VCDS Support for A8 D4 4H (2010+)
sieben
C?ID=34182
Greetings,
I have a 2014 A8L US Model. It's my 6th Audi. Also had 4 VWs: MkI, MkIII, MkIV, MkVI, B5, B7, C5, C6, D1, D2, D4...
Had a VCDS since about 2006.
I'm looking to do a few basic things with the VCDS. on my A8L. I've seen other posts here and in other forums, that answered many of my questions or showed the coding I was looking for...
All I really wanna do now is:
(1) How do I get the tail lights to activate when I have the single-side "European" parking light on? The front works, the back does not.
The full front and back parking lights operate by the light switch in the car, but only the fronts when I put the turn signal stalk in the left or right position.
I've done this in many other VWs and Audis but can't get it to work here.
(2) How do I activate the (orange/amber) rear turn signal? I see the orange lights in the tail light unit, but there seems to be no way to activate it..
(In my C6 Avant, it was easy - I just put a bulb in the orange section and recoded for Germany; Ditto for my B7 Avant...).
I was advised to post a scan to show the modules I have. So here goes...
Thanks in advance.
A8L VCDS Codes status etc 1 Dec 2018
Saturday,01,December,2018,15:13:32:12005
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 18.9.0.2
VIN: WAUR2AFD5E   License Plate:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 20 28 34 36 3B 3C 42
          46 47 52 53 56 5F 62 6C 6D 6F 72 81 85 88 89 8B 8E 8F 90 BA
VIN: WAUR2AFD5E   Mileage: 86km-108miles
Address 01: Engine (------CEUA)       Labels: Redir Fail!
   Part No SW: 4H0 906 014 L    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H62 0005
   Revision: NCH62---
   Coding: 022A00326546010E1000
   Shop #: WSC 00267 002 1048576
   ASAM Dataset: EV_ECM40TFS0114H0906014L 001005
   ROD: EV_ECM40TFS0114H0906014L.rod
   VCID: 2C5C8E084725D22A59-8078
12352 - Coolant Pump for Intercooler
          P023A 00 [047] - Open Circuit
                    Mileage: 62820 km
                    Date: 2018.08.20
                    Time: 16:06:26
                    Engine speed: 554.00 /min
                    Normed load value: 7.1 %
                    Coolant temperature: 87 °C
                    Intake air temperature: 51 °C
                    Voltage terminal 30: 14.135 V
                    Engine status: COENG_RUNNING
4720 - Body Control Module (Central Electric 2)
          U0141 00 [032] - No Communications
   Part No SW: 4H1 927 158 EE    HW: 0BK 927 156 AG
   Component: 0BK 40TFSIUSA H16 1002
   Revision: --H16---
   ROD: EV_TCMALX51011.rod
   VCID: 77F66164CEE3A1F2E4-8022
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 E    HW: 4H0 907 379 E
   Component: ESP PREMIUM   H10 0352
   Coding: C4E5F30023A7CF00E200
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremi 005013
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 346C96689F158AEA01-8060
   Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 DD
   Component: BCM2 2.0      H34 0503
   Coding: 0DA72046000000000000
   VCID: 6ED84400B9B9E03A37-803A
   Serial number: 0213000330958001
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00000078228894
   Coding: C018320085047201010001010101112131313333283333
   VCID: 356AAB6C9C6F93E236-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 L    HW: 4H0 820 043 L
   Component: Klima 4 Zonen H20 0130
   Coding: 688122BE7C
   ASAM Dataset: EV_AirCondiFront 001050
   ROD: EV_AirCondiFront_001_AU64.rod
   VCID: 2952771C48D7C702A2-807C
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001490102
   Coding: 09076091037C9FE38B010904A0003800009CD3088E0001218001085C7B00
   VCID: 6FE65904BEB3E9323C-803A
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 130905  H36 0090
   Serial number:         130923111255
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10341739
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
   Component: E1 - LDS  H07 0044
   Serial number: 18 10 2013  00000215
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R85K003
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000016101300010431
   Coding: 100000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000021101300010088
   Coding: 100000
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA106971000004940572
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 82494EC6000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061329402375
   Coding: A80B0E
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71E25F7CA087FFC22A-8024
