VW Caddy no start issue
Vdtechnik
hex7386-0141d2-a092e6-ef137d-tjiahh-5b5f
Hi All.
Got a 2011 VW Caddy Van here with the 1.6TDI engine and the DSG7 Gearbox. It doesn't start.
When you turn the key to start there is no crank. Instead on the dash the message '--p/n' appears, presumably meaning put the vehicle into park or neutral before trying to start which of course it already is.
Sunday,09,December,2018,15:16:57:37606
VCDS Version: 18.2.1.2
VIN: WV2ZZZ2KZBX268376   License Plate:
Mileage: 237040km-147289mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WV2ZZZ2KZBX268376   Mileage: 237040km-147289miles
Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 FK    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9977
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00254014030500080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023FK 003012
   ROD: EV_ECM16TDI02103L997557M.rod
   VCID: 74E25B53DF29C9E433-8020
   Part No SW: 0AM 300 050 R    HW: 0AM 927 769 D
   Component: GSG DSG AG7     403 9060
   Revision: 00040034    Serial number: CU501101165767
   Shop #: WSC 51771 001 1048576
   VCID: 387AAF634BC16D84DF-806C
   Part No SW: 1K0 907 379 BD    HW: 1K0 907 379 BD
   Revision: 00H31001
   Coding: 633C400D09280302C60E02EB901FC081300000
   Shop #: WSC 35110 377 08192
   VCID: 75E46657DC53D0EC04-8020
                    Reset counter: 137
                    Mileage: 237043 km
                    Date: 2013.04.17
                    Time: 00:02:19
                    Count: 2
                    Count: 12
                    Count: 20992
                    Count: 8210
                    Count: 41728
                    Count: 512
                    Reset counter: 137
                    Mileage: 237043 km
                    Date: 2013.04.17
                    Time: 00:01:25
                    Count: 2
                    Count: 14
                    Count: 20992
                    Count: 8194
                    Count: 43264
                    Count: 512
                    Fault Status: 00101100
                    Reset counter: 137
                    Mileage: 237043 km
                    Date: 2013.04.17
                    Time: 00:06:16
                    Count: 2
                    Count: 14
                    Count: 20992
                    Count: 105
                    Count: 43008
                    Count: 512
                    Reset counter: 137
                    Mileage: 237043 km
                    Date: 2013.04.17
                    Time: 00:06:02
                    Count: 2
                    Count: 14
                    Count: 20992
                    Count: 8195
                    Count: 43008
                    Count: 512
                    Reset counter: 137
                    Count: 2
                    Count: 12
                    Count: 20992
                    Count: 8208
                    Count: 37632
                    Count: 512
   Part No SW: 7N0 907 426 K    HW: 7N0 907 426 K
   Component: AC Manuell    H17 0202
   Revision: 00012001
   Coding: 0000000002
   ROD: EV_ClimaBasis_VW32.rod
   VCID: 3C72B373B7F941A43B-8068
   Part No SW: 2K5 937 085     HW: 2K5 937 085
   Component: BCM PQ35 B+   011 1044
   Revision: BB011001
   Coding: 401A0A3A8025186B088000829000006403017288524F8160648000000040
   VCID: 72EE5D4BAD3DC7D421-8026
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 07011  26  0512
   Coding: 009795
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 137
                    Mileage: 237043 km
                    Date: 2013.05.01
                    Time: 00:06:26
                    Voltage: 12.50 V
   Component: VW10Airbag00Z H06 0013
   Revision: --------    Serial number: 003HL003S5SJ
   Coding: 00000000000000000000000000000000305A
   VCID: 3564A65794D390ECC4-8060
          B1000 1B [137] - Resistance Too High
                    Mileage: 237043 km
                    Date: 2018.12.09
                    Time: 00:06:26
9446677 - Redundant signal path for airbag shut-off; passenger side
          B1025 15 [137] - Open or Short to Plus
                    Mileage: 237043 km
                    Date: 2018.12.09
                    Time: 00:06:25
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [137] - Open or Short to Plus
                    Mileage: 237043 km
                    Date: 2018.12.09
                    Time: 00:06:25
   Part No SW: 5K0 953 507 AB    HW: 5K0 953 549
   Revision: --------    Serial number:  90440KAO000EN
   Coding: 1880060000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 70EA5743AB31F5C4D7-8024
   Part No SW: 2K0 920 965 A    HW: 2K0 920 965 A
   Component: KOMBI         H04 0421
   Coding: 480200
   VCID: 2D548E377C83D82CBC-8078
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 230111F1000751
   Coding: 357401
   VCID: 306A974363B1B5C497-8064
   Component: IMMO          H04 0421
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADE452B8DED0F1499-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0000560
   VCID: 489ADFA33B211D04AF-801C
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 140    3201
   Revision: 00H20000
   VCID: 34629B5357A989E4F3-8060
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 237043 km
                    Date: 2013.05.01
                    Time: 00:06:23
                    Battery Volts: 12.6 V
                        DD
                    Temperature: 16.0∞C
                    Count: 2
                    Steering Angle: 0.00∞
                        SteerAng n.Init
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000560
   VCID: 4798DC9F363F127CA6-8012
   Part No SW: 5K0 035 156     HW: 5K0 035 156
   Component: Radio         510 0521
   Revision: R0510001    Serial number: VWZ5Z1L0445670
   Coding: 0500020001
   VCID: 64C22B1367C95964A3-8030
End-------------------------(Elapsed Time: 02:17)--------------------------
All help welcomed.
regards, M
Vdtechnik
Thanks for the link! I will look at the measuring blocks as mentioned asap. From memory it was all fine as that was one of the first things I checked. I was mostly alarmed by the amount of modules with no communication.
Thanks to UWE for tidying up my original post. Wont forget next time. Ive had Ross-tech for some time now but never really used it much further than basic coding and fault scans. Hopefully it can be used to find the current fault but I may just need steering in the right direction to begin with.
Ive added my VCDS verified number now. Hopefully this is enough to get verified?
Regards, M
Vdtechnik
Ok, Will get registered properly asap.
I have looked through the thread you linked NZDubNurd.
Just to add I'm getting the P symbol on the instruments (well whatever gear the selector is in appears on the instruments).
The measuring block results are on different numbers but I think I've got the information required.
02-AutoTrans-004 Selector Lever Position (E313) = P
09-Cent. Elec. - 064 Park Neutral (P/N) release = PN Inactive/OFF
So the mechatronics unit is reporting that its in Park. But that signal isn't getting to the Cent.Elec and preventing the start?
Erwin i guess would be the next move for the wiring diagram to confirm this?
regards, M
NZDubNurd
New Zealand
C?ID=230482
Your modules with no comms, are low frequency/intermittant - they'll probably not come back after clearing.
Your 2011 Caddy is still very similar electronical archimitecture to the MK5 Golf and 1T1/1T2/1T3 Tourans, so the linked thread probably applies directly to your car, but it doesn't hurt to double check!
I suspect the selector lever position is reported by the lever assembly itself (it is, in the linked thread) - it has hall sensors and magnets. The Mechatronics then tells the J519 CECM that it's in park too... ideally they should match :D
You'll probably find you have a purple/black wire in pin E/7 of the J519 too - you can try the test if from the linked thread - If you're not a betting man, you'll want to check the wiring diagrams first ;) You could also isolate both ends, verifying the colour at the DSG... I suspect that wire will be open circuit though.
