Transporter 2018 + HEX V2
Martbspike
I want to change the auto locking and locking audible notification on my 2018 VW Transporter. I can change the values (Cent elect, Adaptation) using my older Hex + Cam, but even though it has saved the values in VCDS, it hasn’t changed the operation on the vehicle.
Seems strange that it lets me make changes but they don’t function.
A full scan suggests this older lead will not work on a 2018 Transporter. Before I buy, will a Hex V2 allow me to make these changes.
Thank you.
It should.
But what is this other lead you're using? Is it legitimate? If it isn't, that would probably explain the difficulties you seem to be encountering. ;)
Martbspike
The older lead is a genuine Ross Tech Hex +cam. Had it about 8 years. Still works fine on my 2014 Skoda Octavia. It used to work fine on my 2011 Transporter but seems flakey on the 2018 Transporter.
I just want to be sure that buying a new lead will solve the problem before I buy.
Mind posting an Auto-Scan from the 2018 made with your existing interface?
Martbspike
Auto scan file
Tuesday,11,December,2018,14:24:05:63710
VCDS Version: 18.9.0.4
Data version: 20181017 DS296.0
VIN: WV1ZZZ7HZKH036967   License Plate:
Mileage: 100   Repair Order:
Chassis Type: 7H (7E0)
Scan: 01 02 03 04 08 09 10 13 15 17 19 25 55 5F 61 69
Address 01: Engine (2D2D2-CXHA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KG    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 3771
   Revision: 23002001
   Coding: 00254014433401090000
   Shop #: WSC 00012 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KG 004004
   ROD: N/A
   VCID: 7CF71BD8F713B9AA87-8028
Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
No ASAM data for: "EV_ECM20TDI03004L906056KG" ()
Readiness: N/A
   Part No SW: 0BT 300 046 J    HW: 0BH 927 711 G
   Component: DSG DQ500-7F  H11 5301
   Revision: 00H11V01
   ROD: N/A
   VCID: 3D71D6DCAC8970A2F0-8068
No ASAM data for: "EV_TCMDQ500021" ()
   Revision: 00000000    Serial number: 62688000002637
   Coding: 307E4098256584840C7E027CA48921D379F100
   ROD: N/A
   VCID: 3F8DACD4A68562B2E2-806A
No ASAM data for: "EV_Brake1ESCCONTIVN75XGP2" ()
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Serial number: 26091813470181
   Coding: 01
   ROD: N/A
   VCID: 7EF311D0E10FABBAA9-802A
No ASAM data for: "EV_LWSKLOVW25X" ()
Address 08: Auto HVAC (J301)       Labels:. 7E5-907-047.clb
   Part No SW: 7E0 907 047 AC    HW: 7E0 907 047 AC
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ROD: N/A
   VCID: 6BD52884827D2E121E-803E
No ASAM data for: "EV_ClimaticT5" ()
   Part No SW: 7E0 937 090 D    HW: 7E0 937 090 D
   Component: BCM PQ25 Max4 H82 0762
   Revision: B9082001    Serial number: 8601 284180330
   Coding: B8FCF93A0A73341193284F606CEB8FF4C084738960CD79603304003F0860
   Shop #: WSC 66305 512 1752841
   VCID: 2C57EB984FF3E92A57-8078
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 041018 05  50  0106
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 R    HW: 7E0 959 801 R  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  005 0653
   Serial number: KU0KU019091882622140
   Coding: 1400B1
   Subsystem 3 - Part No SW: 7E0 959 802 Q    HW: 7E0 959 802 Q  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  004 0653
   Serial number: KU0KU017091882600037
   Coding: 0400A1
   Subsystem 4 - Part No: 7E1 951 171
   Subsystem 5 - Part No: 1K0 951 605 F
   Subsystem 6 - Part No: 7E1 951 171
   Subsystem 7 - Part No SW: 7E0 959 442     HW: 7E0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39180001652290078365
   Coding: B0FFFF
Address 10: Park/Steer Assist (J446)       Labels:. 7E0-919-475.clb
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231823900221
   Coding: 31810C
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: N/A
   VCID: 71E93AECA051C4C224-8024
No ASAM data for: "EV_VW75XParkAssis8K" ()
Address 13: Auto Dist. Reg (J428)       Labels:. 7N0-907-572.clb
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Serial number: 0310180453A94A
   Coding: 00005800FE0779
   Shop #: WSC 01383 790 50316
   ROD: N/A
   VCID: 3663C9F089BFA3FA31-8062
No ASAM data for: "EV_ACCBEGVW361" ()
Address 15: Airbags (J234)       Labels:. 5K0-959-655.clb
   Part No SW: 7E0 959 655 J    HW: 7E0 959 655 J
   Component: VW10Airbag021 010 0018
