(2011) Audi A4 license plate light
Andreass
Finland
C?ID=124312
I changed my license plate lights from original to led and i get a fault code on them. Is it possible to code this so that the car knows that leds are equipped? I have seen videos on youtube when people do this on other cars but i can't find the same bytes and bits when i try to fix it.
I hope someone knows how to fix this since i like the white light leds give.
Thanks!
Sunday,09,December,2018,21:38:23:57230
VCDS Version: 18.9.0.4 (x64)
Data version: 20181017 DS296.0
VIN: WAUZZZ8K0BA09xxxx   License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 69 72 77
VIN: WAUZZZ8K0BA099677   Mileage: 128550km-79877miles
Address 01: Engine (-----CFKA)       Labels:* None
   Part No SW: 8K2 907 115 R    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H08 0004
   Revision: ECH08---
   Coding: 010C000C184F0960
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_ECM20TFS8K2907115R A01008
   ROD: EV_ECM20TFS8K2907115R.rod
   VCID: 3E76A44BA1A83BBAE9-806A
   Part No SW: 8K0 907 379 BG    HW: 8K0 907 379 BG
   Component: ESP8 quattro  H04 0020
   Coding: 258504
   VCID: 7F08994FEE22F2B2A2-802A
   Part No SW: 8K0 907 064 CP    HW: 8K0 907 064 CP
   Component: BCM2 2.0      H05 0434
   Coding: 032200
   VCID: 000A1AB393DC8D4ADB-8054
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H60 0072
   Serial number: 0810000123911005
   Serial number: 2310000081745001
   Part No SW: 8T1 820 043 AH    HW: 8T1 820 043 AH
   Component: KLIMA 1 ZONE  H08 0180
   Revision: A1000000    Serial number: 01111220100769
   Coding: 64A00000
   VCID: 77F8716FC612CAF2EA-8022
01020 - Water Pump (V36)
                    Fault Status: 00101100
                    Reset counter: 65
                    Mileage: 127204 km
                    Date: 2018.09.16
                    Time: 20:30:24
                    Voltage: 14.30 V
                    Temperature: 69.0°C
                    Current: 0.025 A
                    Voltage: 5.00 V
                    Voltage: 0.00 V
                    Bin. Bits: 00000001
                    RPM: 1400 /min
   Component: BCM1 1.0      H30 0392
   Revision: 10030001    Serial number: 00000000887121
   Coding: 2600D0914134AF010001000300001D0D4F9C270806010101000000
   Shop #: WSC 06335 123 12345
   VCID: 3C72AE43BFB429AAC7-8068
   Component: WWS 161210  H06 0070
   Serial number: SWF10120166111
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 11197898
   Coding: 025028
   Component: E1 - LDS  H08 0090
   Serial number: 00000000000312100537
   Part No SW: 8K0 959 655 L    HW: 8K0 959 655 L
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003JMD082DXR
   Coding: 30513435363030303030554A304C384B3053
   VCID: 4686CCABF978637AA1-8012
   Serial number: 6334MSME5953470CI
   Serial number: 6344MSME5A405647F
   Serial number: 6352QSME39760D22J
   Serial number: 6362QSME06791F1EV
   Serial number: 63732SME4B7B23262
   Serial number: 63832SME607B1528/
   Part No SW: 8R0 953 568 K    HW: 8R0 953 568 K
   Component: Lenks.Modul   H07 0156
   Revision: 00000000    Serial number: 20101210000044
   Coding: 000017
   VCID: 499CC797E0668C024C-801C
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 930 M    HW: 8K0 920 930 M
   Component: KOMBIINSTR.   H27 0258
   Revision: 00200000    Serial number: EJ824R9DA
   Coding: 0F05110002000008010000
   VCID: 3778B16F86920AF22A-8062
   Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0117
   Revision: GB800053    Serial number: 5300G10C068096
   Coding: 00CF07
   VCID: 010C1FB798D68442D4-8054
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005659397100
   Serial number: 10342000665021200181
   Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
   Component: TSG FA        H12 0357
   Revision:             Serial number: 0000111269986
   Coding: 011C02204000410001
   VCID: 4A9EF89BE560871A45-801E
   Revision: 00002001    Serial number: 0140082189
   Coding: 013A062020B904408030023680000000
                    Fault Status: 11101100
                    Reset counter: 25
                    Mileage: 127501 km
                    Date: 2018.10.09
                    Time: 19:36:49
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8R0 035 223 F    HW: 8R0 035 223 E
   Component: DSP STD       H11 0440
   Revision: 00000000    Serial number: 00000000000001
   Coding: 0203010102
   VCID: 2F68890F7EC2C23272-807A
   Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
   Component: TSG BF        H12 0357
   Revision:             Serial number: 0000111175148
   Revision: 00000003    Serial number: 10000000684131
   VCID: 3462866397E4E1EA0F-8060
   Part No: 8K5 907 357 B
   Coding: 0000004
   VCID: 397CB75770861C82DC-806C
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 186 P    HW: 8T1 035 186 P
   Component: Concert3      H07 0350
   Revision: 00000011    Serial number: AUZ5Z6J1512622
   Coding: 05020082010285000159070000
   VCID: 4482D6A3C744516ABF-8010
   Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
   Component: Display
   Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
   Component: TSG HL        H11 0357
   Revision:             Serial number: 0000111213756
   Coding: 010C02204000210001
   VCID: 4584CBA7CC7E6862A8-8010
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Component: Anhaenger     H07 0100
   Revision: 1A001001    Serial number: 00000140120680
   Coding: 010D000000000000
   Shop #: WSC 25397 000 00000
   VCID: 3666BC6B8198F3FA31-8062
   Component: TSG HR        H11 0357
   Revision:             Serial number: 0000111213739
   Part No SW: 8T0 862 335 E    HW: 8T0 862 335 E
   Component: FSE_256x BT     H42 0650
   Revision: 00000000    Serial number: 00000005247539
   Coding: 0010390
   VCID: 3C72AE437FB429AAC7-8068
End-------------------------(Elapsed Time: 03:28)--------------------------
NostraJackAss
Andreass
Finland
C?ID=124312
Thank you for answers!
I know that a resistor would fix the problem but i want to do it through vcds.
Do you or someone else know how to fix the water pump? What part should be replaced or where should i check for a problem?
Thank you @rlarsen, is that in 07 electrical..?
rlarsen
Copenhagen, Denmark
C?ID=78998
It is in unit 46 - and you need to use the security code 16017 to be able to see channel 192
[46 - Comfort System]
[Security Access - 16] -> Enter login-code: 16017
[Adaptation - 10] -> Channel 192
Andreass
Finland
C?ID=124312
Oh, of course! Thanks!
