2018 Audi A3: Turn Off Parking Brake Engage When Door Open
joe9
Canada
C?ID=352303
I saw this tweak for a different Audi, but doesn't work for the '18 A3. Basically when I'm parking I like to look at the curb and my rear tire sometimes to make sure it doesn't hit as I roll slowly into the spot...or backing up and the collision avoidance doesn't see the low curb. The A3 immediately engages the parking brake which is super-annoying. How to turn that off?
Also, I assume this one is impossible as it involves CarPlay, but is there a way to have the map button bring up Waze instead of the non-installed Audi navigation?
Hi and welcome to our forum.
It might be helpful to post an Auto-Scan so that people can see exactly how your car is equipped and configured.
joe9
Canada
C?ID=352303
Sunday,25,November,2018,11:58:03:28469
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 3C 42 44 52 5F 6C
          BB BC CF
Mileage: 1270km-789miles
Address 01: Engine (J623-CNTC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 0A1D00124426010F3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
   ROD: EV_ECM20TFS0205G0906259L_AU37.rod
   VCID: 372B29CCDFCB77EF6FF-8062
   Part No SW: 0D9 300 018 A    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5201
   Revision: 06454104    Serial number: TFK01709271113
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1A6DD0784C194A87701-804E
          P1734 00 [002] - -
   Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0643
   Revision: 00000000    Serial number: 63017000000126
   Coding: 13FF6A9234232274897F0B09A0CC29C8562C4491D0059476124150548288420000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_VW41.rod
   VCID: 78A9EAF09255B897A65-802C
16401 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Reset counter: 114
                    Mileage: 1007 km
                    Date: 2018.11.20
                    Time: 16:31:40
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0460595285
   Coding: 030C0C
   VCID: 3C2136E0E6ED54B782D-8068
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0130
   Revision: 20002000    Serial number: 00000001403586
   Coding: 03000014010000001000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
   VCID: 40D942108A053057DE5-8014
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: FD7097D800PAG0MUFU03
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001731901138
   ROD: EV_BCMBOSCH_018.rod
   VCID: 06559408E8A1DE67A49-8052
   Component: WWS371 171018  043 0585
   Serial number:         171028220216
   Coding: 0A47F7
   Serial number: 21036734X81A955547A0
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 12 06 2017  00000038
   Serial number: 00000000000039742522
   Sun Roof:
   Component: J245 PS73.404  H04 0005
   Serial number: 0000FST001VEFAZ00000
   Coding: 101F00
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418617311
   Coding: 0470155011
   VCID: 4BC3653CB343E30F3B7-801E
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: B500008111F78428949C8055000024
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
   VCID: 3B2335FCE3E3538F8B7-806E
   Serial number: 003GCR09L77G
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47CB590CAF2B076F1FF-8012
   Belt Pretensioner left:
   Serial number: 34230167A08111740990
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34230168A09111740031
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001NNMUW
   Coding: 303334
   Subsystem 4 - Part No SW: -----------    HW: 480 001 311 17
   Serial number: 357000000003A850C92L
   Subsystem 5 - Part No SW: -----------    HW: 480 001 311 17
   Serial number: 358000000007988C692Y
   Subsystem 6 - Part No SW: -----------    HW: 480 402 710 17
   Serial number: 3510001C527CABF3D2FV
   Subsystem 7 - Part No SW: -----------    HW: 480 402 710 17
   Serial number: 3520001C527CABF1C32H
   Subsystem 8 - Part No SW: -----------    HW: 480 402 709 17
   Serial number: 35500029F25629A501C5
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 402 709 17
   Serial number: 35600029F25629A3E0EJ
   Part No SW: 8V0 953 521 KK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 14111704401505
   Coding: 2018
   VCID: 0D47AB248DD7AD3FE53-8058
   Part No SW: 8V0 920 961 C    HW: 8V0 920 961 C
   Component: KOMBI         H01 0311
   Coding: 0BE418192388CF050280A8001800000000000000
   Component: GW MQB High   518 5323
   Serial number: 09101710522906
   Coding: 030100043F085A005B00004C180B00000001010000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 38292AF0D2D57897665-806C
   Subsystem 2 - Part No SW: 81A 951 523 A    HW: 81A 951 523 A
   Component: J453 MFL  H04 0003
   Serial number: 20171108080516 20933
   Serial number: 75886000001711080A9E
   Serial number: HA1-00007.09.17
   Coding: 0001
   VCID: 4CC16620B64DE43732D-8018
   Revision: 00000000    Serial number: 17000323090005
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311EC0CEBD9CF74AD-8060
   Part No SW: 3Q0 907 566 F    HW: 3Q0 907 566