   Revision: --------    Serial number: 003EK002PL98
   Coding: 000000000000000000000000000000003231
   ROD: N/A
No ASAM data for: "EV_AirbaVW10BPAVW12X" ()
Address 17: Instruments (J285)       Labels:. 5K0-920-xxx-17.clb
   Part No SW: 7E0 920 971 A    HW: 7E0 920 971 A
   Component: KOMBI         H02 2030
   Coding: 440F010300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
   ROD: N/A
   VCID: 2959128C4801FC02AC-807C
No ASAM data for: "EV_Kombi_UDS_VDD_RM09" ()
   Part No SW: 7E0 909 901     HW: 7E0 937 090 D
   Component: GW-K-CAN TP20 H82 0762
   Revision: B9082001
   Coding: 042307
   VCID: 68DF57889B8B050A73-803C
   Component: IMMO          H02 2030
   Coding: 000002
   ROD: N/A
   VCID: 6ADB2D808D87371A65-803E
No ASAM data for: "EV_Immo_UDS_VDD_RM09" ()
Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Coding: 0FCE020001000000
   Shop #: WSC 02748 790 50316
   ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
   ROD: N/A
   VCID: 3A7BDDC0BDA7479AD5-806E
No ASAM data for: "EV_HeadlRegulVWLWRCC" ()
5275648 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 5
                    Mileage: 193 km
                    Date: 2001.14.20
                    Time: 15:51:41
Address 5F: Information Electr. (J794)       Labels:. 5G0-035-MIB-STD2.clb
   Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
   Component: MU-S-ND-ER    H41 0472
   Serial number: VWZAZ2U1600329
   Coding: 065700013C00000011111101008808001F0100D6002001004F
   ROD: N/A
   VCID: 25411EBC2419D86288-8070
   Subsystem 1 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
No ASAM data for: "EV_MUStd4CTSAT" ()
   Part No SW: 7E0 907 534     HW: 7E0 937 090 D
   Component: Batt.regelung H82 0762
   Coding: 330B1A73
   Shop #: WSC 00012 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Serial number: 7588570100180928030C
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000493650620
   Coding: 410D000103000000
   VCID: 326BF5E06DD7BFDA1D-8066
End-------------------------(Elapsed Time: 03:42)--------------------------
WV1ZZZ7HZKH036967
That's not a 2018. That's a 2019. You'll have to upgrade to a current interface. The distributor you got the old one from should be able to assist you.
Martbspike
Thank you for your help. I’ll place an order.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
...but even though it has saved the values in VCDS, it hasn’t changed the operation on the vehicle.
Known issue with these BCMs, there seems to be a glitch in the BCM software itself which in some cases saves the changes you make but they won't have an effect. I have had success with changing other unrelated functions and then at some point all changes got accepted. So while you will need to upgrade either way, the upgrade itself may not address this problem.
Martbspike
New lead plugged in, but I still have the problem. It will not change the functions. I will try changing a few other settings, but I am a bit apprehensive about changing something that can have a random ripple effect.
Is the bug in VCDS software, or is it the control module on the vehicle.
Seb was referring to the BCM itself.
We should get you registered and verified for support at some point. If you haven't already registered the new lead using this procedure please start there.
South Molton, UK
Some of the settings in the BCM on my MQB platform car appear to change with VCDS but don't take effect until you reset to factory settings - on my car that's things like the number of comfort blinks. I'm wondering if there's a similar thing going on here?
Martbspike
I tried changing other unrelated values. Same result. In all cases it saves the value but has no effect.
I have now registered.
I can't help feeling disappointed that I have ended up in the very position I was trying to avoid at the start of the thread. I've bought an interface but because my vehicle is 'faulty' I can't carry out the specific initial functions I wanted to.
I don't fancy my chances of success telling VW there is bug in their software. (They haven't got over the shock yet of governments telling them their software has a bug in it, DEISELGATE)
I will ask my dealer to look in to the bug anyway, (when they have stopped laughing)and while they are there, they can make the changes I want on their kit. (they are going to charge at least £120 just to plug in.)
