.33,Wait,132.37,Wait,132.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,132.44,Wait,132.47,Wait,132.51,NO_REQ,,,,,,,,,,,,,,,,,,,
,132.54,Wait,132.58,Wait,132.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,132.64,Wait,132.67,Wait,132.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,132.73,Wait,132.78,Wait,132.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,132.84,Wait,132.87,Wait,132.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,132.93,Wait,132.96,Wait,133.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,133.03,Wait,133.06,Wait,133.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,133.12,Wait,133.16,Wait,133.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,133.21,Wait,133.25,Wait,133.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,133.31,Wait,133.34,Wait,133.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,133.41,Wait,133.46,Wait,133.51,NO_REQ,,,,,,,,,,,,,,,,,,,
,133.55,Wait,133.58,Wait,133.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,133.64,Wait,133.67,Wait,133.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,133.76,Wait,133.79,Wait,133.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,133.86,Wait,133.91,Wait,133.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,133.97,Wait,134.01,Wait,134.05,NO_REQ,,,,,,,,,,,,,,,,,,,
,134.08,Wait,134.11,Wait,134.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,134.17,Wait,134.21,Wait,134.30,NO_REQ,,,,,,,,,,,,,,,,,,,
,134.33,Wait,134.36,Wait,134.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,134.43,Wait,134.47,Wait,134.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,134.53,Wait,134.58,Wait,134.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,134.64,Wait,134.67,Wait,134.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,134.75,Wait,134.78,Wait,134.80,NO_REQ,,,,,,,,,,,,,,,,,,,
,134.85,Wait,134.88,Wait,134.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,134.94,Wait,134.97,Wait,135.01,NO_REQ,,,,,,,,,,,,,,,,,,,
,135.04,Wait,135.08,Wait,135.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,135.14,Wait,135.17,Wait,135.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,135.25,Wait,135.28,Wait,135.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,135.34,Wait,135.37,Wait,135.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,135.45,Wait,135.48,Wait,135.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,135.55,Wait,135.58,Wait,135.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,135.64,Wait,135.67,Wait,135.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,135.75,Wait,135.78,Wait,135.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,135.84,Wait,135.87,Wait,135.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,135.94,Wait,135.97,Wait,136.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,136.03,Wait,136.06,Wait,136.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,136.12,Wait,136.16,Wait,136.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,136.22,Wait,136.25,Wait,136.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,136.33,Wait,136.36,Wait,136.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,136.44,Wait,136.47,Wait,136.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,136.53,Wait,136.56,Wait,136.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,136.62,Wait,136.67,Wait,136.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,136.73,Wait,136.77,Wait,136.80,NO_REQ,,,,,,,,,,,,,,,,,,,
,136.83,Wait,136.86,Wait,136.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,136.92,Wait,136.95,Wait,136.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,137.02,Wait,137.05,Wait,137.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,137.11,Wait,137.14,Wait,137.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,137.20,Wait,137.23,Wait,137.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,137.31,Wait,137.34,Wait,137.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,137.41,Wait,137.44,Wait,137.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,137.51,Wait,137.54,Wait,137.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,137.61,Wait,137.64,Wait,137.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,137.71,Wait,137.75,Wait,137.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,137.81,Wait,137.85,Wait,137.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,137.92,Wait,137.95,Wait,137.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,138.02,Wait,138.06,Wait,138.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,138.12,Wait,138.16,Wait,138.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,138.23,Wait,138.27,Wait,138.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,138.34,Wait,138.37,Wait,138.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,138.44,Wait,138.47,Wait,138.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,138.53,Wait,138.56,Wait,138.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,138.62,Wait,138.66,Wait,138.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,138.73,Wait,138.77,Wait,138.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,138.84,Wait,138.87,Wait,138.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,138.94,Wait,138.97,Wait,139.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,139.03,Wait,139.06,Wait,139.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,139.12,Wait,139.15,Wait,139.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,139.30,Wait,139.33,Wait,139.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,139.39,Wait,139.42,Wait,139.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,139.49,Wait,139.53,Wait,139.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,139.59,Wait,139.62,Wait,139.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,139.70,Wait,139.73,Wait,139.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,139.80,Wait,139.84,Wait,139.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,139.91,Wait,139.94,Wait,139.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,140.01,Wait,140.05,Wait,140.10,NO_REQ,,,,,,,,,,,,,,,,,,,