   Part No SW: 4H0 907 561 B    HW: 4H0 907 561
   Component: ACC3          H19 0410
   Coding: 7E01020101
   ASAM Dataset: EV_AdaptCruisContrAU64X 002021
   ROD: EV_AdaptCruisContrAU64X_002.rod
   VCID: 2A5088104DD1CC1AAB-807E
   Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
   Component: Airbag10.43   H45 0042
   Revision: --------    Serial number: 003JS001L8NH
   Coding: 303143303230303030314A55304C34483053
   VCID: 3776A1648E6361F224-8062
   Subsystem 1 - Part No SW: 4H0 959 339 A    HW: 4H0 959 339 A
   Component: BF-Gewichtss.  H03 0040
   Serial number: 5850000R13927095HP
   Serial number: 3575HRB405H23FC6AHVP
   Serial number: 3585HRB400650KMKAH6E
   Serial number: 3515JRB400O50N8EGPI-
   Serial number: 3525JRB400O50N8EC1C3
   Serial number: 3554VRB400450NI28P25
   Serial number: 3564VRB400250NI2HAA6
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 99999MJ80001E
   Coding: 0004BC
   VCID: 3874A2588B7D6E8A2D-806C
   Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
   Component: E221 - MFL  H09 0010
   Serial number: 04 07 2013  B1183829
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4H0 920 980 K    HW: 4H0 920 980 K
   Component: TBenUSAACC--- H50 0515
   Revision: 36081080    Serial number: 658091013592031
   Coding: 0346080157404F04020100
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K.rod
   VCID: 336E95749A1B8DD218-8066
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
   Component: Analoguhr D4  H05 0225
   Serial number: 2130930002169
   Part No SW: 4H0 907 468 AC    HW: 4H0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000001142423
   Coding: 00E5074800
   ASAM Dataset: EV_GatewPkoUDS 001018
   VCID: 72E05070A581C4DAD3-8026
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 50260515321911072262
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 13295003905011200410
   Part No SW: 8K0 857 511 G    HW: 8K0 857 511 G
   Component: FLA           H04 0020
   Revision: AB001001
   Coding: 04018B6B74745D545420363E00
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
   Component: Klima Fond    H16 0200
   Coding: 2000000000
   ASAM Dataset: EV_AirCondiHeck 002001
   ROD: EV_AirCondiHeck.rod
   VCID: 3874A258837D6E8A2D-806C
   Part No SW: 4H0 907 553 E    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H17 0099
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2E5884007139A03A77-807A
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000078234921
   Coding: C0183B0085057201010001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
   Component: SARA 6D       H03 0056
   Revision: --------    Serial number: EJ1BPA77017JUM
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Part No SW: 4H0 907 566 A    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0050
   Revision: 00H02000    Serial number: 6PZ 010 287-07
   Coding: 0000002
   VCID: 2E588400B939A03A77-807A
   Subsystem 1 - Part No: 4H0 907 568 A
   Component: J770  SWA Slave H02 0050
   Subsystem 2 - Serial number: 6PZ 010 287-27
   Subsystem 3 - Serial number: 5F11.10.1300H02000AMS16584ÿ
   Subsystem 4 - Serial number: S16584ÿ
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H06 0273
   Revision: --------    Serial number: 0000079094383
   Coding: 011F1F005E0062C202003017
   VCID: 4894D298FB9D1E0A5D-801C
   Revision: 00002001    Serial number: 0308354297
   Coding: 0106163A083A759FB230C784020301070000000000000000000000000000
   Shop #: WSC 06342 000 00000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0081
   Serial number: 00000000000000182798
   Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J245  007C  H06 0005
   Serial number: 341200007637
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 BR    HW: 4H0 947 135 BR
   Component: Dachelektroni  H13 0080
   Serial number: A2013000000000742591
   Coding: 070000
   Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J394  0014  H06 0005
   Serial number: 341200007586
   Coding: 020200
   Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J392  006A  H06 0005
   Serial number: 341200007651
   Coding: 020200
   Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J867  00E0  H06 0005
   Serial number: 341200007598
   Coding: 020200
   Subsystem 8 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93077473
   Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
   Component: BOSE-G3C7-ANC H02 0540
   Revision: CJ002700    Serial number: 00000000003632
   Coding: 030000
