Do you remember that I have BOSCH sensors system? I've hear that they are not supported by Valeo modules. This is way I can't do re-pin.If you want to do a demo installation, you would need to re-pin the PDC module connectors from old two small connectors to the new two large connector setup. This harness saves you from having the real hassle of re-pinning to the new connectors]
Guess I didn't remember.Do you remember that I have BOSCH sensors system? I've hear that they are not supported by Valeo modules. This is way I can't do re-pin.
I got Skoda yeti module fI rrom radio seller. It should work with Discover Media. I do not have sensors and harness, but I would build demo currently on this: https://1drv.ms/i/s!AuwAeVEhNnQxgbQb4p-gozBJ6Kz4zA .
So I repeat question - do I have to add additional wires connection from some other modules (BCM, Gateway, 5F or other) to this module?
Here is view from camera installed on bumper https://1drv.ms/i/s!AuwAeVEhNnQxgbQcuT3OIIXo4v_jnw . The camera and holder are from Seat ibiza, but holder is the same as with Bentley logo. Am I able to calibrate camera to show license plate less?
I see on ETKA online that Yeti 2016 group 9, subgroup 919-051 has 6 sensors (4 inner, 2 outer) so the question is if for sure my Skoda 5J0919475C/5J0919475A module support only or at least 4 sensors?5J0919475C should be good for you. According to ETKA, its used from the same time as Škoda's Discover Media PQ 5L0035680 on the Yeti.
I'm not sure about this but perhaps its time look at brochures and pricelists for the Yeti. They should shed light on what equipment was available for the model.I see on ETKA online that Yeti 2016 group 9, subgroup 919-051 has 6 sensors (4 inner, 2 outer) so the question is if for sure my Skoda 5J0919475C/5J0919475A module support only or at least 4 sensors?
I am also looking for information on how to do it - I have passat b7 pdc 1k8 919 472 c and it doesn't work for me either. I found in the network that the sensors should be 5Q0919275 B but I do not know if it is truth because no one has confirmed it.Hello. Does anybody know if I can configure PDC module to keep active parking aid system for a few seconds when forward gear is engaged? In my previous/factory module (Bosch) parking aid was active for a few seconds if the obstacle was detected and I engaged forward gear.
I am not able to help you with this problem. I don't have PDC button in my car, but I would like to ask you about clock and time displayed on the Discover Media? Do you see a correct time on Discover Media?I am also looking for information on how to do it - I have passat b7 pdc 1k8 919 472 c and it doesn't work for me either. I found in the network that the sensors should be 5Q0919275 B but I do not know if it is truth because no one has confirmed it.
Nothing on the subject in PDC adaptations.
I still have a problem with discover media and RVC camera - when I attach reverse gear, I see a camera with lines and a car with PDC sensors. If I press the PDC button, instead of showing the car with sensors, it shows me the lines from the camera. Somewhere something supposedly in the 5F adaptations need to be changed but I don't know what.
Maybe someone solved such a problem
This seem like it's a cluster software issue. The DM get's it's time from the instrument cluster over CAN.I am not able to help you with this problem. I don't have PDC button in my car, but I would like to ask you about clock and time displayed on the Discover Media? Do you see a correct time on Discover Media?