,140.13,Wait,140.16,Wait,140.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,140.22,Wait,140.25,Wait,140.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,140.31,Wait,140.34,Wait,140.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,140.40,Wait,140.43,Wait,140.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,140.50,Wait,140.53,Wait,140.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,140.59,Wait,140.62,Wait,140.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,140.69,Wait,140.71,Wait,140.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,140.77,Wait,140.80,Wait,140.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,140.86,Wait,140.90,Wait,140.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,140.96,Wait,140.99,Wait,141.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,141.06,Wait,141.09,Wait,141.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,141.15,Wait,141.19,Wait,141.22,NO_REQ,,,,,,,,,,,,,,,,,,,
,141.25,Wait,141.28,Wait,141.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,141.34,Wait,141.38,Wait,141.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,141.45,Wait,141.48,Wait,141.51,NO_REQ,,,,,,,,,,,,,,,,,,,
,141.54,Wait,141.56,Wait,141.60,NO_REQ,,,,,,,,,,,,,,,,,,,
,141.64,Wait,141.67,Wait,141.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,141.73,Wait,141.76,Wait,141.80,NO_REQ,,,,,,,,,,,,,,,,,,,
,141.83,Wait,141.86,Wait,141.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,141.92,Wait,141.95,Wait,141.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,142.01,Wait,142.05,Wait,142.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,142.11,Wait,142.14,Wait,142.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,142.21,Wait,142.24,Wait,142.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,142.30,Wait,142.33,Wait,142.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,142.40,Wait,142.43,Wait,142.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,142.50,Wait,142.53,Wait,142.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,142.59,Wait,142.62,Wait,142.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,142.69,Wait,142.72,Wait,142.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,142.78,Wait,142.81,Wait,142.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,142.88,Wait,142.92,Wait,142.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,142.99,Wait,143.01,Wait,143.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,143.08,Wait,143.11,Wait,143.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,143.17,Wait,143.20,Wait,143.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,143.27,Wait,143.31,Wait,143.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,143.37,Wait,143.40,Wait,143.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,143.46,Wait,143.50,Wait,143.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,143.56,Wait,143.59,Wait,143.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,143.66,Wait,143.69,Wait,143.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,143.75,Wait,143.78,Wait,143.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,143.84,Wait,143.87,Wait,143.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,143.95,Wait,143.98,Wait,144.01,NO_REQ,,,,,,,,,,,,,,,,,,,
,144.04,Wait,144.08,Wait,144.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,144.14,Wait,144.17,Wait,144.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,144.23,Wait,144.26,Wait,144.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,144.33,Wait,144.37,Wait,144.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,144.44,Wait,144.47,Wait,144.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,144.53,Wait,144.56,Wait,144.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,144.62,Wait,144.66,Wait,144.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,144.74,Wait,144.78,Wait,144.82,NO_REQ,,,,,,,,,,,,,,,,,,,
,144.86,Wait,144.89,Wait,144.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,144.95,Wait,144.98,Wait,145.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,145.05,Wait,145.09,Wait,145.12,NO_REQ,,,,,,,,,,,,,,,,,,,
,145.16,Wait,145.19,Wait,145.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,145.23,Wait,145.27,Wait,145.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,145.33,Wait,145.36,Wait,145.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,145.42,Wait,145.45,Wait,145.49,NO_REQ,,,,,,,,,,,,,,,,,,,
,145.51,Wait,145.54,Wait,145.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,145.61,Wait,145.64,Wait,145.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,145.70,Wait,145.73,Wait,145.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,145.79,Wait,145.83,Wait,145.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,145.89,Wait,145.92,Wait,145.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,146.00,Wait,146.03,Wait,146.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,146.09,Wait,146.12,Wait,146.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,146.20,Wait,146.24,Wait,146.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,146.30,Wait,146.33,Wait,146.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,146.39,Wait,146.42,Wait,146.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,146.48,Wait,146.52,Wait,146.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,146.59,Wait,146.62,Wait,146.65,NO_REQ,,,,,,,,,,,,,,,,,,,
,146.69,Wait,146.72,Wait,146.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,146.78,Wait,146.81,Wait,146.85,NO_REQ,,,,,,,,,,,,,,,,,,,
,146.89,Wait,146.92,Wait,146.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,146.98,Wait,147.01,Wait,147.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,147.08,Wait,147.12,Wait,147.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,147.23,Wait,147.27,Wait,147.32,NO_REQ,,,,,,,,,,,,,,,,,,,
,147.36,Wait,147.39,Wait,147.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,147.49,Wait,147.53,Wait,147.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,147.59,Wait,147.62,Wait,147.65,NO_REQ,,,,,,,,,,,,,,,,,,,
,147.69,Wait,147.71,Wait,147.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,147.78,Wait,147.81,Wait,147.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,147.87,Wait,147.91,Wait,147.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,147.99,Wait,148.02,Wait,148.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,148.09,Wait,148.12,Wait,148.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,148.19,Wait,148.22,Wait,148.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,148.28,Wait,148.31,Wait,148.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,148.41,Wait,148.44,Wait,148.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,148.51,Wait,148.55,Wait,148.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,148.61,Wait,148.64,Wait,148.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,148.70,Wait,148.73,Wait,148.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,148.80,Wait,148.83,Wait,148.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,148.89,Wait,148.92,Wait,148.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,148.99,Wait,149.03,Wait,149.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,149.09,Wait,149.12,Wait,149.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,149.19,Wait,149.21,Wait,149.24,NO_REQ,,,,,,,,,,,,,,,,,,,
