2015 Jetta TDI, service wrench display 10 seconds on cold start
Larry Manton
C?ID=112505
2015 Jetta TDI, factory refurbished .DSG
Bought this with 49,000 on the clock 62,000 now. Do oil myself but every morning wrench symbol shows on dash but is not a code IMO.
Don't know if there is a reset upon oil change ECT as did not see it addressed in manual. WRENCH goes away after 10 seconds, will post a scan if advised all good.
LARIMORE
Larry Manton
C?ID=112505
No I did not but will..
Just googled it and there were 5 video, all 5 did it 5 different ways, guess there is many roads to Rome.
But did note going to settings seems to be the correct way, will do that and see.
As with most things learn it when confronted with a problem, but thanks and will GET it done and post back, seems pretty straight forward but I usually can make it hard.
LARIMORE
Where's the Auto-Scan, Larimore? ;)
Larry Manton
C?ID=112505
                Address 01: Engine  (04L 906 016 AK)
07:47:27
  IDE00019   Voltage terminal 30 12.080 V
  IDE00432   Particle filter: time since last regeneration 2541 s
  IDE00433   Particle filter: oil ash volume 0.05 l
  IDE00434   Particle filter: soot mass calculated 7.42 g
  IDE00435   Particle filter: soot mass measured -3.49 g
  IDE00436   Particle filter: kilometers since last regeneration 34091 m
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 04 05 08 09 15 17 19 25 2B 2E 44 56 75 77
VIN: 3VWLA7AJ8FM329803   Mileage: 100290km-62317miles
Address 01: Engine (J623-CVCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 AK    HW: 04L 907 309 K
   Component: R4 2.0l TDI   H20 9287
   Revision: 8AH20---
   Coding: 011D0012042410085000
   Shop #: WSC 00004 444 00000
   ASAM Dataset: EV_ECM20TDI01104L906016AK 004012
   ROD: EV_ECM20TDI01104L906016AK_004.rod
   VCID: 72E0C0F8A5A99BDAD3-8026
9647 - Reductant Injector Valve (Bank 1)
          P208E 00 [096] - Stuck Closed
17262 - Terminal 30
          U140A 00 [032] - Open Circuit
4629 - ECM Power Relay Load Circuit
          P068A 00 [032] - Opens Too Early
7934 - Turbocharger Boost Control Position Sensor Circuit
          P2563 00 [096] - Implausible Signal
   Part No SW: 02E 300 061 T    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4517
   Revision: 05653104    Serial number: 00001412300455
   Shop #: WSC 44551 111 44551
   VCID: 254AEBA4ECE7BC6286-8070
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -  - Intermittent
                    Reset counter: 24
                    Mileage: 99817 km
                    Date: 2018.12.02
                    Time: 08:46:54
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: A14B400C49240003851302E4921C0042A1100012
   Shop #: WSC 00066 000 00000
   VCID: 040C9620871DA56AF1-8050
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0357065492
   Coding: 000F0F
   Shop #: WSC 00066 000 00147
   ROD: EV_KESSYPQ35G_A02_VW36.rod
   VCID: 377631EC8E4B3EF224-8062
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 CG    HW: 5C0 820 047 CG
   Component: J301  Klimaanlage   0208
   Revision: 2001001S    Serial number: 00000002631904
   Shop #: WSC 00066 790 00184
   VCID: 67D6A1AC566B6E7274-8032
   Part No SW: 7H0 937 090 E    HW: 7H0 937 090 A
   Component: BCM PQ25 Max3 H78 0725
   Revision: B8078001    Serial number: 78003079150560
   Coding: 7B994B9A08AB0B0008382080240884C50F86702E60000050B0A050022844
   VCID: 30640AF06325E9CA65-8064
   Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 5461
   Serial number: 14102585150305110055
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 5461
   Serial number: 14102584150306080711
   Coding: 820000
   Subsystem 3 - Part No: 5K0 959 591 A
   Component: J245 PS41.402  H02 0003
   Serial number: 0000FST0002S3JG00000
   Coding: 180000
   Subsystem 4 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
   Component: E221__MFL-TAT  H04 0019
   Serial number: 0681515041501443AD1B
   Coding: 280000
   Subsystem 5 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
