Crash shut down activated no power steering
amgbenz
C?ID=345627
car was front damage, everyhting has been replaced inc airbags, still no power steering{red light}, replaced steering rack and coded using my old coding, replaced airbag slip ring still nothing, tried to reset in basic setting say's running the not running, when i try basic settings on steering angle sensor its refused by control module, tried manually to learn new values by steering left hold right hold then centre , nothing is working, dont have a clue what to do next. dont want to take it to the stealers already spent too much. any help would really be appreciated thanks
Chassis Type: KJ-SE27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 44 55 5F CA
VIN: VSSZZZKJZJR103771   Mileage: 4010km-2491miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DKJA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 H    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 5177
   Revision: D7H20000
   Coding: 01250032236405081000
   Shop #: WSC 00049 770 00142
   ASAM Dataset: EV_ECM10TFS01104C906025H 001006
   ROD: EV_ECM10TFS01104C906025H.rod
   VCID: 2517F2F88562526FCDD-8070
   CAN Converter 01:
21472 - Databus
          U1122 00 [039] - Implausible Message
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:20
                    Engine speed: 0.00 /min
                    Coolant temperature: 95 °C
                    Intake air temperature: 30 °C
                    Ambient air pressure: 470 mbar
                    Voltage terminal 30: 27.761 V
17165 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:20
          U0428 00 [039] - -
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:20
Readiness: 1110 0001
   Part No SW: 0CW 300 042 D    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1612
   Revision: 00005008    Serial number: CU501712038113
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 372B28B02FCED0FF6F1-8062
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 2Q0 614 517 T    HW: 2Q0 614 517 M
   Component: ESC_high_vFGS H33 0322
   Serial number: 08511620170908
   Coding: 520D4C5735414AB03203AC1D24DB42A649124D26226A242444541254452442659248B26444562424222A482AA271D642FD8E6B42BF
   Shop #: WSC 00049 770 00156
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
   ROD: EV_Brake1BOSCHESPMQBA0_SE27.rod
   VCID: 3FDB409007FEE8BFA71-806A
1209 - Databus
          [SCL_ACC_Anhalteweg_Error]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:18
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [137] - -
          [Scl_LWI_Lenkradwinkel_Error]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:18
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0464043978
   Coding: 112E0E0703
   Shop #: WSC 00049 770 00221
   ROD: EV_KessyHellaMQBAB_SE27.rod
   VCID: 3E253D9400F4E1B7AC7-806A
12786204 - Databus
          [Message SMLS_01 error received]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:18
                    Terminal_15_Kessy_specified_value: On
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_specified_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_Kessy_specified_value: On
                    Terminal_S_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Park selector lever position: Not engaged and not locked
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition met
                    Control Module Voltage: 12.212 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 0.0 /min
                    Status of vehicle locking: Vehicle locked internally
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID sensor 1 authentication: status: No response
                    ID sensor 2 authentication: status: No response
                    ID sensor 3 authentication: status: No response
                    ID sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 6F0 907 044     HW: 6F0 907 044
   Component: Climatronic   H03 0401
   Coding: 0101000108000100110008000240010D0000000000000000000000000000
   ASAM Dataset: EV_ACClimaBHBMQBA0 004017
   ROD: EV_ACClimaBHBMQBA0_004_SE27.rod
   VCID: 6491AFFCCED8EB671A3-8030
   Part No SW: 2Q0 937 090     HW: 2Q0 937 090
   Component: BCM A0 Std+   H97 0915
   Serial number: 07001735200094
   ASAM Dataset: EV_BCMA0 204001
   ROD: EV_BCMA0_204.rod
   VCID: 6FBBD0D0171E583F771-803A
   Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  047 0105
   Serial number: S4Y17M11D30H04M20S22
   Coding: 00194D
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 2Q2 959 881 D    HW: 2Q2 959 881 D
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000017353027
   Coding: 1D000F
   Subsystem 3 - Part No SW: 2Q2 959 882 D    HW: 2Q2 959 882 D
