2009 Jetta 2.5: 01044 - Control Module Incorrectly Coded
KraftwerkTurbo
Brighton, MI
C?ID=102239
Getting the code since we bought the car. All stock AFAIK.
Is the code thrown because of some shoddy work (change a module) of the previous owner? Which module is incorrectly coded?
Any suggestions how to troubleshoot?
Code comes right back after erasing.
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 100508F2001357
   Coding: ED807F060002021002
   Shop #: WSC 00066 000 00000
   VCID: 3560AC335C4FC7E235-8060
            000 -  -
                    Mileage: 181793 km
                    Time: 00:36:49
Full scan:
Friday,23,November,2018,15:53:55:03761
VCDS Version: 18.9.0.1 (x64)
VIN: 3VWJM71KX9M004386   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWJM71KX9M004386   Mileage: 203180km-126250miles
65-Tire Pressure -- Status: Not registered 0011
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 P    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9205
   Revision: G6H01---    Serial number: VWX7Z0H524L1DD
   Coding: 0000075
   Shop #: WSC 02615 444 84571
   VCID: 3B74BA0B7A6B1192C3-806E
012408 - Throttle Control
               P3078 - 000 - Airflow at Idle too Low
                    Fault Frequency: 8
                    Mileage: 198530 km
                    Time: 02:03:30
                    RPM: 1354 /min
                    Load: 21.2 %
                    Speed: 50.0 km/h
                    Temperature: 83.0°C
                    Temperature: 42.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.843 V
008577 - Performance Malfunction in Cooling System
               P2181 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 202870 km
                    Time: 01:21:25
                    RPM: 2809 /min
                    Load: 65.9 %
                    Speed: 133.0 km/h
                    Temperature: 73.0°C
                    Temperature: 6.0°C
                    Voltage: 14.224 V
   Part No SW: 09G 927 750 JE    HW: 09G 927 750 JE
   Component: AQ 250 6F           1377
   Revision: 00H76000    Serial number:
   Coding: 0000840
   VCID: 7DF0741324FFDFA2BD-8028
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 113B400D492200FE880E02EC921F00413000
   Shop #: WSC 53635 001 1048576
   VCID: 7EF2731FE9F9C4BAA4-802A
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   VCID: 7CF679173FE5D6AA8A-8028
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 00000000974569
   Coding: 14058E234004150007140000001400000008730B5C000120000000000000
   VCID: 6FEC5E5B7E93BD323F-803A
   Component: Wischer 240608 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M05NU2G
   Coding: 0013889
   VCID: 6CD649574F85462A1A-8038
   Subsystem 1 - Part No: 1K0 959 339 F
   Component: BF-Gewichtsens. 007 0005
   Subsystem 2 - Serial number: 6332MSME42150D0D9
   Subsystem 3 - Serial number: 6342MSME3B63617EN
   Subsystem 4 - Serial number: 6351HSME1627202D0
   Subsystem 5 - Serial number: 6361HSME163D13588
   Subsystem 6 - Serial number: 63727SME157D43351
   Subsystem 7 - Serial number: 63827SME160E2C7AD
   Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
   Coding: 0010021
   VCID: 030402EB421BA952CB-8056
   Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0003000    Serial number: VWX7Z0H524L1DD
   Coding: 0023203
   Shop #: WSC 07807 444 69274
   VCID: 3C76B9177F6516AACA-8068
            000 -  -
                    Mileage: 181793 km
                    Time: 00:36:49
   Component: IMMO            3HL 1222
   Shop #: WSC 53734 001 1048576
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000537288617
   Coding: 0001205
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A5A8F4F85F1981AA8-807E
   Coding: 13900F880186083F0904058FB0880F0488DCA0
   VCID: 040601F74715AE6AF2-8050
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 00000024888619
   Coding: 0001204
   VCID: 70EE5D2763ADA2CA26-8024
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 D    HW: 1K0 035 161 D
   Component: Radio DE2       017 0021
   Revision: 00017000    Serial number: VWZ4Z7H6354944
   Coding: 0040401
   VCID: 204E6D67F3CD524AF6-8074
   Component: J388   TUER-SG HL   1120
   Revision: 12006001    Serial number: 00000003188927
   Coding: 0001168
   VCID: 3E72B31F697904BAE4-806A
   Coding: 0100101
                    Reset counter: 63
                    Mileage: 190060 km
                    Time: 19:49:50
   Component: J389   TUER-SG HR   1120
   Revision: 12006001    Serial number: 00000003194149
   Coding: 0001168
   VCID: 3F8CCE1B6E730DB2EF-806A
End-------------------------(Elapsed Time: 01:53)--------------------------
NostraJackAss
The car is not stock, it & is FOD with TPMS being disabled & unlawfully...........
Component: 2,5l R5/4V G 9205 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Update programming needed!
Concerned about the gateway code but not the TPMS code that caused someone to play dirt ball tricks in the installation list, Cheesy again Kraft?