   Component: J388__TSG_HL  006 5460
   Serial number: 14202587150304154036
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Component: J389__TSG_HR  006 5460
   Serial number: 14202586150309084504
   Coding: 800000
   Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
   Component: AirbagVW10    500 0975
   Serial number: 003LZD0633ZX
   Coding: 00004B33
   ASAM Dataset: EV_AirbaVW10SMEVW360 001030
   ROD: EV_AirbaVW10SMEVW360.rod
   Serial number: IBH0000J150002FHLL0I
   Coding: 303146
   Serial number: 3572MSME6C685D4DZZZH
   Serial number: 3582MSME4F685D4DZZZJ
   Serial number: 3516KSME377A2935ZZZZ
   Serial number: 3526KSME200B7A34ZZZR
   Serial number: 3556LSME51141332ZZZE
   Serial number: 3566LSME4D021332ZZZN
   Part No SW: 5C6 920 954 A    HW: 5C6 920 954 A
   Component: KOMBI         H04 0807
   Coding: 270A01
   Shop #: WSC 00066 000 00119
   VCID: 2C5C1E80470D8D2A59-8078
   Part No SW: 6N0 909 901     HW: 7H0 937 090 A
   Component: GW-K-CAN TP20 H78 0725
   Revision: B8078001
   Coding: 102200
   VCID: 70E4CAF0A3A5A9CA25-8024
   Component: IMMO          H04 0807
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD0D8988D79531A6B-803E
   Revision: 00000000    Serial number: 15000030232005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 30640AF06B25E9CA65-8064
Address 2E: Media Player 3
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 306    3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 397237D4705F2882D2-806C
   Part No SW: 1K0 035 188 H    HW: 1K0 035 188 H
   Component: Radio Prem-8  H08 0009
   Revision: -----13S    Serial number: VWZ4Z7R3684839
   Coding: 01000440020006
   VCID: 2D5A1384741784224E-8078
            000 -  -
                    Fault Frequency: 11
                    Reset counter: 180
                    Mileage: 84231 km
                    Date: 2018.01.06
                    Time: 22:05:12
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0156
   Serial number: 000003554140535
   Coding: 02630102C21632007F1606000000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_OCULow 002009
   ROD: EV_OCULow_002.rod
   VCID: 142CA660FF7D35EA61-8040
13635840 - Supply voltage
                    Mileage: 93476 km
                    Date: 2018.06.29
                    Time: 15:10:39
          U1400 00 [008] - -
                    Date: 2018.06.29
                    Time: 01:56:31
   Part No SW: 5N0 035 729 E    HW: 5N0 035 729 E
   Component: TELEFON       H07 0593
   Revision: 1B001001    Serial number: 00007670054252
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 326000F86529DBDA13-8066
End-------------------------(Elapsed Time: 03:24)--------------------------
                Address 01: Engine       Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 906 016 AK    HW: 04L 907 309 K
  Component and/or Version: R4 2.0l TDI   H20 9287
           Software Coding: 011D0012042410085000
            Work Shop Code: WSC 00004 444 00000
              ASAM Dataset: EV_ECM20TDI01104L906016AK 004012 (VW36)
17262 - Terminal 30
Address 01: DTCs cleared
                Address 01: Engine
Advanced Identification/FAZIT
     Identification: ZSC-864
     Revision: 8AH20---
     Date: 17.03.15
     Manufacturer number: 7824
     Test stand number: 0037
Flash Status
     Programming Attempts(application): 1/2/2/2/3
     Successful Attempts(application): 1/2/2/2/3
     Flash Date: 15.03.26
Misc.
     Hardware number: 04L 907 309 K
     Workshop System Name: J623
     ASAM Dataset Revision: 004012
Car Info
     Chassis Number: 3VWLA7AJ8FM329803
     Engine code: CVCA
VCDS Info:
       Readiness: No script available
VCDS Release 18.9.0:  SRI Reset-SRI1.CLB
Control Module Part Number: 5C6 920 954 A       Labels:  .*5K0-920-xxx-17.clb-SRI1
Component:KOMBI         H04 0807, Coding:270A01
Channel        Description                                                 	Current val.                                                	New val.
