2009 GTI Help with ABS long code (MK60EC1)
DEE DEE
HC483374 (2nd hand?)
I have a 2009 GTI and the ABS control module failed. replaced with a salvage unit 1K0-907-379-AP. I could not retrieve the code from old unit. Can you generate a long code ? Here is the latest auto scan
Wednesday,28,November,2018,18:16:12:34514
VCDS Version: 18.9.0.2 (x64)
VIN: WVWHV71K79W123172   License Plate: 2
Mileage: 191750km-119147mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 55 56 62
          65 72
VIN: WVWHV71K79W123172   Mileage: 191750km-119147miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 1K0 907 115 AE    HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0030
   Revision: AAH03---    Serial number: VWX7Z0H83NH82W
   Coding: 0403010A1C070160
   Shop #: WSC 01269 785 00200
   VCID: 69D25E8940FF300262-803C
000051 - Turbocharger Bypass Valve Control Circuit
               P0033 - 000 - Malfunction / Open Circuit
                    Date: 2047.15.31
                    Time: 31:63:63
                    RPM: 582 /min
                    Load: 53.3 %
                    Temperature: 54.0°C
                    Temperature: 35.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 11.049 V
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected - Intermittent
                    Mileage: 190135 km
                    Time: 08:54:58
                    RPM: 840 /min
                    Load: 25.1 %
                    Temperature: 14.0°C
                    Temperature: 8.0°C
                    Voltage: 14.224 V
000770 - Cylinder 2
               P0302 - 000 - Misfire Detected - Intermittent
                    Mileage: 191037 km
                    Time: 10:05:17
                    RPM: 2438 /min
                    Load: 27.0 %
                    Temperature: 7.0°C
                    Temperature: 12.0°C
                    Voltage: 14.478 V
   Part No SW: 02E 300 051 R    HW: 02E 927 770 AM
   Component: GSG DSG AG6     511 1966
   Revision: 05351112    Serial number: 00001102251555
   Shop #: WSC 04940 001 00001
   VCID: 224009A5FD49235AE3-8076
   Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 48605 001 1048576
   VCID: 0004632D9385D14AD5-8054
03306 - Coding Not Valid
            000 -  -  - Intermittent
                    Reset counter: 80
                    Mileage: 191757 km
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 4161
                    Count: 42496
                    Fault Status: 01100101
                    Reset counter: 0
                    Mileage: 191351 km
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 279
                    Count: 41472
                    Count: 64768
                    Reset counter: 0
                    Mileage: 191351 km
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 295
                    Count: 41472
                    Count: 64768
                    Reset counter: 0
                    Mileage: 191351 km
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 270
                    Count: 41472
                    Count: 64768
            000 -  -
                    Reset counter: 71
                    Mileage: 191351 km
                    Count: 7
                    Count: 14
                    Count: 12288
                    Count: 195
                    Count: 41472
                    Count: 64768
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   VCID: 7CFC17DD3F6DB5AA89-8028
   Revision: 00H54000    Serial number: 00000008742796
   Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
   Shop #: WSC 00000 785 00200
   VCID: 336EFCE152B3BAD218-8066
   Component: Wischer 100908 021  0501
   Coding: 00038805
Address 0F: Digital Radio        Labels: None
   Part No SW: 8E0 035 593 Q    HW: 8E0 035 593 Q
   Component: SDAR SIRIUS     H08 0160
   Revision: 00000000    Serial number: AUZ4Z7J0562339
   Coding: 0000000
   VCID: 3776C8F146CB56F224-8062
            000 -  -
                    Reset counter: 71
                    Mileage: 191351 km
                    Time: 11:40:21
   Component: 6K AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0BYWK1
   Coding: 0013899
   VCID: 6CDC279D4F0D252A19-8038
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 6332MSME40243706/
   Subsystem 3 - Serial number: 6342MSME4023551C4
   Subsystem 4 - Serial number: 6352QSME030C060CA
   Subsystem 5 - Serial number: 6362QSME4B0D3D1CZ
   Subsystem 6 - Serial number: 63727SME177D34757
   Subsystem 7 - Serial number: 63827SME177D082CB
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Coding: 0012122
   VCID: 78F40BCD0B55998AED-802C
   Part No SW: 1K6 920 974 H    HW: 1K6 920 974 H
   Component: KOMBIINSTRUMENT VDD 2416
   Revision: V0003000    Serial number: VWX7Z0H83NH82W
   Coding: 0007203
   VCID: 3972CEC970DF4082D2-806C
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 140908F2001645
   Coding: ED817F071013020002
   VCID: 356AC2F95CC7A4E236-8060
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1225223T3ZVW03
   VCID: 7DFA1AD92477BCA2BE-8028
   Component: IMMO            VDD 2416
   Component: Tuer-SG         006 1219
   Coding: 0001205
   VCID: 3874CBCD4BD5598A2D-806C
01552 - Motor for Central Locking; Drivers Door (V56); Lock
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
   Coding: 139006885103281B0904058FB0080F0488DC00
   VCID: 040C6F3D479DCD6AF1-8050
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No SW: 1K6 035 456 B    HW: 1K6 035 456 B
   Component: 08K Audioverst.     0006
   Revision: 00004000    Serial number: 00000008155397
   VCID: 2B5EE4818A83E21250-807E
00875 - Treble Speaker Front Right (R22)
00877 - Treble Speaker Rear Right (R16)
   Coding: 0001204
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74EC3FFD173DFDEAC1-8020
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio PM6       125 0037
   Revision: 00125000    Serial number: VWZ5Z7H2260485
   Coding: 0010011
   VCID: 29521E89807FF002A2-807C
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1302
   Coding: 0001168
   Shop #: WSC 01269 785 1012552
   Coding: 0100101
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0001168
End-------------------------(Elapsed Time: 02:15)--------------------------
DrPeter
16.4905° S, 151.7375° W
Welcome to the Ross-Tech forum!.. We can help you with the ABS coding, please make sure you have followed the steps in this forum post, so we can get you verified.