,149.26,Wait,149.29,Wait,149.32,NO_REQ,,,,,,,,,,,,,,,,,,,
,149.35,Wait,149.39,Wait,149.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,149.45,Wait,149.48,Wait,149.51,NO_REQ,,,,,,,,,,,,,,,,,,,
,149.54,Wait,149.58,Wait,149.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,149.64,Wait,149.67,Wait,149.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,149.73,Wait,149.76,Wait,149.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,149.83,Wait,149.86,Wait,149.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,149.92,Wait,149.95,Wait,150.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,150.03,Wait,150.06,Wait,150.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,150.13,Wait,150.15,Wait,150.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,150.21,Wait,150.24,Wait,150.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,150.31,Wait,150.34,Wait,150.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,150.40,Wait,150.44,Wait,150.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,150.50,Wait,150.53,Wait,150.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,150.59,Wait,150.63,Wait,150.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,150.70,Wait,150.74,Wait,150.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,150.81,Wait,150.84,Wait,150.88,NO_REQ,,,,,,,,,,,,,,,,,,,
,150.92,Wait,150.95,Wait,150.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,151.01,Wait,151.04,Wait,151.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,151.11,Wait,151.14,Wait,151.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,151.21,Wait,151.24,Wait,151.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,151.31,Wait,151.34,Wait,151.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,151.41,Wait,151.44,Wait,151.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,151.50,Wait,151.53,Wait,151.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,151.59,Wait,151.62,Wait,151.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,151.69,Wait,151.71,Wait,151.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,151.79,Wait,151.83,Wait,151.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,151.89,Wait,151.92,Wait,151.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,151.98,Wait,152.03,Wait,152.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,152.09,Wait,152.13,Wait,152.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,152.19,Wait,152.22,Wait,152.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,152.28,Wait,152.31,Wait,152.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,152.37,Wait,152.40,Wait,152.45,NO_REQ,,,,,,,,,,,,,,,,,,,
,152.48,Wait,152.52,Wait,152.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,152.58,Wait,152.65,Wait,152.68,NO_REQ,,,,,,,,,,,,,,,,,,,
,152.72,Wait,152.75,Wait,152.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,152.81,Wait,152.84,Wait,152.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,152.91,Wait,152.96,Wait,153.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,153.03,Wait,153.06,Wait,153.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,153.12,Wait,153.16,Wait,153.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,153.21,Wait,153.24,Wait,153.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,153.31,Wait,153.35,Wait,153.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,153.42,Wait,153.46,Wait,153.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,153.53,Wait,153.56,Wait,153.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,153.62,Wait,153.65,Wait,153.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,153.72,Wait,153.81,Wait,153.85,NO_REQ,,,,,,,,,,,,,,,,,,,
,153.88,Wait,153.91,Wait,153.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,153.97,Wait,154.02,Wait,154.05,NO_REQ,,,,,,,,,,,,,,,,,,,
,154.08,Wait,154.11,Wait,154.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,154.17,Wait,154.20,Wait,154.24,NO_REQ,,,,,,,,,,,,,,,,,,,
,154.27,Wait,154.30,Wait,154.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,154.36,Wait,154.39,Wait,154.43,NO_REQ,,,,,,,,,,,,,,,,,,,
,154.46,Wait,154.53,Wait,154.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,154.59,Wait,154.63,Wait,154.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,154.69,Wait,154.72,Wait,154.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,154.78,Wait,154.81,Wait,154.85,NO_REQ,,,,,,,,,,,,,,,,,,,
,154.88,Wait,154.91,Wait,154.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,154.97,Wait,155.00,Wait,155.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,155.06,Wait,155.10,Wait,155.13,NO_REQ,,,,,,,,,,,,,,,,,,,
,155.17,Wait,155.21,Wait,155.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,155.27,Wait,155.30,Wait,155.34,NO_REQ,,,,,,,,,,,,,,,,,,,
,155.37,Wait,155.41,Wait,155.43,NO_REQ,,,,,,,,,,,,,,,,,,,
,155.47,Wait,155.50,Wait,155.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,155.55,Wait,155.58,Wait,155.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,155.65,Wait,155.69,Wait,155.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,155.75,Wait,155.78,Wait,155.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,155.84,Wait,155.87,Wait,155.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,155.94,Wait,155.99,Wait,156.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,156.04,Wait,156.08,Wait,156.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,156.14,Wait,156.17,Wait,156.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,156.23,Wait,156.26,Wait,156.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,156.32,Wait,156.36,Wait,156.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,156.42,Wait,156.45,Wait,156.49,NO_REQ,,,,,,,,,,,,,,,,,,,
,156.53,Wait,156.56,Wait,156.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,156.62,Wait,156.66,Wait,156.68,NO_REQ,,,,,,,,,,,,,,,,,,,