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                	Reset                                                       	---
IDE00510-ESI: distance driven from inspection                                                       	ESI: Distance since Inspection                              	0 km                                                        	---
IDE00511-ESI: time from inspection        ESI: Time since Inspection                                  	0 d                                                         	---
IDE00515-ESI: oil quality        ESI: Oil Quality                                            	poor oil quality                                            	---
IDE00517-ESI: soot entry        ESI: Soot Quantity                                          	0 km                                                        	---
IDE00518-ESI: thermal load        ESI: Thermal Load                                           	0 km                                                        	---
IDE01153-SIA: maximum value of distance to service                                                  	SIA: Maximum Distance to Service                            	16100 km                                                    	---
IDE01154-SIA: maximum value of time to service                                                      	SIA: Maximum Time to Service                                	372 d                                                       	---
IDE03349-FIX: Max. distance until next mileage-related inspection                                   	FIX: Maximum Distance to Inspection                         	32200 km                                                    	---
IDE03350-FIX: Maximum time until next time-dependent inspection                                     	FIX: Maximum Time to Inspection                             	730 d                                                       	---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                              	FIX: Distance since Inspection                              	36000 km                                                    	---
IDE03352-FIX: Time since last time-dependent inspection                                             	FIX: Time since Inspection                                  	713 d                                                       	---
Okay sorry for the lack of info, thought this would be as simple as re setting the gas milage log, but me and computers never get along.
That said SRI has several entries but only high lights (Save to Log) the perform SRI is not highlighted, but (dONE GO BACK IS. When I click on any of the resets it will not allow me to write in new information, I seems to me but have darn sure been wrong before. Then not in info Dave posted some units don't respond typically and even clicked on the North America thing and other with same response.
All said the SRI is more of an irritation than a problem, but noted faults that interest me, and one of the main ones is the level of soot which I need som tutoring on as those numbers mean nothing to me as to good bad or indifferent.
This Item was addressed by dealer 7,000 miles ago and don't know if it has reappeared or what, but was a plug under seat unplugged during detailing. I have since this scan cleared all codes to see if it raises it head again as is on warranty.
17262 - Terminal 30
Battery puked about 2 months ago and might be the issue here, again will see what comes up later.
This one does not mean JACK to me, no offense to some viewers, might shed some light on it, not too worried till I am.
This one again, never feel it if it is.
LONG AND SHORT IS THIS CAR HAS NO CODES ON DASH, AND RUNS STELLAR, just wanted to get the wrench off the dash.
Anyway, sorry for not posting a scan, thought is would be easier, ALL GOOD, got great tutors.
Almost 400 posts and I still have to do the CODE tags for you? :rolleyes:
The problem is fairly obvious:
IDE03349-FIX: Max. distance until next mileage-related inspection 32200 km
IDE03350-FIX: Maximum time until next time-dependent inspection 730 d
IDE03351-FIX: Distance covered since last mileage-dependent inspection 36000 km
IDE03352-FIX: Time since last time-dependent inspection 713 d
IDE03351 is greater than IDE03349.
Start VCDS.
Click [SRI Reset].
From the drop-down, select the second option (both ESI and FIX). <- I think you've been missing this step. ;)
Then click [Perform SRI].
NostraJackAss
Larrymore
What does 0x33 OBD2 mode say for codes sir and mode nine data too?
Please post......
Larry Manton
C?ID=112505
Start VCDS.
Click [SRI Reset].
UWE, In my life I have missed a lot of steps, getting used to it. Will try and get back in today and give it a whirl.
All my previous VAG projects involved older cars so have never fully utilized the total power of this unit, still learning.
Was some smart SOB designed this 4 sure, but again, have been wrong before if you know what I mean.
LARIMORE
Larry Manton
C?ID=112505
Jack, will look at it again today, as know sometimes you go to the OBD 2 part, and can't quite remember the logic for it but will do as ordered.
All this said, what do you make of the ash numbers on the DPF?, or do I need a secret decoder ring for that?