NostraJackAss
19-CAN Gateway -- Status: Malfunction 0010 <<<<<<<<<<<<<<<<<<<<<<< Here!
65-Tire Pressure -- Status: Not registered 0011<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Here!
More importantly here!
https://www.nhtsa.gov/laws-regulations?page=9
https://www.law.cornell.edu/cfr/text/49/part-578
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
65-Tire Pressure -- Status: [B][COLOR="#FF0000"]Not registered[/COLOR][/B] 0011
The CAN gateway is complaining because there's a module present in the car that it's not configured to recognize. It looks like the previous owner made an attempt to de-equip TPMS from the car, most likely because...
They didn't want to buy sensors. Connect to module 19, go to Installation List, check address 65 Tire Pressure, save it. With that done, the fault in 19 should go away. Then sort out your TPMS sensors so you have properly working TPMS.
KraftwerkTurbo
Brighton, MI
C?ID=102239
Where in my question did I talk about concerned?
Also thanks for the (non requested) legal advise (not applicable).
The TPMS code is self-explanatory to me. Didn't know that someone tried to code out the TPMS module.
But some helpful poster provided the useful information already.
NostraJackAss
I prefer the city under the city in "Demolition Man" the movie Jason & which isn't afraid to express nor hide ones feelings in order to convey the gravity of the situation, end result is OP if working on system should know his own liability and two the collective was deemed not to have the ability to check their own air PSI or was it because the technology has been on aircraft/aerospace and critical components for decades proving the ability to save lives and no reason since cost so low now that it be implemented?
Then again what does it matter kids tomorrow wont check TP and will get in an "Uber" car etc. & so they can stay plugged into the social media, which is far more important to control them?
Anyone want a rat burger?
I'm in.......
My point exactly.............
I just asked questions and pointed you to possible helpful information, I never gave advice to be clear!
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Jack, I would never in a million years ask you to hide your feelings. I love having the Jack Experience on this forum. :)
NostraJackAss
I am very sensitive to ones feelings and I do break the OP's and the collectives balls, but most of all it is out of my duty as a friend with term of endearment!
I don't want to see anyone here getting in trouble for doing stupid illegal shit and not knowing the scope of the pit they are a step away from falling in.
OP think about what I have asked.........
KraftwerkTurbo
Brighton, MI
C?ID=102239
2009 Jetta - CAN Gateway - Control Module Incorrectly Coded - 01044
Bought car, no changes or modifications AFAIK.
The 01044 code keeps coming up.
Is there a 'can gateway module'?
I checked the settings, but they seemed to make sense.
Sunday,27,January,2019,13:19:32:03761
VCDS Version: 18.9.1.0 (x64)
VIN: 3VWJM71KX9M004386   Mileage: 205450km-127660miles
   Coding: 0000075
   VCID: 3B74BA0B7A6B1192C8-806E
Readiness: 0010 0101
   Coding: 0000840
   VCID: 7DF0741324FFDFA2B6-8028
   Revision: 00H45001
   VCID: 7EF2731FE9F9C4BAAF-802A
   VCID: 7CF679173FE5D6AA81-8028
   VCID: 6FEC5E5B7E93BD3234-803A
   Coding: 00038805
   Shop #: WSC 00066
   Coding: 0013889
   VCID: 6CD649574F85462A11-8038
   Coding: 0010021
   VCID: 030402EB421BA952C0-8056
   Coding: 0023203
   VCID: 3C76B9177F6516AAC1-8068
   VCID: 3560AC335C4FC7E23E-8060
            000 -  -
                    Fault Frequency: 14
                    Mileage: 205455 km
                    Time: 23:48:40
   Coding: 0001205
   Revision: 00H15000
   VCID: 2A5A8F4F85F1981AA3-807E
   VCID: 040601F74715AE6AF9-8050
   Coding: 0001204
   VCID: 70EE5D2763ADA2CA2D-8024
   Coding: 0040401
   VCID: 204E6D67F3CD524AFD-8074
   Coding: 0001168
   VCID: 3E72B31F697904BAEF-806A
   Coding: 0100101
                    Fault Status: 01110100
                    Mileage: 205455 km
                    Time: 23:49:01
   Coding: 0001168
   VCID: 3F8CCE1B6E730DB2E4-806A
End-------------------------(Elapsed Time: 01:54)--------------------------
NostraJackAss
I checked the settings, but they seemed to make sense.​
Hey my buddy Cheesy Kraft mysteries ..... :p
WTF is this did you forget already ?
You disabling TPMS again?
Fault Frequency: 14
Mileage: 205455 km
Time: 23:48:40
NostraJackAss
Tricky isn't it jack, i reckon this might be a dealer only job lol
Depends on if you walk to school or take a box lunch by here or by short bus?
Kraft is always the cheesiest isn't it and always in the CAN?
NostraJackAss
Hey Kraft
Are you going to ask this again in couple months or are you going to remember now? :D