,156.71,Wait,156.75,Wait,156.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,156.82,Wait,156.86,Wait,156.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,156.92,Wait,156.95,Wait,156.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,157.02,Wait,157.05,Wait,157.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,157.11,Wait,157.15,Wait,157.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,157.21,Wait,157.23,Wait,157.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,157.29,Wait,157.33,Wait,157.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,157.39,Wait,157.42,Wait,157.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,157.50,Wait,157.53,Wait,157.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,157.61,Wait,157.64,Wait,157.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,157.70,Wait,157.73,Wait,157.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,157.79,Wait,157.83,Wait,157.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,157.89,Wait,157.92,Wait,157.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,157.99,Wait,158.03,Wait,158.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,158.09,Wait,158.12,Wait,158.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,158.19,Wait,158.21,Wait,158.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,158.27,Wait,158.32,Wait,158.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,158.39,Wait,158.43,Wait,158.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,158.49,Wait,158.52,Wait,158.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,158.62,Wait,158.66,Wait,158.68,NO_REQ,,,,,,,,,,,,,,,,,,,
,158.72,Wait,158.75,Wait,158.78,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,158.82,REQ,158.86,Wait,158.89,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,158.92,REQ,158.96,Wait,159.00,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,159.03,REQ,159.06,Wait,159.09,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,159.13,REQ,159.16,Wait,159.19,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,159.23,REQ,159.27,Wait,159.30,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,159.32,REQ,159.36,Wait,159.39,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,159.42,RESP,159.45,Wait,159.49,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,159.53,RESP,159.56,Wait,159.60,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,159.63,RESP,159.65,Wait,159.69,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,159.71,RESP,159.73,Wait,159.77,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,159.83,RESP,159.86,Wait,159.89,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,159.92,RESP,159.95,Wait,159.98,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,160.02,RESP,160.04,Wait,160.07,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,160.11,RESP,160.21,Wait,160.25,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,160.28,RESP,160.31,Wait,160.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,160.40,Wait,160.44,Wait,160.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,160.50,Wait,160.53,Wait,160.56,NO_REQ,,,,,,,,,,,,,,,,,,,
,160.59,Wait,160.62,Wait,160.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,160.69,Wait,160.73,Wait,160.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,160.80,Wait,160.83,Wait,160.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,160.89,Wait,160.92,Wait,160.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,160.99,Wait,161.02,Wait,161.05,NO_REQ,,,,,,,,,,,,,,,,,,,
,161.08,Wait,161.11,Wait,161.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,161.17,Wait,161.20,Wait,161.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,161.26,Wait,161.29,Wait,161.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,161.36,Wait,161.39,Wait,161.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,161.46,Wait,161.50,Wait,161.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,161.56,Wait,161.59,Wait,161.63,NO_REQ,,,,,,,,,,,,,,,,,,,
,161.66,Wait,161.69,Wait,161.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,161.76,Wait,161.78,Wait,161.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,161.84,Wait,161.88,Wait,161.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,161.94,Wait,161.96,Wait,162.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,162.02,Wait,162.06,Wait,162.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,162.12,Wait,162.15,Wait,162.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,162.23,Wait,162.27,Wait,162.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,162.34,Wait,162.37,Wait,162.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,162.44,Wait,162.47,Wait,162.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,162.55,Wait,162.57,Wait,162.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,162.66,Wait,162.69,Wait,162.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,162.75,Wait,162.78,Wait,162.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,162.85,Wait,162.89,Wait,162.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,162.95,Wait,162.99,Wait,163.03,NO_REQ,,,,,,,,,,,,,,,,,,,
,163.06,Wait,163.10,Wait,163.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,163.17,Wait,163.20,Wait,163.23,NO_REQ,,,,,,,,,,,,,,,,,,,
,163.27,Wait,163.30,Wait,163.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,163.36,Wait,163.39,Wait,163.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,163.45,Wait,163.48,Wait,163.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,163.55,Wait,163.58,Wait,163.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,163.64,Wait,163.67,Wait,163.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,163.80,Wait,163.88,Wait,163.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,164.02,Wait,164.06,Wait,164.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,164.12,Wait,164.16,Wait,164.18,NO_REQ,,,,,,,,,,,,,,,,,,,
,164.23,Wait,164.27,Wait,164.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,164.33,Wait,164.36,Wait,164.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,164.42,Wait,164.45,Wait,164.49,NO_REQ,,,,,,,,,,,,,,,,,,,
,164.52,Wait,164.54,Wait,164.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,164.61,Wait,164.64,Wait,164.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,164.71,Wait,164.74,Wait,164.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,164.81,Wait,164.84,Wait,164.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,164.90,Wait,164.93,Wait,164.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,164.99,Wait,165.02,Wait,165.05,NO_REQ,,,,,,,,,,,,,,,,,,,