LARIMORE
Larry Manton
C?ID=112505
Okay, here is the last scan although not asked for, and seems I was able to get rid of some other history which I thought VW would have addressed at the time of the issue it was in for, guess I'm asking too much. Gone are the 4 codes which were most troubling and all that is left is No commo from cruise and a tuner issue. Don't know what to say as both work just fine, but maybe some advice in that direction would be nice.
Okay, The SRI was able to clear the first six to a numeral of 0, also the last 2, but (max distance to service, Max time to svs, max to inspection, distance to inspection, would have thought I could over ride those number and write in my own but not. Picture override said appears to be unitialized control module valid wsc/importer data may be required. That said I got the others reset and wrench is gone, still learning here.
Okay as per Jacks request went to OBD2 was not sure of the request of 0 03 but copied mode 9 if that helps. All said there were no codes in any of the brackets of OBD2, and interesting enough I use Mode 6 in domestic but don't see it here.
Having PC issues here as will not allow me to paste any logs in this reply box, will open another on below and see if I can get it done, both OBD2 mode 9 and mode 3, also logs form new scan.
Larimore.
Larry Manton
C?ID=112505
Okay, again all my fault, too much copy and paste early in the morning, BUT WAIT!!!!. I'll blame it on JACK, no one will ever know, thats it, was JACKS FAULT, works for me.
Mode 3 and 9 at the bottom, and apologize as Jack asked for 0 03, was not sure what that meant again, maybe he can varify, if not can get some more stuff.
Larimore
Monday,10,December,2018,15:41:29:01722
VCDS Version: 18.9.0.2 (x64)
VIN: 3VWLA7AJ8FM329803   License Plate:
Mileage: 100340km-62348mi   Repair Order:
VIN: 3VWLA7AJ8FM329803   Mileage: 100340km-62348miles
   Revision: 8AH20---
                    Reset counter: 20
                    Mileage: 99817 km
                    Date: 2018.12.02
                    Time: 08:46:54
   Revision: 00H46001
   Coding: 000F0F
   Coding: 820000
   Coding: 820000
   Coding: 180000
   Coding: 280000
   Coding: 800000
   Coding: 800000
   Coding: 00004B33
   Coding: 303146
   Coding: 270A01
   Revision: B8078001
   Coding: 102200
   Coding: 000007
   Revision: 00H22000
            000 -  -
                    Fault Frequency: 11
                    Reset counter: 180
                    Mileage: 84231 km
                    Date: 2018.01.06
                    Time: 22:05:12
   ROD: EV_UHVUMI.rod
End-------------------------(Elapsed Time: 03:39)--------------------------
Mode 03: Emission related fault codes
Address 7E8: No fault code found.
Address 7E9: No fault code found.
Address 7E9: No fault code found.Monday,10,December,2018,15:02:36:01722
Type 02 - VIN : 3VWLA7AJ8FM329803 (Address E8)
Type 04 - Calibration ID :  (Address E8)
Type 04 - Calibration ID : 02E (Address E9)
Type 06 - Calibration Verification Number : DF25D31B (Address E8)
Type 06 - Calibration Verification Number : 38D3FF82 (Address E8)
Type 06 - Calibration Verification Number : 00005751 (Address E9)
Type 0A - Controller Name : ECM-EngineContro (Address E8)
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
Type 0B - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 720
    Ignition cycle count : 1903
         NMHC Catalyst : 127 / 90
         NOx/SCR Catalyst : 129 / 712
         NOx Adsorber : 0 / 0
         PM Filter : 655 / 28
         Exhaust Gas Sensor : 270 / 720
         EGR and/or VVT : 184 / 720
         Boost Pressure : 113 / 720
         Fuel : 113 / 720
NostraJackAss
Fuel : 113 / 720
Larrymore
Very Interesting.............?
So whats wrong with distance sensor?
Is car modified in any way?
Larry Manton
C?ID=112505
Larrymore
So whats wrong with distance sensor?????
JACK, your scaring me, like, asking me what is wrong with it???,LOL.
Have no idea as like said everything works perfect, and when we say distance sensor need to define exactly what that is. Milage, speed, not sure. All I know is everything to my knowledge works fine other than has a code here.