How to get Verified
Based on my research the coding for the ABS control module should be: [113B600D492400FD880C06EB921B0041B100]
Copy and Paste that directly into the New Coding and enter non zero WSC/Importer/Equipment numbers before clicking Do It. After the coding is accepted complete the first 3 Basic Setting operations on this page: VW Golf (1K) Brake Electronics (MK60EC1). The Replacement section at the bottom of that page should be helpful.
Make sure the engine is cold before attempting to complete the 2-step Basic Setting operation to resolve: 00003 - Control Module - No or Incorrect Basic Setting / Adaptation. If you receive an error message please take a moment to watch the video while fans are cooling the engine bay.
If you encounter any issues let us know what the exact error messages are. It maybe necessary to store a Workshop Code, Importer and Equipment Number in the Options page of VCDS for the new coding to be accepted. Also send us another Auto-Scan.
Hope this helps,
drpeter
DEE DEE
Thanks. That code works. Now on to adaptation. Where do I send the money?
DEE DEE
the car took the long code no problem, but when I tried the Basic Setting 025 I get a message " no valve". Here is the latest auto scan
Thursday,06,December,2018,16:07:25:34514
          65 72
VIN: WVWHV71K79W123172   Mileage: 191900km-119241miles
                    Date: 2047.15.31
                    Time: 31:63:63
                    RPM: 582 /min
                    Load: 53.3 %
                    Temperature: 54.0°C
                    Temperature: 35.0°C
                    Voltage: 11.049 V
000769 - Cylinder 1
                    Mileage: 190135 km
                    Time: 08:54:58
                    RPM: 840 /min
                    Load: 25.1 %
                    Temperature: 14.0°C
                    Temperature: 8.0°C
                    Voltage: 14.224 V
000770 - Cylinder 2
                    Mileage: 191037 km
                    Time: 10:05:17
                    RPM: 2438 /min
                    Load: 27.0 %
                    Temperature: 7.0°C
                    Temperature: 12.0°C
                    Voltage: 14.478 V
   Revision: 00H45001
                    Reset counter: 86
                    Mileage: 191905 km
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 143
                    Count: 51712
                    Count: 59904
                    Reset counter: 86
                    Mileage: 191905 km
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 279
                    Count: 51712
                    Count: 59904
                    Reset counter: 86
                    Mileage: 191905 km
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 295
                    Count: 51712
                    Count: 59904
                    Reset counter: 86
                    Mileage: 191905 km
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 270
                    Count: 51712
                    Count: 59904
                    Reset counter: 86
                    Mileage: 191905 km
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 212
                    Count: 51712
                    Count: 59904
   Coding: 00038805
   Coding: 0000000
            000 -  -
                    Reset counter: 81
                    Mileage: 191773 km
                    Time: 12:41:26
   Coding: 0013899
   Coding: 0012122
   Coding: 0007203
   Coding: 0001205
   Coding: 0001204
   Coding: 0000003
   Coding: 0010011
   Coding: 0001168
   Coding: 0100101
   Coding: 0001168
End-------------------------(Elapsed Time: 02:13)--------------------------
DrPeter
Glad the coding worked. Did you buy this interface as a second hand owner? If so you will need to register as a second hand owner, see this link.
VCDS Used Dongle Interface Ownership Transfer
Hint: You need to following the instructions in the previous post (#2), these are also found on the Ross-Tech wiki page that was linked in that page.
drpeter
Fredrick Awuor
Kenya
C?ID=309834
          65 72
                    Date: 2047.15.31
                    Time: 31:63:63
                    RPM: 582 /min
                    Load: 53.3 %
                    Temperature: 54.0°C
                    Temperature: 35.0°C
                    Voltage: 11.049 V
000769 - Cylinder 1
                    Mileage: 190135 km
                    Time: 08:54:58
                    RPM: 840 /min
                    Load: 25.1 %
                    Temperature: 14.0°C
                    Temperature: 8.0°C
                    Voltage: 14.224 V
000770 - Cylinder 2
                    Mileage: 191037 km
                    Time: 10:05:17
                    RPM: 2438 /min
                    Load: 27.0 %
                    Temperature: 7.0°C
                    Temperature: 12.0°C
                    Voltage: 14.478 V
   Revision: 00H45001
                    Reset counter: 86
                    Mileage: 191905 km
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 143
                    Count: 51712
                    Count: 59904
                    Reset counter: 86
                    Mileage: 191905 km
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 279
                    Count: 51712
                    Count: 59904
                    Reset counter: 86
                    Mileage: 191905 km
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 295
                    Count: 51712
                    Count: 59904
                    Reset counter: 86
                    Mileage: 191905 km
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 270
                    Count: 51712
                    Count: 59904
                    Reset counter: 86
                    Mileage: 191905 km
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 212
                    Count: 51712
                    Count: 59904
   Coding: 00038805
   Coding: 0000000
            000 -  -
                    Reset counter: 81
                    Mileage: 191773 km
                    Time: 12:41:26
   Coding: 0013899
   Coding: 0012122
   Coding: 0007203
   Coding: 0001205
   Coding: 0001204
   Coding: 0000003
   Coding: 0010011
   Coding: 0001168
   Coding: 0100101
   Coding: 0001168
Isn't it apparent here that the ABS control dumped coding.....