,165.07,Wait,165.11,Wait,165.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,165.19,Wait,165.21,Wait,165.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,165.29,Wait,165.32,Wait,165.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,165.39,Wait,165.42,Wait,165.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,165.50,Wait,165.53,Wait,165.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,165.61,Wait,165.64,Wait,165.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,165.70,Wait,165.73,Wait,165.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,165.79,Wait,165.83,Wait,165.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,165.89,Wait,165.92,Wait,165.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,165.98,Wait,166.02,Wait,166.05,NO_REQ,,,,,,,,,,,,,,,,,,,
,166.09,Wait,166.13,Wait,166.15,NO_REQ,,,,,,,,,,,,,,,,,,,
,166.19,Wait,166.22,Wait,166.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,166.28,Wait,166.32,Wait,166.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,166.39,Wait,166.43,Wait,166.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,166.49,Wait,166.53,Wait,166.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,166.61,Wait,166.64,Wait,166.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,166.70,Wait,166.73,Wait,166.77,NO_REQ,,,,,,,,,,,,,,,,,,,
,166.82,Wait,166.84,Wait,166.88,NO_REQ,,,,,,,,,,,,,,,,,,,
,166.90,Wait,166.94,Wait,166.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,167.00,Wait,167.04,Wait,167.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,167.11,Wait,167.14,Wait,167.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,167.21,Wait,167.23,Wait,167.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,167.30,Wait,167.32,Wait,167.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,167.39,Wait,167.44,Wait,167.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,167.50,Wait,167.54,Wait,167.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,167.61,Wait,167.64,Wait,167.68,NO_REQ,,,,,,,,,,,,,,,,,,,
,167.71,Wait,167.76,Wait,167.80,NO_REQ,,,,,,,,,,,,,,,,,,,
,167.83,Wait,167.86,Wait,167.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,167.92,Wait,167.95,Wait,167.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,168.01,Wait,168.04,Wait,168.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,168.11,Wait,168.14,Wait,168.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,168.21,Wait,168.25,Wait,168.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,168.31,Wait,168.34,Wait,168.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,168.41,Wait,168.43,Wait,168.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,168.50,Wait,168.53,Wait,168.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,168.62,Wait,168.65,Wait,168.68,NO_REQ,,,,,,,,,,,,,,,,,,,
,168.71,Wait,168.76,Wait,168.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,168.82,Wait,168.86,Wait,168.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,168.92,Wait,168.95,Wait,168.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,169.03,Wait,169.06,Wait,169.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,169.12,Wait,169.16,Wait,169.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,169.21,Wait,169.24,Wait,169.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,169.31,Wait,169.34,Wait,169.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,169.41,Wait,169.45,Wait,169.48,NO_REQ,,,,,,,,,,,,,,,,,,,
,169.51,Wait,169.54,Wait,169.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,169.61,Wait,169.64,Wait,169.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,169.70,Wait,169.74,Wait,169.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,169.82,Wait,169.86,Wait,169.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,169.94,Wait,169.96,Wait,170.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,170.03,Wait,170.06,Wait,170.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,170.13,Wait,170.15,Wait,170.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,170.22,Wait,170.25,Wait,170.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,170.31,Wait,170.34,Wait,170.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,170.41,Wait,170.44,Wait,170.49,NO_REQ,,,,,,,,,,,,,,,,,,,
,170.54,Wait,170.58,Wait,170.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,170.65,Wait,170.69,Wait,170.72,NO_REQ,,,,,,,,,,,,,,,,,,,
,170.75,Wait,170.78,Wait,170.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,170.85,Wait,170.88,Wait,170.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,170.94,Wait,170.97,Wait,171.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,171.03,Wait,171.06,Wait,171.10,NO_REQ,,,,,,,,,,,,,,,,,,,
,171.14,Wait,171.17,Wait,171.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,171.23,Wait,171.27,Wait,171.30,NO_REQ,,,,,,,,,,,,,,,,,,,
,171.33,Wait,171.37,Wait,171.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,171.44,Wait,171.47,Wait,171.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,171.53,Wait,171.56,Wait,171.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,171.62,Wait,171.65,Wait,171.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,171.71,Wait,171.75,Wait,171.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,171.82,Wait,171.86,Wait,171.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,171.92,Wait,171.96,Wait,171.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,172.02,Wait,172.04,Wait,172.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,172.11,Wait,172.14,Wait,172.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,172.20,Wait,172.24,Wait,172.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,172.39,Wait,172.42,Wait,172.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,172.49,Wait,172.53,Wait,172.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,172.62,Wait,172.66,Wait,172.69,NO_REQ,,,,,,,,,,,,,,,,,,,
,172.71,Wait,172.74,Wait,172.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,172.82,Wait,172.84,Wait,172.87,NO_REQ,,,,,,,,,,,,,,,,,,,
,172.92,Wait,172.96,Wait,173.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,173.03,Wait,173.06,Wait,173.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,173.12,Wait,173.17,Wait,173.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,173.24,Wait,173.27,Wait,173.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,173.36,Wait,173.40,Wait,173.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,173.47,Wait,173.51,Wait,173.55,NO_REQ,,,,,,,,,,,,,,,,,,,
,173.57,Wait,173.61,Wait,173.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,173.67,Wait,173.70,Wait,173.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,173.77,Wait,173.79,Wait,173.82,NO_REQ,,,,,,,,,,,,,,,,,,,
