Jetta 2005 2.5 L lost battery due to a big leak 2A constant.
   #21
It's replay hard to help you without seeing a proper Auto-Scan :cool:
Since he's using unregistered shareware, it won't do a complete scan; it will stop after finding two or three modules.
Then again, since he's using VCDS-Lite on what looks to be an Mk.5 Jetta, VCDS won't find anything beyond the ECU and TCU anyway, because everything else requires a direct CAN connection, which VCDS-Lite doesn't support.
Bottom line: VCDS-Lite isn't the right tool for the job at hand.
peter11742
C?ID=356126
Thanks.
I have already replaced the burned fuse and is working. The power supply can not maintain the 15 A constant load of the car.
The 2 reports are the only ones I received.
Now I have good news the 2005.5 Jetta will never have any lights with the key in the on position.
I have 2 pages from the VW schematics and I will try to see if I will be lucky tomorrow.
I tried to send my incomplete scan but I had no luck. Is any other hosting service better available?.
Let me know.
Uwe Thanks for remind me to get the software. Let me finish all the necessary repairs and I will bye the software soon.
Peter11742
Westbury, UK
You don't need to use a hosting service if it's a text or CSV file - just copy and paste it in a post, preferably between CODE tags.
If it's a picture file (not good for scans) then I use imgur for hosting them and the Insert Image icon or IMG tags.
peter11742
C?ID=356126
Hi.
Some updates.
First all the colors that my pages have are not visible in the first and second harness of J519.
The colors are very bad and I am very disappointed to see not good quality wires.
Finally I made the starter to work it turns nice but the car is not starting, the trouble was bad connection pin on the startup relay socket.
I checked on the fuel port and it was full of gasoline.
I tried to take the spark plugs out but it was late and cold.
Tomorrow I will continue to see that the spark-plugs are in good shape.
Peter11742
peter11742
C?ID=356126
Hi.
I proved today what fuse can cause the engine not to start depending on the year that the car was build.
Jetta is a good example the 2004 uses SB51 the 2005 uses SB49.
Now I know my car was build in late 2004 it uses SB51.
It works and now I will start to close some parts that I opened to troubleshooted .
Peter11742
   #26
peter11742
C?ID=356126
Hi all.
I did not have an error on the Jetta's display before now I have EPC.
This causing no acceleration.
Can I fix the accelerator petal if is bad?.
Let me know if this is possible.
Peter11742
   #27
Westbury, UK
Trying to guess the cause of your EPC error without seeing an Auto-Scan (or even just the engine ECU part) is a bit like playing "whack the mole"... as there any many, many causes of an EPC light :thumbs:
   #28
peter11742
C?ID=356126
OK.
The car works.
Now time for the 2 A leaks
Youtube has 2 cases of remedy 1) the air flow mass 2) the acceleration pedal.
They are well explained and they had good results.
Peter11742
   #29
peter11742
C?ID=356126
Hi All.
Some more updates.
For the people that have the original clamp from VW to the air mass manifold change it to a regular clamp.
This clamp caused air leakage and gave me the EPC error too much air.
peter11742
peter11742
C?ID=356126
Hi All.
The new year already started but the Jetta is still not done.
I can start the car but now I have some errors and of course the engine light.
In the local store they had a meter to check the VW cars for $15.00 because they said was not working.
I made it to work and I can play with the errors. This meter has no capability reading the can buss it fails.
So I will open again the J519 because I have one more unit that was taken from a working jetta on accident.
I tried this unit but it stops because my keys are from my car, is called immobilizer error for this I need the can buss reader that I do not have.
Errors that I have all the oxygen sensors fail and also the J17 and the J271 relays.
Uwe has a nice cable witch includes the software that I need to see the proper errors and the can buss.
I also have a radio that work without sound protection action the radio is from a very young Jetta that has a different VIN. I hope I can fix this.
Until the next time.
peter11742
peter11742
C?ID=356126
Hi Is the unit that I order on 1-3-2019 fix DLR and imobilizer? Thanks
   #32
Yes, the HEX-V2 will talk to everything in the car.
However, I'm not sure what you mean by "fix DLR and imobilizer".
peter11742
C?ID=356126
Uwe. Thanks for replying.
Let us start with DLR.
This is a VW mistake if you have week battery in the cold I measure with a key on 15 A leak if you do not start the car for 10 minutes you drain your battery. It happened to me with the Jetta
My Prius do not have this Toyota is smarter.
Second the imobilizer is the part of VW to protect the car so it will not start with a different key.
I have a second J519 used from a good Jetta that gives me this error because it has a key stored from a different car. Can I defeat it with the software by correcting the proper key if this is possible.
Third My radio was good until I removed the battery for few days then it works but I have no voice it gives Protection components is on.
