VW Touran DSG problem with changing gear
daniel.b
Europe
C?ID=318819
Hey,
I have a problem with the DSG 7 gearbox in the car VW Touran 1.4 TSI 2014r.
The chest does not choose the 7th gear. The 7th gear can be manually shifted, but when the transmission goes to the drive, the gear is reduced to 6.
Gears are changed to 6 fluently, without jerks, etc.
Any ideas what could be wrong?
Thursday,29,November,2018,19:26:24:07292
VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4441.4
VIN: WVGZZZ1TZFW029312   License Plate:
Chassis Type: 1T-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 2E 37 42 44 46 52 55 56
          61 62 72 77 A5
VIN: WVGZZZ1TZFW029312   Mileage: 122380km-76043miles
Address 01: Engine (J623-CTHB)       Labels:. 03C-907-309-V1.clb
   Part No SW: 03C 906 026 N    HW: 03C 907 309 Q
   Component: 1.4l R4 TSI   H02 3727
   Revision: LMH02---    Serial number: 00000000000000
   Coding: 00250012002400000000
   ASAM Dataset: EV_ECM14TSI01103C906026N 001003
   ROD: EV_ECM14TSI01103C906026AG.rod
   VCID: AB1658FEC219CC12D0-80FE
Readiness: 0000 0101
   Part No SW: 0AM 300 063 T    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 5208
   Revision: 00043014    Serial number: CU501409266603
   Shop #: WSC 66565 257 00032
   VCID: BE3061AAE96B49BA67-80EA
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: 323B601621240E034C0E06E5841B7040A1000021
   VCID: FEB0A1AA69EB89BA27-80AA
   Part No SW: 3AA 907 044 BS    HW: 3AA 907 044 BS
   Component: Climatronic   H05 0607
   Revision: 00001K02
   Coding: 001000C002
   VCID: 8248D55A1513ED5A43-80D6
   Part No SW: 5K0 937 087 AB    HW: 5K0 937 087 AB
   Component: BCM PQ35 H    122 0174
   Revision: BE122001
   Coding: 60180A3880251AE4408800C8540011644BD59008726DA520E48042000048
   VCID: F5A2BE865CDDCAE276-80A0
   Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 30091  26  0512
   Coding: 009795
   Component: RLS 151014 05  54  0403
   Coding: 0230ED
00924 - Relay for Headlamp Cleaning System (J39)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 3
                    Mileage: 122375 km
                    Date: 2018.11.29
                    Time: 02:43:49
                    Voltage: 11.80 V
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 5N0 919 475 D    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0045
   Revision: --------    Serial number: 32901428001791
   Coding: 308101
   ASAM Dataset: EV_EPHVA14VW3680000 001005
   ROD: EV_EPHVA14VW3680000.rod
   VCID: BA386DBA3D43659A5B-80EE
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 E    HW: 1T0 909 605 E
   Component: 02 AIRBAG VW8   022 0100
   Revision: 02022000    Serial number: 003K4D0DC5G0
   Coding: 0012338
   VCID: B73E748EC65178F2A4-80E2
   Subsystem 1 - Serial number: 6332QSME6F46547AW
   Subsystem 2 - Serial number: 6342QSME6F462C7E%
   Subsystem 3 - Serial number: 6352QSME5E451272H
   Subsystem 4 - Serial number: 6362QSME6045357EM
   Part No SW: 5K0 953 501 CS    HW: 5K0 953 569 AL
   Revision: FF010042    Serial number: 20141010301061
   Coding: 399A240000
   VCID: FDB2A6A66CED92A23E-80A8
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0036
   Coding: 830000
   Part No SW: 1T0 920 885 M    HW: 1T0 920 885 M
   Component: KOMBI         H03 0705
   Coding: 180F01
   VCID: C2C8155A55932D5A03-8096
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 5K0 963 272 F
   Component: Standheizer     022 4008
   Revision: 00022000    Serial number: 09029167000000
   Coding: 0031012
   Shop #: WSC 01324 011 00200
   VCID: B326409ED22994D298-80E6
00664 - Fuel gauge
                    Reset counter: 4
                    Mileage: 121515 km
                    Date: 2018.06.15
                    Time: 15:17:34
02251 - Heater Unit Locked
            000 -  -
                    Reset counter: 228
                    Mileage: 121915 km
                    Date: 2018.06.18
                    Time: 11:06:52
   Part No SW: 7N0 907 530 AS    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1653
   Revision:   H56       Serial number: 031014F2000075
   Coding: 358002
   VCID: 814ADA561815F6425A-80D4
   Component: IMMO          H03 0705
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: EA989DFA0D63151AEB-80BE
   Revision: A1001003    Serial number: 7666697243
   Coding: 010100
   VCID: AB1658FECA19CC12D0-80FE
   Part No SW: 3C8 035 686     HW: 3C8 035 686
   Component: RNS-MID       H27 6276
   Revision: AB001001    Serial number: VWZ6Z7P9275134
   Coding: 04000442040000800009
   VCID: EA989DFA0563151AEB-80BE
   Component: EU West V11  8117
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2121
   Coding: 0001205
