Retrofit rear camera A6 2017 MMI?
sers77
Norway
C?ID=26140
I need some help with this project.
Cannot find a complete kit anywhere because this is a FL and doesn't use the same camera module.
Is CP going to be a problem retrofitting this? (if it's possible)
Thank you in advance for any help :)
XPepino
Czech Republic
C?ID=91614
Use aftermarket rear camera...
I have both on Audi A6 4G - original and cheap China camera - and China have much more better picture.
I used RoadPassion (is now only on Alibaba) interface with dynamic guidelines from Ali and also camera from Ali. The camera you will buy have not to have static lines !!! Best is with CCD chip Sony.
Now I have AreaView and cannot swap original camera for China ones , because it have different optical so Area View can be splitted :-(
sers77
Norway
C?ID=26140
Super, thank you for the tip 👍
sers77
Norway
C?ID=26140
Cannot find a way to code 5f.
Tried byte 7 bit 1 and byte 6 bit 2. Only getting wrong coding fault.
6c and gateway is without fault.
sers77
Norway
C?ID=26140
Saturday,08,December,2018,04:50:41:07409
VCDS Version: 18.9.0.2
VIN: WAUZZZ4G9HN063358   License Plate: ALLROAD
Mileage: 12556km-7801mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 18 19 20 22 28 34 36 3B 3C 42
          44 46 52 53 55 5F 62 69 6C 6D 72 85 8B 8E 8F 90 A9 AC C0
VIN: WAUZZZ4G9HN063358   Mileage: 12556km-7801miles
17-Instruments -- Status: Cannot be reached 0100
Address 01: Engine (J623-CVUA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 589 F    HW: 4G0 907 589 B
   Component: 3.0BTD EDC17  H23 0001
   Revision: 54H23---
   Coding: 322A403A25760B030000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30BTD0114G0907589F 001001
   ROD: EV_ECM30BTD0114G0907589F.rod
   VCID: 3779D3088E5175F224-8062
   Part No SW: 4G0 927 158 BC    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H22 1003
   Revision: --H22---
   VCID: 70EB2814ABBFE2CA25-8024
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 49B7DE4D92ED7BB2BB00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 418DBDD0D0953B429A-8014
   Part No SW: 4H0 907 064 HP    HW: 4H0 907 064 HP
   Component: BCM2 2.0      H61 0825
   Coding: 05A96F0E000000000000
   VCID: 7EF7062CE9EB84BAA7-802A
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 18101600041716
   Coding: 369211782D0000
   VCID: 63C157586A494952A8-8036
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0368
   Revision: 15020001    Serial number: 00001495856201
   Coding: 0105C01440349FE2E90140C7A0001800CF9C67082E08020180000894E10117020040002D030000
   VCID: 74E32404D7A7DEEAC1-8020
   Component: WWS57X 160903  H38 0080
   Serial number:         160914092411
   Coding: 0045F7
   Serial number: 62365055
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 21 10 2016  00000479
   Component: EVLS-SG  H08 0300
   Serial number: WA125469000025976063
   Coding: 020300
   Subsystem 5 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: D5C8025800PAG0MUFU03
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0055
   Coding: 7F04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002015
   VCID: 295D057048E5D302A2-807C
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P100BLR79
   Coding: 30333130313730323630554A304C34473053
   VCID: 3B71CF38B2795192C0-806E
   Serial number: 3575HRB405L46U745O7K
   Serial number: 3585HRB405P46HMS19AZ
   Serial number: 3515JRB4014577K0M99U
   Serial number: 3525JRB4014577K0D97K
   Serial number: 3554VRB400A57EUID0U2
   Serial number: 3564VRB400A57EUIG0O0
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [137] - Open or Short to Plus
                    Mileage: 12556 km
                    Date: 2018.12.07
                    Time: 00:31:32
9446677 - Redundant signal path for airbag shut-off; passenger side
          B1025 15 [137] - Open or Short to Plus
                    Mileage: 12556 km
                    Date: 2018.12.07
                    Time: 00:31:31
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 90372PJC000E1
   Coding: 0004FD
   VCID: 387BD0348B4F7A8A2D-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 14 06 2016  C0025886
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G9 920 951 L    HW: 4G9 920 951 L
   Component: TDieRdwAccNv  H14 0225
   Revision: 13001303    Serial number: 658171016596009
   Coding: 138625089F550008010600
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K.rod
   VCID: 3A7FCA3CBD43689ADB-806E
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 J    HW: 4H0 265 105 J
   Component: Standheizung  H26 0270
   Revision: 77007007    Serial number: 20160101034157
   Coding: 5D3F01
   VCID: 295D057040E5D302A2-807C
   Part No SW: 4G8 907 468 H    HW: 4G8 907 468
   Revision: --------    Serial number: 00000002410892
   Coding: C0CD078118
   VCID: 3D75C120AC6D5FA2FE-8068
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 9435731604
   Voltage stabilizer:
   Serial number: 16082200000000000062
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   VCID: 67D943489671257274-8032
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H19 0200
   Serial number: 001410160001015
   VCID: 285B007453EFEA0ABD-807C
