2013 Q5 Radio wont turn off sometimes
machado
Canada
C?ID=59468
The customer claims that after having the car detailed sometimes the radio stays on after closing all doors and one time the hazards were on when he got to the car. The radio will eventually turn off. it will turn off if key is cycled. He has not had any other issues, battery has no drained. I am not sure what the issue could be, other than lift up the carpet and look for any moisture, Any thoughts? Thank you, Mario
Tuesday,11,December,2018,18:53:56:15785
VCDS Version: 18.9.0.4
Data version: 20181017 DS296.0
VIN: WA1CFCFPXDA075591   License Plate: RUDI
Mileage: 157330km-97760mi   Repair Order: december2018
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 69
          6D 72 77
VIN: WA1CFCFPXDA075591   Mileage: 157330km-97760miles
Address 01: Engine (DET-CPMA)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8R1 907 115 B    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0006
   Revision: ECH09---
   Coding: 6A2A0013243600062000
   Shop #: WSC 15784 002 1048576
   ASAM Dataset: EV_ECM20TFS0118R1907115B 001007
   ROD: EV_ECM20TFS0118R1907115B.rod
   VCID: 346CA14A9F06C6EA0F-8060
Readiness: 0000 0100
   Part No SW: 8R1 927 158 C    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H16 1002
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002020
   VCID: 3E788362A14A1CBAE9-806A
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AL    HW: 8R0 907 379 AL
   Component: ESP8 quattro  H09 0040
   Coding: 15950803
   Shop #: WSC 93362 999 125952
   VCID: 0A101FB2A502E01A85-805E
   Part No SW: 8K0 907 064 GN    HW: 8K0 907 064 FN
   Component: BCM2 2.0      H12 0633
   Coding: 09854000000000000000
   Shop #: WSC 06335 000 00000
   VCID: 020037929D32B85ACD-8056
   Subsystem 1 - Part No SW: 8K0 959 754 F    HW: 8K0 959 754 F
   Serial number: 0813000020137013
   Serial number: 2313000025814012
   Part No SW: 8K1 820 043 R    HW: 8K1 820 043 R
   Component: KLIMA 1 ZONE  H02 0123
   Revision: A1000000    Serial number: 01280220131494
   Coding: 6481208000
   VCID: 3776964686702DF22A-8062
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000565179301
   Coding: 26000096863C00C00000480300003D0D0F1C660822090401000004004400030100000020000000
   VCID: 78F4557ACBEEE28AE3-802C
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 130213  H11 0050
   Serial number: 90243014130212080014
   Coding: 01DD13
   Subsystem 2 - Part No SW: 8K0 941 531 AR    HW: 8K0 941 531 AR
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001102134743
   Subsystem 3 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: E048C696000000000001
   Subsystem 4 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Component: G355_FeuchteS  H07 0002
   Serial number: 20303055
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
   Serial number: 003GPD91BWP6
   Coding: 30373431343230303030554A304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 4796E686FE905D725A-8012
   Serial number: 6334MSME76616D3DS
   Serial number: 6344MSME78750A23G
   Serial number: 6352QSME22291A56E
   Serial number: 6362QSME5E28567AZ
   Serial number: 63732SME50280976-
   Serial number: 63832SME302B1C4A0
   Part No SW: 8K0 953 568 L    HW: 8K0 953 568 L
   Revision: --------    Serial number: 90372MBK000CN
   Coding: 000017
   VCID: 438EF296C2A8715286-8016
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 900 H    HW: 8R0 920 900 H
   Component: KOMBIINSTR.   H07 0556
   Revision: 00300000    Serial number: UW831E03E
   Coding: 8B86220002010008020000
   VCID: 36689B42817AD4FA31-8062
   Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0055
   Revision: 1V070026    Serial number: 2641V1321883C7
   Coding: 80C303FF00
   VCID: 4894E5BAFB8E520A53-801C
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000001461053941
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   VCID: 3972907EB0643B82DC-806C
   Component: TSG FA        H02 0508
   Revision:             Serial number: 0000053135830
   Coding: 011D03204000440004
   VCID: 4FA6CEA61EE0853212-801A
   Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0014271415
   Coding: 100000000000
   Shop #: WSC 06334 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3B7E8A76B2580992CE-806E
   Revision: 00002001    Serial number: 0301633775
   Coding: 0126023A20FA300084B0053200040000
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8R0 035 223 G    HW: 8R0 035 223 E
   Component: DSP STD       H11 0460
   Revision: 00000000    Serial number: 00000000000001
   Coding: 0203010102
   VCID: 3064AD5A631EFACA6B-8064
   Component: TSG BF        H02 0508
   Revision:             Serial number: 0000053157413
   VCID: 4E98D3A219EA8C3A19-801A
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 20000000236602
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3874957A836E228A23-806C
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8R1 035 186 Q    HW: 8R1 035 186 Q
   Component: Con3 Sirius   H09 0471
   Revision: 00000002    Serial number: AUZ5Z6M1860454
   Coding: 0402000201058700015A070800
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
            000 -  -  - Intermittent
                    Fault Frequency: 18
                    Reset counter: 166
                    Mileage: 152691 km
                    Date: 2018.10.26
                    Time: 14:28:46
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000053713548
   Coding: 010C03204000240004
   VCID: 4688EB82F19A447AA1-8012
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Revision: 1A001001    Serial number: 00000189400856
   Coding: 0200000000000000
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B7E8A76BA580992CE-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H52 0330
   Serial number: 8R0827852B
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000053713403
   Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005300575
   Coding: 0010370
   VCID: 3E788362694A1CBAE9-806A
End-------------------------(Elapsed Time: 04:11)--------------------------
NostraJackAss
8KR & 8K0 = WATER?
Was the car cleaned inside with a pressure washer?
Maybe bad radio...........
machado
Canada
C?ID=59468
It sounds like a problem I the radio I tapped the side of the dash and the radio turned back on, only did it one time and center button is very sensitive, slight movement and radio turned on. I have to wait for customer to bring car back.
NostraJackAss
Be adventurous and take that thing apart, inspect for corrosion bridge and re-flow the solder joints & on the switch, clean the knob if it has one with tuner cleaner..... :p