   Component: MRR1Rear      H21 0610
   Revision: --------
   Coding: 040002
   Serial number: 011117EJV12615
   Coding: 001C1B204000048000000002
   VCID: 43D34D1C9B132B4FC37-8016
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 103
                    Mileage: 600 km
                    Date: 2018.11.16
                    Time: 10:40:28
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 811F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B3DDDC8B33DBCF937-8026
   Serial number: 281017EJS08517
   Coding: 001C13204000048000000002
   VCID: 42DD481884092247C81-8016
   Part No SW: 8V1 035 652 E    HW: 8V1 035 652
   Component: MU-HS-S-US    050 0160
   Coding: 01730100FF0A000011220001061A00002F002DC401F001040A
   ROD: EV_MUHigScl6C3DELP_AU37.rod
   VCID: 392F2FF4E9DF619F99B-806C
   Subsystem 1 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
   Component: DU High  H49 0014
   Serial number: AUZ8Z9H1Y07590
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 BF    HW: 8V0 919 614 BF
   Component: ControlUnit_B  H50 0103
   Serial number: ALJAL107031700010284
   Coding: 0273010102002001400040
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 241017EJO15091
   Coding: 000C13204000048000000002
   Serial number: 241017EJO1559B
   Part No SW: 3Q0 907 590 F    HW: 3Q0 907 590
   Revision: --------
   Coding: 040002
End----------(Elapsed Time: 01:38, VBatt start/end: 12.0V/12.1V)-----------
Hmm.. There's an Adaption Channel in your ABS module:
IDE03493 Driver door status (not activated / activated)
What's that set to?
joe9
Canada
C?ID=352303
Tog get in to that module it asks for a code and no code pops up like they do in other modules. Thanks
TBAx
C?ID=287144
You mean changing this adaption channel requires a login code? Because I‘m not sure if there is any such thing as requiring a login code upon entering a control module.
However you can try the following: 40168, 20103, 24990, 37202, 31857, 28183, 44595, 24435, 15081, 18573, 10505, 11966 (some might not even be accepted).
When trying multiple Security Access codes, check this Measuring Value after each one:
IDE00323 -- Security Access: Number of invalid keys
If it goes too high, no Security Access will be accepted, not even a valid one. What's too high? 3 definitely is, but in some cases it can be lower. The only way to get it to decrease is to wait -- with the ignition on. A good battery charger is helpful.
joe9
Canada
C?ID=352303
What's that set to?
Workshop code 6385
Importer 790
Equipt 16
ACTIVATED
Thanks for the help!
Try changing it to Not Activated.
joe9
Canada
C?ID=352303
OK, I'll try it out this weekend. Will that impact other things I wonder?
joe9
Canada
C?ID=352303
You know what else is super-irritating, is that if you sit with your foot on the brake for more than like 1 minute (stopped traffic or train) you have to put the car in park before it will let you move again. No idea who came up with this stuff. There is a button to disengage it, but if you use it then the engine doesn't cut out when stopped to save gas.
I don't know, and I don't have access to a car like yours to try it on.
joe9
Canada
C?ID=352303
OK, so I got "Security Access Required", so I went back to the Security Access menu option. Entered the first code you provided. It said "ACCEPTED". Went back in to change the code and it said Security Access Required again. Does that mean the code didn't work, or something else?
South Molton, UK
IIRC some modules have more than 1 security code, each if which enable different additional changes to be made.
hadez16
C?ID=289891
Afaik, this cannot be changed. Driver Door Status has something to do with Auto Hold function I think...
It means that there is another login code needed for that channel. There are a few available...see TBAx post above
downtime
Finland
C?ID=280813
What? You mean the autohold does not disengage? This must be a fault, it cannot work like this as this would be a clear safety risk in traffic. If this is really intentional feature, then this was designed by a complete moron.
joe9
Canada
C?ID=352303
It seems to have a timer. I've only had it happen when stopped for trains or stopped motionless in heavy traffic. When you push the accelerator nothing happens. You have to restart the car. I'm assuming they have added this because people have left the car "running" by mistake, so they have it stop itself after some number of motionless minutes.
downtime
Finland
C?ID=280813
That happens if the car stops the engine and you put the gear to park, then it requires you to restart the car manually. But I've stood in a traffic lights for some minutes and I've never had to restart the car manually. BUT, I have manual handbrake and no keyless system.
I know that keyless system behaves a little bit differently, but I've not had to start that manually either unless I put the gear to park in between. Manual gearbox might be different, that I do not know but who drives a manual nowadays anymore anyway :D
