Highline cecm update in vw caddy 2005
hedge23
C?ID=39726
Hi,
I've upgraded my ccem from mid line (1k0 959 433 AR) to highline 1k0 959 433 AR (I also tried CB) I can’t get the rear door to lock as part of the central locking.
The old module (AK) had setting called “central locking (fond) 1-motor lock installed” I can’t find this setting in the new module just lots of blank sections where you would think the option might be.
these are the working settings in the mid line module
the left and right sliding door options options enabled the side doors to work the "1 lock motor" option stops the side doors locking but still not the back
any help would be very much appreciated
Monday,12,November,2018,17:42:51:53240
VCDS Version: 18.9.0.2 (x64)
VIN: WV1ZZZ2KZ5X034847   License Plate:
Mileage: 266960km-165881mi   Repair Order:
Chassis Type: 2K (1K0)
VIN: WV1ZZZ2KZ5X034847   Mileage: 266960km-165881miles
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 016 DM    HW: 028 101 188 2
   Component: R4 1,9L EDC G240SG  6045
   Revision: 12345678    Serial number: VWZ7Z0D0542292
   Coding: 0050071
   Shop #: WSC 66565 257 00032
   VCID: 71E23E096866E2C22A-8024
17978 - Engine Start Blocked by Immobilizer
            P1570 - 000 -  - Intermittent
                    Torque: 0.0 Nm
                    Voltage: 12.16 V
                    Bin. Bits: 00001100
                    Bin. Bits: 11000000
                    (no units): 1.0
Readiness: 0 0 0 0 X
   Part No: 2K0 907 379 A
   Coding: 0017106
   Shop #: WSC 35110 377 08192
   VCID: 3162FE09A8E6A2C26A-8064
   Part No SW: 1K0 820 047 HB    HW: 1K0 820 047 HB
   Component: Climatic PQ35   141 1010
   Revision: 00141028    Serial number: 00000000000000
   VCID: 6BDE2C614A4A081210-803E
   Part No SW: 1K0 937 049 S    HW: 1K0 937 049 S*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00H30000    Serial number: 00000001078549
   Coding: A8004A0200041000010C00006400000000
   VCID: 3F86A8316EB244B2EC-806A
   Subsystem 1 - Part No: 2K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW357  012  0402
   Coding: 00063445
   Shop #: WSC 35110
01064 - Terminal 58d; Interior Dimming
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 09 AIRBAG VW52  023 2400
   Revision: 04023000    Serial number: 0037TD04MK9L
   Coding: 0012345
   Shop #: WSC 35110 377 00155
   VCID: 7DFA1239243E96A2BE-8028
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 012 0030
   Coding: 0000041
   Shop #: WSC 01324 785 00200
   VCID: 3064FB0DA3ECABCA65-8064
   Part No SW: 1K0 920 974 B    HW: 1K0 920 974 B
   Component: KOMBIINSTRUMENT VDD 2416
   Revision: V0002000    Serial number: VWZ7Z0D0542292
   Coding: 0016403
   Shop #: WSC 65536 011 170213
   VCID: 2D5AE279B4DEC6224E-8078
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 270010483003C1
   Coding: 3D0F0340077401
   VCID: 295216698036DA02A2-807C
   Component: IMMO            VDD 2416
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 281682 km
                    Time: 13:33:11
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1T0 959 701
   Component: Tuersteuergeraet 09 0158
   Coding: 0000116
   VCID: 74EC371D1774D7EAC1-8020
00120 - Outside Warning Light/Door exit Light Driver Side
   Part No: 1K2 909 144 G
   Component: EPS_ZFLS Kl.8       1301
   Part No SW: 1K0 959 433 AR    HW: 1K0 959 433 AR
   Component: 01 KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 988A843851034C7F0004050D30005A0A30B440
   Shop #: WSC 00000 785 00200
   VCID: 00046BCD53CCFB4AD5-8054
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1T0 959 702
   Coding: 0000116
   VCID: 75EA0A191C0ECEE2F6-8020
Address 56: Radio
End-------------------------(Elapsed Time: 01:26)--------------------------
downtime
Finland
C?ID=280813
Are you sure highline CCM is supported with midline CECM module? Your CECM module (09) is still midline.
hedge23
C?ID=39726
Hi thanks for the reply, thats a good shout, but I've managed to get it working!
hedge23
C?ID=39726
I did it! with help from Dana@ross-tech.
here are the settings you need to get the rear doors to lock (the labels are custom provided by Dana and should be in the next vcds release)
note this is on a 2005 caddy but I can't see see why it wouldn't work on a 2006 +(can't remember when the cross over was and not sure about facelift) but you will need a later highline module like a 1k0 959 433 BT
when installing screenshot your old settings but use these on the doors
its bytes 4 and 7 only (if you can't see the labels)
no options ticked
bytes 2, 4, 5 (if you only have a single door untick 4 or 5)
bytes 2 only
if you have used a module from a car the first two bytes might be clicked and those I think stop the rear door locking
no bytes
its amazing how many boot options there are!!!
the rest are the same as your old module
