Polo 9N3 ABS Pump Change
LHSLTD
C?ID=271214
I've been asked to go and scan and code a collection of Polo's and the chap has changed the ABS pump on one and didn't get the long coding copied before he took the old one out.
Is there anyway I can get the coding from somewhere using the VIN number rather than making 2 trips?
I have the part number of the pump too if it helps. Its a 2006 1.4 BKY engine.
Thanks.
DrPeter
16.4905° S, 151.7375° W
Thanks.
Hi there,
ABS Coding charts should be in the Official Factory Repair manuals.
With the VIN number, you can lookup the PR-codes and other information that are needed to build the Login and Coding values, as per the repair manuals.
A helpful website to find PR-Codes and other information is www.PartsLink24.com. Like the repair manual website linked above, these are subscription based sites.
If you want or if you are having trouble, you can post an Auto-Scan and maybe we can try and determine the correct coding of the ABS controller.
ps.. Be sure the correct part number of the ABS controller is being used.
Hope this helps,
drpeter
LHSLTD
C?ID=271214
Hi there,
Hope this helps,
drpeter
Thanks for that @DrPeter.
How do the repair manuals work? I don't mind paying for access provided the customer is agreeable, but I don't want to pay it then get nowhere. If I pay for access for say 24hours, would basically be able to key in the VIN number go through the catalogue to brakes, for example, and be able to see the coding for the abs system?
Just not sure how it works?
Lennie
It's not at all clear to me whether ABS coding would be in there for the 9N.
LHSLTD
C?ID=271214
Bugger
Well that was pretty much a bust, 52 miles each way and got a scan, as detailed below, however on further investigation I found a link fuse burst, 4th from the left on the 9N3 fuse box in the engine compartment.
I am not sure if it the one for the ABS Pump, but my gut feeling is that it is.
Wednesday,12,December,2018,17:40:48:18208
VCDS Version: 18.2.1.2 (x64)
VIN: WVWZZZ9NZ6Y201088   License Plate: SD06 NZM
Mileage: 181960km-113064mi   Repair Order:
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ6Y201088   Mileage: 181960km-113064miles
Address 01: Engine        Labels: 036-906-034-APE.lbl
   Part No: 036 906 034 KA
   Component:  MARELLI 4TV        7448
   Coding: 00071
   VCID: 5BB5F907C962A09C12-4AE8
   WVWZZZ9NZ6Y201088     VWZ7Z0F3449142
18049 - Please check DTC Memory of A/C Controller
            P1641 - 35-00 -
Readiness: 0000 0101
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.clb
   Part No SW: 6Q0 907 379 AF    HW: 6Q0 907 379 AF
   Component: ABS 8.0 front   H03 0002
   Coding: 0002088
   Shop #: WSC 00788 785 00200
   VCID: 0109EB6F5B4E2A4C28-515E
01201 - ABS Pump Supply Voltage
            000 -  -
                    Reset counter: 154
                    Mileage: 181881 km
00301 - ABS Return Flow Pump (V39)
                    Fault Status: 01101000
                    Reset counter: 154
                    Mileage: 181881 km
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 6Q0 820 045
   Component: Klimaanlage        X0840
   VCID: 6ADBACC31638C91499-5122
            07-00 - Signal too Low
            31-10 - Open or Short to Ground - Intermittent
Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 D
   Component: 00BK BN-SG.         1S34
   Coding: 25742
   Shop #: WSC 00788
   VCID: 3C775A9B2C2C87A43B-515E
01598 - Drive Battery Voltage
   Part No: 1C0 909 605 K
   Component: 18 AIRBAG VW51 0P   0008
   Coding: 12600
   Shop #: WSC 00788
   VCID: 2C576ADBDC4C1724AB-5140
Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
   Part No: 6Q0 920 903
   Coding: 01441
   VCID: 6ED3A0D32AD02534C5-515E
00771 - Fuel Level Sensor (G)
            30-00 - Open or Short to Plus
   Part No: 6N0 909 901
   Component: 0B7L GATEWAY CAN    1S34
   Coding: 00014
   Shop #: WSC 00788
   VCID: 70EFBEAB30E433C4D7-5140
   Part No: 6Q0 423 156 AB
   Component: LenkhilfeTRW        V270
   Coding: 10140
   Shop #: WSC 00788
   VCID: 6FEDBDD72DDA2C3CCE-5140
Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
   Part No: 6Q0 959 433 H
   Component: 1N Komfortgerát     0002
   Coding: 00019
   Shop #: WSC 00788
   VCID: 408F2E6B40C4E34467-4B00
   Part No SW: 6Q0 035 152 A    HW: 6Q0 035 152 A
   Component: Radio BVX       005 0004
   Revision: 00005000    Serial number: VWZ1Z5F9014152
   Coding: 0020200
   VCID: 285F96CB98B43B044F-5140
End-------------------------(Elapsed Time: 03:25)--------------------------