,173.86,Wait,173.90,Wait,173.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,173.96,Wait,173.98,Wait,174.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,174.05,Wait,174.08,Wait,174.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,174.14,Wait,174.17,Wait,174.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,174.25,Wait,174.29,Wait,174.33,NO_REQ,,,,,,,,,,,,,,,,,,,
,174.37,Wait,174.41,Wait,174.44,NO_REQ,,,,,,,,,,,,,,,,,,,
,174.47,Wait,174.50,Wait,174.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,174.57,Wait,174.61,Wait,174.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,174.67,Wait,174.70,Wait,174.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,174.78,Wait,174.81,Wait,174.85,NO_REQ,,,,,,,,,,,,,,,,,,,
,174.89,Wait,174.92,Wait,174.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,174.99,Wait,175.03,Wait,175.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,175.11,Wait,175.14,Wait,175.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,175.20,Wait,175.23,Wait,175.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,175.29,Wait,175.33,Wait,175.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,175.39,Wait,175.43,Wait,175.46,NO_REQ,,,,,,,,,,,,,,,,,,,
,175.51,Wait,175.54,Wait,175.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,175.62,Wait,175.66,Wait,175.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,175.75,Wait,175.80,Wait,175.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,175.85,Wait,175.89,Wait,175.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,175.95,Wait,175.98,Wait,176.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,176.07,Wait,176.11,Wait,176.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,176.22,Wait,176.25,Wait,176.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,176.35,Wait,176.40,Wait,176.43,NO_REQ,,,,,,,,,,,,,,,,,,,
,176.47,Wait,176.52,Wait,176.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,176.58,Wait,176.62,Wait,176.66,NO_REQ,,,,,,,,,,,,,,,,,,,
,176.69,Wait,176.71,Wait,176.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,176.77,Wait,176.82,Wait,176.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,176.89,Wait,176.92,Wait,176.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,176.99,Wait,177.02,Wait,177.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,177.07,Wait,177.10,Wait,177.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,177.17,Wait,177.22,Wait,177.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,177.29,Wait,177.33,Wait,177.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,177.40,Wait,177.44,Wait,177.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,177.50,Wait,177.53,Wait,177.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,177.61,Wait,177.64,Wait,177.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,177.71,Wait,177.74,Wait,177.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,177.81,Wait,177.85,Wait,177.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,177.92,Wait,177.96,Wait,178.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,178.03,Wait,178.06,Wait,178.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,178.12,Wait,178.15,Wait,178.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,178.21,Wait,178.25,Wait,178.28,NO_REQ,,,,,,,,,,,,,,,,,,,
,178.32,Wait,178.36,Wait,178.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,178.43,Wait,178.47,Wait,178.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,178.53,Wait,178.56,Wait,178.59,NO_REQ,,,,,,,,,,,,,,,,,,,
,178.62,Wait,178.67,Wait,178.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,178.73,Wait,178.77,Wait,178.80,NO_REQ,,,,,,,,,,,,,,,,,,,
,178.83,Wait,178.86,Wait,178.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,178.92,Wait,178.96,Wait,178.99,NO_REQ,,,,,,,,,,,,,,,,,,,
,179.03,Wait,179.07,Wait,179.10,NO_REQ,,,,,,,,,,,,,,,,,,,
,179.13,Wait,179.16,Wait,179.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,179.25,Wait,179.29,Wait,179.35,NO_REQ,,,,,,,,,,,,,,,,,,,
,179.40,Wait,179.44,Wait,179.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,179.50,Wait,179.52,Wait,179.54,NO_REQ,,,,,,,,,,,,,,,,,,,
,179.57,Wait,179.67,Wait,179.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,179.75,Wait,179.78,Wait,179.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,179.84,Wait,179.87,Wait,179.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,179.94,Wait,179.97,Wait,180.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,180.03,Wait,180.06,Wait,180.10,NO_REQ,,,,,,,,,,,,,,,,,,,
,180.14,Wait,180.17,Wait,180.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,180.23,Wait,180.27,Wait,180.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,180.33,Wait,180.38,Wait,180.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,180.43,Wait,180.47,Wait,180.51,NO_REQ,,,,,,,,,,,,,,,,,,,
,180.54,Wait,180.58,Wait,180.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,180.64,Wait,180.67,Wait,180.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,180.74,Wait,180.77,Wait,180.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,180.83,Wait,180.87,Wait,180.91,NO_REQ,,,,,,,,,,,,,,,,,,,
,180.93,Wait,180.97,Wait,181.00,NO_REQ,,,,,,,,,,,,,,,,,,,
,181.03,Wait,181.06,Wait,181.09,NO_REQ,,,,,,,,,,,,,,,,,,,
,181.12,Wait,181.16,Wait,181.19,NO_REQ,,,,,,,,,,,,,,,,,,,
,181.22,Wait,181.25,Wait,181.29,NO_REQ,,,,,,,,,,,,,,,,,,,
,181.32,Wait,181.37,Wait,181.40,NO_REQ,,,,,,,,,,,,,,,,,,,
,181.44,Wait,181.47,Wait,181.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,181.53,Wait,181.57,Wait,181.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,181.64,Wait,181.67,Wait,181.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,181.74,Wait,181.77,Wait,181.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,181.83,Wait,181.85,Wait,181.88,NO_REQ,,,,,,,,,,,,,,,,,,,
,181.91,Wait,181.94,Wait,181.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,181.99,Wait,182.03,Wait,182.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,182.10,Wait,182.14,Wait,182.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,182.20,Wait,182.23,Wait,182.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,182.32,Wait,182.37,Wait,182.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,182.43,Wait,182.47,Wait,182.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,182.58,Wait,182.61,Wait,182.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,182.67,Wait,182.70,Wait,182.73,NO_REQ,,,,,,,,,,,,,,,,,,,
,182.77,Wait,182.79,Wait,182.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,182.87,Wait,182.91,Wait,182.95,NO_REQ,,,,,,,,,,,,,,,,,,,
,182.99,Wait,183.04,Wait,183.08,NO_REQ,,,,,,,,,,,,,,,,,,,