None of these changes are vital, life threatening, or otherwise. Just nice to have, because you can!
Is it your experience that these bugs get sorted in the fullness of time? Is there anything else I can do?
Thank you.
South Molton, UK
Before giving up and going to the dealer it would help if you could be specific about what changes you are trying to make.
VCDS does keep a log of all the changes you make (attempt to make) so please could you post that log (as well as an Auto-Scan made with the HEX-V2) here for the experts to look at and hopefully make helpful comments. Look in the folder C:\Ross-Tech\VCDS\Logs
Given that you have a 2019 model and that VW have been making some significant changes (e.g. some modules no longer use coding but only adaptation channels) this may be a way forward.
I can't help feeling disappointed that I have ended up in the very position I was trying to avoid at the start of the thread. I've bought an interface but because my vehicle is 'faulty' I can't carry out the specific initial functions I wanted to..
Your old interface was clearly not compatible with the new van you have as evidenced by the fact that VCDS was unable to load data for many of the control module in it.
You have yet to tell us exactly what you're trying to change that won't take. Let's get some details please.
Martbspike
I am trying to change Auto locking to on. (Doors automatically lock at 10 mph) Also want to add audible notification of doors locking from remote key locking. Worked fine on my previous Transporter.
I will save another log file and a scan tomorrow. (Too late in the uk now, plus it’s cold and raining.)
Thanks for all of your help.
VWT6
Finland
C?ID=295527
Somewhat confused now.:confused: Are you saying that if a function exists in VCDS adaptation menu (e.g. Addr 09, Channel 11 Central Audible Locking) it also means that the functionality actually exists in the vehicle? When I got my HEX-V2 cable and experimented quite a few of adaptations noticed that there were few functions that didn't work (e.g. the Audible Locking in BCM). My assumption then was that the VCDS shows whatever adaptations (or just their placeholders) are available (some of them maybe on some other platform) but the actual implementation on the van might be sometimes just a subset.
I never noticed any delay for the changes to take place. However if didn't get the effect, reverted the setting back after a few days, so don't know if that would have taken place later.
MY16 Transporter
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090     HW: 7E0 937 090
   Component: BCM PQ25 Max4 H80 0736
   Revision: B9080001    Serial number: 0771 316150034
   Coding: 62F8793A0A21209301284F602CEB87F4C0B47389604579603204003F0860
   Shop #: WSC 32611 002 1048576
   VCID: 688AB211027AA5A7EBC-803C
No, not necessarily. It may be a question of what's actually allowed by the firmware in a particular module, or (in the case of audible locking confirmation) what's actually wired.
This is one of those modules where there's both a bit in the coding for that and an Adaptation channel for it. I'm not sure why it's that way, but you may have to set it in both places, and possibly in a certain sequence? I'm not sure since I've never had a van like this.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
No, it's not that simple as to which of those two functions are set or what is wired. The Auto-Scan shows that the sounder (LIN-BACKUP HORN) is installed, that's all that is needed in order to get the audible confirmation functional. As mentioned before, there is a glitch in the control module (BCM) firmware, which will allow saving changes in both coding and adaptation but they won't have an effect. This effects most T6 models, though most customers will never notice. Some settings are taking, others are not. Then, months later you tweak a totally unrelated setting and voila everything you tweaked before also comes alive. I've spent the last 2 years on my own T6 again and again to figure this out. At the present time, I got both the audible confirmation as well as the auto-lock/unlock working, as these are the two settings mostly relevant here.
I had some success with flipping byte 8 bit 7 (sound installed yes/no) and cycling the ignition between switching that bit off and on again. Though there is no guarantee if it will work or not... Yes, this may also effect the Auto-Lock/Unlock functionality - don't ask why (the current guesstimate is, that some internal values are reset/reinitialized once certain bits are set, while others don't see to have the same effect). Another context where this is relevant is the mirror folding...
Martbspike
Think I have cracked it. Tried 2 things at the same time, haven’t narrowed it down to one or the other yet, but it works. I read somewhere, not sure how true it was, that vw had introduced a security measure to stop wireless hacking, by needing the bonnet, (hood) to be open to accept coding. The other thing I changed was I reset all the previous attempts back to default, and then made the change through coding and not Adaptation. Bingo! Seems be working every time now.
Bit late in the day to try it again now with the bonnet closed. Could be a complete red hearing, but I’m happy I finally got the changes made that I wanted.