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000017250184
   Coding: 05000F
   Subsystem 4 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY173132H6T
   Serial number: 00000000000071406669
569092 - Databus
          [LCM links Kein Signal/Kommunikation]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:19
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: On
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: not activated
                    Zusaetzliche Umgebungsdaten-OFF: not activated
                    Zusaetzliche Umgebungsdaten-Outside air temperature: 0
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: not activated
                    Zusaetzliche Umgebungsdaten-Parking light: not activated
                    Zusaetzliche Umgebungsdaten-Parking light left: not activated
                    Zusaetzliche Umgebungsdaten-Parking light right: not activated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: 33
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.3 V
576516 - Databus
          [LCM rechts - Kein Signal/Kommunikation]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:19
590853 - Window Regulator; Front Drivers Side
          B14D1 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:18
919560 - Light Switch
          B126A 29 [009] - Signal Implausible
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:28
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.2 V
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418917348
   Coding: 0471151011
   ROD: EV_EPHVA18AU3700000_009_VW27.rod
   VCID: 4BC364404346441F3B9-801E
13679372 - Databus
          [Steuergerät für Lenkhilfe-J500 - LWI_01.LWI_Lenkradwinkel - Fehlerspeicher auslesen]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:18
13637426 - Databus
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:18
   Component: ACCCONTIMQB   H02 0233
   Coding: 3200678140FF8728749C8145804085
8 Faults Found:
2111 - Databus
          [FAULT_ESP_CONS_ACC]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:18
                    Voltage terminal 15: 12.1 V
                    Control Module temperature: 39 °C
                    Longitudinal_acceleration_vehicle_reference: -0.19 m/s²
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:18
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:27
                    Voltage terminal 15: 12.0 V
1116 - Databus
          [FAULT_TSK_CODING_IN_PLAUS_PHASE_FAIL]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:18
2052 - Databus
          [FAULT_ALP_STEERINGWHEEL_FAIL]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:18
2049 - Databus
          [FAULT_ALP_DT_STEERING_WHEEL_FAIL]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:18
2127 - Databus
          [FAULT_OP_FAIL]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:18
0101 - Databus
          [FAULT_GRA_CODE]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:18
   Part No SW: 5QF 959 655 L    HW: 5QF 959 655 L
   Component: Airbag VW22   006 0520
   Revision: --------    Serial number: 003XNPRY3HLE
   Coding: 88CCC0C000000000585400CF008C00000065
   ASAM Dataset: EV_AirbaVW22TS6VW48X 001028
   ROD: EV_AirbaVW22TS6VW48X_SE27.rod
   VCID: 5F9BA010E7BEC8BFC71-800A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 712 17
   Serial number: 3570000000036B7CEA2.
   Subsystem 2 - Part No SW: -----------    HW: 454 000 712 17
   Serial number: 35800000000F6D71AA2.
   Subsystem 3 - Part No SW: -----------    HW: 454 802 511 17
   Serial number: 35100B96606130000008
   Subsystem 4 - Part No SW: -----------    HW: 454 802 511 17
   Serial number: 35200BD4D9712000000R
   Subsystem 5 - Part No SW: -----------    HW: 454 801 303 18
   Component: FrontSensor_D  307 0189
   Serial number: 355008B563513000000C
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:18
   Part No SW: 5Q0 953 521 M    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20160126500903
   Coding: 1400
   Shop #: WSC 73430 031 00063
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3C21379C16E8F3A7823-8068
226843 - Turn Signal Switch
          B1144 13 [009] - Open Circuit
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:18
                    Ubat 30 Voltage: 12.30 V
                    Ignition State: On
                    Terminal 15: 11.50 V
                    A/D #1: 97.25 %
                    A/D #2: 65.49 %
                    A/D #3: 0.00 %
   Part No SW: 6F0 920 940     HW: 6F0 920 940
   Component: KOMBI         206 0450
   Coding: 24A401182D800600018862011000000080000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001020