As far as modified I have no idea?, as bought it off a VW lot here and know no more other than that. Like stated had the Add blue issue a few months in which they accessed as an unplug to that heater under the seat and other than that no issues.
As a side note the Add Blue Heater code was troubling for me as far as trusting anybody wrenching on ones car. Dealer ship called VW corporate and wanted to replace the whole module, VW, said wait a minute???? how about a little more time under the hood before we drop 1000.00, (guessing here.) Well as it turned out now that they were forced to research a little it was unplugged under the passengers seat, ALL GOOD.
My point being if this had been a general guy would have been billed for the module, then when it was not working they would have then done some more work and found it was just wiring. In the end IMO, would have been well NEEDED IT ANYWAY, and nobody any wiser, all this JMO, but not far from the truth.
Also most the codes were still in there which I thought they would have cleaned that up on exit.
LARIMORE
Eric
HC800000
Just putting in my 2c here, on our 2016 NMS with similar enough cluster, the wrench was caused by DTCs in the TCM, which you have. Point of origin seemed easy to me as it shows in place of the gear display.
NostraJackAss
LARIMORE
Larrymore you should know I am collecting data as always first to surmise to help, so when was this aforementioned work procedure performed?
Would you be so kind and make a screen shot of Mode 9 data?
Larry Manton
C?ID=112505
Jack, the work on the add blue douser, was about 5,000 miles ago but will get the paper work out for specifics. I am still learning this system but surmise the heater failure in the unit has to do with not allowing it to freeze as read somewhere it boils and freeze at minimal levels that make it somewhat problematic in both extremes.
Also you asked for mode 9 screen shot, thought that is what I captured at the bottom of the post, but can do again if need be.
Don't have ERWIN info yet and need to get it. Might look at that sensor via PICO and see if I seem issues with it.
Would have bought a stick but wife's back is bad, so is what it is. You said don't buy DSG unless you like being a whipping boy, guess I be it, just have to suck it up and deal with it. Actually I dig the way it works. Like the beautiful blond on the poster, caption under says, SOMBODY SOMEWHERE IS SICK OF HER SHIT, right now I liken the DSG, but was told, so no whining from me if it happens.
All said I really like this car, like the way it pulls but having to relearn driving. Sucker does better at 80 than 60, just not legal here much. Is the definition of Italian tune up.
LARIMORE
NostraJackAss
I'd like to see a screen shot if possible please.
Control/ALT/print screen and save to paint as PNG, then post it.
Thank you
I'm really surprised no one came up with an external strainer and cooler/pump for all the VAG auto-gear boxes and marketed it as a kit.
As always heat is the enemy............
Larry Manton
C?ID=112505
Thank you
Will go in in a day or two and get it for you. Also for posting here does your site see it needed as a PNG, and not a JPEG?, sure can do.
When I say what they fixed, this is it, the reductant heater and was mistaken how long ago as time flies when having fun. Also this happened at 52,000 miles and was last Jan, almost a year. The error was as stated not a malfunction but somebody disconnected wiring which was under the seat.
Also, another question?, did not see it under data, but maybe there and I missed it. Does the ADD BLUE show up anywhere denoting it's level or is this just a crap shoot. Seen where it shows oil level and also, how does it know oil level, is there a sensor there much like coolant in the bottle, just asking as it was pretty specific on where the low is and where mine is.
Larimore.
NostraJackAss
Larimore.
So some prior FOD by "someone"?
Did you read SSP yet?
17262 - Terminal 30
So with the NOX urea injector unplugged it registered as the faults above & no others?
Either will work.
The PNG format is generally better for screen-shots. It uses lossless compression that will display an image as sharp as the original and usually produces a smaller file than JPG for images with a small number of colors (like screen-shots). A JPG can be used for screen-shots but the image probably won't be as sharp and the file size will likely be larger.
A JPG is generally better for actual photos. PNG will also work, but because real photos have a large color gamut, a PNG file's lossless compression will usually make for much larger files than JPG.
So the general rule of thumb is: Photo: JPG. Screen-shot: PNG.
