How to change left handside bi xenon lights to right hendside
Roman
C?ID=149861
Hello guy. my question is how to change the European bi xenon headlights to United Kingdom one as driving in UK the headlamp aim beam image kick up to the offside. possible with vcds? passat b6 2.0tdi 2007
Enriquez
Poland
C?ID=72075
If permanent, You need to change the enrire lamps.
If temporary - in the 55-xenon module adaptation - change the channel "Travel mode".
Depending on the exact Xenon system installed, it might be called "Tourist Mode".
For more precise answers, please post an Auto-Scan so we can see exactly what's installed in this car.
Roman
C?ID=149861
Here is the scan guys.
VCDS Version: Release 14.10.0 (x64)
Data version: 20141022
Monday,10,November,2014,09:15:56:49798
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 55 56 62 72 76 77
VIN: WVWZZZ3CZ7P094846   Mileage: 186490km-115879miles
76-Park Assist -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 03G-906-018-BKP.clb
   Part No SW: 03G 906 018 CE    HW: 03G 906 018 CE
   Component: R4 2.0l PPD1.5 G    9707
   Revision: --H35---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 66565 257 00032
   VCID: 6AD1E24B45BD6F71D1F-803F
Readiness: N/A
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 109     HW: 3C0 614 109
   Component: ESP 440 C4     H018 0001
   Revision:  H018       Serial number: 0668155444
   Coding: 0013602
   Shop #: WSC 00028 028 00001
   VCID: 5BBFB78F9AE706F95A9-800E
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 AF    HW: 3C0 907 044 AF
   Component: ClimatronicPQ46 050 0505
   Revision: 00050005    Serial number: 00000000000000
   VCID: 65CB9177ACA34009FCD-8030
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000004556358
   Coding: 82821F0700041A00470A00000F000000000B5D435C0001
   VCID: 6CDDE4534F497141A33-8039
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 110906 003  0205
   Coding: 00046997
   Shop #: WSC 00028
                    Fault Status: 00101100
                    Reset counter: 136
                    Mileage: 186124 km
                    Date: 2014.10.22
                    Time: 06:04:00
                    Voltage: 11.25 V
02390 - Control / Regulation for Ambience Lighting (E400)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 130
                    Mileage: 186483 km
                    Date: 2014.11.09
                    Time: 11:15:00
                    Voltage: 11.95 V
   Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
   Component: 0B AIRBAG VW8   031 2522
   Revision: 11031000    Serial number: 003B1PNKDA5P
   Coding: 0012354
   VCID: 30653023A3E1D5A1DFB-8065
   Subsystem 1 - Serial number: 6332MSME14426201
   Subsystem 2 - Serial number: 6342MSME14681325
   Subsystem 3 - Serial number: 6351HTS66HBOMKO6
   Subsystem 4 - Serial number: 6361HTS66HBG67G6
   Part No SW: 3C0 953 549 M    HW: 3C0 953 549 M
   Component: J0527               0015
   Revision: 00006000    Serial number: 3C5953507AG
   Coding: 0000111
   VCID: 3669063B4185FB91857-8063
   Part No SW: 3C0 920 871     HW: 3C0 920 871
   Component: KOMBIINSTRUMENT VD1 1614
   Revision: X0006000    Serial number: 00000000000000
   Coding: 0007405
   Shop #: WSC 08142 234 89099
   VCID: 61C38567B88B2C29005-8034
Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0040
   Revision: 00007000    Serial number: 0700C06A310186
   Coding: 7DFD1C04C61002
   VCID: 2143C567F80B6C29405-8074
                    Reset counter: 48
                    Mileage: 185946 km
                    Date: 2014.10.10
                    Time: 08:06:05
01327 - Control Module for Parking Aid (J446)
                    Reset counter: 48
                    Mileage: 185946 km
                    Date: 2014.10.10
                    Time: 08:06:09
01304 - Radio
                    Fault Frequency: 133
                    Reset counter: 169
                    Mileage: 185946 km
                    Date: 2014.10.10
                    Time: 08:06:28
                    Reset counter: 126
                    Mileage: 186483 km
                    Date: 2014.11.09
                    Time: 11:21:38
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   VCID: 39730D07709B14E9685-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Component: J386  TUER-SG FT    1123
   Revision: 32008001    Serial number: 00000578669108
   Coding: 0000181
   VCID: 3B7F170F7AA726F97A9-806E
00096 - Drivers Door Central Locking (Safe) Motor (V161)
                    Fault Frequency: 25
                    Reset counter: 167
                    Mileage: 186007 km
                    Date: 2014.10.11
                    Time: 13:55:57
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.135 H07 1806
   VCID: 346D3C3357F9E981BB3-8061
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 042 0472
   Coding: 01910A0001860E7630049415F0084F0E707C00
   Component: LIN BACKUP HORN H07 8003
   Component: J387  TUER-SG BT    1123
   Revision: 32008001    Serial number: 00000575969110
   Coding: 0000180
   VCID: 3C7D14137FA921C1733-8069
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 E    HW: 3C0 907 801 E
   Component: EPB  VC8HC003   013 0003
   Revision:   013
   Coding: 0000011
   VCID: 244DCC73E71979012B3-8071
   Part No SW: 5M0 907 357 A    HW: 5M0 907 357 A
   Component: AFS-Steuergeraet    X014
   Revision:   H01       Serial number:
   Coding: 2301953
   VCID: 32613A2BADEDE7B1A9F-8067
   Subsystem 1 - Part No: 7L6 941 329
   Component: AFS-Lst.-Modul l    X018
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 330
   Component: AFS-Lst.-Modul r    X018
   Coding: 00000035
Address 56: Radio
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1113
   Revision: 11005001    Serial number: 00000000896849
   Coding: 0000144
   VCID: 3D7B191764B328C944D-8068
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1113
   Revision: 11005001    Serial number: 00000000884008
   Coding: 0000144
   VCID: 3E791E1B69B533D15D7-806B
Address 76: Park Assist
Address 77: Telephone
End-------------------------(Elapsed Time: 01:59)---------------
55-Headlight Range -> Adaptation Channel 02.
Roman
C?ID=149861
Thank you very much I will try it today and let you how it goes :)