,183.11,Wait,183.14,Wait,183.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,183.20,Wait,183.23,Wait,183.27,NO_REQ,,,,,,,,,,,,,,,,,,,
,183.31,Wait,183.34,Wait,183.37,NO_REQ,,,,,,,,,,,,,,,,,,,
,183.41,Wait,183.45,Wait,183.49,NO_REQ,,,,,,,,,,,,,,,,,,,
,183.53,Wait,183.57,Wait,183.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,183.64,Wait,183.67,Wait,183.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,183.75,Wait,183.79,Wait,183.83,NO_REQ,,,,,,,,,,,,,,,,,,,
,183.86,Wait,183.89,Wait,183.92,NO_REQ,,,,,,,,,,,,,,,,,,,
,183.95,Wait,183.99,Wait,184.02,NO_REQ,,,,,,,,,,,,,,,,,,,
,184.04,Wait,184.08,Wait,184.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,184.14,Wait,184.17,Wait,184.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,184.25,Wait,184.28,Wait,184.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,184.35,Wait,184.39,Wait,184.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,184.45,Wait,184.49,Wait,184.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,184.57,Wait,184.61,Wait,184.64,NO_REQ,,,,,,,,,,,,,,,,,,,
,184.67,Wait,184.71,Wait,184.75,NO_REQ,,,,,,,,,,,,,,,,,,,
,184.78,Wait,184.82,Wait,184.84,NO_REQ,,,,,,,,,,,,,,,,,,,
,184.87,Wait,184.91,Wait,184.96,NO_REQ,,,,,,,,,,,,,,,,,,,
,185.00,Wait,185.03,Wait,185.06,NO_REQ,,,,,,,,,,,,,,,,,,,
,185.09,Wait,185.12,Wait,185.16,NO_REQ,,,,,,,,,,,,,,,,,,,
,185.19,Wait,185.22,Wait,185.25,NO_REQ,,,,,,,,,,,,,,,,,,,
,185.28,Wait,185.32,Wait,185.36,NO_REQ,,,,,,,,,,,,,,,,,,,
,185.40,Wait,185.44,Wait,185.47,NO_REQ,,,,,,,,,,,,,,,,,,,
,185.50,Wait,185.53,Wait,185.57,NO_REQ,,,,,,,,,,,,,,,,,,,
,185.61,Wait,185.64,Wait,185.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,185.71,Wait,185.75,Wait,185.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,185.83,Wait,185.86,Wait,185.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,185.92,Wait,185.95,Wait,185.99,NO_REQ,,,,,,,,,,,,,,,,,,,
,186.03,Wait,186.07,Wait,186.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,186.14,Wait,186.17,Wait,186.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,186.25,Wait,186.28,Wait,186.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,186.34,Wait,186.36,Wait,186.41,NO_REQ,,,,,,,,,,,,,,,,,,,
,186.45,Wait,186.49,Wait,186.53,NO_REQ,,,,,,,,,,,,,,,,,,,
,186.57,Wait,186.59,Wait,186.63,NO_REQ,,,,,,,,,,,,,,,,,,,
,186.66,Wait,186.71,Wait,186.74,NO_REQ,,,,,,,,,,,,,,,,,,,
,186.78,Wait,186.82,Wait,186.86,NO_REQ,,,,,,,,,,,,,,,,,,,
,186.90,Wait,186.94,Wait,186.97,NO_REQ,,,,,,,,,,,,,,,,,,,
,187.01,Wait,187.04,Wait,187.07,NO_REQ,,,,,,,,,,,,,,,,,,,
,187.11,Wait,187.14,Wait,187.17,NO_REQ,,,,,,,,,,,,,,,,,,,
,187.21,Wait,187.26,Wait,187.30,NO_REQ,,,,,,,,,,,,,,,,,,,
,187.33,Wait,187.36,Wait,187.39,NO_REQ,,,,,,,,,,,,,,,,,,,
,187.43,Wait,187.47,Wait,187.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,187.54,Wait,187.58,Wait,187.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,187.64,Wait,187.67,Wait,187.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,187.74,Wait,187.78,Wait,187.82,NO_REQ,,,,,,,,,,,,,,,,,,,
,187.87,Wait,187.91,Wait,187.94,NO_REQ,,,,,,,,,,,,,,,,,,,
,187.97,Wait,188.01,Wait,188.04,NO_REQ,,,,,,,,,,,,,,,,,,,
,188.08,Wait,188.11,Wait,188.14,NO_REQ,,,,,,,,,,,,,,,,,,,
,188.17,Wait,188.21,Wait,188.26,NO_REQ,,,,,,,,,,,,,,,,,,,
,188.29,Wait,188.35,Wait,188.38,NO_REQ,,,,,,,,,,,,,,,,,,,
,188.42,Wait,188.45,Wait,188.49,NO_REQ,,,,,,,,,,,,,,,,,,,
,188.52,Wait,188.54,Wait,188.58,NO_REQ,,,,,,,,,,,,,,,,,,,
,188.61,Wait,188.64,Wait,188.67,NO_REQ,,,,,,,,,,,,,,,,,,,
,188.71,Wait,188.74,Wait,188.78,NO_REQ,,,,,,,,,,,,,,,,,,,
,188.81,Wait,188.84,Wait,188.87,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,188.91,REQ,188.94,Wait,188.97,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,189.00,REQ,189.03,Wait,189.06,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,189.10,REQ,189.12,Wait,189.16,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,189.19,REQ,189.22,Wait,189.25,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,189.28,REQ,189.32,Wait,189.36,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,189.39,REQ,189.42,Wait,189.45,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,189.48,REQ,189.53,Wait,189.57,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,189.61,RESP,189.67,Wait,189.73,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,189.77,RESP,189.79,Wait,189.83,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,189.86,RESP,189.90,Wait,189.94,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,189.97,RESP,190.00,Wait,190.03,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,190.06,RESP,190.09,Wait,190.12,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,190.15,RESP,190.19,Wait,190.22,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,190.25,RESP,190.28,Wait,190.31,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,190.34,RESP,190.37,Wait,190.41,SWI_EL_DIAG,,,,,,,,,,,,,,,,,,,
,190.44,Wait,190.47,Wait,190.50,NO_REQ,,,,,,,,,,,,,,,,,,,
,190.54,Wait,190.58,Wait,190.61,NO_REQ,,,,,,,,,,,,,,,,,,,
,190.64,Wait,190.67,Wait,190.70,NO_REQ,,,,,,,,,,,,,,,,,,,
,190.73,Wait,190.77,Wait,190.79,NO_REQ,,,,,,,,,,,,,,,,,,,
,190.83,Wait,190.86,Wait,190.89,NO_REQ,,,,,,,,,,,,,,,,,,,
,190.92,Wait,190.95,Wait,190.98,NO_REQ,,,,,,,,,,,,,,,,,,,
,191.03,Wait,191.07,Wait,191.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,191.14,Wait,191.17,Wait,191.20,NO_REQ,,,,,,,,,,,,,,,,,,,
,191.24,Wait,191.28,Wait,191.32,NO_REQ,,,,,,,,,,,,,,,,,,,
,191.36,Wait,191.39,Wait,191.42,NO_REQ,,,,,,,,,,,,,,,,,,,
,191.45,Wait,191.49,Wait,191.52,NO_REQ,,,,,,,,,,,,,,,,,,,
,191.55,Wait,191.59,Wait,191.62,NO_REQ,,,,,,,,,,,,,,,,,,,
,191.66,Wait,191.69,Wait,191.71,NO_REQ,,,,,,,,,,,,,,,,,,,
,191.75,Wait,191.78,Wait,191.81,NO_REQ,,,,,,,,,,,,,,,,,,,
,191.84,Wait,191.87,Wait,191.90,NO_REQ,,,,,,,,,,,,,,,,,,,
,191.94,Wait,191.98,Wait,192.01,NO_REQ,,,,,,,,,,,,,,,,,,,
,192.04,Wait,192.07,Wait,192.11,NO_REQ,,,,,,,,,,,,,,,,,,,
,192.14,Wait,192.17,Wait,192.21,NO_REQ,,,,,,,,,,,,,,,,,,,
,192.24,Wait,192.28,Wait,192.31,NO_REQ,,,,,,,,,,,,,,,,,,,
,192.35,Wait,192.39,Wait,192.42,NO_REQ,,,,,,,,,,,,,,,,,,,
J909's temperature reading does NOT appear to get passed back to the ECU, at least not that I can find. IDE11600 Tank tightness: ambient temperature is always -48.00C. Basic Settings IDE04102 Read out system status ctrl module for fuel tank leak diagnost. always fails with "ERROR: Temperature too low" without stimulating any traffic on the serial bus. I'm guessing that temp reading and Basic Setting are meant for DMTL vehicles and not NVLD. I don't think there's anything at all to explicitly command for NVLD.