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0113
   Serial number: 19101600041572
   Coding: 21
   Coding: 008003
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F69EB687601BD327C-807A
   Revision: AA000000    Serial number: 00000223371353
   VCID: 77F91308C6D1B5F2E4-8022
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E02F4TM
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H08 0070
   Serial number: 0419525758
   Coding: 040321
   VCID: 397DD530B8456382D2-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0070
   Serial number: 0419793356
   Coding: 040321
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F16015E00628002080013
   VCID: 4585A9C0CCBD1762A6-8010
   Component: RCevo         H54 0202
   Revision: 00000001    Serial number: 0000354032
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   Revision: 00002001    Serial number: 0420222852
   Coding: 013A0E20A0B93095C32009842E010F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 B
   Component: Sensor, DWA  005 0002
   Subsystem 3 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS20.403  H03 0004
   Serial number: 0000FST0018EGZ200000
   Coding: 901F00
   Subsystem 4 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
   Serial number: 0000000AP00025865396
   Subsystem 5 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS20.403  H03 0004
   Serial number: 0000FST0018EO3E00000
   Coding: 801F00
   Component: TSG BF        H03 0511
   Coding: 011F16015E00628002080002
   VCID: 4687AECCF1BB1C7AAF-8012
   Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
   Component: EPB-4         H01 0018
   Revision: --------    Serial number: 00000001964238
   ASAM Dataset: EV_ParkiBrake 001033
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 326FE21C653390DA13-8066
   Coding: 04FA02102A630200
   VCID: 3463E4049F279EEA01-8060
   Coding: E01E00
   Coding: E01E00
   Part No SW: 4G1 035 020 F    HW: 4G1 035 020 D
   Component: MU-H-ND-EU    051 0670
   Serial number: A735J0G7501286
   Coding: 017542010000000013111102000A00002F000AE5F17001009F
   VCID: 1C332CA417B736AA29-8048
   Subsystem 1 - Part No SW: V03 959 801 FB    HW: -----------
   Component: ECE 2016/2017  --- 0153
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9GY806EPG
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349PJD0005P
   Compact Disc Database:
   Component: Gracenote2---  --- 1013
   Component: TSG HL        H03 0511
   Coding: 010F14004000628002080002
   VCID: 499DA5F0E0A5F30242-801C
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
   Component: Anhaenger     H20 0160
   Revision: 7B001003    Serial number: 0419325132
   Coding: 0100000202000000
   VCID: 3361E7189A2999D218-8066
   Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
   Component: D4-PA RVC Mid H07 0050
   Coding: 027502010201000300
   Shop #: WSC 79104 790 00000
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914_VW51.rod
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0152
   Revision: 14005001    Serial number: 287600108
   Coding: 093205C031
   ROD: EV_HDSGAu571.rod
   VCID: 3667DE0C895B8CFA3F-8062
0004 - No Basic Setting
          B2010 00 [137] -  -
                    Reset counter: 60
                    Mileage: 12556 km
                    Date: 2018.12.07
                    Time: 02:25:25
                    Voltage terminal 30: 11.93 V
   Component: TSG HR        H03 0511
   Component: DPC-SG        H27 0081
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C53FC644717C62A59-8078
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7F04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
   VCID: 275903485EF1E572B4-8072
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H34 0090
   Serial number: 005002452010167
   Coding: 04C0BB1E1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0049 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 60
                    Mileage: 12556 km
                    Date: 2018.12.07
                    Time: 02:15:07
                    Outside air temperature: 13.5 °C
                    Voltage terminal 15: 12.0 V
                    Control Module temperature: 21.0 °C
   Component: RGS-VL        H16 0080
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 316DED106035ABC26A-8064
   Component: RGS-VR        H16 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 159 D    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0007
   Serial number: 160925200495
   VCID: 2E57F66C710BB43A77-807A
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 162560084
   ROD: EV_RDCMA00100_008.rod
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4G0 907 160 E    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0011
   Serial number: 160908200473
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
End-------------------------(Elapsed Time: 06:50)--------------------------
sers77
Norway
C?ID=26140
Is byte 19 bit 4 worth a try?
NEtech
Denmark
C?ID=56995
Sure, if you are talking about [5F].
That is for Rearcamera Low (RVC).
sers77
Norway
C?ID=26140
Byte 19 bit 4 was the solution
A I S
S.London Kent
C?ID=359297
Did that work . 19 and 4
