2014 VW Caddy - ESP Function Test Activated
grant@gendan
Hi all,
A colleague called in today with a 2014 VW Caddy. They had been trying to recalibrate the G85 Steering Angle Sensor after a geometry adjustment but had started the ESP Function Test by mistake.
I managed to calibrate the Steering Angle Sensor successfully but cannot get the ESP Function Test to complete. The car has flashing ABS and Traction Control lights.
I tried to follow the Wiki procedure to complete the ESP test but I could not get it to complete.
http://wiki.ross-tech.com/wiki/index.php/ESP_System_Function_Test
The dash lights did not change or go out when we pressed the Brake pedal to start the test, so maybe it ignored the rest of the test drive.
Is there a different procedure for this model?
Thank you.
Here is a scan:
Thursday,13,December,2018,14:16:37:05086
VCDS Version: 18.9.0.1 (x64)  HEX-NET CB: 0.4436.4
VIN: WV2ZZZ2KZFX046667   License Plate:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 4C 52 55 56 77
VIN: WV2ZZZ2KZFX046XXX   Mileage: 152820km-94957miles
Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 TF    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9978
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00114014030500080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023TF 003002
   ROD: EV_ECM16TDI02103L997557M.rod
   VCID: 7DB2381DECE2B0A2BD-8028
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: 633C400D09260300C61102EA9020C081A1040021
   Shop #: WSC 35110 377 08192
   VCID: 7EB03F11E9E4ABBAA4-802A
01486 - System Function Test Activated
            000 -  -
                    Reset counter: 74
                    Mileage: 152825 km
                    Date: 2018.12.13
                    Time: 14:10:46
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 320
                    Count: 50176
                    Count: 1024
                    Count: 255
01487 - System Function Test
            000 -  -
                    Reset counter: 74
                    Mileage: 152825 km
                    Date: 2018.12.13
                    Time: 14:12:30
                    Count: 4
                    Count: 12800
                    Count: 321
                    Count: 49920
                    Count: 7679
                    Count: 65533
   Part No SW: 7N0 907 426 CA    HW: 7N0 907 426 CA
   Component: AC Manuell    H20 0607
   Revision: 00001004
   Coding: 0010004002
   VCID: 75A2203DD4D2E8E2F5-8020
   Part No SW: 5K0 937 086 S    HW: 5K0 937 086 S
   Component: BCM PQ35 M+   122 0174
   Revision: BD122001
   Coding: 411A0A3A8025186B088800809000116403057408724D8560E48000000048
   VCID: 44C48DF9C788016AB2-8010
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 01091  26  0512
   Coding: 009795
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 73
                    Mileage: 152813 km
                    Date: 2018.12.13
                    Time: 09:12:53
                    Voltage: 12.15 V
                    Reset counter: 73
                    Mileage: 152813 km
                    Date: 2018.12.13
                    Time: 09:12:53
                    Voltage: 12.15 V
                    Reset counter: 73
                    Mileage: 152813 km
                    Date: 2018.12.13
                    Time: 09:12:53
                    Voltage: 12.15 V
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 2K0 919 475     HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0004
   Revision: --------    Serial number: 32901424600184
   Coding: 108002
   ASAM Dataset: EV_EPHVA14VN3370000 001006
   ROD: EV_EPHVA14VN3370000.rod
   VCID: 70AC1129ABB0CDCA26-8024
   Component: VW10Airbag02F H07 0013
   Revision: --------    Serial number: 003HL00SF558
   Coding: 000000000000000000000000000000003246
   VCID: 3522E03D9452A8E235-8060
   Part No SW: 5K0 953 569 AK    HW: 5K0 953 569 AK
   Revision: --X01---    Serial number: 20180228100104
   Coding: 1082060000
   Shop #: WSC 59509 002 1048576
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 014A44ED901AD442D9-8054
   Serial number: 0618413
   Coding: 820000
   Part No SW: 2K0 920 976 E    HW: 2K0 920 976 E
   Component: KOMBI         H03 0905
   Coding: 480E01
   VCID: 3326DE259A26B6D21B-8066
   Part No SW: 7N0 907 530 AP    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1653
   Revision:   H57       Serial number: 110914F2000427
   Coding: 357401
   Component: IMMO          H03 0905
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A9803418D6C371A68-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0000560
   VCID: 48DC99C93BA0250A5E-801C
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 140    3501
   Revision: 00H22000
   VCID: 393AEC0D704A4C82D1-806C
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000560
   VCID: 47DE9AF536BE2A7257-8012
   Component: AFS-ECU       H04 0111
   Coding: 090400000F000200
   VCID: 373EEA358E5E5AF227-8062
   Subsystem 1 - Part No: 1T0 941 329 A  Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 1T0 941 329 A  Labels: 3D0-941-329.CLB
   Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
   Component: RCD310 EU     H06 5007
   Revision: -----10S    Serial number: VWZ4Z2P1329983
   Coding: 05000200010013
   VCID: 72A81B21ADBCFFDAD0-8026
   Part No SW: 7P6 035 730 M    HW: 7P6 035 730 M
   Component: TELEFON       H16 4217
   Revision: 1B001001    Serial number: 00007666597740
   Coding: 0A01010000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3C34F519B77879AACA-8068
End----------(Elapsed Time: 00:56, VBatt start/end: 14.1V/14.1V)-----------
Hi Grant,
I don't believe the Caddy would be any different than MK60EC1 in our cars. The 2010 GTI (launch control burn-out car in the video) used that ABS and the cluster lights did change with the brake pressure.
I would lock the doors for a 10 min CAN nap and when you wake it make sure G85 steering angle, G201 brake pressure and the brake light switching are all showing proper MVB data before the next test drive. VCDS cannot be connected during the ESP calibration but if the lights don't go out within 45 seconds I'd stop, reconnect VCDS and clear codes followed by a key/engine cycle before attempting again.
If it still won't complete I'd log MVB 001 for WSS issues. The wheel speeds should be taken into consideration by the 03 module and compared with G85 for the calibration.
grant@gendan
Hi Dana,
Thanks for your reply and suggestions. I have just been messaged to say the test has completed and all warning lights have extinguished.
After leaving the car for a while (and finding a larger carpark) my colleague followed your video instructions carefully and it worked.
When I first connected to the car, this function test had been activated and also quite a few other faults were present for G85 settings.
I managed to recalibrate the G85 in the ABS and Steering Assist (as it was reading 15 degrees with the steering wheel straight) and clear those codes but could not get the ESP test to complete.
As you mention, maybe the car needed a CAN nap after this first stage of calibrations before allowing the ESP test to complete.