   VCID: 1C3C5EC81F8522AA29-8048
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H06 0273
   Revision: --------    Serial number: 0000079100532
   Coding: 011F1F005E0062C202003006
   VCID: 3C7CBE48BF4542AAC9-8068
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000839110
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B5E8D14422BD51250-807E
330240 - Function Restricted due to Missing Message(s)
          U1111 00 [000] - -
   Part No SW: 4H0 035 082 G    HW: 4H0 035 082
   Revision: AB001007    Serial number: 155J60D7574736
   Coding: 020007010000000001
   VCID: 254A7B2C2CCFE36286-8070
   Part No SW: 4H0 035 746 G    HW: 4H0 035 746 F
   Component: H-BNT-NA      H41 0757
   Revision: --------    Serial number: 183JW0D7515012
   Coding: 020200000001F9EF7D128B1E00000003140001000000000000
   VCID: 2C5C8E084F25D22A59-8078
   Subsystem 1 - Part No: 8R0 060 884 BL
   Component: NAR 2014  0902
   Subsystem 2 - Part No SW: 4H0 919 604 G    HW: 4H0 919 604 G
   Component: DU8 D4 SV NB  H48 0021
   Serial number: AUZ8ZDDC900TTNV
   Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000133843
   Component: CD-Database  5571
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H06 0276
   Revision: --------    Serial number: 0000078995642
   Coding: 010F1F00400062C202003006
   Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
   Component: TopView       H05 0220
   Revision: 11001001    Serial number: 82330JF0112534
   Coding: 020A000001010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
   ROD: EV_CamerSysteTopViewAUDI_007.rod
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 AB    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0043
   Revision: 10011001    Serial number: 275300561
   Coding: 0210044100
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6ED84400B1B9E03A37-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000126958
   Coding: 200000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 63CE25346A7B5D52A8-8036
   Component: TSG HR        H06 0276
   Revision: --------    Serial number: 0000078996028
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H08 0083
   Revision: 0L0D5015    Serial number: SN130922  0214
   ROD: EV_GSM2x3Mono.rod
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0038
   Coding: E9060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 26487C2059C9E87A8F-8072
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00013390202402
   Coding: 766FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2F6699047633A9327C-807A
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00013390204901
   Coding: 366FF2
   Part No SW: 4H0 907 541 B    HW: 4H0 907 541
   Component: ACC3          H19 0400
   Coding: 7E01020101
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
   ROD: EV_AdaptCruisContr2AU64X_002.rod
   VCID: 2854721853DDFE0ABD-807C
12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] -  -
                    Reset counter: 134
                    Mileage: 62821 km
                    Date: 2018.08.21
                    Time: 18:01:20
                    Control Module temperature: 27 °C
                    Voltage terminal 15: 14.144 V
                    Velocity_vehicle_reference: 19.42 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.40 m/s²
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H32 0041
   Serial number: 005000120210137
   Coding: 02A19A000111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 0066F609031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 31629F7C6007BFC26A-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 32609070650184DA13-8066
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H07 0008
   Revision: 00001001    Serial number: 97809002721200
   ROD: EV_AEMLearAU64X_AU64.rod
End-------------------------(Elapsed Time: 08:41)--------------------------
rlarsen
Copenhagen, Denmark
C?ID=78998
Can you post a channel map of unit 46 - channel 180 - 210 ??
Use security code: 16017
sieben
C?ID=34182
Hello Rene,
Thanks. I ran the channel map and two files were produced, but not ones that were readable as text - they are PLA and PLB files.
They correspond to files that a Ross Tech video instructs us to send to them.
Can't read them or attach them here.
What's next?
TBAx
C?ID=287144
You should set the output format to CSV for better reading.
Thanks guys. I replied to an email from the OP with the explanation (Open in Notepad and paste to forum) with a similar example thread.