Edit: at least one of my historical 01 adpmaps has a valid IDE11600 reading, so I'm not sure what's going on here yet.
I'm curious how this crap is supposed to actually work in winter with extended ambient temps below 4C. If I lived in a state that required plug-in emissions/readiness checks, and I cleared codes in deep winter before an inspection, it seems like I could be screwed for quite a while. I'm also curious about the bus protocol but that's purely nerd stuff. For S&Gs I wrote to Continental and asked them for anything they'd be willing to provide in the way of OEM implementor's guides, design docs, logic diagrams, or details on the serial bus protocol. In order to route the request to the right people (i.e. to OEM and aftermarket support instead of consumer) I may have very slightly overstated my relationship with the forum proprietor. :D Hopefully they'll come back with some good stuff.
jyoung8607
FoRT
Garrettsville, OH
C?ID=25607
NostraJackass predicts you will become very familiar with J909, and his buddies for function real soon, after warranty expires.
Hope that helps!
Isn't that the way of things, though? Nobody ever understands the things that Just Work. You don't really understand it until you're forced to troubleshoot it, and most of these systems are still too new to have needed repair...
BTW, I love your double N80 Scirocco. :)
Yeah, although I think heard of issues like that with older EVAP systems as as well, where they won't run the tests in the dead of winter on on very hot days.
I would think the single-wire is most likely LIN bus.
Jason Young?
Never heard of him.
:cool:
Gone But Not Forgotten
Yeah well I thought you had to test the LDP & related PSI sensor circuits if integrated & historically at temps below 60 C IAT, as a rule and the EVAP N80 test was to be above 80 C ECT?
This is why you need to know why the splits exist for bits........ remember it, it rhymes! Bit splits!
LDP/PSI/EVAP No Tri bit = Nein Trifecta............ if not in same DCY!
No qualified G400 ADP Reference by J909 = no bit completion
No qualified V144 = no bit completion
No qualified N80= no bit completion
Google search :
EVAPORATION (EVAP) LEAK DETECTION PUMPS (LDP) Prepare for BIFURCATION! TEST'S!
Jason Young?
Never heard of him.
Who's Jason Young?
jyoung8607
FoRT
Garrettsville, OH
C?ID=25607
That was my first thought, but none of the vehicle manufacturers nor Continental will say, beyond a statement from Continental about "bit serial communication with ECU". If it was LIN, one would think they could just say LIN. Maybe they make it in multiple variants. Or, maybe they cheesed up something very low-rate that can be bit-bashed with generic ECU actuator and sensor lines, so manufacturers could implement NVLD without needing an extra LIN or CAN bus driver chip. That's kind of where my mind went when I saw how long it takes to issue commands and receive responses from that log. IDK.
Jason Young?
Never heard of him.
:cool:
Who's Jason Young?
I had to fill a company name in the form, and "Jason's Garage For Volkswagens That Don't Run Good And Want To Learn To Do Other Stuff Good Too" DBA "Southwest Ohio Luxobarge Rescue" didn't have quite that ring of legitimacy to it. So I designated myself official forum representative for troubleshooting of evaporative emissions systems that are currently not broken. ;)
I really like "Southwest Ohio Luxobarge Rescue" !!! :)
NEtech
Denmark
C?ID=56995
Have you checked your wiring diagram, are there 2 wires to J909 ?
It could be SENT protocol, many sensors on VW and Audi use this now.
See for example SSP 547.
8K0 906 651 C from your Golf R
jyoung8607
FoRT
Garrettsville, OH
C?ID=25607
Yes. It appears to be single-wire, unless the protocol is (ab)using the ECU-supplied ground, through July 2018. From July 2018 (presumably MY 2019) it uses two wires, one of which is labeled CAN-LO, the other not labeled. Could be single-wire CAN, could be two wire with the other wire just not labeled, dunno.
Hrm... will research.
Eventually I'll look at DMTL on the Atlas too, but I can't use the factory EOL readiness procedure right now, because it has a bad catalytic converter and I have no idea when it'll be fixed. The lead time on new catcons is so long/unknown that I was able to convince them to give me our Atlas back for now, instead of sit in a loaner for the duration.
Orchid70
Sweden
C?ID=354348
What about setting Basic Setting for natural gas car?
What are the requirements?
Basic settings for catalytic converter and the O2 sensors fails.
Your ECU does not use the UDS protocol, so the question doesn't really belong in this thread.
Moreover, there's little point in worrying about setting readiness until the engine is running correctly and isn't setting faults.