   ROD: EV_DashBoardVDDMQBA0_SE27.rod
10485828 - Internal Control Module Memory Check Sum Error
          B2000 41 [009] - General checksum failure
          [Steuergerät defekt (Fehler durch Selbsttest entdeckt)]
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007204555
   Coding: 030100046F085700E90002581C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW27.rod
   VCID: 38292B8C22D0DF8766B-806C
   Subsystem 2 - Part No SW: 5F0 959 537 D    HW: 5F0 959 537 D
   Serial number: 000000000G1258061017
   Coding: 012000
   Subsystem 3 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
   Component: J367-BDMBOSCH  H02 2011
   Serial number: 100344C1
8526363 - Unknown Error Code
          B189C F0 [009] - Unknown Error Elaboration
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:19
                    Supply voltage: Terminal 30: 12.0 V
                    Terminal 15: On
   Part No SW: 2Q0 905 861     HW: 2Q0 905 861
   Component: ELV-MQBB      H06 0020
   Serial number: 17000213343010
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 70B9D3AC0A2047C76EB-8024
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q2 909 144 J    HW: 2Q2 909 144 F
   Component: TRW_G4L_MQBA0 620 6030
   Serial number: 0364373CB4J0522
   Coding: 00000000000000010101020101000101000001
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
   ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
   VCID: 3A2D31841CDCCD9790F-806E
10531840 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:18
                    Engine speed: 0 /min
                    Voltage terminal 30: 12.27 V
                    Power steering current consumption: 0.5 A
                    max.value: 0.5 A
                    End stage temperature: 215 °C
                    Steering assistance: engine output: 100 %
                    Engine angle: 65535 °
                    Electric motor speed: 45535 /min
                    Steering assistance: target engine torque: 0.0 Nm
                    Steering torque: 0.2 Nm
15793408 - Crash Shut-Down Activated
          P1609 00 [137] - -
          [DEM_FRONT_CRASH_STEERING_ANGLE_FAULT]
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:18
                    max.value: 0.5 A
10551552 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [DEM_CODING_PLA_FAULT]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:23
                    Voltage terminal 30: 12.26 V
                    max.value: 0.5 A
10529280 - Data Set Missing
          U1118 00 [009] - -
          [DEM_NO_INITIAL_VW_DSDL_FAULT]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:18
                    max.value: 0.5 A
10512640 - Steering End Stops Not Learned
          C10AC F0 [137] - Unknown Error Elaboration
          [DEM_BOTH_ENDSTOP_NOT_KNOWN]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:18
                    max.value: 0.5 A
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0070
   Coding: 078E000001200003
   ROD: EV_HeadlRegulAFSMQBMAX_SE27.rod
   VCID: 41DF4668710A9E4FD15-8014
131080 - Databus Front Lights
          U1504 00 [137] - No Communications
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:22
13706005 - Databus
          [Empfangener Fehlerwert im Signal BCM1_LDS_Stellung: CAN Message Gateway_72]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:19
13705992 - Databus
          [Fehlerwert im Signal LWI_Lenkradwinkel]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:19
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 5QA 035 858 B    HW: 5QA 035 858 B
   Component: MU-S-ND-ER    H41 0468
   Serial number: SEZAZ2U0207228
   Coding: 04720001960A000011110101008808002F0101D601200500C6
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: EV_MUStd6C1TSAT_SE27.rod
   VCID: 46D555745824B977E47-8012
   Subsystem 1 - Part No SW: 6F0 919 605 A    HW: 6F0 919 605 A
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: SEZ6ZHT3482331
   Subsystem 2 - Part No SW: 6P0 919 866 AB    HW: -----------
   Component: ECE1 2018  --- 0910
0523 - Front Left Treble Speaker
          B1061 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 3: Unterbrechung (AC-Diagnose)]
                    Reset counter: 161
                    Mileage: 4010 km
                    Date: 2018.12.15
                    Time: 20:53:20
                    Voltage terminal 30: 12.2 V
   Part No SW: 4M0 907 594 H    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Coding: 508040527001
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3B23348013E6F49F8B9-806E
End----------(Elapsed Time: 01:33, VBatt start/end: 12.2V/12.1V)-----------
Data Set Missing - U1118 00
That can't be fixed with VCDS.