sieben
C?ID=34182
this looks like the one
;SW:4H0-907-064-DD HW:4H0-907-064-DD --- Central Conv. --- SA: 16017
;Component:BCM2 2.0 H34 0503 Coding:0106023A00FA759FB0B0C784020301070000000000000000000000000000
;Monday 14 January 2019 20:52:17:12005
;VCDS Version: Release 18.9.0 (x64) Data version: 20181017 DS296.0
;VCID: 6ED84400B9B9E03A39-803A
180
181 65535
182 7
183 16383
184 7
185 65535
186 7
187 3072
188 0
189 3072
190 4
191 65535
192 3
193 6
194 7
195 134
196 166
197 6
198 38
199 43527
200 43559
201 43527
202 43559
203 9
204 41
205 13
206 45
207 0
208 32
209 51201
210 51233
211 51214
212 51215
213 20532
214 3
rlarsen
Copenhagen, Denmark
C?ID=78998
Your current channel mappings are:
195 = 134 = 0000 0000 1000 0110 = Left (Brake, Signal)
196 = 166 = 0000 0000 1010 0110 = Right (Brake, Signal)
197 = 6 = 0000 0000 0000 0110 = Left (Brake, Signal)
198 = 38 = 0000 0000 0010 0110 = Right (Brake, Signal)
199 = 43527 = 1010 1010 0000 0111 = Left (Tail, Brake, CH/LH, Signal)
200 = 43559 = 1010 1010 0010 0111 = Right (Tail, Brake, CH/LH, Signal)
201 = 43527 = 1010 1010 0000 0111 = Left (Tail, Brake, CH/LH, Signal)
202 = 43559 = 1010 1010 0010 0111 = Right (Tail, Brake, CH/LH, Signal)
203 = 9 = 0000 0000 0000 1001 = Left (Fog)
204 = 41 = 0000 0000 0010 1001 = Right (Fog)
205 = 13 = 0000 0000 0000 1101 = Left (Reverse)
206 = 45 = 0000 0000 0010 1101 = Right (Reverse)
207 = 0 = Not used
208 = 32 = Not used
209 = 51201 = Side marker
210 = 51233 = Side marker
One of the "groups" Channel 199, 200 or 201, 202 need to be changed to (this should be for the outer lights):
43528 = 1010 1010 0000 1000 = Left (Tail, Parking, Brake, CH/LH, Signal)
43560 = 1010 1010 0010 1000 = Right (Tail, Parking, Brake, CH/LH, Signal)
sieben
C?ID=34182
Wow, thanks. So will this take care of both the dynamic / amber tail signal and the Euro parking light functionality?
207 = 0 = Not used
208 = 32 = Not used
rlarsen
Copenhagen, Denmark
C?ID=78998
With this coding you'll only get the parking lights activated.
If you today doesn't have any light in the signal part of the tail, you need to do some rewirring, maybe you can use the unused pins, from the side marker (channel 209/210), which are not used on RoW tails. And if you get the yellow signal lights to work, you also need to recode Channel 195/196, 197/198, 199/200 and 201/201 to not have signal as the functionality - and of cause recode channel 209/210 to be signal.
Let us know what you end up doing - changing the channel value to fit your need is easy.
sieben
C?ID=34182
Finally got back to this:
199-200 are inner parking lights
201-202 are the "outer" parking lights, so I went with these
Everything else is working normally - running lights, 4-way flashers, turn signals, brake lights.
Even the normal "full" parking lights (inners and outers) work right when using the light switch (dial) in the "parking light" position.
Thanks!
Now in another 4-6 weeks when we thaw out, I'll look at the wiring for the dynamic turn signal!
Cheers
sieben
C?ID=34182
Might take the tail lights apart this or next weekend.
Question - which of the myriad "repair wires" is proper for rewiring the internals of the taillights?
ECS has about 10 choices...
https://www.ecstuning.com/Audi-A8-D4-4.0T/Search/SiteSearch/repair_wire/
Thanks again!
Thanks!
Cheers
According to PL24 the electrical connector housings are: 4H0 973 713 -and- 4H0 973 713 D. Here's a temp screen shot with your VIN obstructed by the part info box: https://media.trillian.im/media/?m=...zQfeyx/gMp5NKor08FVBXludHKu9a1FfdDK6wuP1K5w==
Please verify the actual part numbers on the black 6 pin connectors. Providing I chose wisely, 4H0 973 713 and 4H0 973 713 D will accept several possible repair wires. The smallest (.5 mm) gauge is 000979025E. The EA suffix (000979025EA) is gold plated and probably unnecessary for a tail light:
https://www.ecstuning.com/Audi-A8-D4-4.0T/Search/SiteSearch/000979025E/
I'd ring the VW and Audi local dealers because $23.65 per wire is crazy! That may be the list price for a bag of 5?
Scratch that earlier reply. I missed a very important detail:
Internal terminals aren't available in the parts catalog. The part numbers above are from the car harness to the tail light connectors.
