2016 GOLF GTE - Voice Control Activation
marcus_gte
C?ID=82876
Hi,
I've returned to the VAG owners fold after selling my Audi TT in 2014. I now own a GOLF (Mk7) GTE. Dusted off my VCDS interface and set about making some tweaks.
Unfortunately. it's not going too well. I'm unable to run an autoscan, but after clicking around, locking/unlocking the doors, turning the ignition on/off - some modules do appear. The autoscan then ran, but it's incomplete.
I've had the Composition Infotainment system upgraded by the selling dealer to a MIB2 and added SatNav and Car-Play. The Steering Wheel Voice Control button isn't working though - is this something I can activate using VCDS? The Steering Wheel module shows an error and the module is inaccessible.
Here's the best I can get - except a later reading this evening did finally access module 09. Strange.
Oh, and I'm running VCDS on Windows 10 under Parallels v14 on a MacBook Pro.
Thursday,29,November,2018,17:24:47:05432
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 18.9.0.2
VIN: WVWZZZAUZGW813882   License Plate:
Chassis Type: AU-VW37 (5QE)
Scan: 01 02 03 08 09 10 13 15 16 17 19 23 42 44 51 52 55 5F 75 8C
          A9 C6
VIN: WVWZZZAUZGW813882   Mileage: 20606km-12803miles
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
Address 08: Auto HVAC
Address 09: Cent. Elect.
   Revision: --------    Serial number: 39391603600858
   Coding: 0071051011
   VCID: 43AB815CCA80E05288-8017
Address 13: Auto Dist. Reg
   Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
   Component: AirbagVW20    010 0870
   Serial number: 003MFR01TZUX
   Coding: 98CCC000002000005C0000CF00C800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 5081BE100BF60BCA05-8005
   Belt Pretensioner left:
   Serial number: 34169677B11021640337
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676B11021640977
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 902 16
   Serial number: 3570000000013110291X
   Subsystem 4 - Part No SW: -----------    HW: 480 000 902 16
   Serial number: 35800000000890202914
   Subsystem 5 - Part No SW: -----------    HW: 480 400 502 16
   Serial number: 3510002B918166C4E265
   Subsystem 6 - Part No SW: -----------    HW: 480 400 502 16
   Serial number: 3520002B51EDD3E3811D
   Subsystem 7 - Part No SW: -----------    HW: 480 400 502 16
   Serial number: 35500029918166C5318+
Address 16: Steering wheel
   Part No SW: 5G1 920 954 A    HW: 5G1 920 954 A
   Component: KOMBI         302 6420
   Coding: 272D1B082FC0260001886A111600030000000000
   Shop #: WSC 21241 003 1048576
   VCID: 2B7BC9FC4210081250-807F
Address 19: CAN Gateway
Address 23: Brake Booster
Address 44: Steering Assist
Address 51: Electric Drive
   Serial number: 040116ELJ04272
   Coding: 003F0020DE01048000801000
   VCID: 42A58458D59AE95A83-8017
   Serial number: 00000000000008946122
   Coding: 150000
Address 55: Headlight Range
   Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
   Component: MU-S-ND-ER    H24 0245
   Serial number: VWZAZ2T1304654
   Coding: 02730001FF0000005111110100880A001F0209C601200100CF
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 3041DE906B366BCA65-8065
   Subsystem 1 - Part No SW: 3G0 919 605     HW: 3G0 919 605
   Component: ABT_Std-2  H43 4064
   Serial number: VWZ6Z9S0432207
   Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
Address 75: Telematics
   Part No SW: 5Q0 915 182 C    HW: 5Q0 915 182 C
   Component: BECM          H05 0752
   Serial number: TA080058
   Coding: 00000000
   ASAM Dataset: EV_BECM09620115Q0915182 006037
   ROD: EV_BECM09620115Q0915182.rod
   VCID: 334BD19C9A2050D218-8067
   Battery Junction Box:
   Subsystem 1 - Part No SW: 5Q0 915 250 D    HW: 5Q0 915 250 D
   Component: BJB  H27 0240
   Cell module: control module 1:
   Subsystem 2 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D1  H14 0472
   Serial number: V013C15A2731189
   Cell module: control module 2:
   Subsystem 3 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D2  H14 0472
   Serial number: V013C15A2731006
   Cell module: control module 3:
   Subsystem 4 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D3  H14 0472
   Serial number: V013C15A2730964
   Cell module: control module 4:
   Subsystem 5 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D4  H14 0472
   Serial number: V013C15A2731005
   Cell module: control module 5:
   Subsystem 6 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D5  H14 0472
   Serial number: V013C15A2731022
   Cell module: control module 6:
   Subsystem 7 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D6  H14 0472
   Serial number: V013C15A2731008
   Cell module: control module 7:
   Subsystem 8 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D7  H14 0472
   Serial number: V013C15A2731021
   Cell module: control module 8:
   Subsystem 9 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D8  H14 0472
   Serial number: V013C15A2731007
Address A9: Struct. Borne Sound
Address C6: Batt. Chrg.
End-------------------------(Elapsed Time: 02:32)--------------------------
Are you sure the ignition was fully ON when you did this scan?
If so, I'm going to suggest trying a real PC without a VM, or another VM like Virtual Box.
downtime
Finland
C?ID=280813
If I remember correctly, the voice control is once again a SWaP function. So if you didn't have before, you ain't gonna get it now. Unless you have your MIB system hacked which I suspect as going to MIB2 and enabling car-play should not be possible at least any official way.
marcus_gte
C?ID=82876
Hi Uwe. Yes, the ignition was on. I don’t possess a PC. Parallels has been reliable for many many years. Do yo think it could be the problem? My results are inconsistent each time I plug/unplug the Micro-Can. I have done the firmware update.
marcus_gte
C?ID=82876
My dealer has told me a softwarepdate/activation is required.... at a cost of £249.
Maybe a stupid question... what’s is SWaP ?
downtime
Finland
C?ID=280813
There's an aftermarket option for Carplay but that is when you have factory installed MIB system that supports carplay activation. If you retrofit MIB2 system, it isn't factory installed and there's no knowledge on the factory database about that.
When the dealer try's to activate the Carplay license the factory server will reject it as it only sees that you're going to try to activate carplay to a system that is not supported.
If you can get a deal with the dealer that if the carplay activation does not go through successfully, they will refund the price. Because the code will be obsolete after the initial try, you cannot try it again, it's one time use only.
SWaP = SoftWare as a Product. VAG is selling some of the options as software licenses which need factory connection to be activated. The activation through factory enables FeC = Feature enable Code on the car's gateway which allows a feature to function.
Lot of modules use FeC's to have certain features turned on or off. For example ACC has FeC's for Stop'n'Go and pedestrian recognition. Depending on what you have bought, one or both are enabled. Then MIB system has FeC codes for navigation standard, navigation high, mirrorlink, voice control etc. Gateway has FeC's like MKE (driver fatigue detection), Driver profile etc.
marcus_gte
C?ID=82876
Thank you for the explanation on SWaP.
Regarding Car-Play - I have that installed after my dealer upgraded my MIB unit to add SatNav to the Composition unit, plus they added App-Connect. All units and coding all correctly registered with VW. I was simply trying to add Voice control, but looks like that's also a dealer (chargeable) option too.
