2018 Golf tdi
ecu tech
Australia
C?ID=340390
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 3C 42 44 47 4B 52
          5F A5 D6 D7
VIN: WVWZZZAUZJW285135   Mileage: 515km-320miles
Address 01: Engine (J623-DCYA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 RJ    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H24 4381
   Revision: B5H24---
   Coding: 01250032046405083000
   ASAM Dataset: EV_ECM20TDI01104L906026RJ 004001
   ROD: EV_ECM20TDI01104L906026RH.rod
   VCID: 035373D86B9E9ECF837-8056
   Part No SW: 0GC 300 042 G    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1404
   Revision: 00H06V07
   ROD: EV_TCMDQ381061.rod
   VCID: 2A0DFE7CAC74AF87E01-807E
   Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
   Component: ESC           H25 0523
   Revision: 00000000    Serial number: 61598000001649
   Coding: 01FA8AA1242809714778060360C82980512490E26006947338625038C2A2430B00000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0482371069
   Coding: 032C0C
   VCID: 3C21C82456E0213782D-8068
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0012011420010000110500001210142A
   VCID: 6D8735605D1A78BF453-8038
   Air quality sensor:
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 8114012401ÿÿÿÿ
   ROD: EV_BCMBOSCH_018.rod
   VCID: 084964F452B8BD97D65-805C
   Component: WWS    180306  042 0551
   Serial number:         180312055033
   Component: RLHS  052 0107
   Serial number: SBY18M06D11H17M12S14
   Coding: 00A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H04 0005
   Serial number: 0000FST0022YL5S00000
   Coding: 181901
   Part No SW: 5QA 919 298 F    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0453
   Serial number: 000308417618151
   Coding: 0371167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   VCID: 53F38398DB7ECE4F737-8006
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 330067C15DFFC728949C810580400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E25C22C40FC3327AC9-806A
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR48VE2N
   Coding: 98CCC000000000005C000000008800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 094F61F049B2C49FC9B-805C
   Belt Pretensioner left:
   Serial number: 34169677E06061820794
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676E06061830889
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 706 18
   Serial number: 35700000000A61A07E2M
   Subsystem 4 - Part No SW: -----------    HW: 480 000 706 18
   Serial number: 35800000000E609C0E2U
   Subsystem 5 - Part No SW: -----------    HW: 480 400 406 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A929F25E2E31A
   Subsystem 6 - Part No SW: -----------    HW: 480 401 206 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001AB29F25E4A72G
   Subsystem 7 - Part No SW: -----------    HW: 480 400 506 18
   Serial number: 3550001162AEB0E2C58D
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 01061804400952
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_VW37.rod
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         409 3197
   Coding: 27A401186F88000801886B0B5401000080000000
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0008050927
   Coding: 030100345F086800FB00025C1C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW37.rod
   VCID: 3829D43462D80D17665-806C
   Component: E221__MFL-DC1  H17 0040
   Serial number: 39180000897230038206
   Coding: 2CFFFF
   Serial number: 6684538004
   Revision: 00000000    Serial number: 18000185865009
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3431E0047EB0E9774AD-8060
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006RF524740
   Coding: 0014000000000500018280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3D27C5204DFA283FB53-8068
   Serial number: 0482545805
   Coding: 02011203
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0482812418
   Coding: 020112
   Serial number: 250518EEO19061
   Coding: 003B1320D201048000001000
   VCID: 43D3B3D82B1E5ECFC37-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Serial number: 00000000000021931014
   Coding: 0D0000
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 93170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B323183B3EAE4F937-8026
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1JMD02FQ9X
   Coding: 12000000008AAA8A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI.rod
   VCID: 2E05F26C909CC3A73C9-807A
   Serial number: 28051810520665
   Coding: 000000070100164E00000101020000000000000000000000000000000000
   VCID: 72BD261C4424A747981-8026
   Serial number: 230418EDM08014
   Coding: 003B1120DE01048000801000
   VCID: 42DDB6DC340457C7C81-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Serial number: 00000000000021903930
   Coding: 150000
   Part No SW: 5NA 035 045 B    HW: 5NA 035 045
   Component: MU-H-N-RW     H54 1161
   Serial number: A849F0JS026848
   Coding: 027310080000000051510002000808001F0100F601200402DF
   VCID: 372BD7086FC6026F6FF-8062
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H52 9130
   Serial number: VWZ6ZJV1625672
   Subsystem 2 - Part No SW: V03 959 801 ED    HW: -----------
   Component: ROW 2017/2018  --- 0065
   Compact Disc Database:
   Component: Gracenote2  --- 4012
1637 - Interface for External Media
          U11B8 00 [008] - No Communications
          [USB - communication error]
                    Reset counter: 45
                    Mileage: 119 km
                    Date: 2018.12.01
                    Time: 11:37:57
                    Voltage terminal 30: 15.0 V
                    Interface for external media: status-Status: Open circuit
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0272
   Serial number: 02051812K11430
   Coding: 000307000000010100022354C150A90088000E200020
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: 7EA5022C007CF327EC9-802A
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW37.rod
End----------(Elapsed Time: 01:53, VBatt start/end: 12.2V/12.2V)-----------
darkchina811
ITALY
C?ID=333184
could I ask you for an admap of module 10? thank you!
darkchina811
ITALY
C?ID=333184
no need for it anymore :P
Nuje
Canada
C?ID=120875
Could you post an admap for module 17 - Instruments?
I retrofitted the Active Info Display into my 2015, and I'm not sure the tank calibration is correct - curious as to what "tank version" is used (and a couple other settings - like what the default "Tube_Version" is).
