Passat 2015 Diesel engine code CRLB
ataylor92
C?ID=156813
Monday,26,November,2018,16:03:42:38326
VCDS Version: 18.9.0.2
VIN: WVWZZZ3CZGE046109   License Plate:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F
VIN: WVWZZZ3CZGE046109   Mileage: 82067km-50994miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ET    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H21 1343
   Revision: B5H21---
   Coding: 011D001203651D083000
   Shop #: WSC 05311 115 00315
   ASAM Dataset: EV_ECM20TDI01104L906026ET 002001
   ROD: EV_ECM20TDI01104L906026FL.rod
   VCID: 0005C24A9B96B54AD5-8054
   Part No SW: 0D9 300 041 A    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4801
   Revision: 06253104    Serial number: TFK01506181464
   Shop #: WSC 05311 115 00075
   ROD: EV_TCMDQ250021.rod
   VCID: 16298412E9122BFA1F-8042
   Revision: 00000000    Serial number: 61995000000792
   Coding: 0FEC928F34240B720778060041CC49F0492CD0E0608292F11862F078C202
   Shop #: WSC 00015 115 00001
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 7AF1B0A2FD4AEF9A9B-802E
   Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
   Component: VWKESSYMQB    026 0709
   Revision: 00026000    Serial number: 0374452187
   Coding: 000F0F0703
   ROD: EV_KessyHellaMQBAB_VW48.rod
   VCID: 39736FAEB8CC2482D2-806C
   Part No SW: 5G0 907 426 AF    HW: 5G0 907 426 AF
   Component: AC Manuell    H03 1202
   Revision: 00001K06
   Coding: 12120104202100001000400000000002
   ASAM Dataset: EV_ACManueBHBVW37X 003129
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: 6FE791F6B608BA323C-803A
   Part No SW: 5Q0 937 086 AH    HW: 5Q0 937 086 AH
   Revision: --------    Serial number: 86581307152723
   Coding: 03011842C2C1027F0FA44094B10407281880000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    150625  043 0607
   Serial number:         150628105738
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S5Y15M07D03H05M37S25
   Coding: 90A8DD
   Subsystem 3 - Part No SW: 3G0 941 633     HW: 3G0 941 633
   Serial number: 03 05 2015  00000196
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  006 0326
   Serial number: 000000000ZY15167410L
   Serial number: 00000000000062910872
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39331519608569
   Coding: 0071051811
   ROD: EV_EPHVA18AU3700000_002_VW48.rod
   VCID: 448D0E5ACF0E696AB1-8010
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Coding: 3200678251FFC428949C804D
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 346D5E9A9FAED9EA01-8060
   Part No SW: 3Q0 959 655 BA    HW: 3Q0 959 655 BA
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003SSPE3LMFU
   Coding: 98FCC0C0000000005C5400CC008800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7EF9BCB2E162C3BAA7-802A
   Belt Pretensioner left:
   Serial number: 3G2857705E0196P00604
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 3G2857706E0194P00828
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 001 207 15
   Serial number: 3576U0000007B1647517
   Subsystem 4 - Part No SW: -----------    HW: 454 001 207 15
   Serial number: 3586U000000D5364751A
   Subsystem 5 - Part No SW: -----------    HW: 454 801 007 15
   Serial number: 3516REC20A3070000004
   Subsystem 6 - Part No SW: -----------    HW: 454 801 207 15
   Serial number: 3526R34E45E070000008
   Subsystem 7 - Part No SW: -----------    HW: 454 800 507 15
   Serial number: 3556V6AA165070000009
   Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150721500954
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3D7B7BBEACE418A2FE-8068
   Part No SW: 3G0 920 941 A    HW: 3G0 920 941 A
   Component: KOMBI         201 6421
   Coding: 27A409182780260001886B011000000000000000
   ROD: EV_DashBoardVDDMQBAB_VW48.rod
   VCID: 244DAEDA2F4E496A91-8070
1048578 - No Basic Setting
          B2010 00 [009] -  -
                    Reset counter: 21
                    Mileage: 82060 km
                    Date: 2018.11.26
                    Time: 14:41:24
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2227
   Revision: --------    Serial number: 09071510801465
   Coding: 030300045F087300FB00005C1C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013_VW48.rod
   VCID: 75EBA39ED45480E2F6-8020
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150001420920095281
   Coding: 2CFFFF
   Serial number: 0559857103
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
   Serial number: 15000066707006
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71E3978EA03CACC22A-8024
   Serial number: 070715BG700627
   Coding: 00350A20D001028000001000
   VCID: 438F0D46CA006E5288-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001824912
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 8103
   Shop #: WSC 00015 115 00315
   Serial number: 090715BG817348
   Coding: 00350020D001028000001000
   VCID: 42810842D51A675A83-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001833049
   Coding: 050000
   Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
   Component: MU-S-ND-ER    820 0629
   Coding: 02840201FF00000051111101008808001F0100C601200100CF
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 3065528A6BB6E5CA65-8064
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H43 4064
   Serial number: VWZ6Z9R1961694
   Subsystem 2 - Part No SW: 3G0 919 866 H    HW: -----------
   Component: ECE 2015/16  --- 0430
End-------------------------(Elapsed Time: 06:20)--------------------------