The dealer from Florida told me only the WV dealer can fix it.
Now I have a technical question All my Injectors are failing today I measure 2 of them the wire after the heating element both get 2.5 volts. The 2 other wires have 0.5 between them the car is ruining good but I get engine light. Can you tell me if is wiring or the injectors. I will appreciated.
Last I received an email today the unit I ordered is shipped to me.
peter11742
   #34
Daytime Running Lights. DRL. Not DLR. ;)
Correct me if I'm wrong, but don't they turn off if you set the hand-brake?
No, you cannot defeat the immobilizer with VCDS. But J519 (the CECM) has nothing to do with the immobilizer in 2005 Jetta. The immobilizer is in the Instrument Cluster.
I'm confused. Engines with failing injectors don't run well.
Let's see what a proper scan turns up when you get your VCDS.
I've changed your status here to Verified. :)
peter11742
C?ID=356126
Uwe.
Thanks. Sorry for the spelling.
Good answers.
DRL The lights come off with hand brake it works this way. This is not a good solution I want them out period.
Now the car is running very good it smells perfect no smoke accelerates perfect and I have no other errors.
I took it for a ride in my local street and it behaved good.
Now why I get the engine light we will find what fails in the can buss with the new unit.
The unit that I have some times tells me controller is not formatted correctly, error.
This is the reason I will try to use the other controller that I have with the key issue.
So we started now and we will see how far we will reach.
A note this car is solid and rides very good.
Later this year I will get one on eBay but I need to know what is the best wagon they have. Texas dealers have perfect prices on eBay.
I like to know if my values are within a good range on the injectors. I will use my scope to see how the pulses look.
Peter11742
Should be easy enough to do with VCDS on that car. I'd like to see a scan before I try to give you detailed instructions though.
peter11742
C?ID=356126
OK.
Thanks to both of you.
I will try to do this when I will be ready.
So far any of you can tell me which is the best VW Wagon back 2 years I do not know.
Uwe I got the unit this afternoon it works on my laptop I will use it tomorrow.
peter11742
peter11742
C?ID=356126
Hi,
I think these results are not any good I will try the other controller to see if I have better readings.
Let me know if this system can be corrected.
Sunday,06,January,2019,11:23:37:56328
VCDS Version: 18.9.0.4  HEX-V2 CB: 0.4437.4
Data version: 20181017 DS296.0
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 47 52 56 62
          72 77
VIN: 3VWDG71KX5M602637   Mileage: 174340km-108329miles
1C-Position Sensing -- Status: Malfunction 0010
56-Radio -- Status: Sporadic communication error 1000
77-Telephone -- Status: Not registered 0001
Address 01: Engine        Labels: 06A-906-032-BGQ.lbl
   Part No SW: 06A 906 032 QC    HW: Hardware No
   Component: 2.5l R5/4V      G   6605
   Revision: 00000000    Serial number: VWZ7Z0D1108127
   Coding: 0000003
   Shop #: WSC 00066 000 00000
   VCID: 6FBBD1C63B90CCFF771-803A
16426 - Oxygen (Lambda) Sensor B1 S3: Heating Circuit
            P0042 - 004 - Malfunction /Open Circuit - MIL ON
16420 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
            P0036 - 004 - Malfunction / Open Circuit
16415 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
            P0031 - 002 - Short to Ground - MIL ON
17925 - Power Supply Relay for ECU
            P1517 - 004 - Electrical Malfunction
Readiness: 0010 1101
   Part No: 09G 927 750 AS
   Component: AQ 250 6F           0649
   Coding: 0000008
   VCID: 025D88721802D19788F-8056
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0021122
   VCID: 3A2D30923052595790F-806E
   Part No: 1K0 907 044 AC
   Component: ClimatronicPQ35 066 0404
   VCID: 6889BADA1E7E1BC736B-803C
   Part No SW: 1K0 937 049 C    HW: 1K0 937 049 C*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000000006675
   Coding: F4058E02400418000014000000140000002077035C
   VCID: 2F3B11C6FB108CFF371-807A
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
02092 - Enabling Heated Seat
00061 - Footwell Lights
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
   Component: SDAR XM         H03 0060
   Revision: 00000000    Serial number: AUZ4Z7D7020608
   VCID: 2B0305D6CF08F0DF1B9-807E
            000 -  -
                    Reset counter: 233
                    Mileage: 174349 km
                    Time: 00:00:07
01304 - Radio
                    Fault Status: 01101000
                    Fault Frequency: 9
                    Reset counter: 233
                    Mileage: 174349 km
                    Time: 00:03:29
                    Fault Status: 00101110
                    Reset counter: 229