   VCID: C8DC0772BBAF070ADD-809C
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.293 1401
   Revision: 1BH04739    Serial number: 00142660304801
   Coding: 0000258
   VCID: C1CA1A56989536421A-8094
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0001205
   VCID: C7DE044EB6B10872D4-8092
   Component: AFS-ECU       H04 0111
   Coding: 030200104F000200
   VCID: B73E748E0E5178F2A4-80E2
   Subsystem 1 - Part No: 1T0 941 329 A  Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 1T0 941 329 A  Labels: 3D0-941-329.CLB
5276435 - Stationary Cornering Lamp Left
          C1083 13 [009] - Open Circuit
                    Reset counter: 3
                    Mileage: 122375 km
                    Date: 2018.11.29
                    Time: 02:44:10
   Component: Batt.regelung H56 1653
   Coding: 01241864
   VCID: F1AA8A9628B5E6C2AA-80A4
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2104
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: B228459A2D339DDA93-80E6
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0001168
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
   Component: Telefon       022 0982
   Revision: --------    Serial number: 35502105201152
   Coding: 020100000100000000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: A404B3C2AFC7036A11-80F0
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3AA-980-654.clb
   Part No SW: 3AA 980 654 D    HW: 3AA 980 654 A
   Component: MFK_Gen1      H09 0300
   Serial number: 0196105691
   Coding: 010002000102020E0200040000000000
   ASAM Dataset: EV_47X 001639
   ROD: EV_47X.rod
   VCID: B93A72B638456E8252-80EC
End----------(Elapsed Time: 01:32, VBatt start/end: 12.3V/12.1V)-----------
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Hey,
Thank you for the Auto-Scan.
No apparent faults, and it can be selected manually... are you sure you're driving in conditions that merit Auto selection of 7th gear? A Touran is on the heavier side for a vehicle with a 1.4 TSI, so it won't be up in 7th gear that much until you're at higher speeds with fairly low load. Also, are you sure you aren't inadvertently going into Sport mode? If you pull the gearshift lever too far back when going into Drive, that will select Sport mode on many DSGs, which will have much higher shift points and probably rule out most use of 7th gear around town. Look in the instrument cluster and make sure you're seeing D instead of S.
NZDubNurd
New Zealand
C?ID=230482
Maybe not related, but your Auxilliary heater is locked out from the fuel tank running low. If you clear it's codes, it'll function when it's cold outside, heating your engine faster, improving economy and heating - assuming you live in a cold climate.
I haven't seen that many petrol cars with the auxilliary heater.
I also wonder, if the DSG won't select 7th until the engine coolant or oil temp is to a predetermined level? Lots of cars used to hold a lower gear to heat up cats etc.
siLc
Tallinn, Estonia
C?ID=330192
This particular car seems to be rather well equipped, so perhaps this was just part of the package :P
I have a similar 1.4 TSI twincharged engine with a DQ200 DSG box and it changes to 7th at 70kmh, even with a cold engine.
Also it seems you have factory xenon headlights but the headlight washers doesn't seem to be working according to module 09.
daniel.b
Europe
C?ID=318819
After disconnecting the plug from the ABS controller, the dsg normally selects the 7th gear. What impact does ABS have on DSG? I checked vcds if all speeds on wheels are the same, it's OK. Where else to look for a problem?
siLc
Tallinn, Estonia
C?ID=330192
You can check in the DSG controller the speed it sees from the ABS and/or ECU.
daniel.b
Europe
C?ID=318819
DSG coding 0000020 is good?
It would seem so. Do a search for something like, "0AM 300 063" VCDS and you'll find that seems to be the standard coding.
NZDubNurd
New Zealand
C?ID=230482
perhaps the ABS is reporting the car is going up hill, so the DSG holds a lower gear?
My Touran is much older, but when it was auto, it would change down as the cars angle increased at the base of a hill, not even requiring additional throttle.
Perhaps the ABS/ESP is reporting a slope, when on the flat??? PERHAPS adaptation on the longitudinal sensor may be required??? Maybe it was calibrated while on an angle, and has upset the "zero" point???
Probably unrelated: BMW E39's with auto trans were known to hold 4th if the tyre sizes were too far off, or even tyre pressures really uneven.
daniel.b
Europe
C?ID=318819
Fixed. The problem was the incorrect configuration of the G251 sensor. After adaptation, DSG pushes 7th gear.
Thanks for the help