                    Mileage: 174349 km
                    Time: 19:54:28
                    Reset counter: 232
                    Mileage: 174349 km
                    Time: 00:06:14
   Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
   Component: 1S AIRBAG VW8R  024 6300
   Revision: 03024000    Serial number: 0037KD009JN8
   Coding: 0012627
   VCID: 2E050CC2FC1A85F73C7-807A
   Subsystem 1 - Part No: 1K0 959 339 B
   Component: BF-Gewichtsens. 006 0003
   Subsystem 2 - Serial number: 6332MSME06015E276
   Subsystem 3 - Serial number: 6342MSME0738210E7
   Subsystem 4 - Serial number: 6351HSME041B522B3
   Subsystem 5 - Serial number: 6361HSME040D4E1FJ
   Subsystem 6 - Serial number: 63727SME052B4110R
   Subsystem 7 - Serial number: 63827SME052C093A2
00591 - Seat Belt Switch; Driver (E24)
   Part No SW: 1K0 953 549 AC    HW: 1K0 953 549 AC
   Component: J0527           010 0045
   Coding: 0012041
   VCID: 73B3DDB657B8E81F939-8026
   Component: E0221           004 0030
   Part No: 1K0 920 971 C
   Component: KOMBIINSTRUMENT 3HL 2120
   Coding: 0023203
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104A120448
   Coding: 3F7F03620F1002
   VCID: 290FFFDEC5F4E2CFE95-807C
            000 -  -
                    Fault Frequency: 44
                    Reset counter: 193
                    Mileage: 174349 km
                    Time: 01:50:16
01304 - Radio
                    Reset counter: 233
                    Mileage: 174349 km
                    Time: 01:52:50
   Part No SW: 1K5 919 965     HW: 1K5 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 0371356TMVE903
   VCID: 78A9EA9A4EDE8B47A6B-802C
                    Reset counter: 229
00457 - Control Module for Network (J519)
            015 - Cannot Be Tested at this Time - Intermittent - MIL ON
                    Fault Status: 10111111
                    Fault Frequency: 15
                    Reset counter: 232
                    Mileage: 174349 km
                    Time: 01:25:07
                    Reset counter: 229
                    Mileage: 174349 km
                    Time: 19:54:28
   Component: IMMO            3HL 2120
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 A    HW: 3C0 959 760 A
   Component: Sitzverstellung     0601
   Revision: 00002000    Serial number: 00000000000000
02327 - Position Sensor for Front Seat Height Adjustment (G438)
            006 - Short to Plus - Intermittent
02341 - Position Sensor for Seat Fore/Aft Adjustment (G441)
02328 - Position Sensor for Rear Seat Height Adjustment (G439)
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2339
   Coding: 0001271
   VCID: 363524A2044ABD37747-8062
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.3       1502
   VCID: 303912BAE62E93072EB-8064
            000 -  -
   Part No SW: 1K0 959 433 AT    HW: 1K0 959 433 AT
   Component:    KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 13100F880106281B0906050FA0080F0490A540
   Component: LIN BACKUP HORN H02 1301
9 Faults Found:
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Fault Frequency: 121
                    Reset counter: 193
                    Fault Status: 01101101
                    Reset counter: 193
                    Mileage: 174349 km
                    Time: 21:02:14
                    Fault Status: 01110011
                    Fault Frequency: 18
                    Reset counter: 193
                    Fault Status: 01110010
                    Fault Frequency: 9
                    Reset counter: 232
                    Mileage: 174349 km
                    Time: 00:11:24
                    Reset counter: 232
                    Reset counter: 232
                    Mileage: 174349 km
                    Time: 00:33:57
                    Reset counter: 232
                    Reset counter: 232
                    Mileage: 174349 km
                    Time: 00:06:54
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No: 1K6 035 456
   Component: 08K Audioverst.     0003
   Revision: 00002000    Serial number: 00000000002248
   VCID: 698FBFDE057422CF295-803C
   Part No: 1K0 959 702 K
   Coding: 0001271
   VCID: 372B29A60340443F6F1-8062
00110 - Right Mirror Turn Signal Lamp (L132)
Address 56: Radio
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2416
   Coding: 0000144
   VCID: 313F17BEED249A0F215-8064
   Part No: 1K0 959 704 D
   Coding: 0000144
   VCID: 323D18B2E822A11758F-8066
Address 77: Telephone
End----------(Elapsed Time: 01:17, VBatt start/end: 14.1V/14.1V)-----------
To kill off DRLs:
[Select]
[09-Cent. Elect.]
[Coding]
[Long Coding Helper]
In Byte 0, I expect you'll find a checkmark next to "Daytime Running Lights (North America)". Un-check it.
Close Long Coding Helper. This will transfer the modified coding back to the New Coding field in VCDS.
[Do It!]
